path: root/arch/ia64/Kconfig
2008-05-14[IA64] machvec support for SGI UV platformJack Steiner
This patch adds the basic IA64 machvec infrastructure to support the SGI "UV" platform. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29dma: add dma_*map*_attrs() interfacesArthur Kepner
Introduce new interfaces, dma_*map*_attrs(), for passing architecture-specific attributes when memory is mapped and unmapped for DMA. Give the interfaces default implementations which ignore attributes. Also introduce the dma_{set|get}_attr() interfaces for setting and retrieving individual attributes. Define one attribute, DMA_ATTR_WRITE_BARRIER, in anticipation of its use by ia64/sn. Select whether architectures implement arch-specific versions of the dma_*map*_attrs() interfaces via HAVE_DMA_ATTRS in Kconfig. [markn@au1.ibm.com: dma_{set,get}_attr() have to be static inline] Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27KVM: ia64: Enable kvm build for ia64Xiantao Zhang
Update the related Makefile and KConfig for kvm build Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-17Pull miscellaneous into release branchTony Luck
Conflicts: arch/ia64/kernel/mca.c
2008-04-17Pull virt-cpu-accounting into release branchTony Luck
2008-04-09[IA64] make IOMMU respect the segment boundary limitsFUJITA Tomonori
IA64's IOMMU implementation allocates memory areas spanning LLD's segment boundary limit. It forces low level drivers to have a workaround to adjust scatter lists that the IOMMU builds. We are in the process of making all the IOMMUs respect the segment boundary limits to remove such work around in LLDs. This patch is for IA64's IOMMU. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix ia64 kprobes compilation [IA64] move gcc_intrin.h from header-y to unifdef-y [IA64] workaround tiger ia64_sal_get_physical_id_info hang [IA64] move defconfig to arch/ia64/configs/ [IA64] Fix irq migration in multiple vector domain [IA64] signal(ia64_ia32): add a signal stack overflow check [IA64] signal(ia64): add a signal stack overflow check [IA64] CONFIG_SGI_SN2 - auto select NUMA and ACPI_NUMA
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04[IA64] CONFIG_SGI_SN2 - auto select NUMA and ACPI_NUMAJes Sorensen
Auto select CONFIG_NUMA and CONFIG_ACPI_NUMA when picking SN2, similar to how they are selected automatically for CONFIG_IA64_GENERIC. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-20[IA64] VIRT_CPU_ACCOUNTING (accurate cpu time accounting)Hidetoshi Seto
This patch implements VIRT_CPU_ACCOUNTING for ia64, which enable us to use more accurate cpu time accounting. The VIRT_CPU_ACCOUNTING is an item of kernel config, which s390 and powerpc arch have. By turning this config on, these archs change the mechanism of cpu time accounting from tick-sampling based one to state-transition based one. The state-transition based accounting is done by checking time (cycle counter in processor) at every state-transition point, such as entrance/exit of kernel, interrupt, softirq etc. The difference between point to point is the actual time consumed during in the state. There is no doubt about that this value is more accurate than that of tick-sampling based accounting. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-11[IA64] Fix build for sim_defconfigTony Luck
Commit bdc807871d58285737d50dc6163d0feb72cb0dc2 broke the build for this config because the sim_defconfig selects CONFIG_HZ=250 but include/asm-ia64/param.h has an ifdef for the simulator to force HZ to 32. So we ended up with a kernel/timeconst.h set for HZ=250 ... which then failed the check for the right HZ value and died with: Drop the #ifdef magic from param.h and make force CONFIG_HZ=32 directly for the simulator. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03remove Documentation/smp.txtAdrian Bunk
After seeing the filename I'd have expected something about the implementation of SMP in the Linux kernel - not some notes on kernel configuration and building trivialities noone would search at this place. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03Add HAVE_KPROBESMathieu Desnoyers
Linus: On the per-architecture side, I do think it would be better to *not* have internal architecture knowledge in a generic file, and as such a line like depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32 really shouldn't exist in a file like kernel/Kconfig.instrumentation. It would be much better to do depends on ARCH_SUPPORTS_KPROBES in that generic file, and then architectures that do support it would just have a bool ARCH_SUPPORTS_KPROBES default y in *their* architecture files. That would seem to be much more logical, and is readable both for arch maintainers *and* for people who have no clue - and don't care - about which architecture is supposed to support which interface... Changelog: Actually, I know I gave this as the magic incantation, but now that I see it, I realize that I should have told you to just use config KPROBES_SUPPORT def_bool y instead, which is a bit denser. We seem to use both kinds of syntax for these things, but this is really what "def_bool" is there for... - Use HAVE_KPROBES - Use a select - Yet another update : Moving to HAVE_* now. - Update ARM for kprobes support. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03Add HAVE_OPROFILEMathieu Desnoyers
