git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits)
ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework
ACPI: fix resource check message
ACPI / Battery: Update information on info notification and resume
ACPI: Drop device flag wake_capable
ACPI: Always check if _PRW is present before trying to evaluate it
ACPI / PM: Check status of power resources under mutexes
ACPI / PM: Rename acpi_power_off_device()
ACPI / PM: Drop acpi_power_nocheck
ACPI / PM: Drop acpi_bus_get_power()
Platform / x86: Make fujitsu_laptop use acpi_bus_update_power()
ACPI / Fan: Rework the handling of power resources
ACPI / PM: Register power resource devices as soon as they are needed
ACPI / PM: Register acpi_power_driver early
ACPI / PM: Add function for updating device power state consistently
ACPI / PM: Add function for device power state initialization
ACPI / PM: Introduce __acpi_bus_get_power()
ACPI / PM: Introduce function for refcounting device power resources
ACPI / PM: Add functions for manipulating lists of power resources
ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes
ACPICA: Update version to 20101209
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
cpuidle/x86/perf: fix power:cpu_idle double end events and throw cpu_idle events from the cpuidle layer
intel_idle: open broadcast clock event
cpuidle: CPUIDLE_FLAG_CHECK_BM is omap3_idle specific
cpuidle: CPUIDLE_FLAG_TLB_FLUSHED is specific to intel_idle
cpuidle: delete unused CPUIDLE_FLAG_SHALLOW, BALANCED, DEEP definitions
SH, cpuidle: delete use of NOP CPUIDLE_FLAGS_SHALLOW
cpuidle: delete NOP CPUIDLE_FLAG_POLL
ACPI: processor_idle: delete use of NOP CPUIDLE_FLAGs
cpuidle: Rename X86 specific idle poll state[0] from C0 to POLL
ACPI, intel_idle: Cleanup idle= internal variables
cpuidle: Make cpuidle_enable_device() call poll_idle_init()
intel_idle: update Sandy Bridge core C-state residency targets
Having four variables for the same thing:
idle_halt, idle_nomwait, force_mwait and boot_option_idle_overrides
is rather confusing and unnecessary complex.
if idle= boot param is passed, only set up one variable:
Introduces following functional changes/fixes:
- intel_idle driver does not register if any idle=xy
boot param is passed.
- processor_idle.c will also not register a cpuidle driver
and get active if idle=halt is passed.
Before a cpuidle driver with one (C1, halt) state got registered
Now the default_idle function will be used which finally uses
the same idle call to enter sleep state (safe_halt()), but
without registering a whole cpuidle driver.
That means idle= param will always avoid cpuidle drivers to register
with one exception (same behavior as before):
idle=nomwait
may still register acpi_idle cpuidle driver, but C1 will not use
mwait, but hlt. This can be a workaround for IO based deeper sleep
states where C1 mwait causes problems.
Signed-off-by: Thomas Renninger <trenn@suse.de>
cc: x86@kernel.org
Signed-off-by: Len Brown <len.brown@intel.com>
IA64 support forces us to abstract the allocation of the kvm structure.
But instead of mixing this up with arch-specific initialization and
doing the same on destruction, split both steps. This allows to move
generic destruction calls into generic code.
It also fixes error clean-up on failures of kvm_create_vm for IA64.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This piggybacks on git commit 8fd524b355daef0945692227e726fb444cebcd4f
("x86: Kill bad_dma_address variable") wherein we use now the
dma_map_ops->mapping_error to check for errors and the standard
check is against DMA_ERROR_CODE. Introduce it to the IA64 world.
CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Although the temporary boot-time ACPI table mappings
were set up with CPU caching enabled, the permanent table
mappings and AML run-time region memory accesses were
set up with ioremap(), which on x86 is a synonym for
ioremap_nocache().
Changing this to ioremap_cache() improves performance as
seen when accessing the tables via acpidump,
or /sys/firmware/acpi/tables. It should also improve
AML run-time performance.
No change on ia64.
