path: root/arch/h8300
2019-04-05h8300: use cc-cross-prefix instead of hardcoding h8300-unknown-linux-Masahiro Yamada
[ Upstream commit fc2b47b55f17fd996f7a01975ce1c33c2f2513f6 ] It believe it is a bad idea to hardcode a specific compiler prefix that may or may not be installed on a user's system. It is annoying when testing features that should not require compilers at all. For example, mrproper, headers_install, etc. should work without any compiler. They look like follows on my machine. $ make ARCH=h8300 mrproper ./scripts/gcc-version.sh: line 26: h8300-unknown-linux-gcc: command not found ./scripts/gcc-version.sh: line 27: h8300-unknown-linux-gcc: command not found make: h8300-unknown-linux-gcc: Command not found make: h8300-unknown-linux-gcc: Command not found [ a bunch of the same error messages continue ] $ make ARCH=h8300 headers_install ./scripts/gcc-version.sh: line 26: h8300-unknown-linux-gcc: command not found ./scripts/gcc-version.sh: line 27: h8300-unknown-linux-gcc: command not found make: h8300-unknown-linux-gcc: Command not found HOSTCC scripts/basic/fixdep make: h8300-unknown-linux-gcc: Command not found WRAP arch/h8300/include/generated/uapi/asm/kvm_para.h [ snip ] The solution is to delete this line, or to use cc-cross-prefix like some architectures do. I chose the latter as a moderate fixup. I added an alternative 'h8300-linux-' because it is available at: https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/8.1.0/ Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-03-28h8300: remove extraneous __BIG_ENDIAN definitionArnd Bergmann
commit 1705f7c534163594f8b05e060cb49fbea86ca70b upstream. A bugfix I did earlier caused a build regression on h8300, which defines the __BIG_ENDIAN macro in a slightly different way than the generic code: arch/h8300/include/asm/byteorder.h:5:0: warning: "__BIG_ENDIAN" redefined We don't need to define it here, as the same macro is already provided by the linux/byteorder/big_endian.h, and that version does not conflict. While this is a v4.16 regression, my earlier patch also got backported to the 4.14 and 4.15 stable kernels, so we need the fixup there as well. Link: http://lkml.kernel.org/r/20180313120752.2645129-1-arnd@arndb.de Fixes: 101110f6271c ("Kbuild: always define endianess in kconfig.h") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02License cleanup: add SPDX license identifier to uapi header files with no ↵Greg Kroah-Hartman
license Many user space API headers are missing licensing information, which makes it hard for compliance tools to determine the correct license. By default are files without license information under the default license of the kernel, which is GPLV2. Marking them GPLV2 would exclude them from being included in non GPLV2 code, which is obviously not intended. The user space API headers fall under the syscall exception which is in the kernels COPYING file: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". otherwise syscall usage would not be possible. Update the files which contain no license information with an SPDX license identifier. The chosen identifier is 'GPL-2.0 WITH Linux-syscall-note' which is the officially assigned identifier for the Linux syscall exception. SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-08arch: define CPU_BIG_ENDIAN for all fixed big endian archsBabu Moger
Patch series "Define CPU_BIG_ENDIAN or warn for inconsistencies", v3. While working on enabling queued rwlock on SPARC, found this following code in include/asm-generic/qrwlock.h which uses CONFIG_CPU_BIG_ENDIAN to clear a byte. static inline u8 *__qrwlock_write_byte(struct qrwlock *lock) { return (u8 *)lock + 3 * IS_BUILTIN(CONFIG_CPU_BIG_ENDIAN); } Problem is many of the fixed big endian architectures don't define CPU_BIG_ENDIAN and clears the wrong byte. Define CPU_BIG_ENDIAN for all the fixed big endian architecture to fix it. Also found few more references of this config parameter in drivers/of/base.c drivers/of/fdt.c drivers/tty/serial/earlycon.c drivers/tty/serial/serial_core.c Be aware that this may cause regressions if someone has worked-around problems in the above code already. Remove the work-around. Here is our original discussion https://lkml.org/lkml/2017/5/24/620 Link: http://lkml.kernel.org/r/1499358861-179979-2-git-send-email-babu.moger@oracle.com Signed-off-by: Babu Moger <babu.moger@oracle.com> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Stafford Horne <shorne@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Jonas Bonn <jonas@southpole.se> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Michal Simek <monstr@monstr.eu> Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-10h8300: Mark _stext and _etext as char-arrays, not single char variablesMasami Hiramatsu
