path: root/arch/hexagon
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.hAl Viro
now it can be done... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28hexagon: switch to generic clone()Al Viro
2012-11-28consolidate sys_execve() prototypeAl Viro
2012-11-16Merge branch 'arch-frv' into no-rebasesAl Viro
2012-11-13tracing,x86: Add a TSC trace_clockDavid Sharp
In order to promote interoperability between userspace tracers and ftrace, add a trace_clock that reports raw TSC values which will then be recorded in the ring buffer. Userspace tracers that also record TSCs are then on exactly the same time base as the kernel and events can be unambiguously interlaced. Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large timestamp values. v2: Move arch-specific bits out of generic code. v3: Rename "x86-tsc", cleanups v7: Generic arch bits in Kbuild. Google-Bug-Id: 6980623 Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Signed-off-by: David Sharp <dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-10-23hexagon: switch to generic sys_execve()Al Viro
2012-10-23hexagon: kernel_thread()/kernel_execve() conversionAl Viro
introduce sane current_pt_regs(), use it in syscalls where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-18Hexagon: Copyright marking changesRichard Kuo
Code Aurora Forum (CAF) is becoming a part of Linux Foundation Labs. Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2012-10-18UAPI: (Scripted) Disintegrate arch/hexagon/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09readahead: fault retry breaks mmap file read random detectionShaohua Li
.fault now can retry. The retry can break state machine of .fault. In filemap_fault, if page is miss, ra->mmap_miss is increased. In the second try, since the page is in page cache now, ra->mmap_miss is decreased. And these are done in one fault, so we can't detect random mmap file access. Add a new flag to indicate .fault is tried once. In the second try, skip ra->mmap_miss decreasing. The filemap_fault state machine is ok with it. I only tested x86, didn't test other archs, but looks the change for other archs is obvious, but who knows :) Signed-off-by: Shaohua Li <shaohua.li@fusionio.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-07Merge branch 'uapi-prep' of git://git.infradead.org/users/dhowells/linux-headersLinus Torvalds
Pull UAPI disintegration fixes from David Howells: "There are three main parts: (1) I found I needed some more fixups in the wake of testing Arm64 (some asm/unistd.h files had weird guards that caused problems - mostly in arches for which I don't have a compiler) and some __KERNEL__ splitting needed to take place in Arm64. (2) I found that c6x was missing some __KERNEL__ guards in its asm/signal.h. Mark Salter pointed me at a tree with a patch to remove that file entirely and use the asm-generic variant instead. (3) Lastly, m68k turned out to have a header installation problem due to it lacking a kvm_para.h file. The conditional installation bits for linux/kvm_para.h, linux/kvm.h and linux/a.out.h weren't very well specified - and didn't work if an arch didn't have the asm/ version of that file, but there *was* an asm-generic/ version. It seems the "ifneq $((wildcard ...),)" for each of those three headers in include/kernel/Kbuild is invoked twice during header installation, and the second time it matches on the just installed asm-generic/kvm_para.h file and thus incorrectly installs linux/kvm_para.h as well. Most arches actually have an asm/kvm_para.h, so this wasn't detectable in those." * 'uapi-prep' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k) c6x: remove c6x signal.h UAPI: Split compound conditionals containing __KERNEL__ in Arm64 UAPI: Fix the guards on various asm/unistd.h files c6x: make dsk6455 the default config
2012-10-06cross-arch: don't corrupt personality flags upon exec()Jiri Kosina
Historically, the top three bytes of personality have been used for things such as ADDR_NO_RANDOMIZE, which made sense only for specific architectures. We now however have a flag there that is general no matter the architecture (UNAME26); generally we have to be careful to preserve the personality flags across exec(). This patch tries to fix all architectures that forcefully overwrite personality flags during exec() (ppc32 and s390 have been fixed recently by commits f9783ec862ea ("[S390] Do not clobber personality flags on exec") and 59e4c3a2fe9c ("powerpc/32: Don't clobber personality flags on exec") in a similar way already). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04Merge branch 'disintegrate-asm-generic' of ↵Arnd Bergmann
