Compiles way better.
irq_chip.end got obsolete with the removal of __do_IRQ().
irq-mb93093.c even lacks an implementation, but nobody noticed that
it's broken since commit 88d6e1 in 2006.
All kthreads being created from a single helper task, they all use memory
from a single node for their kernel stack and task struct.
This patch suite creates kthread_create_on_cpu(), adding a 'cpu' parameter
to parameters already used by kthread_create().
This parameter serves in allocating memory for the new kthread on its
memory node if available.
Users of this new function are : ksoftirqd, kworker, migration, pktgend...
This patch:
Add a node parameter to alloc_task_struct(), and change its name to
alloc_task_struct_node()
This change is needed to allow NUMA aware kthread_create_on_cpu()
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support
percpu: Generic support for this_cpu_cmpxchg_double()
alpha: use L1_CACHE_BYTES for cacheline size in the linker script
percpu: align percpu readmostly subsection to cacheline
Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the
percpu alignment having changed ("x86: Reduce back the alignment of the
per-CPU data section")
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits)
posix-clocks: Check write permissions in posix syscalls
hrtimer: Remove empty hrtimer_init_hres_timer()
hrtimer: Update hrtimer->state documentation
hrtimer: Update base[CLOCK_BOOTTIME].offset correctly
timers: Export CLOCK_BOOTTIME via the posix timers interface
timers: Add CLOCK_BOOTTIME hrtimer base
time: Extend get_xtime_and_monotonic_offset() to also return sleep
time: Introduce get_monotonic_boottime and ktime_get_boottime
hrtimers: extend hrtimer base code to handle more then 2 clockids
ntp: Remove redundant and incorrect parameter check
mn10300: Switch do_timer() to xtimer_update()
posix clocks: Introduce dynamic clocks
posix-timers: Cleanup namespace
posix-timers: Add support for fd based clocks
x86: Add clock_adjtime for x86
posix-timers: Introduce a syscall for clock tuning.
time: Splitout compat timex accessors
ntp: Add ADJ_SETOFFSET mode bit
time: Introduce timekeeping_inject_offset
posix-timer: Update comment
Fix up new system-call-related conflicts in
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/syscall_table_32.S
(name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some
due to movement of get_jiffies_64() in:
kernel/time.c
Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic
prototypes to use u32 types for the futex as this is the data type the
futex core code uses all over the place.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Darren Hart <darren@dvhart.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
LKML-Reference: <20110311025058.GD26122@google.com>
__set_LEDS() does not need to be protected by xtime_lock.
its used unprotected in other places.
[ tglx: Removed stale comment ]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: hch@infradead.org
Cc: johnstul@us.ibm.com
Cc: yong.zhang0@gmail.com
LKML-Reference: <20110127145946.23248.57952.stgit@localhost>
Currently percpu readmostly subsection may share cachelines with other
percpu subsections which may result in unnecessary cacheline bounce
and performance degradation.
This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR()
linker macros, makes each arch linker scripts specify its cacheline
size and use it to align percpu subsections.
This is based on Shaohua's x86 only patch.
Cc: Shaohua Li <shaohua.li@intel.com>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Use new 'regno', 'datap' variables in order to remove duplicated
expressions and unnecessary castings. Alse remove checking @addr
less than 0 because addr is now unsigned.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: "Daniel K." <dk@uw.no>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
We need to make sure that only the first do_signal() to be handled on
the way out syscall will bother with syscall restarts; additionally, the
check on the "signal has user handler" path had been wrong - compare
with restart prevention in sigreturn()...
do_signal() should place the syscall number in gr7, not gr8 when
handling ERESTART_WOULDBLOCK.
Use force_sigsegv() rather than force_sig(SIGSEGV, ...) as the former
resets the SEGV handler pointer which will kill the process, rather than
leaving it open to an infinite loop if the SEGV handler itself caused a
SEGV signal.
a) sa_handler might be maliciously set to point to kernel memory;
blindly dereferencing it in FDPIC case is a Bad Idea(tm).
b) I'm not sure you need that set_fs(USER_DS) there at all, but if you
do, you'd better do it *before* checking the frame you've decided to
use with access_ok(), lest sigaltstack() becomes a convenient
roothole.
Reset restart_block.fn on executing a sigreturn such that any currently
pending system call restarts will be forced to return -EINTR.
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
Reinstate the null behaviour that the in-kernel gdbstub had for the GDB
remote protocol 'p' command (retrieve a single register value) prior to
commit 7ca8b9c0dafd ("frv: extend gdbstub to support more features of
gdb").
Before that, the 'p' command just returned an empty reply, which causes
gdb to then go and use the 'g' command. However, since that commit, the
'p' command returns an error string, which causes gdb to abort its
connection to the target.
Not all gdb versions are affected, some use try 'g' first, and if that
works, don't bother with 'p', and so don't see the error.
On 64bit, local_t is of size long, and thus we make local64_t an alias.
On 32bit, we fall back to atomic64_t. (architecture can provide optimized
32-bit version)
(This new facility is to be used by perf events optimizations.)