Mark _stext and _etext as character arrays instead of single character variables, like include/asm-generic/sections.h does. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Chris Zankel <chris@zankel.net> Cc: David S . Miller <davem@davemloft.net> Cc: Francis Deslauriers <francis.deslauriers@efficios.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: linux-arch@vger.kernel.org Cc: linux-cris-kernel@axis.com Cc: mathieu.desnoyers@efficios.com Link: http://lkml.kernel.org/r/150172769415.27216.12021110228384155707.stgit@devbox Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-16h8300: Add missing closing parenthesis in flat_get_addr_from_rp()Geert Uytterhoeven
In file included from include/linux/flat.h:13:0, from fs/binfmt_flat.c:36: arch/h8300/include/asm/flat.h: In function 'flat_get_addr_from_rp': arch/h8300/include/asm/flat.h:28:3: error: expected ')' before 'val' val &= 0x00ffffff; ^ arch/h8300/include/asm/flat.h:31:1: error: expected expression before '}' token } ^ In file included from include/linux/flat.h:13:0, from fs/binfmt_flat.c:36: arch/h8300/include/asm/flat.h:26:6: warning: unused variable 'val' [-Wunused-variable] u32 val = get_unaligned((__force u32 *)rp); ^ In file included from include/linux/flat.h:13:0, from fs/binfmt_flat.c:36: arch/h8300/include/asm/flat.h:31:1: warning: no return statement in function returning non-void [-Wreturn-type] } ^ Reported-by: kbuild test robot <fengguang.wu@intel.com> Fixes: 468138d78510688f ("binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-15Merge branch 'work.uaccess-unaligned' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uacess-unaligned removal from Al Viro: "That stuff had just one user, and an exotic one, at that - binfmt_flat on arm and m68k" * 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: kill {__,}{get,put}_user_unaligned() binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
2017-07-10h8300: move generic-y of exported headers to uapi/asm/KbuildMasahiro Yamada
Since commit fcc8487d477a ("uapi: export all headers under uapi directories"), all (and only) headers under uapi directories are exported, but asm-generic wrappers are still exceptions. To complete de-coupling the uapi from kernel headers, move generic-y of exported headers to uapi/asm/Kbuild. With this change, "make headers_install" will just need to parse uapi/asm/Kbuild to build up exported headers. Also, move "generic-y += kprobes.h" and "generic-y += trace_clock.h" in order to keep the entries sorted. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-03Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather large update for timers/timekeeping: - compat syscall consolidation (Al Viro) - Posix timer consolidation (Christoph Helwig / Thomas Gleixner) - Cleanup of the device tree based initialization for clockevents and clocksources (Daniel Lezcano) - Consolidation of the FTTMR010 clocksource/event driver (Linus Walleij) - The usual set of small fixes and updates all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (93 commits) timers: Make the cpu base lock raw clocksource/drivers/mips-gic-timer: Fix an error code in 'gic_clocksource_of_init()' clocksource/drivers/fsl_ftm_timer: Unmap region obtained by of_iomap clocksource/drivers/tcb_clksrc: Make IO endian agnostic clocksource/drivers/sun4i: Switch to the timer-of common init clocksource/drivers/timer-of: Fix invalid iomap check Revert "ktime: Simplify ktime_compare implementation" clocksource/drivers: Fix uninitialized variable use in timer_of_init kselftests: timers: Add test for frequency step kselftests: timers: Fix inconsistency-check to not ignore first timestamp time: Add warning about imminent deprecation of CONFIG_GENERIC_TIME_VSYSCALL_OLD time: Clean up CLOCK_MONOTONIC_RAW time handling posix-cpu-timers: Make timespec to nsec conversion safe itimer: Make timeval to nsec conversion range limited timers: Fix parameter description of try_to_del_timer_sync() ktime: Simplify ktime_compare implementation clocksource/drivers/fttmr010: Factor out clock read code clocksource/drivers/fttmr010: Implement delay timer clocksource/drivers: Add timer-of common init routine clocksource/drivers/tcb_clksrc: Save timer context on suspend/resume ...
