Impact: build fix
Ingo Molnar wrote:
> tip/arch/blackfin/kernel/irqchip.c: In function 'show_interrupts':
> tip/arch/blackfin/kernel/irqchip.c:85: error: 'struct kernel_stat' has no member named 'irqs'
> make[2]: *** [arch/blackfin/kernel/irqchip.o] Error 1
> make[2]: *** Waiting for unfinished jobs....
So could move kstat_irqs array to irq_desc struct.
(s390, m68k, sparc) are not touched yet, because they don't support genirq
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
CONFIG_GENERIC_BUG support.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
- Update selection
- Update common timer handler
- Add support functions
New timer handler files.
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit
boundary. For example:
u64 val = PAGE_ALIGN(size);
always returns a value < 4GB even if size is greater than 4GB.
The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for
example):
#define PAGE_SHIFT 12
#define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT)
#define PAGE_MASK (~(PAGE_SIZE-1))
#define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK)
The "~" is performed on a 32-bit value, so everything in "and" with
PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary.
Using the ALIGN() macro seems to be the right way, because it uses
typeof(addr) for the mask.
Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in
include/linux/mm.h.
See also lkml discussion: http://lkml.org/lkml/2008/6/11/237
[akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c]
[akpm@linux-foundation.org: fix v850]
[akpm@linux-foundation.org: fix powerpc]
[akpm@linux-foundation.org: fix arm]
[akpm@linux-foundation.org: fix mips]
[akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c]
[akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c]
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: <linux-arch@vger.kernel.org>
This replaces the duplicated arch-specific versions of "sys_pipe()" with
one unified implementation. This removes almost 250 lines of duplicated
code.
It's marked __weak, so that *if* an architecture wants to override the
default implementation it can do so by simply having its own replacement
version, since many architectures use alternate calling conventions for
the 'pipe()' system call for legacy reasons (ie traditional UNIX
implementations often return the two file descriptors in registers)
I still haven't changed the cris version even though Linus says the BKL
isn't needed. The arch maintainer can easily do it if there are really
no obstacles.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Semaphores are no longer performance-critical, so a generic C
implementation is better for maintainability, debuggability and
extensibility. Thanks to Peter Zijlstra for fixing the lockdep
warning. Thanks to Harvey Harrison for pointing out that the
unlikely() was unnecessary.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
- add missing file and declare.
- remove unused file and macros.
- some cleanup.
typo fix.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-By: David Howells <dhowells@redhat.com>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Add a proper prototype for show_interrupts() in include/linux/interrupt.h
This patch consolidate all definitions of .init.text, .init.data
and .exit.text, .exit.data section definitions in
the generic vmlinux.lds.h.
This is a preparational patch - alone it does not buy
us much good.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Spelling fixes in arch/h8300/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
All asm/ipc.h files do only #include <asm-generic/ipc.h>.
This patch therefore removes all include/asm-*/ipc.h files and moves the
contents of include/asm-generic/ipc.h to include/linux/ipc.h.
Build error fix.
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata()
function.
AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless
return EPERM.
arch/h8300/kernel/ints.c is unused.
- warning fix.
- call trace area check fix.
- There is no meaning, ' & ' it deletes
With this consolidation we can now modify the .data
section definition in one spot for all archs.
Move definition of .text section to asm-generic.
h8300 systemcall entry table update.
This finally renames the thread_info field in task structure to stack, so that
the assumptions about this field are gone and archs have more freedom about
placing the thread_info structure.
Nonbroken archs which have a proper thread pointer can do the access to both
current thread and task structure via a single pointer.
It'll allow for a few more cleanups of the fork code, from which e.g. ia64
could benefit.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
[akpm@linux-foundation.org: build fix]
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Andi Kleen <ak@muc.de>
Cc: Chris Zankel <chris@zankel.net>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
h8300 using generic irq handler patch.
Currently h8/300 does not implement sub-jiffy timekeeping, so there is no
benefit to having arch specific timekeeping code.
This patch simply removes those functions and enables the generic
timekeeping code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp>
powerpc gets:
init/main.c: In function `do_basic_setup':
init/main.c:714: warning: implicit declaration of function `init_irq_proc'
but we cannot include linux/irq.h in generic code.
Fix it by moving the declaration into linux/interrupt.h instead.
