This change allows us to pass DMA_ATTR_SKIP_CPU_SYNC which allows us to
avoid invoking cache line invalidation if the driver will just handle it
later via a sync_for_cpu or sync_for_device call.
Link: http://lkml.kernel.org/r/20161110113452.76501.45864.stgit@ahduyck-blue-test.jf.intel.com
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
No need to duplicate the same define everywhere. Since
the only user is stop-machine and the only provider is
s390, we can use a default implementation of cpu_relax_yield()
in sched.h.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Noam Camus <noamc@ezchip.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: kvm@vger.kernel.org
Cc: linux-s390 <linux-s390@vger.kernel.org>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Cc: virtualization@lists.linux-foundation.org
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1479298985-191589-1-git-send-email-borntraeger@de.ibm.com
As there are no users left, we can remove cpu_relax_lowlatency()
implementations from every architecture.
Cc: Russell King <linux@armlinux.org.uk>
Cc: <linux-arch@vger.kernel.org>
Link: http://lkml.kernel.org/r/1477386195-32736-6-git-send-email-borntraeger@de.ibm.com
For spinning loops people do often use barrier() or cpu_relax().
For most architectures cpu_relax and barrier are the same, but on
some architectures cpu_relax can add some latency.
For example on power,sparc64 and arc, cpu_relax can shift the CPU
towards other hardware threads in an SMT environment.
On s390 cpu_relax does even more, it uses an hypercall to the
hypervisor to give up the timeslice.
In contrast to the SMT yielding this can result in larger latencies.
In some places this latency is unwanted, so another variant
"cpu_relax_lowlatency" was introduced. Before this is used in more
and more places, lets revert the logic and provide a cpu_relax_yield
that can be called in places where yielding is more important than
latency. By default this is the same as cpu_relax on all architectures.
Link: http://lkml.kernel.org/r/1477386195-32736-2-git-send-email-borntraeger@de.ibm.com
Its all generic atomic_long_t stuff now.
Tested-by: Jason Low <jason.low2@hpe.com>
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
It's -EFAULT, not -1 (and contrary to the comment in there,
__strnlen_user() can return 0 - on faults).
Cc: stable@vger.kernel.org
Acked-by: Richard Kuo <rkuo@codeaurora.org>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
There was only one use of __initdata_refok and __exit_refok
__init_refok was used 46 times against 82 for __ref.
Those definitions are obsolete since commit 312b1485fb50 ("Introduce new
section reference annotations tags: __ref, __refdata, __refconst")
This patch removes the following compatibility definitions and replaces
them treewide.
/* compatibility defines */
#define __init_refok __ref
#define __initdata_refok __refdata
#define __exit_refok __ref
I can also provide separate patches if necessary.
(One patch per tree and check in 1 month or 2 to remove old definitions)
Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Merge updates from Andrew Morton:
- a few misc bits
- ocfs2
- most(?) of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (125 commits)
thp: fix comments of __pmd_trans_huge_lock()
cgroup: remove unnecessary 0 check from css_from_id()
cgroup: fix idr leak for the first cgroup root
mm: memcontrol: fix documentation for compound parameter
mm: memcontrol: remove BUG_ON in uncharge_list
mm: fix build warnings in <linux/compaction.h>
mm, thp: convert from optimistic swapin collapsing to conservative
mm, thp: fix comment inconsistency for swapin readahead functions
thp: update Documentation/{vm/transhuge,filesystems/proc}.txt
shmem: split huge pages beyond i_size under memory pressure
thp: introduce CONFIG_TRANSPARENT_HUGE_PAGECACHE
khugepaged: add support of collapse for tmpfs/shmem pages
shmem: make shmem_inode_info::lock irq-safe
khugepaged: move up_read(mmap_sem) out of khugepaged_alloc_page()
thp: extract khugepaged from mm/huge_memory.c
shmem, thp: respect MADV_{NO,}HUGEPAGE for file mappings
shmem: add huge pages support
shmem: get_unmapped_area align huge page
shmem: prepare huge= mount option and sysfs knob
mm, rmap: account shmem thp pages
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.8 kernel cycle. The big
news is the completion of the chardev ABI which I'm very happy about
and apart from that it's an ordinary, quite busy cycle. The details
are below.