git://git.infradead.org/users/dhowells/linux-headers into asm-generic Patches from David Howells <dhowells@redhat.com>: This is to complete part of the UAPI disintegration for which the preparatory patches were pulled recently. Note that there are some fixup patches which are at the base of the branch aimed at you, plus all arches get the asm-generic branch merged in too. * 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/asm-generic UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k) c6x: remove c6x signal.h UAPI: Split compound conditionals containing __KERNEL__ in Arm64 UAPI: Fix the guards on various asm/unistd.h files Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-04UAPI: Fix the guards on various asm/unistd.h filesDavid Howells
asm-generic/unistd.h and a number of asm/unistd.h files have been given reinclusion guards that allow the guard to be overridden if __SYSCALL is defined. Unfortunately, these files define __SYSCALL and don't undefine it when they've finished with it, thus rendering the guard ineffective. The reason for this override is to allow the file to be #included multiple times with different settings on __SYSCALL for purposes like generating syscall tables. The following guards are problematic: arch/arm64/include/asm/unistd.h:#if !defined(__ASM_UNISTD_H) || defined(__SYSCALL) arch/arm64/include/asm/unistd32.h:#if !defined(__ASM_UNISTD32_H) || defined(__SYSCALL) arch/c6x/include/asm/unistd.h:#if !defined(_ASM_C6X_UNISTD_H) || defined(__SYSCALL) arch/hexagon/include/asm/unistd.h:#if !defined(_ASM_HEXAGON_UNISTD_H) || defined(__SYSCALL) arch/openrisc/include/asm/unistd.h:#if !defined(__ASM_OPENRISC_UNISTD_H) || defined(__SYSCALL) arch/score/include/asm/unistd.h:#if !defined(_ASM_SCORE_UNISTD_H) || defined(__SYSCALL) arch/tile/include/asm/unistd.h:#if !defined(_ASM_TILE_UNISTD_H) || defined(__SYSCALL) arch/unicore32/include/asm/unistd.h:#if !defined(__UNICORE_UNISTD_H__) || defined(__SYSCALL) include/asm-generic/unistd.h:#if !defined(_ASM_GENERIC_UNISTD_H) || defined(__SYSCALL) On the assumption that the guards' ineffectiveness has passed unnoticed, just remove these guards entirely. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Catalin Marinas <catalin.marinas@arm.com>
2012-10-03asm-generic: Add default clkdev.hMark Brown
Ease the deployment of clkdev by providing a default asm/clkdev.h for use if the arch does not have an include/asm/clkdev.h. Due to limitations in Kbuild we manually add clkdev.h to all architectures that don't have one rather than having the header appear by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-02UAPI: (Scripted) Set up UAPI Kbuild filesDavid Howells
Set up empty UAPI Kbuild files to be populated by the header splitter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Uninclude linux/freezer.hRichard Weinberger
This include is no longer needed. (seems to be a leftover from try_to_freeze()) Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01bury the rest of TIF_IRETAl Viro
Some architectures had blindly copied it for no reason whatsoever. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01sanitize tsk_is_polling()Al Viro
Make default just return 0. The current default (checking TIF_POLLING_NRFLAG) is taken to architectures that need it; ones that don't do polling in their idle threads don't need to defined TIF_POLLING_NRFLAG at all. ia64 defined both TS_POLLING (used by its tsk_is_polling()) and TIF_POLLING_NRFLAG (not used at all). Killed the latter... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01bury _TIF_RESTORE_SIGMASKAl Viro
never used... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-20don't bother exporting kernel_execve()Al Viro
most of the architectures don't and there's not a single caller outside of core kernel. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-30Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull treewide kbuild cleanup from Michal Marek: "Paul Bolle did a cleanup of <asm/*.h> headers in various architectures. Because the patch touch several architectures at once, it was easiest for me to apply them to the kbuild tree." * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Remove useless wrappers of asm-generic/rmap.h Remove useless wrappers of asm-generic/ipc.h Remove useless wrappers of asm-generic/cpumask.h
2012-06-28Remove useless wrappers of asm-generic/ipc.hPaul Bolle
mn10300 has a header (in its include/asm directory) that is a thin wrapper around asm-generic/ipc.h. This wrapper is useless, since that header doesn't exist. It is also unused (no file includes asm/ipc.h). hexagon and tile generate similar headers at build time (using a generic-y entry in include/asm/Kbuild). These generated headers are useless and unused too. Remove this header and these generic-y entries. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Richard Kuo <rkuo@codeaurora.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David Howells <dhowells@redhat.com> [MN10300] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28Remove useless wrappers of asm-generic/cpumask.hPaul Bolle
