[ Upstream commit fc2b47b55f17fd996f7a01975ce1c33c2f2513f6 ]
It believe it is a bad idea to hardcode a specific compiler prefix
that may or may not be installed on a user's system. It is annoying
when testing features that should not require compilers at all.
For example, mrproper, headers_install, etc. should work without
any compiler.
They look like follows on my machine.
$ make ARCH=h8300 mrproper
./scripts/gcc-version.sh: line 26: h8300-unknown-linux-gcc: command not found
./scripts/gcc-version.sh: line 27: h8300-unknown-linux-gcc: command not found
make: h8300-unknown-linux-gcc: Command not found
[ a bunch of the same error messages continue ]
$ make ARCH=h8300 headers_install
HOSTCC scripts/basic/fixdep
WRAP arch/h8300/include/generated/uapi/asm/kvm_para.h
[ snip ]
The solution is to delete this line, or to use cc-cross-prefix like
some architectures do. I chose the latter as a moderate fixup.
I added an alternative 'h8300-linux-' because it is available at:
https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/8.1.0/
commit 502585c7555083d4a949c08350306b9ec196779e upstream.
regs_set() and regs_get() are vulnerable to an off-by-1 buffer overrun
if CONFIG_CPU_H8S is set, since this adds an extra entry to
register_offset[] but not to user_regs_struct.
So, iterate over user_regs_struct based on its actual size, not based on
the length of register_offset[].
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
commit 21753583056d48a5fad964d6f272e28168426845 upstream.
Back in commit f56141e3e2d9 ("all arches, signal: move restart_block to
struct task_struct"), all architectures and core code were changed to
use task_struct::restart_block. However, when h8300 support was
subsequently restored in v4.2, it was not updated to account for this,
and maintains thread_info::restart_block, which is not kept in sync.
This patch drops the redundant restart_block from thread_info, and moves
h8300 to the common one in task_struct, ensuring that syscall restarting
always works as expected.
Fixes: f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct")
Link: http://lkml.kernel.org/r/1476714934-11635-1-git-send-email-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: uclinux-h8-devel@lists.sourceforge.jp
Pull h8300 updates from Yoshinori Sato:
"Some bug fixes"
* tag 'for-4.4' of git://git.osdn.jp/gitroot/uclinux-h8/linux:
h8300: enable CLKSRC_OF
h8300: Don't set CROSS_COMPILE unconditionally
asm-generic: {get,put}_user ptr argument evaluate only 1 time
h8300: bit io fix
h8300: zImage fix
h8300: register address fix
h8300: Fix alignment for .data
h8300: unaligned divcr register support.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
The h8300 architecture Makefile sets the CROSS_COMPILE variable to
"h8300-unknown-linux-" unconditionally but doing that prevents the
variable to be used if a toolchain with a different binary name is
installed in the machine.
So only set CROSS_COMPILE to that default if the variable has not
been set by the user before.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
"WU" constraint required memory address.
- stack fix
- configure base address
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
"A fairly large (by DT standards) pull request this time with the
majority being some overdue moving DT binding docs around to
consolidate similar bindings.
- DT binding doc consolidation moving similar bindings to common
locations. The majority of these are display related which were
scattered in video/, fb/, drm/, gpu/, and panel/ directories.
- Add new config option, CONFIG_OF_ALL_DTBS, to enable building all
dtbs in the tree for most arches with dts files (except powerpc for
now).
- OF_IRQ=n fixes for user enabled CONFIG_OF.
- of_node_put ref counting fixes from Julia Lawall.
- Common DT binding for wakeup-source and deprecation of all similar
bindings.
- DT binding for PXA LCD controller.
- Allow ignoring failed PCI resource translations in order to ignore
64-bit addresses on non-LPAE 32-bit kernels.
- Support setting the NUMA node from DT instead of only from parent
device.
- Couple of earlycon DT parsing fixes for address and options"
* tag 'devicetree-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits)
MAINTAINERS: update DT binding doc locations
devicetree: add Sigma Designs vendor prefix
of: simplify arch_find_n_match_cpu_physical_id() function
Documentation: arm: Fixed typo in socfpga fpga mgr example
Documentation: devicetree: fix reference to legacy wakeup properties
Documentation: devicetree: standardize/consolidate on "wakeup-source" property
drivers: of: removing assignment of 0 to static variable
xtensa: enable building of all dtbs
mips: enable building of all dtbs
metag: enable building of all dtbs
metag: use common make variables for dtb builds
h8300: enable building of all dtbs
arm64: enable building of all dtbs
arm: enable building of all dtbs
arc: enable building of all dtbs
arc: use common make variables for dtb builds
of: add config option to enable building of all dtbs
of/fdt: fix error checking for earlycon address
of/overlay: add missing of_node_put
of/platform: add missing of_node_put
Enable building all dtb files when CONFIG_OF_ALL_DTBS is enabled. The dtbs
are not really dependent on a platform being enabled or any other kernel
config, so for testing coverage it is convenient to build all of the dtbs.
This builds all dts files in the tree, not just targets listed.
