path: root/arch/i386
2007-09-19xen: don't bother trying to set cr4Jeremy Fitzhardinge
Xen ignores all updates to cr4, and some versions will kill the domain if you try to change its value. Just ignore all changes. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-12i386: Fix leak of ../kernel from top levelAndi Kleen
Fix a compile error when the directory above the kernel source contains a file named "kernel". Originally from Ben LaHaise, modified based on feedback from Sam Ravnborg Signed-off-by: Andi Kleen <ak@suse.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Ben LaHaise <bcrl@kvack.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-12x86_64: Prevent doing anything from cache_remove_dev() when info setup failed.Andi Kleen
AK: Removed the unlikelies because gcc heuristics default to unlikely AK: for test == NULL and for negative returns. Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11revert "highmem: catch illegal nesting"Andrew Morton
Revert commit 656dad312fb41ed95ef08325e9df9bece3aacbbb Author: Ingo Molnar <mingo@elte.hu> Date: Sat Feb 10 01:46:36 2007 -0800 [PATCH] highmem: catch illegal nesting Catch illegally nested kmap_atomic()s even if the page that is mapped by the 'inner' instance is from lowmem. This avoids spuriously zapped kmap-atomic ptes and turns hard to find crashes into clear asserts at the bug site. Problem is, a get_zeroed_page(GFP_KERNEL) from interrupt context will trigger this check if non-irq code on this CPU holds a KM_USER0 mapping. But that get_zeroed_page() will never be altering the kmap slot anyway due to the GFP_KERNEL. Cc: Christoph Lameter <clameter@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11PCI: irq and pci_ids patch for Intel TolapaiJason Gaston
This patch adds the Intel Tolapai LPC and SMBus Controller DID's. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11PCI: Remove __devinit from pcibios_get_irq_routing_tableRalf Baechle
pcibios_get_irq_routing_table is an exported symbol. This results in a modpost warning: WARNING: vmlinux.o(.text+0xdca51): Section mismatch: reference to .init.text:pcibios_fixup_bus (between 'pci_scan_child_bus' and 'pci_scan_bus_parented') Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-10i386: fix a hang on stuck nmi watchdogDaniel Walker
In the case when an nmi gets stucks the endflag stays equal to zero. This causes the busy looping on other cpus to continue, even though the nmi test is done. On my machine with out the change below the system would hang right after check_nmi_watchdog(). The change below just sets endflag prior to checking if the test was successful or not. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-10x86_64: Remove CLFLUSH in text_poke()Andi Kleen
The CLFLUSH for the modified code line in text_poke was supposed to speed up CPU recovery. Unfortunately it seems to cause hangs on some VIA C3s (at least on VIA Esther Model 10 Stepping 9) Remove it. Thanks to Stefan Becker for reporting/testing. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-10i386: Fix perfctr watchdog on core duoStephane Eranian
Fix the NMI watchdog on Intel CoreDuo processor where the kernel would get stuck during boot. The issue is related to errata AE49, where the PERFEVTSEL1 counter does not have a working enable bit. Thus it is not possible to use it for NMI. The patch creates a dedicated wd_ops for CoreDuo which falls back to using PERFEVTSEL0. The other Intel processors supporting the architectural PMU will keep on using PERFEVTSEL1 as this allows other subsystems, such as perfmon, to use PERFEVTSEL0 for PEBS monitoring in particular. Bug initially reported by Daniel Walker. AK: Added comments Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-10Fix spurious syscall tracing after PTRACE_DETACH + PTRACE_ATTACHRoland McGrath
When PTRACE_SYSCALL was used and then PTRACE_DETACH is used, the TIF_SYSCALL_TRACE flag is left set on the formerly-traced task. This means that when a new tracer comes along and does PTRACE_ATTACH, it's possible he gets a syscall tracing stop even though he's never used PTRACE_SYSCALL. This happens if the task was in the middle of a system call when the second PTRACE_ATTACH was done. The symptom is an unexpected SIGTRAP when the tracer thinks that only SIGSTOP should have been provoked by his ptrace calls so far. A few machines already fixed this in ptrace_disable (i386, ia64, m68k). But all other machines do not, and still have this bug. On x86_64, this constitutes a regression in IA32 compatibility support. Since all machines now use TIF_SYSCALL_TRACE for this, I put the clearing of TIF_SYSCALL_TRACE in the generic ptrace_detach code rather than adding it to every other machine's ptrace_disable. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-05[x86 setup] Work around bug in Xen HVMChristian Ehrhardt