The patches are tested in linux-next for some time, patches to other
subsystem mostly have ACKs.
I got overly ambitious with configureing lines as input for IRQ lines
but it turns out that some controllers have their interrupt-enable and
input-enabling in orthogonal settings so the assumption that all IRQ
lines are input lines does not hold. Oh well, revert and back to the
drawing board with that.
Core changes:
- The big item is of course the completion of the character device
ABI. It has now replaced and surpassed the former unmaintainable
sysfs ABI: we can now hammer (bitbang) individual lines or sets of
lines and read individual lines or sets of lines from userspace,
and we can also register to listen to GPIO events from userspace.
As a tie-in we have two new tools in tools/gpio: gpio-hammer and
gpio-event-mon that illustrate the proper use of the new ABI. As
someone said: the wild west days of GPIO are now over.
- Continued to remove the pointless ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB
Kconfig symbols. I'm patching hexagon, openrisc, powerpc, sh,
unicore, ia64 and microblaze. These are either ACKed by their
maintainers or patched anyways after a grace period and no response
from maintainers.
Some archs (ARM) come in from their trees, and others (x86) are
still not fixed, so I might send a second pull request to root it
out later in this merge window, or just defer to v4.9.
- The GPIO tools are moved to the tools build system.
New drivers:
- New driver for the MAX77620/MAX20024.
- New driver for the Intel Merrifield.
- Enabled PCA953x for the TI PCA9536.
- Enabled PCA953x for the Intel Edison.
- Enabled R8A7792 in the RCAR driver.
Driver improvements:
- The STMPE and F7188x now supports the .get_direction() callback.
- The Xilinx driver supports setting multiple lines at once.
- ACPI support for the Vulcan GPIO controller.
- The MMIO GPIO driver supports device tree probing.
- The Acer One 10 is supported through the _DEP ACPI attribute.
Cleanups:
- A major cleanup of the OF/DT support code. It is way easier to
read and understand now, probably this improves performance too.
- Drop a few redundant .owner assignments.
- Remove CLPS711x boardfile support: we are 100% DT"
* tag 'gpio-v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (67 commits)
MAINTAINERS: Add INTEL MERRIFIELD GPIO entry
gpio: dwapb: add missing fwnode_handle_put() in dwapb_gpio_get_pdata()
gpio: merrifield: Protect irq_ack() and gpio_set() by lock
gpio: merrifield: Introduce GPIO driver to support Merrifield
gpio: intel-mid: Make it depend to X86_INTEL_MID
gpio: intel-mid: Sort header block alphabetically
gpio: intel-mid: Remove potentially harmful code
gpio: rcar: add R8A7792 support
gpiolib: remove duplicated include from gpiolib.c
Revert "gpio: convince line to become input in irq helper"
gpiolib: of_find_gpio(): Don't discard errors
gpio: of: Allow overriding the device node
gpio: free handles in fringe cases
gpio: tps65218: Add platform_device_id table
gpio: max77620: get gpio value based on direction
gpio: lynxpoint: avoid potential warning on error path
tools/gpio: add install section
tools/gpio: move to tools buildsystem
gpio: intel-mid: switch to devm_gpiochip_add_data()
gpio: 74x164: Use spi_write() helper instead of open coding
We always have vma->vm_mm around.
Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com
Pull locking updates from Ingo Molnar:
"The locking tree was busier in this cycle than the usual pattern - a
couple of major projects happened to coincide.