Reported-by: Jack Steiner <steiner@sgi.com>
The taskstats interface uses microsecond granularity for the user and
system time values. The conversion from cputime to the taskstats values
uses the cputime_to_msecs primitive which effectively limits the
granularity to milliseconds. Add the cputime_to_usecs primitive for
architectures that have better, more precise CPU time values. Remove
cputime_to_msecs primitive because there are no more users left.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Luck Tony <tony.luck@intel.com>
Cc: Shailabh Nagar <nagar1234@in.ibm.com>
Cc: Shailabh Nagar <nagar@us.ibm.com>
Since we no longer need to provide KM_type, the whole pte_*map_nested()
API is now redundant, remove it.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (22 commits)
Add _addr_lsb field to ia64 siginfo
Fix migration.c compilation on s390
HWPOISON: Remove retry loop for try_to_unmap
HWPOISON: Turn addr_valid from bitfield into char
HWPOISON: Disable DEBUG by default
HWPOISON: Convert pr_debugs to pr_info
HWPOISON: Improve comments in memory-failure.c
x86: HWPOISON: Report correct address granuality for huge hwpoison faults
Encode huge page size for VM_FAULT_HWPOISON errors
Fix build error with !CONFIG_MIGRATION
hugepage: move is_hugepage_on_freelist inside ifdef to avoid warning
Clean up __page_set_anon_rmap
HWPOISON, hugetlb: fix unpoison for hugepage
HWPOISON, hugetlb: soft offlining for hugepage
HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASED
hugetlb: move refcounting in hugepage allocation inside hugetlb_lock
HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page()
hugetlb: hugepage migration core
hugetlb: redefine hugepage copy functions
hugetlb: add allocate function for hugepage migration
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits)
serial8250: ratelimit "too much work" error
serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster
serial: abstraction for 8250 legacy ports
serial/imx: check that the buffer is non-empty before sending it out
serial: mfd: add more baud rates support
jsm: Remove the uart port on errors
Alchemy: Add UART PM methods.
8250: allow platforms to override PM hook.
altera_uart: Don't use plain integer as NULL pointer
altera_uart: Fix missing prototype for registering an early console
altera_uart: Fixup type usage of port flags
altera_uart: Make it possible to use Altera UART and 8250 ports together
altera_uart: Add support for different address strides
altera_uart: Add support for getting mapbase and IRQ from resources
altera_uart: Add support for polling mode (IRQ-less)
serial: Factor out uart_poll_timeout() from 8250 driver
serial: mark the 8250 driver as maintained
serial: 8250: Don't delay after transmitter is ready.
tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver
vcs: invoke the vt update callback when /dev/vcs* is written to
This patch converts ia64 to use asm-generic/ioctls.h instead of its
own version.
The differences between the arch-specific version and the generic
version are as follows:
- The generic version adds TIOCSRS485 and TIOCGRS485, which are unused
by any driver available on this architecture.
- The generic version adds support for termiox
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags:
Fix IRQ flag handling naming
MIPS: Add missing #inclusions of <linux/irq.h>
smc91x: Add missing #inclusion of <linux/irq.h>
Drop a couple of unnecessary asm/system.h inclusions
SH: Add missing consts to sys_execve() declaration
Blackfin: Rename IRQ flags handling functions
Blackfin: Add missing dep to asm/irqflags.h
Blackfin: Rename DES PC2() symbol to avoid collision
Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header
Blackfin: Split PLL code from mach-specific cdef headers
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Cannot use register_percpu_irq() from ia64_mca_init()
[IA64] Initialize interrupts later (from init_IRQ())
[IA64] enable ARCH_DMA_ADDR_T_64BIT
[IA64] ioc3_serial: release resources in error return path
[IA64] Stop using the deprecated __do_IRQ() code path
[IA64] Remove unnecessary casts of private_data in perfmon.c
[IA64] Fix missing iounmap in error path in cyclone.c
[IA64] salinfo: sema_init instead of init_MUTEX
[IA64] xen: use ARRAY_SIZE macro in xen_pv_ops.c
[IA64] Use static const char * const in palinfo.c
[IA64] remove asm/compat.h
[IA64] Add CONFIG_STACKTRACE_SUPPORT
[IA64] Move local_softirq_pending() definition
[IA64] iommu: Add a dummy iommu_table.h file in IA64.