Apparently XEN does not keep the contents of the 48-bit gdt_48 data structure that is passed to lgdt in the XEN machine state. Instead it appears to save the _address_ of the 48-bit descriptor somewhere. Unfortunately this data happens to reside on the stack and is probably no longer availiable at the time of the actual protected mode jump. This is Xen bug but given that there is a one-line patch to work around this problem, the linux kernel should probably do this. My fix is to make the gdt_48 description in setup_gdt static (in setup_idt this is already the case). This allows the kernel to boot under Xen HVM again. Signed-off-by: Christian Ehrhardt <lk@c--e.de> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup: [x86 setup] Don't rely on the VESA BIOS being register-clean
2007-08-31x86: be even more careful about checking the stack frame on dumpingLinus Torvalds
lguest didn't initialize the kernel stack the way a real i386 kernel does, and ended up triggering a corner-case in the stack frame checking that doesn't happen on naive i386, and that the stack dumping didn't handle quite right. This makes the frame handling more correct, and tries to clarify the code at the same time so that it's a bit more obvious what is going on. Thanks to Rusty Russell for debugging the lguest failure- Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31[x86 setup] Don't rely on the VESA BIOS being register-cleanH. Peter Anvin
The VESA BIOS is specified to be register-clean. However, we have now found at least one system which violates that. Thus, be as paranoid about VESA calls as about everything else. Huge thanks to Will Simoneau for reporting, diagnosing, and testing this out on Dell Inspiron 5150. Cc: Will Simoneau <simoneau@ele.uri.edu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-31hugepage: fix broken check for offset alignment in hugepage mappingsDavid Gibson
For hugepage mappings, the file offset, like the address and size, needs to be aligned to the size of a hugepage. In commit 68589bc353037f233fe510ad9ff432338c95db66, the check for this was moved into prepare_hugepage_range() along with the address and size checks. But since BenH's rework of the get_unmapped_area() paths leading up to commit 4b1d89290b62bb2db476c94c82cf7442aab440c8, prepare_hugepage_range() is only called for MAP_FIXED mappings, not for other mappings. This means we're no longer ever checking for an aligned offset - I've confirmed that mmap() will (apparently) succeed with a misaligned offset on both powerpc and i386 at least. This patch restores the check, removing it from prepare_hugepage_range() and putting it back into hugetlbfs_file_mmap(). I'm putting it there, rather than in the get_unmapped_area() path so it only needs to go in one place, than separately in the half-dozen or so arch-specific implementations of hugetlb_get_unmapped_area(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-25Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (30 commits) ACPI: work around duplicate name "VID" problem on T61 acpiphp_ibm: add missing '\n' to error message ACPI: add dump_stack() to trace acpi_format_exception programming errors make drivers/acpi/scan.c:create_modalias() static ACPI: Fix a warning of discarding qualifiers from pointer target type ACPI: "ACPI handle has no context!" should be KERN_DEBUG ACPI video hotkey: export missing ACPI video hotkey events via input layer ACPI: Validate XSDT, use RSDT if XSDT fails ACPI: /proc/acpi/thermal_zone trip points are now read-only, mark them as such ACPI: fix ia64 allnoconfig build PNP: remove null pointer checks PNP: remove MODULE infrastructure ISAPNP: removed unused isapnp_detected and ISAPNP_DEBUG PNPACPI: remove unnecessary casts of "void *" PNPACPI: simplify irq_flags() PNP: fix up after Lindent ACPI: enable GPEs before calling _WAK on resume asus-laptop: Fix rmmod of asus_laptop sony-laptop: call sonypi_compat_init earlier sony-laptop: enable Vaio FZ events ...
