path: root/arch/frv
2018-05-19futex: Remove duplicated code and fix undefined behaviourJiri Slaby
commit 30d6e0a4190d37740e9447e4e4815f06992dd8c3 upstream. There is code duplicated over all architecture's headers for futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr, and comparison of the result. Remove this duplication and leave up to the arches only the needed assembly which is now in arch_futex_atomic_op_inuser. This effectively distributes the Will Deacon's arm64 fix for undefined behaviour reported by UBSAN to all architectures. The fix was done in commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump. And as suggested by Thomas, check for negative oparg too, because it was also reported to cause undefined behaviour report. Note that s390 removed access_ok check in d12a29703 ("s390/uaccess: remove pointless access_ok() checks") as access_ok there returns true. We introduce it back to the helper for the sake of simplicity (it gets optimized away anyway). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390] Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org> Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64] Cc: linux-mips@linux-mips.org Cc: Rich Felker <dalias@libc.org> Cc: linux-ia64@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: peterz@infradead.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: sparclinux@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: linux-s390@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: linux-hexagon@vger.kernel.org Cc: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: linux-snps-arc@lists.infradead.org Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-xtensa@linux-xtensa.org Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Cc: openrisc@lists.librecores.org Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Stafford Horne <shorne@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Richard Henderson <rth@twiddle.net> Cc: Chris Zankel <chris@zankel.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-parisc@vger.kernel.org Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-alpha@vger.kernel.org Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08frv: declare jiffies to be located in the .data sectionMatthias Kaehlcke
commit 60b0a8c3d2480f3b57282b47b7cae7ee71c48635 upstream. Commit 7c30f352c852 ("jiffies.h: declare jiffies and jiffies_64 with ____cacheline_aligned_in_smp") removed a section specification from the jiffies declaration that caused conflicts on some platforms. Unfortunately this change broke the build for frv: kernel/built-in.o: In function `__do_softirq': (.text+0x6460): relocation truncated to fit: R_FRV_GPREL12 against symbol `jiffies' defined in *ABS* section in .tmp_vmlinux1 kernel/built-in.o: In function `__do_softirq': (.text+0x6574): relocation truncated to fit: R_FRV_GPREL12 against symbol `jiffies' defined in *ABS* section in .tmp_vmlinux1 kernel/built-in.o: In function `pwq_activate_delayed_work': workqueue.c:(.text+0x15b9c): relocation truncated to fit: R_FRV_GPREL12 against symbol `jiffies' defined in *ABS* section in .tmp_vmlinux1 ... Add __jiffy_arch_data to the declaration of jiffies and use it on frv to include the section specification. For all other platforms __jiffy_arch_data (currently) has no effect. Fixes: 7c30f352c852 ("jiffies.h: declare jiffies and jiffies_64 with ____cacheline_aligned_in_smp") Link: http://lkml.kernel.org/r/20170516221333.177280-1-mka@chromium.org Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Reported-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: David Howells <dhowells@redhat.com> Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24mm: larger stack guard gap, between vmasHugh Dickins
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream. Stack guard page is a useful feature to reduce a risk of stack smashing into a different mapping. We have been using a single page gap which is sufficient to prevent having stack adjacent to a different mapping. But this seems to be insufficient in the light of the stack usage in userspace. E.g. glibc uses as large as 64kB alloca() in many commonly used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX] which is 256kB or stack strings with MAX_ARG_STRLEN. This will become especially dangerous for suid binaries and the default no limit for the stack size limit because those applications can be tricked to consume a large portion of the stack and a single glibc call could jump over the guard page. These attacks are not theoretical, unfortunatelly. Make those attacks less probable by increasing the stack guard gap to 1MB (on systems with 4k pages; but make it depend on the page size because systems with larger base pages might cap stack allocations in the PAGE_SIZE units) which should cover larger alloca() and VLA stack allocations. It is obviously not a full fix because the problem is somehow inherent, but it should reduce attack space a lot. One could argue that the gap size should be configurable from userspace, but that can be done later when somebody finds that the new 1MB is wrong for some special case applications. For now, add a kernel command line option (stack_guard_gap) to specify the stack gap size (in page units). Implementation wise, first delete all the