path: root/arch/h8300/include
2009-09-22h8300: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove duplicate asm/mman.h filesArnd Bergmann
A number of architectures have identical asm/mman.h files so they can all be merged by using the new generic file. The remaining asm/mman.h files are substantially different from each other. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-09PCI: remove pcibios_scan_all_fns()Alex Chiang
This was #define'd as 0 on all platforms, so let's get rid of it. This change makes pci_scan_slot() slightly easier to read. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16kmap_types: make most arches use generic header fileRandy Dunlap
Convert most arches to use asm-generic/kmap_types.h. Move the KM_FENCE_ macro additions into asm-generic/kmap_types.h, controlled by __WITH_KM_FENCE from each arch's kmap_types.h file. Would be nice to be able to add custom KM_types per arch, but I don't yet see a nice, clean way to do that. Built on x86_64, i386, mips, sparc, alpha(tonyb), powerpc(tonyb), and 68k(tonyb). Note: avr32 should be able to remove KM_PTE2 (since it's not used) and then just use the generic kmap_types.h file. Get avr32 maintainer approval. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename termios.h, signal.h and mman.hArnd Bergmann
The existing asm-generic versions are incomplete and included by some architectures. New architectures should be able to use a generic version, so rename the existing files and change all users, which lets us add the new files. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-05-29flat: fix data sections alignmentOskar Schirmer
The flat loader uses an architecture's flat_stack_align() to align the stack but assumes word-alignment is enough for the data sections. However, on the Xtensa S6000 we have registers up to 128bit width which can be used from userspace and therefor need userspace stack and data-section alignment of at least this size. This patch drops flat_stack_align() and uses the same alignment that is required for slab caches, ARCH_SLAB_MINALIGN, or wordsize if it's not defined by the architecture. It also fixes m32r which was obviously kaput, aligning an uninitialized stack entry instead of the stack pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oskar Schirmer <os@emlix.com> Cc: David Howells <dhowells@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <cooloney@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Johannes Weiner <jw@emlix.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-17Get rid of final remnants of include/asm-$(ARCH)Linus Torvalds
This renames include/asm-h8300/timer.h into arch/h8300/include/asm: it was left over just because that file had been created in the -mm tree before the whole h8300 header subdirectory had been moved, and then got merged in the old location afterwards. (See commits e0b0f9e4ead2468f84c26332ec42b118e76af572: "h8300: update timer handler - new files" and 758db3f2118703a1e36374dae5d58bed963e7e0d: "[h8300] move include/asm-h8300 to arch/h8300/include/asm" for details). This also removes a left-over .gitignore file in include/asm-arm that became stale when the ARM header files were moved (which happened in multiple commits, just see "git log -- include/asm-arm" for details). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-26Merge branch 'header-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'header-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) x86: headers cleanup - setup.h emu101k1.h: fix duplicate include of <linux/types.h> compiler-gcc4: conditionalize #error on __KERNEL__ remove __KERNEL_STRICT_NAMES make netfilter use strict integer types make drm headers use strict integer types make MTD headers use strict integer types make most exported headers use strict integer types make exported headers use strict posix types unconditionally include asm/types.h from linux/types.h make linux/types.h as assembly safe Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h headers_check fix cleanup: linux/reiserfs_fs.h headers_check fix cleanup: linux/nubus.h headers_check fix cleanup: linux/coda_psdev.h headers_check fix: x86, setup.h headers_check fix: x86, prctl.h headers_check fix: linux/reinserfs_fs.h headers_check fix: linux/socket.h headers_check fix: linux/nubus.h ... Manually fix trivial conflicts in: include/linux/netfilter/xt_limit.h include/linux/netfilter/xt_statistic.h
2009-03-06Merge branch 'x86/core' into tracing/texteditIngo Molnar
Conflicts: arch/x86/Kconfig block/blktrace.c kernel/irq/handle.c Semantic conflict: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02tracing: make CALLER_ADDRx overwriteableUwe Kleine-Koenig
The current definition of CALLER_ADDRx isn't suitable for all platforms. E.g. for ARM __builtin_return_address(N) doesn't work for N > 0 and AFAIK for powerpc there are no frame pointers needed to have a working __builtin_return_address. This patch allows defining the CALLER_ADDRx macros in <asm/ftrace.h> and let these take precedence. Because now <asm/ftrace.h> is included unconditionally in <linux/ftrace.h> all archs that don't already had this include get an empty one for free. Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-15net: new user space API for time stamping of incoming and outgoing packetsPatrick Ohly
User space can request hardware and/or software time stamping. Reporting of the result(s) via a new control message is enabled separately for each field in the message because some of the fields may require additional computation and thus cause overhead. User space can tell the different kinds of time stamps apart and choose what suits its needs. When a TX timestamp operation is requested, the TX skb will be cloned and the clone will be time stamped (in hardware or software) and added to the socket error queue of the skb, if the skb has a socket associated with it. The actual TX timestamp will reach userspace as a RX timestamp on the cloned packet. If timestamping is requested and no timestamping is done in the device driver (potentially this may use hardware timestamping), it will be done in software after the device's start_hard_xmit routine. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01headers_check fix: h8300, swab.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/asm-h8300/swab.h:4: include of <linux/types.h> is preferred over <asm/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-06h8300: introduce asm/swab.hHarvey Harrison
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-03h8300: define __flsRusty Russell
Like fls, but can't be handed 0 and returns the bit number. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-10-20container freezer: add TIF_FREEZE flag to all architecturesMatt Helsley
This patch series introduces a cgroup subsystem that utilizes the swsusp freezer to freeze a group of tasks. It's immediately useful for batch job management scripts. It should also be useful in the future for implementing container checkpoint/restart. The freezer subsystem in the container filesystem defines a cgroup file named freezer.state. Reading freezer.state will return the current state of the cgroup. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This patch: The first step in making the refrigerator() available to all architectures, even for those without power management. The purpose of such a change is to be able to use the refrigerator() in a new control group subsystem which will implement a control group freezer. [akpm@linux-foundation.org: fix sparc] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Merge branch 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITY
2008-10-16asm-h8300/md.h: remove CVS keywordAdrian Bunk
Remove a CVS keyword that wasn't updated for a long time from a comment. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: GENERIC_BUG supportYoshinori Sato
CONFIG_GENERIC_BUG support. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - misc updateYoshinori Sato
- Update selection - Update common timer handler - Add support functions Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-13[h8300] move include/asm-h8300 to arch/h8300/include/asmLinus Torvalds
Done as a script (well, a single "git mv" actually) on request from Yoshinori Sato as a way to avoid a huge diff. Requested-by: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