2007-08-24Pull bugzilla-1641 into release branchLen Brown
2007-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup: [x86 setup] Make sure AH=00h when setting a video mode [x86 setup] Volatilize asm() statements
2007-08-23[x86 setup] Make sure AH=00h when setting a video modeH. Peter Anvin
Passing a u8 into a register doesn't mean gcc will zero-extend it. Also, don't depend on thhe register not to change. Per bug report from Saul Tamari. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-23[x86 setup] Volatilize asm() statementsH. Peter Anvin
asm() statements need to be volatile when: a. They have side effects (other than value returned). b. When the value returned can vary over time. c. When they have ordering constraints that cannot be expressed to gcc. In particular, the keyboard and timer reads were violating constraint (b), which resulted in the keyboard/timeout poll getting loop-invariant-removed when compiling with gcc 4.2.0. Thanks to an anonymous bug reporter for pointing this out. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-23sched: sched_clock_idle_[sleep|wakeup]_event()Ingo Molnar
construct a more or less wall-clock time out of sched_clock(), by using ACPI-idle's existing knowledge about how much time we spent idling. This allows the rq clock to work around TSC-stops-in-C2, TSC-gets-corrupted-in-C3 type of problems. ( Besides the scheduler's statistics this also benefits blktrace and printk-timestamps as well. ) Furthermore, the precise before-C2/C3-sleep and after-C2/C3-wakeup callbacks allow the scheduler to get out the most of the period where the CPU has a reliable TSC. This results in slightly more precise task statistics. the ACPI bits were acked by Len. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Len Brown <len.brown@intel.com>
2007-08-22Xen i386 xen-head.S fix sections mixupMathieu Desnoyers
Xen i386 xen-head.S fix sections mixup xen-head.S does not come back to the data section, leaving the text section as current section. It causes problems with a slightly enhanced DEBUG_RODATA that supports CONFIG_HOTPLUG and bringing a CPU up after the text has been marked read-only: reference to early_gdt_descr causes a page fault. Updates: - It should be using pushsection/popsection. - Actually, the push/popsections around the ELFNOTEs are redundant; ELFNOTE() does its own push/popsection to put things into the appropriate .note* section anyway. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Fix lazy mode vmalloc synchronization for paravirtZachary Amsden
Touching vmalloc memory in the middle of a lazy mode update can generate a kernel PDE update, which must be flushed immediately. The fix is to leave lazy mode when doing a vmalloc sync. Signed-off-by: Zachary Amsden <zach@vmware.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-21i386: Mark NUMA support experimentalAndi Kleen
I did some testing and found quite a lot of problems (doesn't boot at all on non NUMA and misassigns cores on Opteron systems). Mark it as experimental and warn against its use for now. It's still default y for SUMMIT/NUMAQ because it'll presumably work on these systems. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-21ACPI: boot correctly with "nosmp" or "maxcpus=0"Len Brown
In MPS mode, "nosmp" and "maxcpus=0" boot a UP kernel with IOAPIC disabled. However, in ACPI mode, these parameters didn't completely disable the IO APIC initialization code and boot failed. init/main.c: Disable the IO_APIC if "nosmp" or "maxcpus=0" undefine disable_ioapic_setup() when it doesn't apply. i386: delete ioapic_setup(), it was a duplicate of parse_noapic() delete undefinition of disable_ioapic_setup() x86_64: rename disable_ioapic_setup() to parse_noapic() to match i386 define disable_ioapic_setup() in header to match i386 http://bugzilla.kernel.org/show_bug.cgi?id=1641 Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-18x86: properly initialize temp insn buffer for paravirt patchingChris Wright
With commit ab144f5ec64c42218a555ec1dbde6b60cf2982d6 the patching code now collects the complete new instruction stream into a temp buffer before finally patching in the new insns. In some cases the paravirt patchers will choose to leave the patch site unpatched (length mismatch, clobbers mismatch, etc). This causes the new patching code to copy an uninitialized temp buffer, i.e. garbage, to the callsite. Simply make sure to always initialize the buffer with the original instruction stream. A better fix is to audit all the patchers and return proper length so that apply_paravirt() can skip copies when we leave the patch site untouched. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-18x86_64: Check for .cfi_rel_offset in CFI probeAndi Kleen
Very old 64bit binutils have .cfi_startproc/endproc, but no .cfi_rel_offset. Check for .cfi_rel_offset too. Cc: Jan Beulich <jbeulich@novell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-18x86_64: Fix to keep watchdog disabled by default for i386/x86_64Daniel Gollub