old code for stack guard page: because although we could get away with accounting one extra page in a stack vma, accounting a larger gap can break userspace - case in point, a program run with "ulimit -S -v 20000" failed when the 1MB gap was counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK and strict non-overcommit mode. Instead of keeping gap inside the stack vma, maintain the stack guard gap as a gap between vmas: using vm_start_gap() in place of vm_start (or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few places which need to respect the gap - mainly arch_get_unmapped_area(), and and the vma tree's subtree_gap support for that. Original-patch-by: Oleg Nesterov <oleg@redhat.com> Original-patch-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Tested-by: Helge Deller <deller@gmx.de> # parisc Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [wt: backport to 4.11: adjust context] [wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide] Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17frv: add missing atomic64 operationsSudip Mukherjee
[ Upstream commit 4180c4c170a5a33b9987b314d248a9d572d89ab0 ] Some more atomic64 operations were missing and as a result frv allmodconfig was failing. Add the missing operations. Link: http://lkml.kernel.org/r/1485193844-12850-1-git-send-email-sudip.mukherjee@codethink.co.uk Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17frv: add atomic64_add_unless()Sudip Mukherjee
[ Upstream commit 545d58f677b21401f6de1ac12c25cc109f903ace ] The build of frv allmodconfig was failing with the error: lib/atomic64_test.c:209:9: error: implicit declaration of function 'atomic64_add_unless' All the atomic64 operations were defined in frv, but atomic64_add_unless() was not done. Implement atomic64_add_unless() as done in other arches. Link: http://lkml.kernel.org/r/1484781236-6698-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-11Merge branch 'work.uaccess2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uaccess.h prepwork from Al Viro: "Preparations to tree-wide switch to use of linux/uaccess.h (which, obviously, will allow to start unifying stuff for real). The last step there, ie PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ `git grep -l "$PATT"|grep -v ^include/linux/uaccess.h` is not taken here - I would prefer to do it once just before or just after -rc1. However, everything should be ready for it" * 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: remove a stray reference to asm/uaccess.h in docs sparc64: separate extable_64.h, switch elf_64.h to it score: separate extable.h, switch module.h to it mips: separate extable.h, switch module.h to it x86: separate extable.h, switch sections.h to it remove stray include of asm/uaccess.h from cacheflush.h mn10300: remove a bogus processor.h->uaccess.h include xtensa: split uaccess.h into C and asm sides bonding: quit messing with IOCTL kill __kernel_ds_p off mn10300: finish verify_area() off frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h exceptions: detritus removal
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-27kill __kernel_ds_p offAl Viro
2016-09-27frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.hAl Viro
it has no business in uaccess.h, everything else has it in pgtable.h and the only user (mm/mmap.c) unconditionally pulls asm/pgtable.h via linux/mm.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-13frv: fix clear_user()Al Viro
It should check access_ok(). Otherwise a bunch of places turn into trivially exploitable rootholes. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-08-05Merge tag 'rtc-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.8 Cleanups: - huge cleanup of rtc-generic and char/genrtc this allowed to cleanup rtc-cmos, rtc-sh, rtc-m68k, rtc-powerpc and rtc-parisc - move mn10300 to rtc-cmos Subsystem: - fix wakealarms after hibernate - multiples fixes for rctest - simplify implementations of .read_alarm New drivers: - Maxim MAX6916 Drivers: - ds1307: fix weekday - m41t80: add wakeup support - pcf85063: add support for PCF85063A variant - rv8803: extend i2c fix and other fixes - s35390a: fix alarm reading, this fixes instant reboot after shutdown for QNAP TS-41x - s3c: clock fixes" * tag 'rtc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (65 commits) rtc: rv8803: Clear V1F when setting the time rtc: rv8803: Stop the clock while setting the time rtc: rv8803: Always apply the I²C workaround rtc: rv8803: Fix read day of week rtc: rv8803: Remove the check for valid time rtc: rv8803: Kconfig: Indicate rx8900 support rtc: asm9260: remove .owner field for driver rtc: at91sam9: Fix missing spin_lock_init() rtc: m41t80: add suspend handlers for alarm IRQ rtc: m41t80: make it a real error message rtc: pcf85063: Add support for the PCF85063A device rtc: pcf85063: fix year range rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracy rtc: explicitly set tm_sec = 0 for drivers with minute accurancy rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq() rtc: s3c: Remove unnecessary call to disable already disabled clock rtc: abx80x: use devm_add_action_or_reset() rtc: m41t80: use devm_add_action_or_reset() rtc: fix a typo and reduce three empty lines to one rtc: s35390a: improve two comments in .set_alarm ...
