path: root/arch/frv
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Add basic performance counter supportDavid Howells
Add basic performance counter support to the FRV arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Implement atomic64_tDavid Howells
Implement atomic64_t and its ops for FRV. Tested with the following patch: diff --git a/arch/frv/kernel/setup.c b/arch/frv/kernel/setup.c index 55e4fab..086d50d 100644 --- a/arch/frv/kernel/setup.c +++ b/arch/frv/kernel/setup.c @@ -746,6 +746,52 @@ static void __init parse_cmdline_early(char *cmdline) } /* end parse_cmdline_early() */ +static atomic64_t xxx; + +static void test_atomic64(void) +{ + atomic64_set(&xxx, 0x12300000023LL); + + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000023LL); + mb(); + if (atomic64_inc_return(&xxx) != 0x12300000024LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000024LL); + mb(); + if (atomic64_sub_return(0x36900000050LL, &xxx) != -0x2460000002cLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002cLL); + mb(); + if (atomic64_dec_return(&xxx) != -0x2460000002dLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002dLL); + mb(); + if (atomic64_add_return(0x36800000001LL, &xxx) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x123456789abcdefLL, 0x121ffffffd4LL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x121ffffffd4LL, 0x123456789abcdefLL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x123456789abcdefLL); + mb(); + if (atomic64_xchg(&xxx, 0xabcdef123456789LL) != 0x123456789abcdefLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0xabcdef123456789LL); + mb(); +} + /*****************************************************************************/ /* * @@ -845,6 +891,8 @@ void __init setup_arch(char **cmdline_p) // asm volatile("movgs %0,timerd" :: "r"(10000000)); // __set_HSR(0, __get_HSR(0) | HSR0_ETMD); + test_atomic64(); + } /* end setup_arch() */ #if 0 Note that this doesn't cover all the trivial wrappers, but does cover all the substantial implementations. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30FRV: Wire up new syscallsDavid Howells
Wire up new syscalls rt_tgsigqueueinfo and perf_counter_open. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-13FRV: Fix interaction with new generic header stuffDavid Howells
Fix interaction with new generic header stuff as added by: commit 6103ec56c65c33774c7c38652c8204120c3c7519 Author: Arnd Bergmann <arnd@arndb.de> Date: Wed May 13 22:56:27 2009 +0000 asm-generic: add generic ABI headers The problem is that asm/signal.h has been made to include asm-generic/signal.h, but the redundant stuff from asm/signal.h has not been discarded, leading to multiple redefinitions. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: make pci.h usable directlyArnd Bergmann
Some generic code is using the horribly misnamed PCI_DMA_BUS_IS_PHYS from asm/pci.h. This makes sure that an architecture without PCI support does not have to define this itself but can rely on the asm-generic version. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename termios.h, signal.h and mman.hArnd Bergmann
The existing asm-generic versions are incomplete and included by some architectures. New architectures should be able to use a generic version, so rename the existing files and change all users, which lets us add the new files. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11FRV: Implement new-style ptraceDavid Howells
Implement the new-style ptrace for FRV, including adding appropriate tracehooks. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Don't turn on TIF_SYSCALL_TRACE unconditionally in syscall prologueDavid Howells
Don't turn on TIF_SYSCALL_TRACE unconditionally in syscall prologue in FRV's entry.S. This was originally for debugging stuff and should have been removed a long time ago. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Implement TIF_NOTIFY_RESUMEDavid Howells
Implement the TIF_NOTIFY_RESUME thread flag, making it call do_notify_resume() which then clears it. This will be made use of later by tracehooks in the new-style ptrace implementation Also discard TIF_IRET as that's not used by FRV. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Remove in-kernel strace codeDavid Howells
Remove in-kernel strace code from the FRV arch as it's not really needed any more. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: BUG to BUG_ON changesStoyan Gaydarov
Change some BUG()'s to BUG_ON()'s. Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: bitops: Change the bitmap index from int to unsigned longJustin Chen
Change the index to unsigned long in all bitops for [frv] Signed-off-by: Justin Chen <justin.chen@hp.com> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-27FRV: Use __INIT macro instead of .text.init.Tim Abbott