LKML-Reference: <new-submission>
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits)
kbuild: Revert part of e8d400a to resolve a conflict
kbuild: Fix checking of scm-identifier variable
gconfig: add support to show hidden options that have prompts
menuconfig: add support to show hidden options which have prompts
gconfig: remove show_debug option
gconfig: remove dbg_print_ptype() and dbg_print_stype()
kconfig: fix zconfdump()
kconfig: some small fixes
add random binaries to .gitignore
kbuild: Include gen_initramfs_list.sh and the file list in the .d file
kconfig: recalc symbol value before showing search results
.gitignore: ignore *.lzo files
headerdep: perlcritic warning
scripts/Makefile.lib: Align the output of LZO
kbuild: Generate modules.builtin in make modules_install
Revert "kbuild: specify absolute paths for cscope"
kbuild: Do not unnecessarily regenerate modules.builtin
headers_install: use local file handles
headers_check: fix perl warnings
export_report: fix perl warnings
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
The Blackfin/FRV/SuperH guys all have the same exact FDPIC ptrace code in
their arch handlers (since they were probably copied & pasted). Since
these ptrace interfaces are an arch independent aspect of the FDPIC code,
unify them in the common ptrace code so new FDPIC ports don't need to copy
and paste this fundamental stuff yet again.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Extend gdbstub to support more features of gdb remote protocol to keep
gdb-7 and emacs gud mode happy:
(*) The D command. Detach debugger.
(*) The H command. Handle setting the target thread by ignoring it.
(*) The qAttached command. Indicate we 'attached' to an existing process.
(*) The qC command. Indicate that the current thread ID is 0.
(*) The qOffsets command. Indicate that no relocation has been done.
(*) The qSymbol:: command. Indicate that we're not interested in looking up
any symbol addresses.
(*) The qSupported command. Indicate the maximum packet size and the fact
that reverse step and continue aren't supported.
(*) The vCont? command. Indicate that we don't support any of its variants.
Also make it possible to trace the commands and replies without tracing
the individual character I/O.
[akpm@linux-foundation.org: make gdbstub_handle_query() static]
Cc: Jason Wessel <jason.wessel@windriver.com>
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch converts the frv architecture to use the generic
read_persistent_clock and update_persistent_clock interfaces, reducing
the amount of arch specific code we have to maintain, and allowing for
further cleanups in the future.
I have not built or tested this patch, so help from arch maintainers
would be appreciated.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1267675049-12337-4-git-send-email-johnstul@us.ibm.com>
Add a generic implementation of the ipc demultiplexer syscall. Except for
s390 and sparc64 all implementations of the sys_ipc are nearly identical.
There are slight differences in the types of the parameters, where mips
and powerpc as the only 64-bit architectures with sys_ipc use unsigned
long for the "third" argument as it gets casted to a pointer later, while
it traditionally is an "int" like most other paramters. frv goes even
further and uses unsigned long for all parameters execept for "ptr" which
is a pointer type everywhere. The change from int to unsigned long for
"third" and back to "int" for the others on frv should be fine due to the
in-register calling conventions for syscalls (we already had a similar
issue with the generic sys_ptrace), but I'd prefer to have the arch
maintainers looks over this in details.
Except for that h8300, m68k and m68knommu lack an impplementation of the
semtimedop sub call which this patch adds, and various architectures have
gets used - at least on i386 it seems superflous as the compat code on
x86-64 and ia64 doesn't even bother to implement it.
[akpm@linux-foundation.org: add sys_ipc to sys_ni.c]
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits)
net: fix for utsrelease.h moving to generated
gen_init_cpio: fixed fwrite warning
kbuild: fix make clean after mismerge
kbuild: generate modules.builtin
genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()
score: add asm/asm-offsets.h wrapper
unifdef: update to upstream revision 1.190
kbuild: create include/generated in silentoldconfig
scripts/package: deb-pkg: use fakeroot if available
scripts/package: add KBUILD_PKG_ROOTCMD variable
scripts/package: tar-pkg: use tar --owner=root
Kbuild: clean up marker
net: add net_tstamp.h to headers_install
kbuild: move utsrelease.h to include/generated
kbuild: move autoconf.h to include/generated
drop explicit include of autoconf.h
kbuild: move compile.h to include/generated
kbuild: drop include/asm
kbuild: do not check for include/asm-$ARCH
Fixed non-conflicting clean merge of modpost.c as per comments from
Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h
that needed to be changed to generated/autoconf.h)
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Fix up all users of utsrelease.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
* 'bkl-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
mn10300: Remove the BKL from sys_execve
m68knommu: Remove the BKL from sys_execve
m68k: Remove the BKL from sys_execve
h83000: Remove BKL from sys_execve
frv: Remove the BKL from sys_execve
blackfin: Remove the BKL from sys_execve
um: Remove BKL from mmapper
um: Remove BKL from random
s390: Remove BKL from prng
For consistency drop & in front of every proc_handler. Explicity
taking the address is unnecessary and it prevents optimizations
like stubbing the proc_handlers to NULL.
Cc: Joe Perches <joe@perches.com>
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name
and .strategy members of sysctl tables are dead code. Remove them.
The frv sysctl tables can only be used from proc so kill
the sysctl numbers.
syscallno is unsigned
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
sys_execve for frv seems to be a copy-and-paste of sys_execve that no
longer requires the bkl. Just remove it.
Signed-off-by: John Kacur <jkacur@redhat.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <alpine.LFD.2.00.0910130008320.3658@localhost.localdomain>
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
Use asm/generic-hardirq.h to build asm/hardirq.h and also remove the unused
idle_timestamp field in irq_cpustat whilst we're at it.
Impact: cleanup
No need for redeclaration.
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