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: do not pass mm_struct into handle_mm_faultKirill A. Shutemov
We always have vma->vm_mm around. Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-25Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The locking tree was busier in this cycle than the usual pattern - a couple of major projects happened to coincide. The main changes are: - implement the atomic_fetch_{add,sub,and,or,xor}() API natively across all SMP architectures (Peter Zijlstra) - add atomic_fetch_{inc/dec}() as well, using the generic primitives (Davidlohr Bueso) - optimize various aspects of rwsems (Jason Low, Davidlohr Bueso, Waiman Long) - optimize smp_cond_load_acquire() on arm64 and implement LSE based atomic{,64}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() on arm64 (Will Deacon) - introduce smp_acquire__after_ctrl_dep() and fix various barrier mis-uses and bugs (Peter Zijlstra) - after discovering ancient spin_unlock_wait() barrier bugs in its implementation and usage, strengthen its semantics and update/fix usage sites (Peter Zijlstra) - optimize mutex_trylock() fastpath (Peter Zijlstra) - ... misc fixes and cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits) locking/atomic: Introduce inc/dec variants for the atomic_fetch_$op() API locking/barriers, arch/arm64: Implement LDXR+WFE based smp_cond_load_acquire() locking/static_keys: Fix non static symbol Sparse warning locking/qspinlock: Use __this_cpu_dec() instead of full-blown this_cpu_dec() locking/atomic, arch/tile: Fix tilepro build locking/atomic, arch/m68k: Remove comment locking/atomic, arch/arc: Fix build locking/Documentation: Clarify limited control-dependency scope locking/atomic, arch/rwsem: Employ atomic_long_fetch_add() locking/atomic, arch/qrwlock: Employ atomic_fetch_add_acquire() locking/atomic, arch/mips: Convert to _relaxed atomics locking/atomic, arch/alpha: Convert to _relaxed atomics locking/atomic: Remove the deprecated atomic_{set,clear}_mask() functions locking/atomic: Remove linux/atomic.h:atomic_fetch_or() locking/atomic: Implement atomic{,64,_long}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() locking/atomic: Fix atomic64_relaxed() bits locking/atomic, arch/xtensa: Implement atomic_fetch_{add,sub,and,or,xor}() locking/atomic, arch/x86: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/tile: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/sparc: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() ...
2016-07-04Merge 4.7-rc6 into tty-nextGreg Kroah-Hartman
We want the tty/serial fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-25tty: frv, remove unused serial macrosJiri Slaby
STD_COM_FLAGS needs not be defined as it is not used anywhere on frv. SERIAL_PORT_DFNS is defined to be empty. 8250 is aware of empty SERIAL_PORT_DFNS and does: #ifndef SERIAL_PORT_DFNS #define SERIAL_PORT_DFNS #endif So no need to define it on frv. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24tree wide: get rid of __GFP_REPEAT for order-0 allocations part IMichal Hocko
This is the third version of the patchset previously sent [1]. I have basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get rid of superfluous gfp flags" which went through dm tree. I am sending it now because it is tree wide and chances for conflicts are reduced considerably when we want to target rc2. I plan to send the next step and rename the flag and move to a better semantic later during this release cycle so we will have a new semantic ready for 4.8 merge window hopefully. Motivation: While working on something unrelated I've checked the current usage of __GFP_REPEAT in the tree. It seems that a majority of the usage is and always has been bogus because __GFP_REPEAT has always been about costly high order allocations while we are using it for order-0 or very small orders very often. It seems that a big pile of them is just a copy&paste when a code has been adopted from one arch to another. I think it makes some sense to get rid of them because they are just making the semantic more unclear. Please note that GFP_REPEAT is documented as * __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt * _might_ fail. This depends upon the particular VM implementation. while !costly requests have basically nofail semantic. So one could reasonably expect that order-0 request with __GFP_REPEAT will not loop for ever. This is not implemented right now though. I would like to move on with __GFP_REPEAT and define a better semantic for it. $ git grep __GFP_REPEAT origin/master | wc -l 111 $ git grep __GFP_REPEAT | wc -l 36 So we are down to the third after this patch series. The remaining places really seem to be relying on __GFP_REPEAT due to large allocation requests. This still needs some double checking which I will do later