2017-07-03binfmt_flat: flat_{get,put}_addr_from_rp() should be able to failAl Viro
on MMU targets EFAULT is possible here. Make both return 0 or error, passing what used to be the return value of flat_get_addr_from_rp() by reference. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-28arch: remove unused macro/function thread_saved_pc()Tobias Klauser
The only user of thread_saved_pc() in non-arch-specific code was removed in commit 8243d5597793 ("sched/core: Remove pointless printout in sched_show_task()"). Remove the implementations as well. Some architectures use thread_saved_pc() in their arch-specific code. Leave their thread_saved_pc() intact. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-06-14clocksource/drivers: Rename CLKSRC_OF to TIMER_OFDaniel Lezcano
The config option name is now renamed to 'TIMER_OF' for consistency with the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2017-06-14clocksource/drivers: Rename clocksource_probe to timer_probeDaniel Lezcano
The function name is now renamed to 'timer_probe' for consistency with the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2017-06-04signal: Remove non-uapi <asm/siginfo.h>Christoph Hellwig
By moving the kernel side __SI_* defintions right next to the userspace ones we can kill the non-uapi versions of <asm/siginfo.h> include include/asm-generic/siginfo.h and untangle the unholy mess of includes. [ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-ia64@vger.kernel.org Cc: Arnd Bergmann <arnd@arndb.de> Cc: sparclinux@vger.kernel.org Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
2017-05-11uapi: export all headers under uapi directoriesNicolas Dichtel
Regularly, when a new header is created in include/uapi/, the developer forgets to add it in the corresponding Kbuild file. This error is usually detected after the release is out. In fact, all headers under uapi directories should be exported, thus it's useless to have an exhaustive list. After this patch, the following files, which were not exported, are now exported (with make headers_install_all): asm-arc/kvm_para.h asm-arc/ucontext.h asm-blackfin/shmparam.h asm-blackfin/ucontext.h asm-c6x/shmparam.h asm-c6x/ucontext.h asm-cris/kvm_para.h asm-h8300/shmparam.h asm-h8300/ucontext.h asm-hexagon/shmparam.h asm-m32r/kvm_para.h asm-m68k/kvm_para.h asm-m68k/shmparam.h asm-metag/kvm_para.h asm-metag/shmparam.h asm-metag/ucontext.h asm-mips/hwcap.h asm-mips/reg.h asm-mips/ucontext.h asm-nios2/kvm_para.h asm-nios2/ucontext.h asm-openrisc/shmparam.h asm-parisc/kvm_para.h asm-powerpc/perf_regs.h asm-sh/kvm_para.h asm-sh/ucontext.h asm-tile/shmparam.h asm-unicore32/shmparam.h asm-unicore32/ucontext.h asm-x86/hwcap2.h asm-xtensa/kvm_para.h drm/armada_drm.h drm/etnaviv_drm.h drm/vgem_drm.h linux/aspeed-lpc-ctrl.h linux/auto_dev-ioctl.h linux/bcache.h linux/btrfs_tree.h linux/can/vxcan.h linux/cifs/cifs_mount.h linux/coresight-stm.h linux/cryptouser.h linux/fsmap.h linux/genwqe/genwqe_card.h linux/hash_info.h linux/kcm.h linux/kcov.h linux/kfd_ioctl.h linux/lightnvm.h linux/module.h linux/nbd-netlink.h linux/nilfs2_api.h linux/nilfs2_ondisk.h linux/nsfs.h linux/pr.h linux/qrtr.h linux/rpmsg.h linux/sched/types.h linux/sed-opal.h linux/smc.h linux/smc_diag.h linux/stm.h linux/switchtec_ioctl.h linux/vfio_ccw.h linux/wil6210_uapi.h rdma/bnxt_re-abi.h Note that I have removed from this list the files which are generated in every exported directories (like .install or .install.cmd). Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all subdirs with a pure makefile command. For the record, note that exported files for asm directories are a mix of files listed by: - include/uapi/asm-generic/Kbuild.asm; - arch/<arch>/include/uapi/asm/Kbuild; - arch/<arch>/include/asm/Kbuild. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Acked-by: Mark Salter <msalter@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-11h8300: put bitsperlong.h in uapiNicolas Dichtel