Fixed wrong expression which enabled watchdogs even if nmi_watchdog kernel parameter wasn't set. This regression got slightly introduced with commit b7471c6da94d30d3deadc55986cc38d1ff57f9ca. Introduced NMI_DISABLED (-1) which allows to switch the value of NMI_DEFAULT without breaking the APIC NMI watchdog code (again). Fixes: https://bugzilla.novell.com/show_bug.cgi?id=298084 http://bugzilla.kernel.org/show_bug.cgi?id=7839 And likely some more nmi_watchdog=0 related issues. Signed-off-by: Daniel Gollub <dgollub@suse.de> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-18Add some help texts to recently-introduced kconfig itemsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (edited MACINTOSH_DRIVERS per Geert Uytterhoeven's remark) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-14[x86 setup] edd.c: make sure MBR signatures actually get reportedH. Peter Anvin
When filling in the MBR signature array, the setup code failed to advance boot_params.edd_mbr_sig_buf_entries, which resulted in the valid data being ignored. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-14[x86 setup] Don't use EDD to get the MBR signatureH. Peter Anvin
At least one machine has been identified in the field which advertises EDD for all drives but locks up if one attempts an extended read from a non-primary drive. The MBR is always at CHS 0-0-1, so there is no reason to use an extended read, other than the possibility that the BIOS cannot handle it. Although this might break as many machines as it fixes (a small number either way), the current state is a regression but the reverse is not. Therefore revert to the previous state of not using extended read. Quite probably the Right Thing to do is to read using plain (CHS) read and extended read on failure, but that change would definitely have to go through -mm first. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-14[x86 setup] The current display page is returned in %bh, not %blH. Peter Anvin
The current display page is an 8-bit number, even though struct screen_info gives it a 16-bit number. The number is returned in %bh, so it needs to be >> 8 before storing. Special thanks to Jeff Chua for detailed bug reporting. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-12genirq: mark io_apic level interrupts to avoid resendThomas Gleixner
Level type interrupts do not need to be resent. It was also found that some chipsets get confused in case of the resend. Mark the ioapic level type interrupts as such to avoid the resend functionality in the generic irq code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-12Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (28 commits) ACPI: thermal: add DMI hooks to handle AOpen's broken Award BIOS ACPI: thermal: create "thermal.act=" to disable or override active trip point ACPI: thermal: create "thermal.nocrt" to disable critical actions ACPI: thermal: create "thermal.psv=" to override passive trip points ACPI: thermal: expose "thermal.tzp=" to set global polling frequency ACPI: thermal: create "thermal.off=1" to disable ACPI thermal support ACPI: thinkpad-acpi: fix sysfs paths in documentation ACPI: static ACPI EC: remove potential deadlock from EC ACPI: dock: Send key=value pair instead of plain value ACPI: bay: send envp with uevent - fix acpi-cpufreq: Fix some x86/x86-64 acpi-cpufreq driver issues ACPI: fix "Time Problems with 2.6.23-rc1-gf695baf2" ACPI: thinkpad-acpi: change thinkpad-acpi input default and kconfig help ACPI: EC: fix run-together printk lines ACPI: sbs: remove dead code ACPI: EC: acpi_ec_remove(): fix use-after-free ACPI: EC: Switch from boot_ec as soon as we find its desc in DSDT. ACPI: EC: fix build warning ACPI: EC: If ECDT is not found, look up EC in DSDT. ...
2007-08-12i386: Fix broken mmiocfg accessesLinus Torvalds
Commit 3320ad994afb2c44ad34b3b34c3c5cf0da297331 broke mmio config space accesses totally on i386 - it dropped the "reg" offset to the address. Cc: dean gaudet <dean@arctic.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-12Pull processor into release branchLen Brown
2007-08-11i386: Fix double fault handlerChuck Ebbert
The new percpu code has apparently broken the doublefault handler when CONFIG_DEBUG_SPINLOCK is set. Doublefault is handled by a hardware task, making the check SPIN_BUG_ON(lock->owner == current, lock, "recursion"); fault because it uses the FS register to access the percpu data for current, and that register is zero in the new TSS. (The trace I saw was on 2.6.20 where it was GS, but it looks like this will still happen with FS on 2.6.22.) Initializing FS in the doublefault_tss should fix it. AK: Also fix broken ptr_ok() and turn printks into KERN_EMERG AK: And add a PANIC prefix to make clear the system will hang AK: (e.g. x86-64 will recover) Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11i386: Fix start_kernel warningAndi Kleen
Fix WARNING: vmlinux.o(.text+0x183): Section mismatch: reference to .init.text:start_kernel (between 'is386' and 'check_x87') Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11i386: Use global flag to disable broken local apic timer on AMD CPUs.Andi Kleen
The Averatec 2370 and some other Turion laptop BIOS seems to program the ENABLE_C1E MSR inconsistently between cores. This confuses the lapic use heuristics because when C1E is enabled anywhere it seems to affect the complete chip. Use a global flag instead of a per cpu flag to handle this. If any CPU has C1E enabled disabled lapic use. Thanks to Cal Peake for debugging. Cc: tglx@linutronix.de Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11i386: really stop MCEs during code patchingAdrian Bunk