The main changes are:
- implement the atomic_fetch_{add,sub,and,or,xor}() API natively
across all SMP architectures (Peter Zijlstra)
- add atomic_fetch_{inc/dec}() as well, using the generic primitives
(Davidlohr Bueso)
- optimize various aspects of rwsems (Jason Low, Davidlohr Bueso,
Waiman Long)
- optimize smp_cond_load_acquire() on arm64 and implement LSE based
atomic{,64}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}()
on arm64 (Will Deacon)
- introduce smp_acquire__after_ctrl_dep() and fix various barrier
mis-uses and bugs (Peter Zijlstra)
- after discovering ancient spin_unlock_wait() barrier bugs in its
implementation and usage, strengthen its semantics and update/fix
usage sites (Peter Zijlstra)
- optimize mutex_trylock() fastpath (Peter Zijlstra)
- ... misc fixes and cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits)
locking/atomic: Introduce inc/dec variants for the atomic_fetch_$op() API
locking/barriers, arch/arm64: Implement LDXR+WFE based smp_cond_load_acquire()
locking/static_keys: Fix non static symbol Sparse warning
locking/qspinlock: Use __this_cpu_dec() instead of full-blown this_cpu_dec()
locking/atomic, arch/tile: Fix tilepro build
locking/atomic, arch/m68k: Remove comment
locking/atomic, arch/arc: Fix build
locking/Documentation: Clarify limited control-dependency scope
locking/atomic, arch/rwsem: Employ atomic_long_fetch_add()
locking/atomic, arch/qrwlock: Employ atomic_fetch_add_acquire()
locking/atomic, arch/mips: Convert to _relaxed atomics
locking/atomic, arch/alpha: Convert to _relaxed atomics
locking/atomic: Remove the deprecated atomic_{set,clear}_mask() functions
locking/atomic: Remove linux/atomic.h:atomic_fetch_or()
locking/atomic: Implement atomic{,64,_long}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}()
locking/atomic: Fix atomic64_relaxed() bits
locking/atomic, arch/xtensa: Implement atomic_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/x86: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/tile: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/sparc: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
This is the third version of the patchset previously sent [1]. I have
basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get
rid of superfluous gfp flags" which went through dm tree. I am sending
it now because it is tree wide and chances for conflicts are reduced
considerably when we want to target rc2. I plan to send the next step
and rename the flag and move to a better semantic later during this
release cycle so we will have a new semantic ready for 4.8 merge window
hopefully.
Motivation:
While working on something unrelated I've checked the current usage of
__GFP_REPEAT in the tree. It seems that a majority of the usage is and
always has been bogus because __GFP_REPEAT has always been about costly
high order allocations while we are using it for order-0 or very small
orders very often. It seems that a big pile of them is just a
copy&paste when a code has been adopted from one arch to another.
I think it makes some sense to get rid of them because they are just
making the semantic more unclear. Please note that GFP_REPEAT is
documented as
* __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt
* _might_ fail. This depends upon the particular VM implementation.
while !costly requests have basically nofail semantic. So one could
reasonably expect that order-0 request with __GFP_REPEAT will not loop
for ever. This is not implemented right now though.
I would like to move on with __GFP_REPEAT and define a better semantic
for it.
$ git grep __GFP_REPEAT origin/master | wc -l
111
$ git grep __GFP_REPEAT | wc -l
36
So we are down to the third after this patch series. The remaining
places really seem to be relying on __GFP_REPEAT due to large allocation
requests. This still needs some double checking which I will do later
after all the simple ones are sorted out.
I am touching a lot of arch specific code here and I hope I got it right
but as a matter of fact I even didn't compile test for some archs as I
do not have cross compiler for them. Patches should be quite trivial to
review for stupid compile mistakes though. The tricky parts are usually
hidden by macro definitions and thats where I would appreciate help from
arch maintainers.
[1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org
This patch (of 19):
__GFP_REPEAT has a rather weak semantic but since it has been introduced
around 2.6.12 it has been ignored for low order allocations. Yet we
have the full kernel tree with its usage for apparently order-0
allocations. This is really confusing because __GFP_REPEAT is
explicitly documented to allow allocation failures which is a weaker
semantic than the current order-0 has (basically nofail).
Let's simply drop __GFP_REPEAT from those places. This would allow to
identify place which really need allocator to retry harder and formulate
a more specific semantic for what the flag is supposed to do actually.
Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Helge Deller <deller@gmx.de>
Cc: Jan Kara <jack@suse.cz>
Cc: John Crispin <blogic@openwrt.org>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Rich Felker <dalias@libc.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Since all architectures have this implemented now natively, remove this
dead code.