[IA64] unwind - optimise linked-list searches for modules
[IA64] unwind: remove preprocesser noise, and correct comment
* 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, iommu: Update header comments with appropriate naming
ia64, iommu: Add a dummy iommu_table.h file in IA64.
x86, iommu: Fix IOMMU_INIT alignment rules
x86, doc: Adding comments about .iommu_table and its neighbors.
x86, iommu: Utilize the IOMMU_INIT macros functionality.
x86, VT-d: Make Intel VT-d IOMMU use IOMMU_INIT_* macros.
x86, GART/AMD-VI: Make AMD GART and IOMMU use IOMMU_INIT_* macros.
x86, calgary: Make Calgary IOMMU use IOMMU_INIT_* macros.
x86, xen-swiotlb: Make Xen-SWIOTLB use IOMMU_INIT_* macros.
x86, swiotlb: Make SWIOTLB use IOMMU_INIT_* macros.
x86, swiotlb: Simplify SWIOTLB pci_swiotlb_detect routine.
x86, iommu: Add proper dependency sort routine (and sanity check).
x86, iommu: Make all IOMMU's detection routines return a value.
x86, iommu: Add IOMMU_INIT macros, .iommu_table section, and iommu_table_entry structure
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits)
sched: Export account_system_vtime()
sched: Call tick_check_idle before __irq_enter
sched: Remove irq time from available CPU power
sched: Do not account irq time to current task
x86: Add IRQ_TIME_ACCOUNTING
sched: Add IRQ_TIME_ACCOUNTING, finer accounting of irq time
sched: Add a PF flag for ksoftirqd identification
sched: Consolidate account_system_vtime extern declaration
sched: Fix softirq time accounting
sched: Drop group_capacity to 1 only if local group has extra capacity
sched: Force balancing on newidle balance if local group has capacity
sched: Set group_imb only a task can be pulled from the busiest cpu
sched: Do not consider SCHED_IDLE tasks to be cache hot
sched: Drop all load weight manipulation for RT tasks
sched: Create special class for stop/migrate work
sched: Unindent labels
sched: Comment updates: fix default latency and granularity numbers
tracing/sched: Add sched_pi_setprio tracepoint
sched: Give CPU bound RT tasks preference
sched: Try not to migrate higher priority RT tasks
Ugly #include dependencies. We need to have local_softirq_pending()
defined before it gets used in <linux/interrupt.h>. But <asm/hardirq.h>
provides the definition *after* this #include chain:
<linux/irq.h>
<asm/irq.h>
<asm/hw_irq.h>
<linux/interrupt.h>
[ cherry-picked from the ia64 tree to fix "2bf2160: irq: Add tracepoint to softirq_raise" ]
Just a minor cleanup patch that makes things easier to the following patches.
No functionality change in this patch.
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-3-git-send-email-venki@google.com>
'next-fixes', 'optimize-unwind', 'remove-compat-h' and 'stack_trace' into release
The huge pages code uses the siginfo _addr_lsb field, but ia64
was missing it. Add it to ia64 too (over some padding) to avoid
compilation failures.
Acked-by: Tony Luck <tony.luck@intel.com>
We don't need a complex IOMMU dependency list on IA64 so
we just define the IOMMU_* macro which is used the DMAR driver, as a dummy.
LKML-Reference: <1286564028-2352-2-git-send-email-konrad.wilk@oracle.com>
Reported-by: Tony Luck <tony.luck@intel.com>
Tested-by: Tony Luck <tony.luck@intel.com>
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration,
it maps:
local_irq_enable() -> raw_local_irq_enable()
local_irq_disable() -> raw_local_irq_disable()
local_irq_save() -> raw_local_irq_save()
and under the other configuration, it maps:
raw_local_irq_enable() -> local_irq_enable()
raw_local_irq_disable() -> local_irq_disable()
raw_local_irq_save() -> local_irq_save()
This is quite confusing. There should be one set of names expected of the
arch, and this should be wrapped to give another set of names that are expected
by users of this facility.
Change this to have the arch provide:
flags = arch_local_save_flags()
flags = arch_local_irq_save()
arch_local_irq_restore(flags)
arch_local_irq_disable()
arch_local_irq_enable()
arch_irqs_disabled_flags(flags)
arch_irqs_disabled()
arch_safe_halt()
Then linux/irqflags.h wraps these to provide:
raw_local_save_flags(flags)
raw_local_irq_save(flags)
raw_local_irq_restore(flags)
raw_irqs_disabled_flags(flags)
raw_irqs_disabled()
raw_safe_halt()
with type checking on the flags 'arguments', and then wraps those to provide:
local_irq_disable()
local_irq_enable()
irqs_disabled()
safe_halt()
with tracing included if enabled.
