path: root/arch/frv/lib
2015-07-27frv: Rewrite atomic implementationPeter Zijlstra
Mostly complete rewrite of the FRV atomic implementation, instead of using assembly files, use inline assembler. The out-of-line CONFIG option makes a bit of a mess of things, but a little CPP trickery gets that done too. FRV already had the atomic logic ops but under a non standard name, the reimplementation provides the generic names and provides the intermediate form required for the bitops implementation. The slightly inconsistent __atomic32_fetch_##op naming is because __atomic_fetch_##op conlicts with GCC builtin functions. The 64bit atomic ops use the inline assembly %Ln construct to access the low word register (r+1), afaik this construct was not previously used in the kernel and is completely undocumented, but I found it in the FRV GCC code and it seems to work. FRV had a non-standard definition of atomic_{clear,set}_mask() which would work types other than atomic_t, the one user relying on that (arch/frv/kernel/dma.c) got converted to use the new intermediate form. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-01FRV: Add basic performance counter supportDavid Howells
Add basic performance counter support to the FRV arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Implement atomic64_tDavid Howells
Implement atomic64_t and its ops for FRV. Tested with the following patch: diff --git a/arch/frv/kernel/setup.c b/arch/frv/kernel/setup.c index 55e4fab..086d50d 100644 --- a/arch/frv/kernel/setup.c +++ b/arch/frv/kernel/setup.c @@ -746,6 +746,52 @@ static void __init parse_cmdline_early(char *cmdline) } /* end parse_cmdline_early() */ +static atomic64_t xxx; + +static void test_atomic64(void) +{ + atomic64_set(&xxx, 0x12300000023LL); + + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000023LL); + mb(); + if (atomic64_inc_return(&xxx) != 0x12300000024LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000024LL); + mb(); + if (atomic64_sub_return(0x36900000050LL, &xxx) != -0x2460000002cLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002cLL); + mb(); + if (atomic64_dec_return(&xxx) != -0x2460000002dLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002dLL); + mb(); + if (atomic64_add_return(0x36800000001LL, &xxx) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x123456789abcdefLL, 0x121ffffffd4LL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x121ffffffd4LL, 0x123456789abcdefLL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x123456789abcdefLL); + mb(); + if (atomic64_xchg(&xxx, 0xabcdef123456789LL) != 0x123456789abcdefLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0xabcdef123456789LL); + mb(); +} + /*****************************************************************************/ /* * @@ -845,6 +891,8 @@ void __init setup_arch(char **cmdline_p) // asm volatile("movgs %0,timerd" :: "r"(10000000)); // __set_HSR(0, __get_HSR(0) | HSR0_ETMD); + test_atomic64(); + } /* end setup_arch() */ #if 0 Note that this doesn't cover all the trivial wrappers, but does cover all the substantial implementations. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03move frv docs one level upAdrian Bunk
My first guess for "fujitsu" was it might be related to the fujitsu-laptop.c driver... Move the frv directory one level up since frv is the name of the architecture in the Linux kernel. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-12-02[NET]: FRV checksum annotations.Al Viro
* sanitize prototypes and annotate * collapse csum_partial_copy Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Kill direct includes of asm/checksum.hAl Viro
2006-01-08[PATCH] frv: implement and export various things required by modulesDavid Howells
Export a number of features required to build all the modules. It also implements the following simple features: (*) csum_partial_copy_from_user() for MMU as well as no-MMU. (*) __ucmpdi2(). so that they can be exported too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] frv: drop 8/16-bit xchg and cmpxchgDavid Howells
Drop support for 8-bit and 16-bit xchg and cmpxchg emulation and implements 32-bit xchg with the SWAP/SWAPI instruction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