FRV is placing some code in the .text.init section but does not reference that section in its linker scripts. This change moves this code from the .text.init section to the .init.text section, which is presumably where it belongs. Signed-off-by: Tim Abbott <tabbott@mit.edu> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-27FRV: Remove unused header asm/init.h.Tim Abbott
It seems nothing has included the frv asm/init.h header for some time, and its actual contents are out of date with include/linux/init.h. So just delete it. Signed-off-by: Tim Abbott <tabbott@mit.edu> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-27FRV: Stop gcc from generating uninitialised variable warnings after BUG()David Howells
Stop gcc from generating uninitialised variable warnings after BUG(). The problem is that FRV's call into its gdbstub appears to return (if the function is marked noreturn, then the compiler is under no obligation to pass it a return address, and so GDB won't know where the bug happened). To get around this, we make the do...while wrapper in _debug_bug_trap() an endless loop from which there's no escape. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-27FRV: Wire up new syscallsDavid Howells
Wire up new system calls for the FRV arch (preadv and pwritev). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-26frv: convert frv to use __HEAD and HEAD_TEXT macros.Tim Abbott
This has the consequence of changing the section name use for head code from ".text.head" to ".head.text". Since this commit changes all users in the architecture, this change should be harmless. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21frv: insert PCI root bus resources for the MB93090 devel motherboardDavid Howells
Insert PCI root bus resources for the FRV-based MB93090 development kit motherboard. This is required because the CPU's window onto the PCI bus address space is considerably smaller than the CPU's full address space and non-PCI devices lie outside of the PCI window that we might want to access. Without this patch, the PCI root bus uses the platform-level bus resources, and these are then confined to the PCI window, thus making platform_device_add() reject devices outside of this window. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-20FRV: Don't attempt to #include <linux/blk.h> as it doesn't existDavid Howells
Stop the FRV arch from attempting to #include <linux/blk.h> as it doesn't exist. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10FRV: Move to arch/frv/include/asm/David Howells
Move arch headers from include/asm-frv/ to arch/frv/include/asm/. Signed-off-by: David Howells <dhowells@redhat.com>
2009-04-06FRV: Fix compile breakageAdrian Bunk
This patch fixes the follwing build error caused by commit 7ca43e7564679604d86e9ed834e7bbcffd8a4a3f (mm: use debug_kmap_atomic): ... AS arch/frv/mm/tlb-miss.o In file included from arch/frv/mm/tlb-miss.S:13: ... Assembler messages: include/asm-generic/ioctl.h:73: Error: unrecognized instruction `extern unsigned int __invalid_size_argument_for_IO...' ... Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Simplify copy_thread()Alexey Dobriyan
First argument unused since 2.3.11. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-02-13Merge branches 'irq/genirq', 'irq/sparseirq' and 'irq/urgent' into irq/coreIngo Molnar
2009-02-09FRV: in_interrupt() requires #inclusion of linux/hardirq.h not asm/hardirq.h nowDavid Howells
in_interrupt() requires #inclusion of linux/hardirq.h not asm/hardirq.h now. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-11sparseirq: use kstat_irqs_cpu insteadYinghai Lu
Impact: build fix Ingo Molnar wrote: > tip/arch/blackfin/kernel/irqchip.c: In function 'show_interrupts': > tip/arch/blackfin/kernel/irqchip.c:85: error: 'struct kernel_stat' has no member named 'irqs' > make[2]: *** [arch/blackfin/kernel/irqchip.o] Error 1 > make[2]: *** Waiting for unfinished jobs.... > So could move kstat_irqs array to irq_desc struct. (s390, m68k, sparc) are not touched yet, because they don't support genirq Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2008-12-31take init_fs to saner placeAl Viro
2008-12-01frv: fix mmap2 error handlingDavid Howells
Fix the error handling in sys_mmap2(). Currently, if the pgoff check fails, fput() might have to be called (which it isn't), so do the pgoff check first, before fget() is called. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: implement freezer cgroup subsystemMatt Helsley