And make sure all code that defines init_irq_proc() is including
linux/interrupt.h.
And nuke an ifdef-in-C
1. Rename saved_command_line into boot_command_line.
2. Set command_line as __initdata.
Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com>
* Split the implementation-agnostic stuff in separate files.
* Make sure that targets using non-default request_irq() pull
kernel/irq/devres.o
* Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive;
allow architectures to turn them off (we needed these symbols anyway for
dependencies of quite a few drivers).
* protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT.
Use attribute(weak).
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs
when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes
on most platfoms (some reserve PAGE_SIZE for initramfs).
Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits)
[PATCH] x86-64: Export smp_call_function_single
[PATCH] i386: Clean up smp_tune_scheduling()
[PATCH] unwinder: move .eh_frame to RODATA
[PATCH] unwinder: fully support linker generated .eh_frame_hdr section
[PATCH] x86-64: don't use set_irq_regs()
[PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq
[PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM
[PATCH] i386: replace kmalloc+memset with kzalloc
[PATCH] x86-64: remove remaining pc98 code
[PATCH] x86-64: remove unused variable
[PATCH] x86-64: Fix constraints in atomic_add_return()
[PATCH] x86-64: fix asm constraints in i386 atomic_add_return
[PATCH] x86-64: Correct documentation for bzImage protocol v2.05
[PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code
[PATCH] x86-64: Fix numaq build error
[PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header
[PATCH] unwinder: Add debugging output to the Dwarf2 unwinder
[PATCH] x86-64: Clarify error message in GART code
[PATCH] x86-64: Fix interrupt race in idle callback (3rd try)
[PATCH] x86-64: Remove unwind stack pointer alignment forcing again
Fixed conflict in include/linux/uaccess.h manually
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Print the addresses of non-absolute symbols relative to _text
so that ld will generate relocations. Allowing a relocatable
kernel to relocate them. We can't actually use the symbol names
because kallsyms includes static symbols that are not exported
from their object files.
Add the _text symbol definitions to the architectures which don't
define it otherwise linker will fail.
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
Signed-off-by: Andi Kleen <ak@suse.de>
* sanitize prototypes and annotate
* collapse csum_partial_copy
NB: csum_partial() is almost certainly still buggy.
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table,
teach all the architectures to use it.
This is a prerequisite for a patch which performs initcall synchronisation for
multithreaded-probing.
[ Added AVR32 as well ]
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
kbuild explicitly includes this at build time.
Signed-off-by: Dave Jones <davej@redhat.com>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
This adds the new kernel_execve function on all architectures that were using
_syscall3() to implement execve.
The implementation uses code from the _syscall3 macros provided in the
unistd.h header file. I don't have cross-compilers for any of these
architectures, so the patch is untested with the exception of i386.
Most architectures can probably implement this in a nicer way in assembly or
by combining it with the sys_execve implementation itself, but this should do
it for now.
[bunk@stusta.de: m68knommu build fix]
[markh@osdl.org: build fix]
[bero@arklinux.org: build fix]
[ralf@linux-mips.org: mips fix]
[schwidefsky@de.ibm.com: s390 fix]
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org>
Signed-off-by: Mark Haverkamp <markh@osdl.org>
Move the init_nsproxy definition out of arch/ into kernel/nsproxy.c. This
avoids all arches having to be updated. Compiles and boots on s390.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
This patch adds a nsproxy structure to the task struct. Later patches will
move the fs namespace pointer into this structure, and introduce a new utsname
namespace into the nsproxy.
The vserver and openvz functionality, then, would be implemented in large part
by virtualizing/isolating more and more resources into namespaces, each
contained in the nsproxy.
[akpm@osdl.org: build fix]
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390
timer interrupt handler with this change.
Currently update_times() calculates ticks by "jiffies - wall_jiffies", but
callers of do_timer() should know how many ticks to update. Passing ticks
get rid of this redundant calculation. Also there are another redundancy
pointed out by Martin Schwidefsky.
This cleanup make a barrier added by
5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes
it.
As a bonus, this cleanup make wall_jiffies can be removed easily, since now
wall_jiffies is always synced with jiffies. (This patch does not really
remove wall_jiffies. It would be another cleanup patch)
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: john stultz <johnstul@us.ibm.com>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