This header file is exported, thus move it to uapi. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-01Merge branch 'work.uaccess' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uaccess unification updates from Al Viro: "This is the uaccess unification pile. It's _not_ the end of uaccess work, but the next batch of that will go into the next cycle. This one mostly takes copy_from_user() and friends out of arch/* and gets the zero-padding behaviour in sync for all architectures. Dealing with the nocache/writethrough mess is for the next cycle; fortunately, that's x86-only. Same for cleanups in iov_iter.c (I am sold on access_ok() in there, BTW; just not in this pile), same for reducing __copy_... callsites, strn*... stuff, etc. - there will be a pile about as large as this one in the next merge window. This one sat in -next for weeks. -3KLoC" * 'work.uaccess' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (96 commits) HAVE_ARCH_HARDENED_USERCOPY is unconditional now CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional now m32r: switch to RAW_COPY_USER hexagon: switch to RAW_COPY_USER microblaze: switch to RAW_COPY_USER get rid of padding, switch to RAW_COPY_USER ia64: get rid of copy_in_user() ia64: sanitize __access_ok() ia64: get rid of 'segment' argument of __do_{get,put}_user() ia64: get rid of 'segment' argument of __{get,put}_user_check() ia64: add extable.h powerpc: get rid of zeroing, switch to RAW_COPY_USER esas2r: don't open-code memdup_user() alpha: fix stack smashing in old_adjtimex(2) don't open-code kernel_setsockopt() mips: switch to RAW_COPY_USER mips: get rid of tail-zeroing in primitives mips: make copy_from_user() zero tail explicitly mips: clean and reorder the forest of macros... mips: consolidate __invoke_... wrappers ...
2017-04-26CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional nowAl Viro
all architectures converted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-26Merge branches 'uaccess.alpha', 'uaccess.arc', 'uaccess.arm', ↵Al Viro
'uaccess.arm64', 'uaccess.avr32', 'uaccess.bfin', 'uaccess.c6x', 'uaccess.cris', 'uaccess.frv', 'uaccess.h8300', 'uaccess.hexagon', 'uaccess.ia64', 'uaccess.m32r', 'uaccess.m68k', 'uaccess.metag', 'uaccess.microblaze', 'uaccess.mips', 'uaccess.mn10300', 'uaccess.nios2', 'uaccess.openrisc', 'uaccess.parisc', 'uaccess.powerpc', 'uaccess.s390', 'uaccess.score', 'uaccess.sh', 'uaccess.sparc', 'uaccess.tile', 'uaccess.um', 'uaccess.unicore32', 'uaccess.x86' and 'uaccess.xtensa' into work.uaccess
2017-04-06Merge commit 'b4fb8f66f1ae2e167d06c12d018025a8d4d3ba7e' into uaccess.ia64Al Viro
backmerge of mainline ia64 fix
2017-04-06Merge commit 'fc69910f329d' into uaccess.mipsAl Viro
backmerge of a build fix from mainline
2017-04-02Merge branch 'parisc-4.11-3' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into uaccess.parisc
2017-03-29Merge branch 'regset' (PTRACE_SETREGSET data leakage)Linus Torvalds
Merge PTRACE_SETREGSET leakage fixes from Dave Martin: "This series is the collection of fixes I proposed on this topic, that have not yet appeared upstream or in the stable branches, The issue can leak kernel stack, but doesn't appear to allow userspace to attack the kernel directly. The affected architectures are c6x, h8300, metag, mips and sparc. [ Mark Salter points out that c6x has no MMU or other mechanism to prevent userspace access to kernel code or data on c6x, but it doesn't hurt to clean that case up too. ] The bugs arise from use of user_regset_copyin(). Users of user_regset_copyin() can work in one of two ways: 1) Copy directly to thread_struct or equivalent. (This seems to be the design assumption of the regset API, and is the most common approach.) 2) Copy to a local variable and then transfer to thread_struct. (A significant minority of cases.) Buggy code typically involves approach 2" * emailed patches from Dave Martin <Dave.Martin@arm.com>: sparc/ptrace: Preserve previous registers for short regset write mips/ptrace: Preserve previous registers for short regset write metag/ptrace: Reject partial NT_METAG_RPIPE writes metag/ptrace: Provide default TXSTATUS for short NT_PRSTATUS metag/ptrace: Preserve previous registers for short regset write h8300/ptrace: Fix incorrect register transfer count c6x/ptrace: Remove useless PTRACE_SETREGSET implementation
2017-03-29h8300/ptrace: Fix incorrect register transfer countDave Martin
regs_set() and regs_get() are vulnerable to an off-by-1 buffer overrun if CONFIG_CPU_H8S is set, since this adds an extra entry to register_offset[] but not to user_regs_struct. So, iterate over user_regs_struct based on its actual size, not based on the length of register_offset[]. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-288300: switch to RAW_COPY_USERAl Viro
