path: root/arch/h8300
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-09alpha/h8300/m68k: remove obsolete <asm/md.h> filesGeert Uytterhoeven
Removal of these started in 2.3.43pre3, ca. 10 years ago. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07remove needless ISA_DMA_THRESHOLDFUJITA Tomonori
Architectures don't need to define ISA_DMA_THRESHOLD anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-18Merge commit 'v2.6.35-rc3' into perf/coreIngo Molnar
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-09arch: Implement local64_tPeter Zijlstra
On 64bit, local_t is of size long, and thus we make local64_t an alias. On 32bit, we fall back to atomic64_t. (architecture can provide optimized 32-bit version) (This new facility is to be used by perf events optimizations.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-arch@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-27h8300: use asm-generic/scatterlist.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-17atomic_t: Cast to volatile when accessing atomic variablesAnton Blanchard
In preparation for removing volatile from the atomic_t definition, this patch adds a volatile cast to all the atomic read functions. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14add descriptive comment for TIF_MEMDIE task flag declaration.Andreas Dilger
Signed-off-by: Andreas Dilger <adilger@dilger.ca> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13h8300: Convert h8300 to use read/update_persistent_clockJohn Stultz
This patch converts the h8300 architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. I have not built or tested this patch, so help from arch maintainers would be appreciated. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1267675049-12337-6-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12h8300: use generic ptrace_resume codeChristoph Hellwig
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT, PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining arch_has_single_step in <asm/ptrace.h> and implementing the user_enable_single_step and user_disable_single_step functions, which also causes the breakpoint information to be cleared on fork, which could be considered a bug fix. Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which it previously wasn't which is consistent with all architectures using the modern ptrace code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ptrace: use ptrace_request() in the remaining architecturesChristoph Hellwig
Use ptrace_request() in the three remaining architectures that didn't use it (m68knommu, h8300, microblaze). This means: - ptrace_request now handles PTRACE_{PEEK,POKE}{TEXT,DATA} and PTRACE_DETATCH calls that were previously called directly, or in case of h8300 even open coded. - adds new support for PTRACE_SETOPTIONS/PTRACE_GETEVENTMSG/ PTRACE_GETSIGINFO/PTRACE_SETSIGINFO Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-03Rename .text.startup to .text..startup.Denys Vlasenko
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-27m68k{,nommu}/h8300: Remove obsolete comment about map_chunkPhilippe De Muyter
Remove the comments referring to a function map_chunk that no longer exists. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16Merge branch 'module' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: fix segfault with short symbol names module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y Kbuild: clear marker out of modpost module: make MODULE_SYMBOL_PREFIX into a CONFIG option ARM: unexport symbols used to implement floating point emulation ARM: use unified discard definition in linker script x86: don't export inline function sparc64: don't export static inline pci_ functions
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-09Merge branch 'bkl-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mn10300: Remove the BKL from sys_execve m68knommu: Remove the BKL from sys_execve m68k: Remove the BKL from sys_execve h83000: Remove BKL from sys_execve frv: Remove the BKL from sys_execve blackfin: Remove the BKL from sys_execve um: Remove BKL from mmapper um: Remove BKL from random s390: Remove BKL from prng
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-14h83000: Remove BKL from sys_execveJohn Kacur
This looks like a copy-and-paste job for code that no-longer needs the BKL Just remove it. Signed-off-by: John Kacur <jkacur@redhat.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> LKML-Reference: <alpine.LFD.2.00.0910130010000.3658@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24h8300: Cleanup linker script using new linker script macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22h8300: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove duplicate asm/mman.h filesArnd Bergmann
A number of architectures have identical asm/mman.h files so they can all be merged by using the new generic file. The remaining asm/mman.h files are substantially different from each other. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove references to non-existent include/linux/config.hMarkus Heidelberg
Ignore drivers/staging/ since it is very likely that new drivers introduce it again. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