This patch implements a new freezer subsystem in the control groups framework. It provides a way to stop and resume execution of all tasks in a cgroup by writing in the cgroup filesystem. The freezer subsystem in the container filesystem defines a file named freezer.state. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. Reading will return the current state. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This is the basic mechanism which should do the right thing for user space task in a simple scenario. It's important to note that freezing can be incomplete. In that case we return EBUSY. This means that some tasks in the cgroup are busy doing something that prevents us from completely freezing the cgroup at this time. After EBUSY, the cgroup will remain partially frozen -- reflected by freezer.state reporting "FREEZING" when read. The state will remain "FREEZING" until one of these things happens: 1) Userspace cancels the freezing operation by writing "RUNNING" to the freezer.state file 2) Userspace retries the freezing operation by writing "FROZEN" to the freezer.state file (writing "FREEZING" is not legal and returns EIO) 3) The tasks that blocked the cgroup from entering the "FROZEN" state disappear from the cgroup's set of tasks. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: export thaw_process] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16FRV: Eliminate NULL test and memset after alloc_bootmemJulia Lawall
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem and related functions never return NULL and always return a zeroed region of memory. Thus a NULL test or memset after calls to these functions is unnecessary. arch/frv/mm/init.c | 2 -- 1 file changed, 2 deletions(-) This was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; statement S; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E ( - BUG_ON (E == NULL); | - if (E == NULL) S ) @@ expression E,E1; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E - memset(E,0,E1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16FRV: Provide dma_map_page() for NOMMU and fix commentsDavid Howells
Provide dma_map_page() for the NOMMU-mode FRV arch. Also do some fixing on the comments attached to the various DMA functions for both MMU and NOMMU mode FRV code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16frv: use generic pci_enable_resources()Bjorn Helgaas
Use the generic pci_enable_resources() instead of the arch-specific code. Unlike this arch-specific code, the generic version: - checks PCI_NUM_RESOURCES (11), not 6, resources - skips resources that have neither IORESOURCE_IO nor IORESOURCE_MEM set - skips ROM resources unless IORESOURCE_ROM_ENABLE is set - checks for resource collisions with "!r->parent" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01FRV: Wire up new system callsDavid Howells
Wire up for FRV the system calls that were added in the last merge window. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26frv: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() where show_mem() calls show_free_areas(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26frv: use the common ascii hex helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24remove include/linux/pm_legacy.hAdrian Bunk
Remove the obsolete and no longer used include/linux/pm_legacy.h Reviewed-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Pavel Machek <pavel@suse.cz> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-27PCI: remove unused arch pcibios_update_resource() functionsAdrian Bunk
Russell King did the following back in 2003: <-- snip --> [PCI] pci-9: Kill per-architecture pcibios_update_resource() Kill pcibios_update_resource(), replacing it with pci_update_resource(). pci_update_resource() uses pcibios_resource_to_bus() to convert a resource to a device BAR - the transformation should be exactly the same as the transformation used for the PCI bridges. pci_update_resource "knows" about 64-bit BARs, but doesn't attempt to set the high 32-bits to anything non-zero - currently no architecture attempts to do something different. If anyone cares, please fix; I'm going to reflect current behaviour for the time being. Ivan pointed out the following architectures need to examine their pcibios_update_resource() implementation - they should make sure that this new implementation does the right thing. #warning's have been added where appropriate. ia64 mips mips64 This cset also includes a fix for the problem reported by AKPM where 64-bit arch compilers complain about the resource mask being placed in a u32. <-- snip --> This patch removes the unused pcibios_update_resource() functions the kernel gained since, from FRV, m68k, mips & sh architectures. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