after all the simple ones are sorted out. I am touching a lot of arch specific code here and I hope I got it right but as a matter of fact I even didn't compile test for some archs as I do not have cross compiler for them. Patches should be quite trivial to review for stupid compile mistakes though. The tricky parts are usually hidden by macro definitions and thats where I would appreciate help from arch maintainers. [1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org This patch (of 19): __GFP_REPEAT has a rather weak semantic but since it has been introduced around 2.6.12 it has been ignored for low order allocations. Yet we have the full kernel tree with its usage for apparently order-0 allocations. This is really confusing because __GFP_REPEAT is explicitly documented to allow allocation failures which is a weaker semantic than the current order-0 has (basically nofail). Let's simply drop __GFP_REPEAT from those places. This would allow to identify place which really need allocator to retry harder and formulate a more specific semantic for what the flag is supposed to do actually. Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andy Lutomirski <luto@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: John Crispin <blogic@openwrt.org> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-16locking/atomic: Remove linux/atomic.h:atomic_fetch_or()Peter Zijlstra
Since all architectures have this implemented now natively, remove this dead code. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-16locking/atomic, arch/frv: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()Peter Zijlstra
Implement FETCH-OP atomic primitives, these are very similar to the existing OP-RETURN primitives we already have, except they return the value of the atomic variable _before_ modification. This is especially useful for irreversible operations -- such as bitops (because it becomes impossible to reconstruct the state prior to modification). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-04rtc: cmos: remove empty asm/mc146818rtc.h filesArnd Bergmann
Nothing on these architectures ever includes the asm/mc146818rtc.h file, the drivers that used to do this have been fixed long ago, and the remaining users are all PC-specific. This removes the files for good. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-24Merge tag 'asm-generic-4.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "There are only three patches this time, most other changes to files in include/asm-generic tend to go through the tree of whoever depends on the change. Two patches are cleanups for stuff that is no longer needed, the main change is to adapt the generic version of BUG_ON() for CONFIG_BUG=n to make it behave consistently with BUG(). This avoids undefined behavior along with a number of warnings about that undefined behavior in randconfig builds when we keep going on after hitting a BUG_ON()" * tag 'asm-generic-4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: remove old nonatomic-io wrapper files asm-generic: default BUG_ON(x) to if(x)BUG() asm-generic: page.h: Remove useless get_user_page and free_user_page
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-17Merge tag 'tty-4.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial updates from Greg KH: "Here's the big tty/serial driver pull request for 4.6-rc1. Lots of changes in here, Peter has been on a tear again, with lots of refactoring and bugs fixes, many thanks to the great work he has been doing. Lots of driver updates and fixes as well, full details in the shortlog. All have been in linux-next for a while with no reported issues" * tag 'tty-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (220 commits) serial: 8250: describe CONFIG_SERIAL_8250_RSA serial: samsung: optimize UART rx fifo access routine serial: pl011: add mark/space parity support serial: sa1100: make sa1100_register_uart_fns a function tty: serial: 8250: add MOXA Smartio MUE boards support serial: 8250: convert drivers to use up_to_u8250p() serial: 8250/mediatek: fix building with SERIAL_8250=m serial: 8250/ingenic: fix building with SERIAL_8250=m serial: 8250/uniphier: fix modular build Revert "drivers/tty/serial: make 8250/8250_ingenic.c explicitly non-modular" Revert "drivers/tty/serial: make 8250/8250_mtk.c explicitly non-modular" serial: mvebu-uart: initial support for Armada-3700 serial port serial: mctrl_gpio: Add missing module license serial: ifx6x60: avoid uninitialized variable use tty/serial: at91: fix bad offset for UART timeout register tty/serial: at91: restore dynamic driver binding serial: 8250: Add hardware dependency to RT288X option TTY, devpts: document pty count limiting tty: goldfish: support platform_device with id -1 drivers: tty: goldfish: Add device tree bindings ...