2017-03-28asm-generic/uaccess.h: don't mess with __copy_{to,from}_userAl Viro
only h8300 actually used those; might as well define them there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-27add asm-generic/extable.hAl Viro
... and make the users of generic uaccess.h use that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-03-09arch, mm: convert all architectures to use 5level-fixup.hKirill A. Shutemov
If an architecture uses 4level-fixup.h we don't need to do anything as it includes 5level-fixup.h. If an architecture uses pgtable-nop*d.h, define __ARCH_USE_5LEVEL_HACK before inclusion of the header. It makes asm-generic code to use 5level-fixup.h. If an architecture has 4-level paging or folds levels on its own, include 5level-fixup.h directly. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-07h8300: Fix build breakage caused by header file changesGuenter Roeck
Fix the following h8300 build failures: arch/h8300/kernel/ptrace_h.c: In function ‘trace_trap’: arch/h8300/kernel/ptrace_h.c:253:3: error: implicit declaration of function ‘force_sig’ Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Fixes: c3edc4010e9d ("sched/headers: Move task_struct::signal and ...") Link: http://lkml.kernel.org/r/1488738434-3504-1-git-send-email-linux@roeck-us.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-02sched/headers: Prepare to remove the <linux/mm_types.h> dependency from ↵Ingo Molnar
<linux/sched.h> Update code that relied on sched.h including various MM types for them. This will allow us to remove the <linux/mm_types.h> include from <linux/sched.h>. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/task_stack.h> We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task_stack.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/task.h> We are going to split <linux/sched/task.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/debug.h> We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/debug.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/signal.h> We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/signal.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-27kprobes: move kprobe declarations to asm-generic/kprobes.hLuis R. Rodriguez
Often all is needed is these small helpers, instead of compiler.h or a full kprobes.h. This is important for asm helpers, in fact even some asm/kprobes.h make use of these helpers... instead just keep a generic asm file with helpers useful for asm code with the least amount of clutter as possible. Likewise we need now to also address what to do about this file for both when architectures have CONFIG_HAVE_KPROBES, and when they do not. Then for when architectures have CONFIG_HAVE_KPROBES but have disabled CONFIG_KPROBES. Right now most asm/kprobes.h do not have guards against CONFIG_KPROBES, this means most architecture code cannot include asm/kprobes.h safely. Correct this and add guards for architectures missing them. Additionally provide architectures that not have kprobes support with the default asm-generic solution. This lets us force asm/kprobes.h on the header include/linux/kprobes.h always, but most importantly we can now safely include just asm/kprobes.h on architecture code without bringing the full kitchen sink of header files. Two architectures already provided a guard against CONFIG_KPROBES on its kprobes.h: sh, arch. The rest of the architectures needed gaurds added. We avoid including any not-needed headers on asm/kprobes.h unless kprobes have been enabled. In a subsequent atomic change we can try now to remove compiler.h from include/linux/kprobes.h. During this sweep I've also identified a few architectures defining a common macro needed for both kprobes and ftrace, that of the definition of the breakput instruction up. Some refer to this as BREAKPOINT_INSTRUCTION. This must be kept outside of the #ifdef CONFIG_KPROBES guard. [mcgrof@kernel.org: fix arm64 build] Link: http://lkml.kernel.org/r/CAB=NE6X1WMByuARS4mZ1g9+W=LuVBnMDnh_5zyN0CLADaVh=Jw@mail.gmail.com [sfr@canb.auug.org.au: fixup for kprobes declarations moving] Link: http://lkml.kernel.org/r/20170214165933.13ebd4f4@canb.auug.org.au Link: http://lkml.kernel.org/r/20170203233139.32682-1-mcgrof@kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-25Merge tag 