path: root/arch/i386/power/cpu.c
2007-10-11i386: move powerThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-02[PATCH] x86: Save and restore the fixed-range MTRRs of the BSP when suspendingBernhard Kaindl
Note: This patch didn'nt need an update since it's initial post. Some BIOSes may modify fixed-range MTRRs in SMM, e.g. when they transition the system into ACPI mode, which is entered thru an SMI, triggered by Linux in acpi_enable(). SMIs which cause that Linux is interrupted and BIOS code is executed (which may change e.g. fixed-range MTRRs) in SMM may be raised by an embedded system controller which is often found in notebooks also at other occasions. If we would not update our copy of the fixed-range MTRRs before suspending to RAM or to disk, restore_processor_state() would set the fixed-range MTRRs of the BSP using old backup values which may be outdated and this could cause the system to fail later during resume. This patch ensures that our copy of the fixed-range MTRRs is updated when saving the boot processor state on suspend to disk and suspend to RAM. In combination with other patches this allows to fix s2ram and s2disk on the Acer Ferrari 1000 notebook and at least s2disk on the Acer Ferrari 5000 notebook. Signed-off-by: Bernhard Kaindl <bk@suse.de> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Dave Jones <davej@codemonkey.org.uk>
2006-12-07[PATCH] paravirt: header and stubs for paravirtualisationRusty Russell
Create a paravirt.h header for all the critical operations which need to be replaced with hypervisor calls, and include that instead of defining native operations, when CONFIG_PARAVIRT. This patch does the dumbest possible replacement of paravirtualized instructions: calls through a "paravirt_ops" structure. Currently these are function implementations of native hardware: hypervisors will override the ops structure with their own variants. All the pv-ops functions are declared "fastcall" so that a specific register-based ABI is used, to make inlining assember easier. And: +From: Andy Whitcroft <apw@shadowen.org> The paravirt ops introduce a 'weak' attribute onto memory_setup(). Code ordering leads to the following warnings on x86: arch/i386/kernel/setup.c:651: warning: weak declaration of `memory_setup' after first use results in unspecified behavior Move memory_setup() to avoid this. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andy Whitcroft <apw@shadowen.org>
2006-06-23[PATCH] Don't trigger full rebuild via CONFIG_X86_MCEAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Don't trigger full rebuild via CONFIG_MTRRAlexey Dobriyan
Only drm, framebuffer, mtrr parts + misc files here and there. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-23[PATCH] swsusp: fix typo in cr0 handlingPavel Machek
Writing cr0 to cr2 register can't be right. This fixes the typo. I wonder how it could survive so long. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] x86: add MCE resumeShaohua Li
It's widely seen a MCE non-fatal error reported after resume. It seems MCE resume is lacked under ia32. This patch tries to fix the gap. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] FPU context corrupted after resumeShaohua Li
mxcsr_feature_mask_init isn't needed in suspend/resume time (we can use boot time mask). And actually it's harmful, as it clear task's saved fxsave in resume. This bug is widely seen by users using zsh. (akpm: my eyes. Fixed some surrounding whitespace mess) Signed-off-by: Shaohua Li<shaohua.li@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] useless includes of linux/irq.h in arch/i386Al Viro
Most of these guys are simply not needed (pulled by other stuff via asm-i386/hardirq.h). One that is not entirely useless is hilarious - arch/i386/oprofile/nmi_timer_int.c includes linux/irq.h... as a way to get linux/errno.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: remove redundant TSS clearingZachary Amsden