Signed-off-by: Rob Herring <robh@kernel.org>
changes
arch/tile added word-at-a-time.h after the patch that added generic-y
entries; the generic-y entry is now stale.
arch/h8300 is newer than the generic-y patch for word-at-a-time.h,
and needs a generic-y entry.
arch/powerpc seems to have gotten a generic-y entry by mistake in
the first patch; this change removes it.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
This patch makes sure that atomic_{read,set}() are at least
{READ,WRITE}_ONCE().
We already had the 'requirement' that atomic_read() should use
ACCESS_ONCE(), and most archs had this, but a few were lacking.
All are now converted to use READ_ONCE().
And, by a symmetry and general paranoia argument, upgrade atomic_set()
to use WRITE_ONCE().
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: james.hogan@imgtec.com
Cc: oleg@redhat.com
Cc: will.deacon@arm.com
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Most architectures just call into ->dma_supported, but some also return 1
if the method is not present, or 0 if no dma ops are present (although
that should never happeb). Consolidate this more broad version into
common code.
Also fix h8300 which inorrectly always returned 0, which would have been
a problem if it's dma_set_mask implementation wasn't a similarly buggy
noop.
As a few architectures have much more elaborate implementations, we
still allow for arch overrides.
Currently there are three valid implementations of dma_mapping_error:
(1) call ->mapping_error
(2) check for a hardcoded error code
(3) always return 0
This patch provides a common implementation that calls ->mapping_error
if present, then checks for DMA_ERROR_CODE if defined or otherwise
returns 0.
Most architectures do not support non-coherent allocations and either
define dma_{alloc,free}_noncoherent to their coherent versions or stub
them out.
Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips
implements them directly.
This patch moves the Openrisc version to common code, and handles the
DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance.
Note that actual non-coherent allocations require a dma_cache_sync
implementation, so if non-coherent allocations didn't work on
an architecture before this patch they still won't work after it.
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel
gunzip error.
| early console in decompress_kernel
| decompress_kernel:
| input: [0x807f2143b4-0x807ff61aee]
| output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len
| boot via startup_64
| KASLR using RDTSC...
| new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size
| decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee]
| Decompressing Linux... gz...
| uncompression error
| -- System halted
the new buffer is at 0x46fe000000ULL, decompressor_gzip is using
0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap
that len to 0x01ffffff and decompress fails later.
We could hit this problem with crashkernel booting that uses kexec loading
kernel above 4GiB.
We have decompress_* support:
1. inbuf[]/outbuf[] for kernel preboot.
2. inbuf[]/flush() for initramfs
3. fill()/flush() for initrd.
This bug only affect kernel preboot path that use outbuf[].
Add __decompress and take real out_buf_len for gunzip instead of guessing
wrong buf size.
Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length)
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: <stable@vger.kernel.org>
Move the now generic definitions of atomic_{set,clear}_mask() into
linux/atomic.h to avoid endless and pointless repetition.
Also, provide an atomic_andnot() wrapper for those few archs that can
implement that.
Implement atomic logic ops -- atomic_{or,xor,and}.
These will replace the atomic_{set,clear}_mask functions that are
available on some archs.
Also rework the atomic implementation in terms of CPP macros to avoid
the typical repetition -- I seem to have missed this arch the last
time around when I did that.
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
- h8300h_sim: GDB H8/300H simulator
- h8s_sim: GDB H8S simulator
- edosk2674: Renesas EDOSK2674R Evalution board
h8300h-sim_defconfig: GDB simulator H8/300H mode.
h8s-sim_defconfig: GDB simulator H8S mode.
edosk2674_defconfig: Renesas EDOSK2674R.
h8300's Makefile, Kconfig and memory layout.
H8/300 has been dead for several years, and the kernel for it
has not compiled for ages. Drop support for it.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
Rename LL_SO to BUSY_POLL_SO
Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll}
Fix up users of these variables.
Fix documentation for sysctl.
a patch for the socket.7 man page will follow separately,
because of limitations of my mail setup.
Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com>
Pull networking updates from David Miller:
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Prepare for removing num_physpages and simplify mem_init().
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Generate mandatory global variables __bss_start/__bss_stop in
file vmlinux.lds.
Also remove one unused declaration of _text.
Cc: Jiang Liu <jiang.liu@huawei.com>
Concentrate code to modify totalram_pages into the mm core, so the arch
memory initialized code doesn't need to take care of it. With these
changes applied, only following functions from mm core modify global
variable totalram_pages: free_bootmem_late(), free_all_bootmem(),
free_all_bootmem_node(), adjust_managed_page_count().
With this patch applied, it will be much more easier for us to keep
totalram_pages and zone->managed_pages in consistence.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Address more review comments from last round of code review.
1) Enhance free_reserved_area() to support poisoning freed memory with
pattern '0'. This could be used to get rid of poison_init_mem()
on ARM64.
2) A previous patch has disabled memory poison for initmem on s390
by mistake, so restore to the original behavior.
3) Remove redundant PAGE_ALIGN() when calling free_reserved_area().