2016-03-13ipv6: Pass proto to csum_ipv6_magic as __u8 instead of unsigned shortAlexander Duyck
This patch updates csum_ipv6_magic so that it correctly recognizes that protocol is a unsigned 8 bit value. This will allow us to better understand what limitations may or may not be present in how we handle the data. For example there are a number of places that call htonl on the protocol value. This is likely not necessary and can be replaced with a multiplication by ntohl(1) which will be converted to a shift by the compiler. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-07PCI: Move pci_dma_* helpers to common codeChristoph Hellwig
For a long time all architectures implement the pci_dma_* functions using the generic DMA API, and they all use the same header to do so. Move this header, pci-dma-compat.h, to include/linux and include it from the generic pci.h instead of having each arch duplicate this include. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-03-07frv/PCI: Remove stray pci_{alloc,free}_consistent() declarationChristoph Hellwig
FRV doesn't implement pci_{alloc,free}_consistent(), so remove the declarations for them. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: David Howells <dhowells@redhat.com>
2016-02-26asm-generic: page.h: Remove useless get_user_page and free_user_pageChen Gang
They are not symmetric with each other, neither are used in real world (can not be found by grep command in source code root directory), so remove them. Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-02-25net: Facility to report route quality of connected socketsTom Herbert
This patch add the SO_CNX_ADVICE socket option (setsockopt only). The purpose is to allow an application to give feedback to the kernel about the quality of the network path for a connected socket. The value argument indicates the type of quality report. For this initial patch the only supported advice is a value of 1 which indicates "bad path, please reroute"-- the action taken by the kernel is to call dst_negative_advice which will attempt to choose a different ECMP route, reset the TX hash for flow label and UDP source port in encapsulation, etc. This facility should be useful for connected UDP sockets where only the application can provide any feedback about path quality. It could also be useful for TCP applications that have additional knowledge about the path outside of the normal TCP control loop. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-28serial: Fix ASYNC_* => UPF_* flags misusePeter Hurley
The UPF_* flags are the correct values to use for struct uart_port and struct old_serial_port/SERIAL_PORT_DFNS. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20frv: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: David Howells <dhowells@redhat.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20arch/frv/include/asm/io.h: accept const void pointers for read{b,w,l}()Stephen Boyd
The SMD driver is reading and writing chunks of data to iomem, and there's an __iowrite32_copy() function for the writing part, but no __ioread32_copy() function for the reading part. This series adds __ioread32_copy() and uses it in two places. This patch (of 4): The frv port uses compiler builtins, __builtin_read*(), for the I/O read routines. Unfortunately, these don't accept const void pointers although the generic ASM implementations do, so generic code passing const pointers to these APIs cause compilers to emit warnings. Add wrapper functions that cast away the const to avoid the warnings. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: David Howells <dhowells@redhat.com> Cc: <zajec5@gmail.com> Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com> Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15frv: fix compiler warning from definition of __pmd()Dan Williams
Take into account that the pmd_t type is a array inside a struct, so it needs two levels of brackets to initialize. Otherwise, a usage of __pmd generates a warning: include/linux/mm.h:986:2: warning: missing braces around initializer [-Wmissing-braces] Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-13Merge tag 'libnvdimm-for-4.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "The bulk of this has appeared in -next and independently received a build success notification from the kbuild robot. The 'for-4.5/block- dax' topic branch was rebased over the weekend to drop the "block device end-of-life" rework that Al would like to see re-implemented with a notifier, and to address bug reports against the badblocks integration. There is pending feedback against "libnvdimm: Add a poison list and export badblocks" received last week. Linda identified some localized fixups that we will handle incrementally. Summary: - Media error handling: The 'badblocks' implementation that originated in md-raid is up-levelled to a generic capability of a block device. This initial implementation is limited to being consulted in the pmem block-i/o path. Later, 'badblocks' will be consulted when creating dax mappings. - Raw block device dax: For virtualization and other cases that want large contiguous mappings of persistent memory, add the capability to dax-mmap a block device directly. - Increased /dev/mem restrictions: Add an option to treat all io-memory as IORESOURCE_EXCLUSIVE, i.e. disable /dev/mem access while a driver is actively using an address range. This behavior is controlled via the new CONFIG_IO_STRICT_DEVMEM option and can be overridden by the existing "iomem=relaxed" kernel command line option. - Miscellaneous fixes include a 'pfn'-device huge page alignment fix, block device shutdown crash fix, and other small libnvdimm fixes" * tag 'libnvdimm-for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (32 commits) block: kill disk_{check|set|clear|alloc}_badblocks libnvdimm, pmem: nvdimm_read_bytes() badblocks support pmem, dax: disable dax in the presence of bad blocks pmem: fail io-requests to known bad blocks libnvdimm: convert to statically allocated badblocks libnvdimm: don't fail init for full badblocks list block, badblocks: introduce devm_init_badblocks block: clarify badblocks lifetime badblocks: rename badblocks_free to badblocks_exit libnvdimm, pmem: move definition of nvdimm_namespace_add_poison to nd.h libnvdimm: Add a poison list and export badblocks nfit_test: Enable DSMs for all test NFITs md: convert to use the generic badblocks code block: Add badblock management for gendisks badblocks: Add core badblock management code block: fix del_gendisk() vs blkdev_ioctl crash block: enable dax for raw block devices block: introduce bdev_file_inode() restrict /dev/mem to idle io memory ranges arch: consolidate CONFIG_STRICT_DEVM in lib/Kconfig.debug ...