When reviewing GDT updates, I found the code: set_tss_desc(cpu,t); /* This just modifies memory; ... */ per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS].b &= 0xfffffdff; This second line is unnecessary, since set_tss_desc() has already cleared the busy bit. Commented disassembly, line 1: c028b8bd: 8b 0c 86 mov (%esi,%eax,4),%ecx c028b8c0: 01 cb add %ecx,%ebx c028b8c2: 8d 0c 39 lea (%ecx,%edi,1),%ecx => %ecx = per_cpu(cpu_gdt_table, cpu) c028b8c5: 8d 91 80 00 00 00 lea 0x80(%ecx),%edx => %edx = &per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS] c028b8cb: 66 c7 42 00 73 20 movw $0x2073,0x0(%edx) c028b8d1: 66 89 5a 02 mov %bx,0x2(%edx) c028b8d5: c1 cb 10 ror $0x10,%ebx c028b8d8: 88 5a 04 mov %bl,0x4(%edx) c028b8db: c6 42 05 89 movb $0x89,0x5(%edx) => ((char *)%edx)[5] = 0x89 (equivalent) ((char *)per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS])[5] = 0x89 c028b8df: c6 42 06 00 movb $0x0,0x6(%edx) c028b8e3: 88 7a 07 mov %bh,0x7(%edx) c028b8e6: c1 cb 10 ror $0x10,%ebx => other bits Commented disassembly, line 2: c028b8e9: 8b 14 86 mov (%esi,%eax,4),%edx c028b8ec: 8d 04 3a lea (%edx,%edi,1),%eax => %eax = per_cpu(cpu_gdt_table, cpu) c028b8ef: 81 a0 84 00 00 00 ff andl $0xfffffdff,0x84(%eax) => per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS].b &= 0xfffffdff; (equivalent) ((char *)per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS])[5] &= 0xfd Note that (0x89 & ~0xfd) == 0; i.e, set_tss_desc(cpu,t) has already stored the type field in the GDT with the busy bit clear. Eliminating redundant and obscure code is always a good thing; in fact, I pointed out this same optimization many moons ago in arch/i386/setup.c, back when it used to be called that. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: inline assembler: cleanup and encapsulate descriptor and task ↵Zachary Amsden
register management i386 inline assembler cleanup. This change encapsulates descriptor and task register management. Also, it is possible to improve assembler generation in two cases; savesegment may store the value in a register instead of a memory location, which allows GCC to optimize stack variables into registers, and MOV MEM, SEG is always a 16-bit write to memory, making the casting in math-emu unnecessary. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: inline asm cleanupZachary Amsden
i386 Inline asm cleanup. Use cr/dr accessor functions. Also, a potential bugfix. Also, some CR accessors really should be volatile. Reads from CR0 (numeric state may change in an exception handler), writes to CR4 (flipping CR4.TSD) and reads from CR2 (page fault) prevent instruction re-ordering. I did not add memory clobber to CR3 / CR4 / CR0 updates, as it was not there to begin with, and in no case should kernel memory be clobbered, except when doing a TLB flush, which already has memory clobber. I noticed that page invalidation does not have a memory clobber. I can't find a bug as a result, but there is definitely a potential for a bug here: #define __flush_tlb_single(addr) \ __asm__ __volatile__("invlpg %0": :"m" (*(char *) addr)) Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] MTRR suspend/resume cleanupShaohua Li
There has been some discuss about solving the SMP MTRR suspend/resume breakage, but I didn't find a patch for it. This is an intent for it. The basic idea is moving mtrr initializing into cpu_identify for all APs (so it works for cpu hotplug). For BP, restore_processor_state is responsible for restoring MTRR. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] swsusp: clean assembly partsPavel Machek
This patch fixes register saving so that each register is only saved once, and adds missing saving of %cr8 on x86-64. Some reordering so that save/restore is more logical/safer (segment registers should be restored after gdt). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sep initializing reworkLi Shaohua
Make SEP init per-cpu, so it is hotplug safe. Signed-off-by: Li Shaohua<shaohua.li@intel.com> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] xen: x86: Use new macro for debugregVincent Hanquez
Make use of the 2 new macro set_debugreg and get_debugreg. Signed-off-by: Vincent Hanquez <vincent.hanquez@cl.cam.ac.uk> Cc: Ian Pratt <m+Ian.Pratt@cl.cam.ac.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
