path: root/arch/h8300/kernel
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24h8300: Use generic show_interrupts()Thomas Gleixner
2011-03-24h8300: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31h8300: Switch do_timer() to xtime_update()Torben Hohn
xtime_update() takes the xtime_lock itself. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127145951.23248.92727.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21h8300: Use generic irq KconfigThomas Gleixner
Switch to the generic irq Kconfig. h8300 has all irq chips converted to the new functions, so select the GENERIC_HARDIRQS_NO_DEPRECATED switch as well. Fixup the resulting fallout in show_interrupts(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21h8300: Convert interrupt handling to flow handlerThomas Gleixner
__do_IRQ is deprecated so h8300 needs to be converted to proper flow handling. The irq chip is simple and does not required any mask/ack/eoi functions, so we can use handle_simple_irq. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21h8300: Convert to new irq_chip functionsThomas Gleixner
No functional change, just straight forward conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup arch_ptrace() on h8300Namhyung Kim
Use new 'regno', 'datap' variables in order to remove duplicated expressions and unnecessary castings. Alse remove checking @addr less than 0 because addr is now unsigned. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: Fix missing consts in kernel_execve()David Howells
Fix missing consts in h8300's kernel_execve(): arch/h8300/kernel/sys_h8300.c: In function 'kernel_execve': arch/h8300/kernel/sys_h8300.c:59: warning: initialization from incompatible pointer type arch/h8300/kernel/sys_h8300.c:60: warning: initialization from incompatible pointer type Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: Fix die()David Howells
Fix h8300's die() to take care of a number of problems: CC arch/h8300/kernel/traps.o In file included from arch/h8300/include/asm/bitops.h:10, from include/linux/bitops.h:22, from include/linux/kernel.h:17, from include/linux/sched.h:54, from arch/h8300/kernel/traps.c:18: arch/h8300/include/asm/system.h:136: warning: 'struct pt_regs' declared inside parameter list arch/h8300/include/asm/system.h:136: warning: its scope is only this definition or declaration, which is probably not what you want arch/h8300/kernel/traps.c:100: error: conflicting types for 'die' arch/h8300/include/asm/system.h:136: error: previous declaration of 'die' was here make[2]: *** [arch/h8300/kernel/traps.o] Error 1 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13h8300: Convert h8300 to use read/update_persistent_clockJohn Stultz
This patch converts the h8300 architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. I have not built or tested this patch, so help from arch maintainers would be appreciated. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1267675049-12337-6-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-12h8300: use generic ptrace_resume codeChristoph Hellwig
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT, PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining arch_has_single_step in <asm/ptrace.h> and implementing the user_enable_single_step and user_disable_single_step functions, which also causes the breakpoint information to be cleared on fork, which could be considered a bug fix. Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which it previously wasn't which is consistent with all architectures using the modern ptrace code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ptrace: use ptrace_request() in the remaining architecturesChristoph Hellwig
Use ptrace_request() in the three remaining architectures that didn't use it (m68knommu, h8300, microblaze). This means: - ptrace_request now handles PTRACE_{PEEK,POKE}{TEXT,DATA} and PTRACE_DETATCH calls that were previously called directly, or in case of h8300 even open coded. - adds new support for PTRACE_SETOPTIONS/PTRACE_GETEVENTMSG/ PTRACE_GETSIGINFO/PTRACE_SETSIGINFO Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16Merge branch 'module' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: fix segfault with short symbol names module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y Kbuild: clear marker out of modpost module: make MODULE_SYMBOL_PREFIX into a CONFIG option ARM: unexport symbols used to implement floating point emulation ARM: use unified discard definition in linker script x86: don't export inline function sparc64: don't export static inline pci_ functions
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-14h83000: Remove BKL from sys_execveJohn Kacur
This looks like a copy-and-paste job for code that no-longer needs the BKL Just remove it. Signed-off-by: John Kacur <jkacur@redhat.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> LKML-Reference: <alpine.LFD.2.00.0910130010000.3658@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-09-24h8300: Cleanup linker script using new linker script macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22h8300: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove references to non-existent include/linux/config.hMarkus Heidelberg
Ignore drivers/staging/ since it is very likely that new drivers introduce it again. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-09KEYS: Add missing linux/tracehook.h #inclusionsDavid Howells
Add #inclusions of linux/tracehook.h to those arch files that had the tracehook call for TIF_NOTIFY_RESUME added when support for that flag was added to that arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-18ptrace: remove PT_DTRACE from arch/h8300Oleg Nesterov
h8300 defines PT_DTRACE for asm but never uses it. DEFINE(PT_PTRACED, PT_PTRACED) seems to be unused too. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