Linus: On the per-architecture side, I do think it would be better to *not* have internal architecture knowledge in a generic file, and as such a line like depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32 really shouldn't exist in a file like kernel/Kconfig.instrumentation. It would be much better to do depends on ARCH_SUPPORTS_KPROBES in that generic file, and then architectures that do support it would just have a bool ARCH_SUPPORTS_KPROBES default y in *their* architecture files. That would seem to be much more logical, and is readable both for arch maintainers *and* for people who have no clue - and don't care - about which architecture is supposed to support which interface... Changelog: Actually, I know I gave this as the magic incantation, but now that I see it, I realize that I should have told you to just use config ARCH_SUPPORTS_KPROBES def_bool y instead, which is a bit denser. We seem to use both kinds of syntax for these things, but this is really what "def_bool" is there for... Changelog : - Moving to HAVE_*. - Add AVR32 oprofile. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-30percpu: change Kconfig to HAVE_SETUP_PER_CPU_AREAtravis@sgi.com
Change: config ARCH_SETS_UP_PER_CPU_AREA to: config HAVE_SETUP_PER_CPU_AREA Cc: Andi Kleen <ak@suse.de> Cc: Tony Luck <tony.luck@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: linuxppc-dev@ozlabs.org Cc: linux-ia64@vger.kernel.org Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30percpu: use a kconfig variable to signal arch specific percpu setuptravis@sgi.com
The use of the __GENERIC_PERCPU is a bit problematic since arches may want to run their own percpu setup while using the generic percpu definitions. Replace it through a kconfig variable. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30spinlock: lockbreak cleanupNick Piggin
The break_lock data structure and code for spinlocks is quite nasty. Not only does it double the size of a spinlock but it changes locking to a potentially less optimal trylock. Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a __raw_spin_is_contended that uses the lock data itself to determine whether there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is not set. Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to decouple it from the spinlock implementation, and make it typesafe (rwlocks do not have any need_lockbreak sites -- why do they even get bloated up with that break_lock then?). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17KCONFIG: Make "Instrumentation support" non-EXPERIMENTALRobert P. J. Day
It makes more sense to make instrumentation support experimental on a case-by-case basis. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: page offlineKAMEZAWA Hiroyuki
Logic. - set all pages in [start,end) as isolated migration-type. by this, all free pages in the range will be not-for-use. - Migrate all LRU pages in the range. - Test all pages in the range's refcnt is zero or not. Todo: - allocate migration destination page from better area. - confirm page_count(page)== 0 && PageReserved(page) page is safe to be freed.. (I don't like this kind of page but.. - Find out pages which cannot be migrated. - more running tests. - Use reclaim for unplugging other memory type area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Do not depend on MAX_ORDER when grouping pages by mobilityMel Gorman
Currently mobility grouping works at the MAX_ORDER_NR_PAGES level. This makes sense for the majority of users where this is also the huge page size. However, on platforms like ia64 where the huge page size is runtime configurable it is desirable to group at a lower order. On x86_64 and occasionally on x86, the hugepage size may not always be MAX_ORDER_NR_PAGES. This patch groups pages together based on the value of HUGETLB_PAGE_ORDER. It uses a compile-time constant if possible and a variable where the huge page size is runtime configurable. It is assumed that grouping should be done at the lowest sensible order and that the user would not want to override this. If this is not true, page_block order could be forced to a variable initialised via a boot-time kernel parameter. One potential issue with this patch is that IA64 now parses hugepagesz with early_param() instead of __setup(). __setup() is called after the memory allocator has been initialised and the pageblock bitmaps already setup. In tests on one IA64 there did not seem to be any problem with using early_param() and in fact may be more correct as it guarantees the parameter is handled before the parsing of hugepages=. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16IA64: SPARSEMEM_VMEMMAP 16K page size supportChristoph Lameter