It's CONFIG_X86_MCE, not CONFIG_MCE. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11i386: Make patching more robust, fix paravirt issueAndi Kleen
Commit 19d36ccdc34f5ed444f8a6af0cbfdb6790eb1177 "x86: Fix alternatives and kprobes to remap write-protected kernel text" uses code which is being patched for patching. In particular, paravirt_ops does patching in two stages: first it calls paravirt_ops.patch, then it fills any remaining instructions with nop_out(). nop_out calls text_poke() which calls lookup_address() which calls pgd_val() (aka paravirt_ops.pgd_val): that call site is one of the places we patch. If we always do patching as one single call to text_poke(), we only need make sure we're not patching the memcpy in text_poke itself. This means the prototype to paravirt_ops.patch needs to change, to marshal the new code into a buffer rather than patching in place as it does now. It also means all patching goes through text_poke(), which is known to be safe (apply_alternatives is also changed to make a single patch). AK: fix compilation on x86-64 (bad rusty!) AK: fix boot on x86-64 (sigh) AK: merged with other patches Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11x86: Disable CLFLUSH support againAndi Kleen
It turns out CLFLUSH support is still not complete; we flush the wrong pages. Again disable it for the release. Noticed by Jan Beulich who then also noticed a stupid typo later. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11x86: Work around mmio config space quirk on AMD Fam10hdean gaudet
Some broken devices have been discovered to require %al/%ax/%eax registers for MMIO config space accesses. Modify mmconfig.c to use these registers explicitly (rather than modify the global readb/writeb/etc inlines). AK: also changed i386 to always use eax AK: moved change to extended space probing to different patch AK: reworked with inlines according to Linus' requirements. AK: improve comments. Signed-off-by: dean gaudet <dean@arctic.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11finish i386 and x86-64 sysdata conversionMuli Ben-Yehuda
This patch finishes the i386 and x86-64 ->sysdata conversion and hopefully also fixes Riku's and Andy's observed bugs. It is based on Yinghai Lu's and Andy Whitcroft's patches (thanks!) with some changes: - introduce pci_scan_bus_with_sysdata() and use it instead of pci_scan_bus() where appropriate. pci_scan_bus_with_sysdata() will allocate the sysdata structure and then call pci_scan_bus(). - always allocate pci_sysdata dynamically. The whole point of this sysdata work is to make it easy to do root-bus specific things (e.g., support PCI domains and IOMMU's). I dislike using a default struct pci_sysdata in some places and a dynamically allocated pci_sysdata elsewhere - the potential for someone indavertantly changing the default structure is too high. - this patch only makes the minimal changes necessary, i.e., the NUMA node is always initialized to -1. Patches to do the right thing with regards to the NUMA node can build on top of this (either add a 'node' parameter to pci_scan_bus_with_sysdata() or just update the node when it becomes known). The patch was compile tested with various configurations (e.g., NUMAQ, VISWS) and run-time tested on i386 and x86-64. Unfortunately none of my machines exhibited the bugs so caveat emptor. Andy, could you please see if this fixes the NUMA issues you've seen? Riku, does this fix "pci=noacpi" on your laptop? Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: <riku.seppala@kymp.net> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-07acpi-cpufreq: Fix some x86/x86-64 acpi-cpufreq driver issuesFenghua Yu
This patch addresses some issues in x86/x86-64 acpi-cpufreq driver: 1. Current memory allocation for acpi_perf_data is actually open-coded alloc_percpu(). The patch defines and handles acpi_perf_data as percpu data. The code will be cleaner and easier to be maintained with this change. 2. Won't load driver in acpi_cpufreq_early_init() failure case. 3. Add __init for acpi_cpufreq_early_init(). Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-02[x86 setup] EDD: add missing =m constraintH. Peter Anvin
Add a missing =m constraint to the EDD-probing code, that could have caused improper dead-code elimination. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-08-02[x86 setup] video setup: Fix VBE DDC readingAntonino A. Daplas
Add memory operand constraint and write-only modifier to the inline assembly to effect the writing of the EDID block to boot_params.edid_info. Without this, gcc would think the EDID query was dead code and would eliminate it. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hpa/linux-2.6-x86setup: [x86 setup] EDD: Fix the computation of the MBR sector buffer [x86 setup] Newline after setup signature failure message x86 boot code comments typos
2007-07-31i386: include asm/bugs.h in bugs.c for check_bugs prototypeJosh Triplett
C files should include the header files that prototype their functions. Eliminates a sparse warning: warning: symbol 'check_bugs' was not declared. Should it be static? Signed-off-by: Josh Triplett <josh@kernel.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Remove one more leftover reference to devfsMichael Tokarev
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