Implement FETCH-OP atomic primitives, these are very similar to the
existing OP-RETURN primitives we already have, except they return the
value of the atomic variable _before_ modification.
This is especially useful for irreversible operations -- such as
bitops (because it becomes impossible to reconstruct the state prior
to modification).
Cc: linux-hexagon@vger.kernel.org
This patch updates/fixes all spin_unlock_wait() implementations.
The update is in semantics; where it previously was only a control
dependency, we now upgrade to a full load-acquire to match the
store-release from the spin_unlock() we waited on. This ensures that
when spin_unlock_wait() returns, we're guaranteed to observe the full
critical section we waited on.
This fixes a number of spin_unlock_wait() users that (not
unreasonably) rely on this.
I also fixed a number of ticket lock versions to only wait on the
current lock holder, instead of for a full unlock, as this is
sufficient.
Furthermore; again for ticket locks; I added an smp_rmb() in between
the initial ticket load and the spin loop testing the current value
because I could not convince myself the address dependency is
sufficient, esp. if the loads are of different sizes.
I'm more than happy to remove this smp_rmb() again if people are
certain the address dependency does indeed work as expected.
Note: PPC32 will be fixed independently
Cc: chris@zankel.net
Cc: cmetcalf@mellanox.com
Cc: davem@davemloft.net
Cc: dhowells@redhat.com
Cc: james.hogan@imgtec.com
Cc: jejb@parisc-linux.org
Cc: linux@armlinux.org.uk
Cc: mpe@ellerman.id.au
Cc: ralf@linux-mips.org
Cc: realmz6@gmail.com
Cc: rkuo@codeaurora.org
Cc: rth@twiddle.net
Cc: schwidefsky@de.ibm.com
Cc: tony.luck@intel.com
Cc: vgupta@synopsys.com
Cc: ysato@users.sourceforge.jp
The symbol that will be selected when GPIO is implemented
for Hexagon will be GPIOLIB, we have removed
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB.
Cc: Michael Büsch <m@bues.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanup from Arnd Bergmann:
"I have only one patch for asm-generic in this release, this one is
from James Hogan and updates the generic system call table for
renameat2 so we don't need to provide both renameat and renameat2 in
newly added architectures"
* tag 'asm-generic-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic: Drop renameat syscall from default list
most architectures are relying on mmap_sem for write in their
arch_setup_additional_pages. If the waiting task gets killed by the oom
killer it would block oom_reaper from asynchronous address space reclaim
and reduce the chances of timely OOM resolving. Wait for the lock in
the killable mode and return with EINTR if the task got killed while
waiting.
Acked-by: Andy Lutomirski <luto@amacapital.net> [x86 vdso]
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Define HAVE_EXIT_THREAD for archs which want to do something in
exit_thread. For others, let's define exit_thread as an empty inline.
This is a cleanup before we change the prototype of exit_thread to
accept a task parameter.
[akpm@linux-foundation.org: fix mips]
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Richard Weinberger <richard@nod.at>
Cc: Steven Miao <realmz6@gmail.com>
The newer renameat2 syscall provides all the functionality provided by
the renameat syscall and adds flags, so future architectures won't need
to include renameat.
Therefore drop the renameat syscall from the generic syscall list unless
__ARCH_WANT_RENAMEAT is defined by the architecture's unistd.h prior to
including asm-generic/unistd.h, and adjust all architectures using the
generic syscall list to define it so that no in-tree architectures are
affected.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-metag@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: nios2-dev@lists.rocketboards.org
Cc: uclinux-h8-devel@lists.sourceforge.jp
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
This patch updates all instances of csum_tcpudp_magic and
csum_tcpudp_nofold to reflect the types that are usually used as the source
inputs. For example the protocol field is populated based on nexthdr which
is actually an unsigned 8 bit value. The length is usually populated based
on skb->len which is an unsigned integer.
This addresses an issue in which the IPv6 function csum_ipv6_magic was
generating a checksum using the full 32b of skb->len while
csum_tcpudp_magic was only using the lower 16 bits. As a result we could
run into issues when attempting to adjust the checksum as there was no
protocol agnostic way to update it.