The arch functions can now all be inline functions rather than some of them
having to be macros.
Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300]
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile]
Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze]
Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR]
Acked-by: Tony Luck <tony.luck@intel.com> [IA-64]
Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R]
Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS]
Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC]
Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC]
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390]
Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score]
Acked-by: Matt Fleming <matt@console-pimps.org> [SH]
Acked-by: David S. Miller <davem@davemloft.net> [Sparc]
Acked-by: Chris Zankel <chris@zankel.net> [Xtensa]
Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha]
Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300]
Cc: starvik@axis.com [CRIS]
Cc: jesper.nilsson@axis.com [CRIS]
Cc: linux-cris-kernel@axis.com
Missed this file in commit 32974ad4907cdde6c9de612cd1b2ee0568fb9409
[IA64] Remove COMPAT_IA32 support
It is no longer needed, so remove it.
<linux/irq.h>
<asm/irq.h>
<asm/hw_irq.h>
<linux/interrupt.h>
We don't need a comlex IOMMU dependency list on IA64 so
we just define the IOMMU_* macro as a dummy.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <stable@kernel.org>
arch/ia64/kernel/process.c:636: error: conflicting types for ‘sys_execve’
commit d7627467b7a8dd6944885290a03a07ceb28c10eb
Make do_execve() take a const filename pointer
Missed the declaration of sys_execve in the ia64 asm/unistd.h (perhaps
because there is no reason for it to be there ... it might be a left over
from the COMPAT code?). Just delete the conflicting version.
unifdef-y and header-y have same semantic, so drop unifdef-y
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
[IA64] Add latest crop of syscalls
[IA64] Fix 64-bit atomic routines to return "long"
Three new syscalls for 2.6.36: prlimit64, fanotify_init and
fanotify_mark. Wire up the ia64 syscall table for them.
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
These have been broken (returning "int") since the dawn of
time. But there were no users that needed the whole value
until commit
424acaaeb3a3932d64a9b4bd59df6cf72c22d8f3
rwsem: wake queued readers when writer blocks on active read lock
made this change:
- (rwsem_atomic_update(0, sem) & RWSEM_ACTIVE_MASK))
- /* Someone grabbed the sem already */
+ rwsem_atomic_update(0, sem) < RWSEM_WAITING_BIAS)
+ /* Someone grabbed the sem for write already */
RWSEM_ACTIVE_MASK is 0xffffffffL, so the old code only looked
at the low order 32-bits. The new code needs to see all 64 bits.
Some nice improvements were made to rwsem in commit:
but this change overlooked that ia64 had defined RWSEM_WAITING_BIAS
as an unsigned value, while the new code required a signed value (as
it is in every other architecture).
This fix suggested by the original patch author: Michel Lespinasse.
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
This patch is against the 2.6.34 source.
Paraphrased from the 1989 BSD patch by David Borman @ cray.com:
These are the changes needed for the kernel to support
LINEMODE in the server.
There is a new bit in the termios local flag word, EXTPROC.
When this bit is set, several aspects of the terminal driver
are disabled. Input line editing, character echo, and mapping
of signals are all disabled. This allows the telnetd to turn
off these functions when in linemode, but still keep track of
what state the user wants the terminal to be in.
New ioctl:
TIOCSIG Generate a signal to processes in the
current process group of the pty.
There is a new mode for packet driver, the TIOCPKT_IOCTL bit.
When packet mode is turned on in the pty, and the EXTPROC bit
is set, then whenever the state of the pty is changed, the
next read on the master side of the pty will have the TIOCPKT_IOCTL
bit set. This allows the process on the server side of the pty
to know when the state of the terminal has changed; it can then
issue the appropriate ioctl to retrieve the new state.
Since the original BSD patches accompanied the source code for telnet
I've left that reference here, but obviously the feature is useful for
any remote terminal protocol, including ssh.
The corresponding feature has existed in the BSD tty driver since 1989.
For historical reference, a good copy of the relevant files can be found
here:
http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741
Signed-off-by: Howard Chu <hyc@symas.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
As Jeff Dike pointed out, the Hayes ESP driver was removed in commit
f53a2ade0bb9f2a81f473e6469155172a96b7c38, so these ioctl definitions
should also be removed. This cleans up the remaining arch-specific
locations of this ioctl value.