2016-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from Davic Miller: 1) Support busy polling generically, for all NAPI drivers. From Eric Dumazet. 2) Add byte/packet counter support to nft_ct, from Floriani Westphal. 3) Add RSS/XPS support to mvneta driver, from Gregory Clement. 4) Implement IPV6_HDRINCL socket option for raw sockets, from Hannes Frederic Sowa. 5) Add support for T6 adapter to cxgb4 driver, from Hariprasad Shenai. 6) Add support for VLAN device bridging to mlxsw switch driver, from Ido Schimmel. 7) Add driver for Netronome NFP4000/NFP6000, from Jakub Kicinski. 8) Provide hwmon interface to mlxsw switch driver, from Jiri Pirko. 9) Reorganize wireless drivers into per-vendor directories just like we do for ethernet drivers. From Kalle Valo. 10) Provide a way for administrators "destroy" connected sockets via the SOCK_DESTROY socket netlink diag operation. From Lorenzo Colitti. 11) Add support to add/remove multicast routes via netlink, from Nikolay Aleksandrov. 12) Make TCP keepalive settings per-namespace, from Nikolay Borisov. 13) Add forwarding and packet duplication facilities to nf_tables, from Pablo Neira Ayuso. 14) Dead route support in MPLS, from Roopa Prabhu. 15) TSO support for thunderx chips, from Sunil Goutham. 16) Add driver for IBM's System i/p VNIC protocol, from Thomas Falcon. 17) Rationalize, consolidate, and more completely document the checksum offloading facilities in the networking stack. From Tom Herbert. 18) Support aborting an ongoing scan in mac80211/cfg80211, from Vidyullatha Kanchanapally. 19) Use per-bucket spinlock for bpf hash facility, from Tom Leiming. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1375 commits) net: bnxt: always return values from _bnxt_get_max_rings net: bpf: reject invalid shifts phonet: properly unshare skbs in phonet_rcv() dwc_eth_qos: Fix dma address for multi-fragment skbs phy: remove an unneeded condition mdio: remove an unneed condition mdio_bus: NULL dereference on allocation error net: Fix typo in netdev_intersect_features net: freescale: mac-fec: Fix build error from phy_device API change net: freescale: ucc_geth: Fix build error from phy_device API change bonding: Prevent IPv6 link local address on enslaved devices IB/mlx5: Add flow steering support net/mlx5_core: Export flow steering API net/mlx5_core: Make ipv4/ipv6 location more clear net/mlx5_core: Enable flow steering support for the IB driver net/mlx5_core: Initialize namespaces only when supported by device net/mlx5_core: Set priority attributes net/mlx5_core: Connect flow tables net/mlx5_core: Introduce modify flow table command net/mlx5_core: Managing root flow table ...