With this change the value is still truncated as many architectures use
"(len + proto) << 8", however this truncation only occurs for values
greater than 16776960 in length and as such is unlikely to occur as we stop
the inner headers at ~64K in size.
I did have to make a few minor changes in the arm, mn10300, nios2, and
score versions of the function in order to support these changes as they
were either using things such as an OR to combine the protocol and length,
or were using ntohs to convert the length which would have truncated the
value.
I also updated a few spots in terms of whitespace and type differences for
the addresses. Most of this was just to make sure all of the definitions
were in sync going forward.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Let the non boot cpus call into idle with the corresponding hotplug state, so
the hotplug core can handle the further bringup. That's a first step to
convert the boot side of the hotplugged cpus to do all the synchronization
with the other side through the state machine. For now it'll only start the
hotplug thread and kick the full bringup of the cpu.
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20160226182341.614102639@linutronix.de
Move the generic implementation to <linux/dma-mapping.h> now that all
architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now
that everyone supports them.
[valentinrothberg@gmail.com: remove leftovers in Kconfig]
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
changes
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
This patch makes sure that atomic_{read,set}() are at least
{READ,WRITE}_ONCE().
We already had the 'requirement' that atomic_read() should use
ACCESS_ONCE(), and most archs had this, but a few were lacking.
All are now converted to use READ_ONCE().
And, by a symmetry and general paranoia argument, upgrade atomic_set()
to use WRITE_ONCE().
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: oleg@redhat.com
Cc: will.deacon@arm.com
Merge third patch-bomb from Andrew Morton:
- even more of the rest of MM
- lib/ updates
- checkpatch updates
- small changes to a few scruffy filesystems
- kmod fixes/cleanups
- kexec updates
- a dma-mapping cleanup series from hch
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits)
dma-mapping: consolidate dma_set_mask
dma-mapping: consolidate dma_supported
dma-mapping: cosolidate dma_mapping_error
dma-mapping: consolidate dma_{alloc,free}_noncoherent
dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}
mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()
mm: make sure all file VMAs have ->vm_ops set
mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()
mm: mark most vm_operations_struct const
namei: fix warning while make xmldocs caused by namei.c
ipc: convert invalid scenarios to use WARN_ON
zlib_deflate/deftree: remove bi_reverse()
lib/decompress_unlzma: Do a NULL check for pointer
lib/decompressors: use real out buf size for gunzip with kernel
fs/affs: make root lookup from blkdev logical size
sysctl: fix int -> unsigned long assignments in INT_MIN case
kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo
kexec: align crash_notes allocation to make it be inside one physical page
kexec: remove unnecessary test in kimage_alloc_crash_control_pages()
kexec: split kexec_load syscall from kexec core code
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel
Pull hexagon updates from Richard Kuo:
"Just two fixes -- one for a uapi header and one for a timer interface"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel:
Revert "Hexagon: fix signal.c compile error"
hexagon/time: Migrate to new 'set-state' interface
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Most architectures just call into ->dma_supported, but some also return 1
if the method is not present, or 0 if no dma ops are present (although
that should never happeb). Consolidate this more broad version into
common code.
Also fix h8300 which inorrectly always returned 0, which would have been
a problem if it's dma_set_mask implementation wasn't a similarly buggy
noop.
As a few architectures have much more elaborate implementations, we
still allow for arch overrides.
Currently there are three valid implementations of dma_mapping_error:
(1) call ->mapping_error
(2) check for a hardcoded error code
(3) always return 0
This patch provides a common implementation that calls ->mapping_error
if present, then checks for DMA_ERROR_CODE if defined or otherwise
returns 0.
Most architectures do not support non-coherent allocations and either
define dma_{alloc,free}_noncoherent to their coherent versions or stub
them out.
Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips
implements them directly.
This patch moves the Openrisc version to common code, and handles the
DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance.
Note that actual non-coherent allocations require a dma_cache_sync
implementation, so if non-coherent allocations didn't work on
an architecture before this patch they still won't work after it.
