path: root/arch/frv/mm/init.c
2008-05-24frv: export empty_zero_pageAdrian Bunk
Fix the following build error: ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-09FRV: Remove the section annotation on free_initmem()David Howells
Remove the section annotation on FRV's free_initmem(). It can't be marked __init, lest it free itself. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] FRV: No ZONE_DMADavid Howells
FRV does not require a ZONE_DMA, so all DMA'able pages that aren't highmem should be in ZONE_NORMAL. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: fix MAX_NR_ZONES array initializationsChristoph Lameter
Fix array initialization in lots of arches The number of zones may now be reduced from 4 to 2 for many arches. Fix the array initialization for the zones array for all architectures so that it is not initializing a fixed number of elements. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] FRV: Make the FRV arch work againDavid Howells
The attached patch implements a bunch of small changes to the FRV arch to make it work again. It deals with the following problems: (1) SEM_DEBUG should be SEMAPHORE_DEBUG. (2) The argument list to pcibios_penalize_isa_irq() has changed. (3) CONFIG_HIGHMEM can't be used directly in #if as it may not be defined. (4) page->private is no longer directly accessible. (5) linux/hardirq.h assumes asm/hardirq.h will include linux/irq.h (6) The IDE MMIO access functions are given pointers, not integers, and so get type casting errors. (7) __pa() is passed an explicit u64 type in drivers/char/mem.c, but that can't be cast directly to a pointer on a 32-bit platform. (8) SEMAPHORE_DEBUG should not be contingent on WAITQUEUE_DEBUG as that no longer exists. (9) PREEMPT_ACTIVE is too low a value. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] mm: remove PG_highmemBadari Pulavarty
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll generate a little more code, but we don't use PageHigheMem() in many places. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