Equip IA64 sparsemem with a virtual memmap. This is similar to the existing CONFIG_VIRTUAL_MEM_MAP functionality for DISCONTIGMEM. It uses a PAGE_SIZE mapping. This is provided as a minimally intrusive solution. We split the 128TB VMALLOC area into two 64TB areas and use one for the virtual memmap. This should replace CONFIG_VIRTUAL_MEM_MAP long term. [apw@shadowen.org: convert to new helper based initialisation] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[IA64] add driver for ACPI methods to call native firmwareBjorn Helgaas
This driver for HPQ5001 devices installs a global ACPI OpRegion handler. AML methods can use this OpRegion to call native firmware entry points. ACPI does not define a mechanism for AML methods to call native firmware interfaces such as PAL or SAL. This OpRegion handler adds such a mechanism. After the handler is installed, an AML method can call native firmware by storing the arguments and firmware entry point to specific offsets in the OpRegion. When AML reads the "return value" offset from the OpRegion, this handler loads up the arguments, makes the firmware call, and returns the result. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-08-13[IA64] Include Kconfig.preemptSatyam Sharma
arch/ia64/Kconfig failed to include kernel/Kconfig.preempt that meant it did not support PREEMPT_VOLUNTARY and PREEMPT_BKL (inadvertently). This was recently noticed when the newly-added PREEMPT_NOTIFIERS in Kconfig.preempt that was "select"ed from drivers/kvm/Kconfig (therefore) started giving bogus warnings ('select' used by config symbol 'KVM' refers to undefined symbol 'PREEMPT_NOTIFIERS') on ia64 builds. So let's remove the open-coded definition of CONFIG_PREEMPT in arch/ia64/Kconfig and replace it with just including Kconfig.preempt instead, like the other archs do. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-27[IA64] Fix build failure in fs/quota.cTony Luck
b716395e2b8e450e294537de0c91476ded2f0395 added code to handle a compatability issue with 32bit quota tools, but the new compat routines are only needed when CONFIG_COMPAT=y (and with this set to 'n' there are compilation problems since some new typedefs are not visible). Reported by Doug Chapman. Fix tuned by a cast of thousands (Andi, Andreas, Arthur, HPA, Willy) Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-20[IA64] Convert to generic timekeeping/clocksourceTony Luck
This is a merge of Peter Keilty's initial patch (which was revived by Bob Picco) for this with Hidetoshi Seto's fixes and scaling improvements. Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-17Kprobes on select architectures no longer EXPERIMENTALAnanth N Mavinakayanahalli
Based on usage and testing over the past couple of years, kprobes on i386, ia64, powerpc and x86_64 is no longer EXPERIMENTAL. This is a follow-up to Robert P.J. Day's patch making "Instrumentation support" non-EXPERIMENTAL: http://marc.info/?l=linux-kernel&m=118396955423812&w=2 Arch maintainers for sparc64, avr32 and s390 need to take a similar call. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Only build PCI syscalls on architectures that want themMatthew Wilcox
The PCI syscalls are built on every architecture except X86, but only a few have ever hooked them up. Use a new Kconfig symbol to save a couple of kB on the architectures that have never used the syscalls. Tested on x86 and ia64 only. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-11[IA64] Quicklist support for IA64Christoph Lameter
IA64 is the origin of the quicklist implementation. So cut out the pieces that are now in core code and modify the functions called. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] update memory attribute aliasing documentation & test cases [IA64] fail mmaps that span areas with incompatible attributes [IA64] allow WB /sys/.../legacy_mem mmaps [IA64] make ioremap avoid unsupported attributes [IA64] rename ioremap variables to match i386 [IA64] relax per-cpu TLB requirement to DTC [IA64] remove per-cpu ia64_phys_stacked_size_p8 [IA64] Fix example error injection program [IA64] Itanium MC Error Injection Tool: pal_mc_error_inject() interface [IA64] Itanium MC Error Injection Tool: Makefile changes [IA64] Itanium MC Error Injection Tool: Driver sysfs interface [IA64] Itanium MC Error Injection Tool: Doc and sample application [IA64] Itanium MC Error Injection Tool: Kernel configuration