'for-next-dma_ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma DMA mapping updates from Doug Ledford: "Drop IB DMA mapping code and use core DMA code instead. Bart Van Assche noted that the ib DMA mapping code was significantly similar enough to the core DMA mapping code that with a few changes it was possible to remove the IB DMA mapping code entirely and switch the RDMA stack to use the core DMA mapping code. This resulted in a nice set of cleanups, but touched the entire tree and has been kept separate for that reason." * tag 'for-next-dma_ops' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (37 commits) IB/rxe, IB/rdmavt: Use dma_virt_ops instead of duplicating it IB/core: Remove ib_device.dma_device nvme-rdma: Switch from dma_device to dev.parent RDS: net: Switch from dma_device to dev.parent IB/srpt: Modify a debug statement IB/srp: Switch from dma_device to dev.parent IB/iser: Switch from dma_device to dev.parent IB/IPoIB: Switch from dma_device to dev.parent IB/rxe: Switch from dma_device to dev.parent IB/vmw_pvrdma: Switch from dma_device to dev.parent IB/usnic: Switch from dma_device to dev.parent IB/qib: Switch from dma_device to dev.parent IB/qedr: Switch from dma_device to dev.parent IB/ocrdma: Switch from dma_device to dev.parent IB/nes: Remove a superfluous assignment statement IB/mthca: Switch from dma_device to dev.parent IB/mlx5: Switch from dma_device to dev.parent IB/mlx4: Switch from dma_device to dev.parent IB/i40iw: Remove a superfluous assignment statement IB/hns: Switch from dma_device to dev.parent ...
2017-02-01sched/cputime: Remove generic asm headersFrederic Weisbecker
cputime_t is now only used by two architectures: * powerpc (when CONFIG_VIRT_CPU_ACCOUNTING_NATIVE=y) * s390 And since the core doesn't use it anymore, we don't need any arch support from the others. So we can remove their stub implementations. A final cleanup would be to provide an efficient pure arch implementation of cputime_to_nsec() for s390 and powerpc and finally remove include/linux/cputime.h . Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Link: http://lkml.kernel.org/r/1485832191-26889-36-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-01-24treewide: Consolidate get_dma_ops() implementationsBart Van Assche
Introduce a new architecture-specific get_arch_dma_ops() function that takes a struct bus_type * argument. Add get_dma_ops() in <linux/dma-mapping.h>. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-01-24treewide: Constify most dma_map_ops structuresBart Van Assche
Most dma_map_ops structures are never modified. Constify these structures such that these can be write-protected. This patch has been generated as follows: git grep -l 'struct dma_map_ops' | xargs -d\\n sed -i \ -e 's/struct dma_map_ops/const struct dma_map_ops/g' \ -e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \ -e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \ -e 's/const const struct dma_map_ops /const struct dma_map_ops /g'; sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops intel_dma_ops'); sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc); sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \ -e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \ -e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \ drivers/pci/host/*.c sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-17locking/core: Provide common cpu_relax_yield() definitionChristian Borntraeger
No need to duplicate the same define everywhere. Since the only user is stop-machine and the only provider is s390, we can use a default implementation of cpu_relax_yield() in sched.h. Suggested-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Hildenbrand <david@redhat.com> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-s390 <linux-s390@vger.kernel.org> Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1479298985-191589-1-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core, arch: Remove cpu_relax_lowlatency()Christian Borntraeger
As there are no users left, we can remove cpu_relax_lowlatency() implementations from every architecture. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Cc: <linux-arch@vger.kernel.org> Link: http://lkml.kernel.org/r/1477386195-32736-6-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-16locking/core: Introduce cpu_relax_yield()Christian Borntraeger