frv and xtensa both have a header (in their include/asm directories) that are thin wrappers around asm-generic/cpumask.h. These wrappers are useless, since that header doesn't exist. They are also unused (all files including asm/cpumask.h are x86 specific). hexagon and openrisc generate similar headers at build time (using a generic-y entry in include/asm/Kbuild). These generated headers are useless and unused too. Remove these headers and generic-y entries. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Richard Kuo <rkuo@codeaurora.org> Acked-by: David Howells <dhowells@redhat.com> [FRV] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-05hexagon: SMP: Remove call to ipi_call_lock()/ipi_call_unlock()Yong Zhang
ipi_call_lock/unlock() lock resp. unlock call_function.lock. This lock protects only the call_function data structure itself, but it's completely unrelated to cpu_online_mask. The mask to which the IPIs are sent is calculated before call_function.lock is taken in smp_call_function_many(), so the locking around set_cpu_online() is pointless and can be removed. [ tglx: Massaged changelog ] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Cc: ralf@linux-mips.org Cc: sshtylyov@mvista.com Cc: david.daney@cavium.com Cc: nikunj@linux.vnet.ibm.com Cc: paulmck@linux.vnet.ibm.com Cc: axboe@kernel.dk Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Link: http://lkml.kernel.org/r/1338275765-3217-2-git-send-email-yong.zhang0@gmail.com Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-06-01new helper: signal_delivered()Al Viro
Does block_sigmask() + tracehook_signal_handler(); called when sigframe has been successfully built. All architectures converted to it; block_sigmask() itself is gone now (merged into this one). I'm still not too happy with the signature, but that's a separate story (IMO we need a structure that would contain signal number + siginfo + k_sigaction, so that get_signal_to_deliver() would fill one, signal_delivered(), handle_signal() and probably setup...frame() - take one). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from setAl Viro
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(), added set_current_blocked() that will exclude unblockable signals, switched open-coded instances to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01don't call try_to_freeze() from do_signal()Al Viro
get_signal_to_deliver() will handle it itself Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01pull clearing RESTORE_SIGMASK into block_sigmask()Al Viro
2012-06-01new helper: sigmask_to_save()Al Viro
replace boilerplate "should we use ->saved_sigmask or ->blocked?" with calls of obvious inlined helper... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helper: restore_saved_sigmask()Al Viro
first fruits of ..._restore_sigmask() helpers: now we can take boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK and restore the blocked mask from ->saved_mask" into a common helper. Open-coded instances switched... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull second pile of signal handling patches from Al Viro: "This one is just task_work_add() series + remaining prereqs for it. There probably will be another pull request from that tree this cycle - at least for helpers, to get them out of the way for per-arch fixes remaining in the tree." Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the pr_foo() infrastructure to prefix printks") which changed one of the pr_err() calls that this merge moves around. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: keys: kill task_struct->replacement_session_keyring keys: kill the dummy key_replace_session_keyring() keys: change keyctl_session_to_parent() to use task_work_add() genirq: reimplement exit_irq_thread() hook via task_work_add() task_work_add: generic process-context callbacks avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers parisc: need to check NOTIFY_RESUME when exiting from syscall move key_repace_session_keyring() into tracehook_notify_resume() TIF_NOTIFY_RESUME is defined on all targets now
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-05-24Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner. Various trivial conflict fixups in arch Kconfig due to addition of unrelated entries nearby. And one slightly more subtle one for sparc32 (new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) timekeeping: Fix a few minor newline issues. time: remove obsolete declaration ntp: Fix a stale comment and a few stray newlines. ntp: Correct TAI offset during leap second timers: Fixup the Kconfig consolidation fallout x86: Use generic time config unicore32: Use generic time config um: Use generic time config tile: Use generic time config sparc: Use: generic time config sh: Use generic time config score: Use generic time config s390: Use generic time config openrisc: Use generic time config powerpc: Use generic time config mn10300: Use generic time config mips: Use generic time config microblaze: Use generic time config m68k: Use generic time config m32r: Use generic time config ...