2016-01-09arch: consolidate CONFIG_STRICT_DEVM in lib/Kconfig.debugDan Williams
Let all the archs that implement devmem_is_allowed() opt-in to a common definition of CONFIG_STRICT_DEVM in lib/Kconfig.debug. Cc: Kees Cook <keescook@chromium.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [heiko: drop 'default y' for s390] Acked-by: Ingo Molnar <mingo@redhat.com> Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2016-01-04soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPFCraig Gallek
Expose socket options for setting a classic or extended BPF program for use when selecting sockets in an SO_REUSEPORT group. These options can be used on the first socket to belong to a group before bind or on any socket in the group after bind. This change includes refactoring of the existing sk_filter code to allow reuse of the existing BPF filter validation checks. Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-04locking/cmpxchg, arch: Remove tas() definitionsDavidlohr Bueso
It seems that commit 5dc12ddee93 ("Remove tas()") missed some files. Correct this and fully drop this macro, for which we should be using cmpxchg() like calls. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <linux-arch@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@re hat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave@stgolabs.net Link: http://lkml.kernel.org/r/1445975631-17047-2-git-send-email-dave@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-09kmap_atomic_to_page() has no users, remove itNicolas Pitre
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused kmap_atomic_to_page"). Let's do it across the whole tree. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-06Merge tag 'v4.3-rc4' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-15PCI: Revert "PCI: Call pci_read_bridge_bases() from core instead of arch code"Bjorn Helgaas
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead of arch code"). Reading PCI bridge windows is not arch-specific in itself, but there is PCI core code that doesn't work correctly if we read them too early. For example, Hannes found this case on an ARM Freescale i.mx6 board: pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff] pci 0000:00:00.0: PCI bridge to [bus 01-ff] pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window) pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000] pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000] pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100] The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs 0x204100 of space, and mem windows are megabyte-aligned. Bus sizing can increase a bridge window size, but never *decrease* it (see d65245c3297a ("PCI: don't shrink bridge resources")). Prior to dff22d2054b5, ARM didn't read bridge windows at all, so the "original size" was zero, and we assigned a 3MB window. After dff22d2054b5, we read the bridge windows before sizing the bus. The firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since we never decrease the size, we kept 16MB even though we only needed 3MB. But 16MB doesn't fit in the host bridge aperture, so we failed to assign space for the window and the downstream devices. I think this is a defect in the PCI core: we shouldn't rely on the firmware to assign sensible windows. Ray reported a similar problem, also on ARM, with Broadcom iProc. Issues like this are too hard to fix right now, so revert dff22d2054b5. Reported-by: Hannes <oe5hpm@gmail.com> Reported-by: Ray Jui <rjui@broadcom.com> Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
2015-09-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "The dominant change in this cycle was the continued work to isolate kernel drivers from MTRR legacies: this tree gets rid of all kernel internal driver interfaces to MTRRs (mostly by rewriting it to proper PAT interfaces), the only access left is the /proc/mtrr ABI. This work was done by Luis R Rodriguez. There's also some related PCI interface additions for which I've Cc:-ed Bjorn" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del() s390/io: Add pci_iomap_wc() and pci_iomap_wc_range() drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc() PCI: Add pci_iomap_wc() variants drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() PCI: Add pci_ioremap_wc_bar() x86/mm: Make kernel/check.c explicitly non-modular x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular x86/mm/pat: Add comments to cachemode translation tables arch/*/io.h: Add ioremap_uc() to all architectures drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc() drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC drivers/video/fbdev/atyfb: Clarify ioremap() base and length used drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default ...