For spinning loops people do often use barrier() or cpu_relax(). For most architectures cpu_relax and barrier are the same, but on some architectures cpu_relax can add some latency. For example on power,sparc64 and arc, cpu_relax can shift the CPU towards other hardware threads in an SMT environment. On s390 cpu_relax does even more, it uses an hypercall to the hypervisor to give up the timeslice. In contrast to the SMT yielding this can result in larger latencies. In some places this latency is unwanted, so another variant "cpu_relax_lowlatency" was introduced. Before this is used in more and more places, lets revert the logic and provide a cpu_relax_yield that can be called in places where yielding is more important than latency. By default this is the same as cpu_relax on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Noam Camus <noamc@ezchip.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: virtualization@lists.linux-foundation.org Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1477386195-32736-2-git-send-email-borntraeger@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-11Merge branch 'linus' into locking/core, to pick up fixesIngo Molnar
2016-10-27h8300: fix syscall restartingMark Rutland
Back in commit f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct"), all architectures and core code were changed to use task_struct::restart_block. However, when h8300 support was subsequently restored in v4.2, it was not updated to account for this, and maintains thread_info::restart_block, which is not kept in sync. This patch drops the redundant restart_block from thread_info, and moves h8300 to the common one in task_struct, ensuring that syscall restarting always works as expected. Fixes: f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct") Link: http://lkml.kernel.org/r/1476714934-11635-1-git-send-email-mark.rutland@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Cc: <stable@vger.kernel.org> [4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-25locking/mutex: Kill arch specific codePeter Zijlstra
Its all generic atomic_long_t stuff now. Tested-by: Jason Low <jason.low2@hpe.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-13h8300: Add missing include file to asm/io.hGuenter Roeck
h8300 builds fail with arch/h8300/include/asm/io.h:9:15: error: unknown type name ‘u8’ arch/h8300/include/asm/io.h:15:15: error: unknown type name ‘u16’ arch/h8300/include/asm/io.h:21:15: error: unknown type name ‘u32’ and many related errors. Fixes: 23c82d41bdf4 ("kexec-allow-architectures-to-override-boot-mapping-fix") Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-08-05Merge tag 'rtc-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.8 Cleanups: - huge cleanup of rtc-generic and char/genrtc this allowed to cleanup rtc-cmos, rtc-sh, rtc-m68k, rtc-powerpc and rtc-parisc - move mn10300 to rtc-cmos Subsystem: - fix wakealarms after hibernate - multiples fixes for rctest - simplify implementations of .read_alarm New drivers: - Maxim MAX6916 Drivers: - ds1307: fix weekday - m41t80: add wakeup support - pcf85063: add support for PCF85063A variant - rv8803: extend i2c fix and other fixes - s35390a: fix alarm reading, this fixes instant reboot after shutdown for QNAP TS-41x - s3c: clock fixes" * tag 'rtc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (65 commits) rtc: rv8803: Clear V1F when setting the time rtc: rv8803: Stop the clock while setting the time rtc: rv8803: Always apply the I²C workaround rtc: rv8803: Fix read day of week rtc: rv8803: Remove the check for valid time rtc: rv8803: Kconfig: Indicate rx8900 support rtc: asm9260: remove .owner field for driver rtc: at91sam9: Fix missing spin_lock_init() rtc: m41t80: add suspend handlers for alarm IRQ rtc: m41t80: make it a real error message rtc: pcf85063: Add support for the PCF85063A device rtc: pcf85063: fix year range rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracy rtc: explicitly set tm_sec = 0 for drivers with minute accurancy rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq() rtc: s3c: Remove unnecessary call to disable already disabled clock rtc: abx80x: use devm_add_action_or_reset() rtc: m41t80: use devm_add_action_or_reset() rtc: fix a typo and reduce three empty lines to one rtc: s35390a: improve two comments in .set_alarm ...