2012-05-23move key_repace_session_keyring() into tracehook_notify_resume()Al Viro
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull first series of signal handling cleanups from Al Viro: "This is just the first part of the queue (about a half of it); assorted fixes all over the place in signal handling. This one ends with all sigsuspend() implementations switched to generic one (->saved_sigmask-based). With this, a bunch of assorted old buglets are fixed and most of the missing bits of NOTIFY_RESUME hookup are in place. Two more fixes sit in arm and um trees respectively, and there's a couple of broken ones that need obvious fixes - parisc and avr32 check TIF_NOTIFY_RESUME only on one of two codepaths; fixes for that will happen in the next series" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (55 commits) unicore32: if there's no handler we need to restore sigmask, syscall or no syscall xtensa: add handling of TIF_NOTIFY_RESUME microblaze: drop 'oldset' argument of do_notify_resume() microblaze: handle TIF_NOTIFY_RESUME score: add handling of NOTIFY_RESUME to do_notify_resume() m68k: add TIF_NOTIFY_RESUME and handle it. sparc: kill ancient comment in sparc_sigaction() h8300: missing checks of __get_user()/__put_user() return values frv: missing checks of __get_user()/__put_user() return values cris: missing checks of __get_user()/__put_user() return values powerpc: missing checks of __get_user()/__put_user() return values sh: missing checks of __get_user()/__put_user() return values sparc: missing checks of __get_user()/__put_user() return values avr32: struct old_sigaction is never used m32r: struct old_sigaction is never used xtensa: xtensa_sigaction doesn't exist alpha: tidy signal delivery up score: don't open-code force_sigsegv() cris: don't open-code force_sigsegv() blackfin: don't open-code force_sigsegv() ...
2012-05-23Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull fpu state cleanups from Ingo Molnar: "This tree streamlines further aspects of FPU handling by eliminating the prepare_to_copy() complication and moving that logic to arch_dup_task_struct(). It also fixes the FPU dumps in threaded core dumps, removes and old (and now invalid) assumption plus micro-optimizes the exit path by avoiding an FPU save for dead tasks." Fixed up trivial add-add conflict in arch/sh/kernel/process.c that came in because we now do the FPU handling in arch_dup_task_struct() rather than the legacy (and now gone) prepare_to_copy(). * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, fpu: drop the fpu state during thread exit x86, xsave: remove thread_has_fpu() bug check in __sanitize_i387_state() coredump: ensure the fpu state is flushed for proper multi-threaded core dump fork: move the real prepare_to_copy() users to arch_dup_task_struct()
2012-05-22various Kconfig cleanup and old platform build code removalRichard Kuo
2012-05-22hexagon/mm/vm_fault.c: Port OOM changes to do_page_faultKautuk Consul
Commit d065bd810b6deb67d4897a14bfe21f8eb526ba99 (mm: retry page fault when blocking on disk transfer) and commit 37b23e0525d393d48a7d59f870b3bc061a30ccdb (x86,mm: make pagefault killable) The above commits introduced changes into the x86 pagefault handler for making the page fault handler retryable as well as killable. These changes reduce the mmap_sem hold time, which is crucial during OOM killer invocation. Port these changes to hexagon. Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