2015-08-31Merge tag 'pci-v4.3-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v4.3 merge window: Enumeration: - Allocate ATS struct during enumeration (Bjorn Helgaas) - Embed ATS info directly into struct pci_dev (Bjorn Helgaas) - Reduce size of ATS structure elements (Bjorn Helgaas) - Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas) - iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas) - Move MPS configuration check to pci_configure_device() (Bjorn Helgaas) - Set MPS to match upstream bridge (Keith Busch) - ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri) - Add pci_scan_root_bus_msi() (Lorenzo Pieralisi) - ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi) Resource management: - Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi) PCI device hotplug: - pciehp: Remove unused interrupt events (Bjorn Helgaas) - pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas) - pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson) - pciehp: Simplify pcie_poll_cmd() (Yijing Wang) - Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang) - Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang) - Hold pci_slot_mutex while searching bus->slots list (Yijing Wang) Power management: - Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui) Virtualization: - Add ACS quirks for Intel I219-LM/V (Alex Williamson) - Restore ACS configuration as part of pci_restore_state() (Alexander Duyck) MSI: - Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu) - x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu) - Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu) - Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu) - ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi) - Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi) Generic host bridge driver: - Remove dependency on ARM-specific struct hw_pci (Jayachandran C) - Build setup-irq.o for arm64 (Jayachandran C) - Add arm64 support (Jayachandran C) APM X-Gene host bridge driver: - Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang) - Add support for a 64-bit prefetchable memory window (Duc Dang) - Drop owner assignment from platform_driver (Krzysztof Kozlowski) Broadcom iProc host bridge driver: - Allow BCMA bus driver to be built as module (Hauke Mehrtens) - Delete unnecessary checks before phy calls (Markus Elfring) - Add arm64 support (Ray Jui) Synopsys DesignWare host bridge driver: - Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri) TI DRA7xx host bridge driver: - Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I) - Add PM support (Kishon Vijay Abraham I) - Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I) - Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I) Xilinx AXI host bridge driver: - Check for MSI interrupt flag before handling as INTx (Russell Joyce) Miscellaneous: - Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa) - Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas) - Fix generic NCR 53c810 class code quirk (Bjorn Helgaas) - Fix TI816X class code quirk (Bjorn Helgaas) - Remove unused "pci_probe" flags (Bjorn Helgaas) - Host bridge driver code simplifications (Fabio Estevam) - Add dev_flags bit to access VPD through function 0 (Mark Rustad) - Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad) - Kill off set_irq_flags() usage (Rob Herring) - Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar) - Clean up pci_find_capability() (Wei Yang)" * tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits) PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI PCI: Set MPS to match upstream bridge PCI: Move MPS configuration check to pci_configure_device() PCI: Drop references acquired by of_parse_phandle() PCI/MSI: Remove unused pcibios_msi_controller() hook ARM/PCI: Remove msi_controller from struct pci_sys_data ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() PCI: Add pci_scan_root_bus_msi() ARM/PCI: Replace panic with WARN messages on failures PCI: generic: Add arm64 support PCI: Build setup-irq.o for arm64 PCI: generic: Remove dependency on ARM-specific struct hw_pci PCI: imx6: Simplify a trivial if-return sequence PCI: spear: Use BUG_ON() instead of condition followed by BUG() PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE() PCI: Remove pci_ats_enabled() PCI: Stop caching ATS Invalidate Queue Depth PCI: Move ATS declarations to linux/pci.h so they're all together PCI: Clean up ATS error handling PCI: Use pci_physfn() rather than looking up physfn by hand ...
2015-08-25Merge tag 'v4.2-rc8' into x86/mm, before applying new changesIngo Molnar
2015-08-04Merge branches 'pci/irq', 'pci/misc', 'pci/resource' and ↵Bjorn Helgaas
'pci/virtualization' into next * pci/irq: PCI/MSI: Free legacy IRQ when enabling MSI/MSI-X PCI: Add helpers to manage pci_dev->irq and pci_dev->irq_managed PCI, x86: Implement pcibios_alloc_irq() and pcibios_free_irq() PCI: Add pcibios_alloc_irq() and pcibios_free_irq() * pci/misc: PCI: Remove unused "pci_probe" flags PCI: Add VPD function 0 quirk for Intel Ethernet devices PCI: Add dev_flags bit to access VPD through function 0 PCI / ACPI: Fix pci_acpi_optimize_delay() comment PCI: Remove a broken link in quirks.c PCI: Remove useless redundant code PCI: Simplify pci_find_(ext_)capability() return value checks PCI: Move PCI_FIND_CAP_TTL to pci.h and use it in quirks PCI: Add pcie_downstream_port() (true for Root and Switch Downstream Ports) PCI: Fix pcie_port_device_resume() comment PCI: Shift PCI_CLASS_NOT_DEFINED consistently with other classes PCI: Revert aeb30016fec3 ("PCI: add Intel USB specific reset method") PCI: Fix TI816X class code quirk PCI: Fix generic NCR 53c810 class code quirk PCI: Use PCI_CLASS_SERIAL_USB instead of bare number PCI: Add quirk for Intersil/Techwell TW686[4589] AV capture cards PCI: Remove Intel Cherrytrail D3 delays * pci/resource: PCI: Call pci_read_bridge_bases() from core instead of arch code * pci/virtualization: PCI: Restore ACS configuration as part of pci_restore_state()