2007-05-02msi: introduce ARCH_SUPPORTS_MSI Kconfig option (rev2)Dan Williams
Allows architectures to advertise that they support MSI rather than listing each architecture as a PCI_MSI dependency. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-30Pull error-inject into release branchTony Luck
2007-03-19ACPI: IA64: fix allnoconfig buildLen Brown
The evils of Kconfig's select bite us once again... ia64/Kconfig selects ACPI, which depends on PM. But select ignores dependencies, allnoconfig chooses CONFIG_PM=n, and thus the menu of sub-options under ACPI vanish, which breaks the build. Manually select PM along with ACPI for now. Some day, we should delete them both, or fix select. Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-15ATA convert GSI to irq on ia64Zhang, Yanmin
If an ATA drive uses legacy mode, ata driver will choose 14 and 15 as the fixed irq number. On ia64 platform, such numbers are GSI and should be converted to irq vector. Below patch against kernel 2.6.20 fixes it. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-11[PATCH] optional ZONE_DMA: optional ZONE_DMA for ia64Christoph Lameter
ZONE_DMA less operation for IA64 SGI platform Disable ZONE_DMA for SGI SN2. All memory is addressable by all devices and we do not need any special memory pool. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] optional ZONE_DMA: introduce CONFIG_ZONE_DMAChristoph Lameter
This patch simply defines CONFIG_ZONE_DMA for all arches. We later do special things with CONFIG_ZONE_DMA after the VM and an arch are prepared to work without ZONE_DMA. CONFIG_ZONE_DMA can be defined in two ways depending on how an architecture handles ISA DMA. First if CONFIG_GENERIC_ISA_DMA is set by the arch then we know that the arch needs ZONE_DMA because ISA DMA devices are supported. We can catch this in mm/Kconfig and do not need to modify arch code. Second, arches may use ZONE_DMA in an unknown way. We set CONFIG_ZONE_DMA for all arches that do not set CONFIG_GENERIC_ISA_DMA in order to insure backwards compatibility. The arches may later undefine ZONE_DMA if their arch code has been verified to not depend on ZONE_DMA. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05[IA64] Enable SWIOTLB only when neededJan Beulich
Don't force CONFIG_SWIOTLB on when not actually needed (i.e. HP_ZX1 and SGI_SN2). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] fix ACPI Kconfig issuesLen Brown
All IA64 systems except IA64_HP_SIM include ACPI and PCI. So prevent IA64 Kconfigs that try to do irritating things like building PCI without building ACPI. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-01-29[IA64] Itanium MC Error Injection Tool: Kernel configurationFenghua Yu
This patch has kenrel configuration changes for the MC Error Injection Tool. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[IA64] IA64 Kexec/kdumpZou Nan hai
Changes and updates. 1. Remove fake rendz path and related code according to discuss with Khalid Aziz. 2. fc.i offset fix in relocate_kernel.S. 3. iospic shutdown code eoi and mask race fix from Fujitsu. 4. Warm boot hook in machine_kexec to SN SAL code from Jack Steiner. 5. Send slave to SAL slave loop patch from Jay Lan. 6. Kdump on non-recoverable MCA event patch from Jay Lan 7. Use CTL_UNNUMBERED in kdump_on_init sysctl. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-11-13[PATCH] mspec driver build fixJes Sorensen
Fix MSPEC driver to build for non SN2 enabled configs as the driver should work in cached and uncached modes (no fetchop) on these systems. In addition make MSPEC select IA64_UNCACHED_ALLOCATOR, which is required for it and move it to arch/ia64/Kconfig to avoid warnings on non ia64 architectures running allmodconfig. Once the Kconfig code is fixed, we can move it back. Signed-off-by: Jes Sorensen <jes@sgi.com> Cc: Fernando Luis Vzquez Cao <fernando@oss.ntt.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] ia64: select ACPI_NUMA if ACPIKAMEZAWA Hiroyuki
When ACPI && NUMA, pxm_to_node is used and it exists in drivers/acpi/numa.c Tony said: The patch makes sense ... if you pick both of "ACPI" and "NUMA", then you need (and should automatically be given) ACPI_NUMA too. The only open question is whether there is a better way of getting there. Perhaps with less configuration options in the first place? We are heading towards a future where so many systems will be NUMA that there would seem to be little benefit in keeping ACPI_NUMA separate from ACPI ... but perhaps we aren't quite there yet. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com> Cc: Len Brown <lenb@kernel.org> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