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
This reverts commit f3f601c1d2728f02544cfd143eaa82e5398b3e9b.
UAPI headers cannot use "uapi/" in their paths by design -- when they're
installed, they do not have the uapi/ prefix. Otherwise doing so breaks
userland badly.
Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
Migrate hexagon driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
We weren't doing anything in the ->set_mode() callback. So, this patch
doesn't provide any set-state callbacks.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Implement atomic logic ops -- atomic_{or,xor,and}.
These will replace the atomic_{set,clear}_mask functions that are
available on some archs.
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Added the x86 implementation of word-at-a-time to the
generic version, which previously only supported big-endian.
Omitted the x86-specific load_unaligned_zeropad(), which in
any case is also not present for the existing BE-only
implementation of a word-at-a-time, and is only used under
CONFIG_DCACHE_WORD_ACCESS.
Added as a "generic-y" to the Kbuilds of all architectures
that didn't previously have it.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
CRIU is recreating the process memory layout by remapping the checkpointee
memory area on top of the current process (criu). This includes remapping
the vDSO to the place it has at checkpoint time.
However some architectures like powerpc are keeping a reference to the
vDSO base address to build the signal return stack frame by calling the
vDSO sigreturn service. So once the vDSO has been moved, this reference
is no more valid and the signal frame built later are not usable.
This patch serie is introducing a new mm hook framework, and a new
arch_remap hook which is called when mremap is done and the mm lock still
hold. The next patch is adding the vDSO remap and unmap tracking to the
powerpc architecture.
This patch (of 3):
This patch introduces a new set of header file to manage mm hooks:
- per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h)
- a generic header (include/linux/mm-arch-hooks.h)
The architecture which need to overwrite a hook as to redefine it in its
header file, while architecture which doesn't need have nothing to do.
The default hooks are defined in the generic header and are used in the
case the architecture is not defining it.
In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should
be moved here.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Pull scheduler updates from Ingo Molnar:
"The main changes are:
- lockless wakeup support for futexes and IPC message queues
(Davidlohr Bueso, Peter Zijlstra)
- Replace spinlocks with atomics in thread_group_cputimer(), to
improve scalability (Jason Low)
- NUMA balancing improvements (Rik van Riel)
- SCHED_DEADLINE improvements (Wanpeng Li)
- clean up and reorganize preemption helpers (Frederic Weisbecker)
- decouple page fault disabling machinery from the preemption
counter, to improve debuggability and robustness (David
Hildenbrand)
- SCHED_DEADLINE documentation updates (Luca Abeni)
- topology CPU masks cleanups (Bartosz Golaszewski)
- /proc/sched_debug improvements (Srikar Dronamraju)"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits)
sched/deadline: Remove needless parameter in dl_runtime_exceeded()
sched: Remove superfluous resetting of the p->dl_throttled flag
sched/deadline: Drop duplicate init_sched_dl_class() declaration
sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target
sched/deadline: Make init_sched_dl_class() __init
sched/deadline: Optimize pull_dl_task()
sched/preempt: Add static_key() to preempt_notifiers
sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration
sched/stop_machine: Fix deadlock between multiple stop_two_cpus()
sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched
sched/debug: Replace vruntime with wait_sum in /proc/sched_debug
sched/debug: Properly format runnable tasks in /proc/sched_debug
sched/numa: Only consider less busy nodes as numa balancing destinations
Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced")
sched/fair: Prevent throttling in early pick_next_task_fair()
preempt: Reorganize the notrace definitions a bit
preempt: Use preempt_schedule_context() as the official tracing preemption point
sched: Make preempt_schedule_context() function-tracing safe
x86: Remove cpu_sibling_mask() and cpu_core_mask()
x86: Replace cpu_**_mask() with topology_**_cpumask()
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
enabled
In general, non-atomic variants of user access functions must not sleep
if pagefaults are disabled.
Let's update all relevant comments in uaccess code. This also reflects
the might_sleep() checks in might_fault().
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-4-git-send-email-dahi@linux.vnet.ibm.com
We removed the only user of this define in the rtmutex code. Get rid
of it.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
