path: root/arch/frv
2010-07-05frv: set ARCH_KMALLOC_MINALIGNFUJITA Tomonori
commit 69dcf3db03626c4f18de624e8632454ea12ff260 upstream. Architectures that handle DMA-non-coherent memory need to set ARCH_KMALLOC_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09FDPIC: Respect PT_GNU_STACK exec protection markings when creating NOMMU stackMike Frysinger
commit 04e4f2b18c8de1389d1e00fef0f42a8099910daf upstream. The current code will load the stack size and protection markings, but then only use the markings in the MMU code path. The NOMMU code path always passes PROT_EXEC to the mmap() call. While this doesn't matter to most people whilst the code is running, it will cause a pointless icache flush when starting every FDPIC application. Typically this icache flush will be of a region on the order of 128KB in size, or may be the entire icache, depending on the facilities available on the CPU. In the case where the arch default behaviour seems to be desired (EXSTACK_DEFAULT), we probe VM_STACK_FLAGS for VM_EXEC to determine whether we should be setting PROT_EXEC or not. For arches that support an MPU (Memory Protection Unit - an MMU without the virtual mapping capability), setting PROT_EXEC or not will make an important difference. It should be noted that this change also affects the executability of the brk region, since ELF-FDPIC has that share with the stack. However, this is probably irrelevant as NOMMU programs aren't likely to use the brk region, preferring instead allocation via mmap(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-29frv: fix check on unsigned in do_signal()Roel Kluin
syscallno is unsigned Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24FRV: Flash mappings for the MB93090-MB00 motherboardDavid Howells
Flash mappings for the MB93090-MB00 evaluation motherboard. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23FRV: Use asm/generic-hardirq.hChristoph Hellwig
Use asm/generic-hardirq.h to build asm/hardirq.h and also remove the unused idle_timestamp field in irq_cpustat whilst we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23misc: remove redundant start_kernel prototypesRusty Russell
Impact: cleanup No need for redeclaration. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22mm: remove duplicate asm/mman.h filesArnd Bergmann
A number of architectures have identical asm/mman.h files so they can all be merged by using the new generic file. The remaining asm/mman.h files are substantially different from each other. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-18frv: clean up linker script using new linker script macros.Nelson Elhage
This is largely a straightforward conversion. The patch results in fewer output sections, and some data being reordered, but should have no functional impact. Also, note that this patch moves some data (namely, init_task and cacheline-aligned) inside [_sdata,_edata]. Because frv already builds using -ffunction-sections -fdata-sections, we can't use BSS_SECTION or RW_DATA_SECTION yet, since they do not currently include the required .bss.* and .data.* sections. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18frv: remove unused .altinstructions codeNelson Elhage
It appears that frv copied the .altinstructions definitions in its linker script from x86. Since frv doesn't put anything in those sections, this is just dead code. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-09frv/PCI: Use pci_claim_resourceMatthew Wilcox
Instead of open-coding pci_find_parent_resource and request_resource, just call pci_claim_resource. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-07-01FRV: Add basic performance counter supportDavid Howells
Add basic performance counter support to the FRV arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Implement atomic64_tDavid Howells
Implement atomic64_t and its ops for FRV. Tested with the following patch: diff --git a/arch/frv/kernel/setup.c b/arch/frv/kernel/setup.c index 55e4fab..086d50d 100644 --- a/arch/frv/kernel/setup.c +++ b/arch/frv/kernel/setup.c @@ -746,6 +746,52 @@ static void __init parse_cmdline_early(char *cmdline) } /* end parse_cmdline_early() */ +static atomic64_t xxx; + +static void test_atomic64(void) +{ + atomic64_set(&xxx, 0x12300000023LL); + + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000023LL); + mb(); + if (atomic64_inc_return(&xxx) != 0x12300000024LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000024LL); + mb(); + if (atomic64_sub_return(0x36900000050LL, &xxx) != -0x2460000002cLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002cLL); + mb(); + if (atomic64_dec_return(&xxx) != -0x2460000002dLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002dLL); + mb(); + if (atomic64_add_return(0x36800000001LL, &xxx) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x123456789abcdefLL, 0x121ffffffd4LL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x121ffffffd4LL, 0x123456789abcdefLL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x123456789abcdefLL); + mb(); + if (atomic64_xchg(&xxx, 0xabcdef123456789LL) != 0x123456789abcdefLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0xabcdef123456789LL); + mb(); +} + /*****************************************************************************/ /* * @@ -845,6 +891,8 @@ void __init setup_arch(char **cmdline_p) // asm volatile("movgs %0,timerd" :: "r"(10000000)); // __set_HSR(0, __get_HSR(0) | HSR0_ETMD); + test_atomic64(); + } /* end setup_arch() */ #if 0 Note that this doesn't cover all the trivial wrappers, but does cover all the substantial implementations. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30FRV: Wire up new syscallsDavid Howells
Wire up new syscalls rt_tgsigqueueinfo and perf_counter_open. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-13FRV: Fix interaction with new generic header stuffDavid Howells
Fix interaction with new generic header stuff as added by: commit 6103ec56c65c33774c7c38652c8204120c3c7519 Author: Arnd Bergmann <arnd@arndb.de> Date: Wed May 13 22:56:27 2009 +0000 asm-generic: add generic ABI headers The problem is that asm/signal.h has been made to include asm-generic/signal.h, but the redundant stuff from asm/signal.h has not been discarded, leading to multiple redefinitions. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: make pci.h usable directlyArnd Bergmann
Some generic code is using the horribly misnamed PCI_DMA_BUS_IS_PHYS from asm/pci.h. This makes sure that an architecture without PCI support does not have to define this itself but can rely on the asm-generic version. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename termios.h, signal.h and mman.hArnd Bergmann
The existing asm-generic versions are incomplete and included by some architectures. New architectures should be able to use a generic version, so rename the existing files and change all users, which lets us add the new files. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11FRV: Implement new-style ptraceDavid Howells
Implement the new-style ptrace for FRV, including adding appropriate tracehooks. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Don't turn on TIF_SYSCALL_TRACE unconditionally in syscall prologueDavid Howells
Don't turn on TIF_SYSCALL_TRACE unconditionally in syscall prologue in FRV's entry.S. This was originally for debugging stuff and should have been removed a long time ago. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Implement TIF_NOTIFY_RESUMEDavid Howells
Implement the TIF_NOTIFY_RESUME thread flag, making it call do_notify_resume() which then clears it. This will be made use of later by tracehooks in the new-style ptrace implementation Also discard TIF_IRET as that's not used by FRV. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11FRV: Remove in-kernel strace codeDavid Howells
Remove in-kernel strace code from the FRV arch as it's not really needed any more. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