Thanks to Arnd for pointing these out.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Alan Cox <alan@linux.intel.com>
Architectures don't need to define ISA_DMA_THRESHOLD anymore.
Acked-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
[IA64] increase ia64 static per cpu area
[IA64] Put ia64 config files on the Uwe Kleine-König diet
[IA64] perfmon: convert to unlocked_ioctl
[IA64] beautify vmlinux.lds.h
This patch converts unnecessary divide and modulo operations
in the KVM large page related code into logical operations.
This allows to convert gfn_t to u64 while not breaking 32
bit builds.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
I've been trying to avoid this for a long time ... but per-cpu space
has slowly been growing. Tejun has some patches in linux-next that
pre-reserve some space (PERCPU_DYNAMIC_EARLY_SIZE) for use before
slab comes online ... and this pushes ia64 above the 64K current
limit on static percpu space.
I could probably squeeze it back under (we are only over by 512 bytes).
But I don't think that I'll be able to squeeze it down enough to build
a comfortable breathing space - and I don't want to keep nibbling off
a dozen bytes here and there every time some generic code bumps us
back over the limit.
Next available supported page size is 256K ... so we have to quadruple
the available space - a bigger jump than I'd like. But perhaps it will
be enough to last a few more years before it needs to be increased again.
Acked-by: Tejun Heo <tj@kernel.org>
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
On 64bit, local_t is of size long, and thus we make local64_t an alias.
On 32bit, we fall back to atomic64_t. (architecture can provide optimized
32-bit version)
(This new facility is to be used by perf events optimizations.)
LKML-Reference: <new-submission>
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits)
kbuild: Revert part of e8d400a to resolve a conflict
kbuild: Fix checking of scm-identifier variable
gconfig: add support to show hidden options that have prompts
menuconfig: add support to show hidden options which have prompts
gconfig: remove show_debug option
gconfig: remove dbg_print_ptype() and dbg_print_stype()
kconfig: fix zconfdump()
kconfig: some small fixes
add random binaries to .gitignore
kbuild: Include gen_initramfs_list.sh and the file list in the .d file
kconfig: recalc symbol value before showing search results
.gitignore: ignore *.lzo files
headerdep: perlcritic warning
scripts/Makefile.lib: Align the output of LZO
kbuild: Generate modules.builtin in make modules_install
Revert "kbuild: specify absolute paths for cscope"
kbuild: Do not unnecessarily regenerate modules.builtin
headers_install: use local file handles
headers_check: fix perl warnings
export_report: fix perl warnings
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI: Don't let acpi_pad needlessly mark TSC unstable
drivers/acpi/sleep.h: Checkpatch cleanup
ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion
ACPI: delete unused c-state promotion/demotion data strucutures
ACPI: video: fix acpi_backlight=video
ACPI: EC: Use kmemdup
drivers/acpi: use kasprintf
ACPI, APEI, EINJ injection parameters support
Add x64 support to debugfs
ACPI, APEI, Use ERST for persistent storage of MCE
ACPI, APEI, Error Record Serialization Table (ERST) support
ACPI, APEI, Generic Hardware Error Source memory error support
ACPI, APEI, UEFI Common Platform Error Record (CPER) header
Unified UUID/GUID definition
ACPI Hardware Error Device (PNP0C33) support
ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup
ACPI, APEI, Document for APEI
ACPI, APEI, EINJ support
ACPI, APEI, HEST table parsing
ACPI, APEI, APEI supporting infrastructure
ia64: Use generic percpu implementation of numa_node_id()
+ intialize per cpu 'numa_node'
+ remove ia64 cpu_to_node() macro; use generic
+ define CONFIG_USE_PERCPU_NUMA_NODE_ID when NUMA configured
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Eric Whitney <eric.whitney@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
There are more architectures that don't support ARCH_HAS_SG_CHAIN than
those that support it. This removes removes ARCH_HAS_SG_CHAIN in
asm-generic/scatterlist.h and lets arhictectures to define it.
It's clearer than defining ARCH_HAS_SG_CHAIN asm-generic/scatterlist.h and
undefing it in arhictectures that don't support it.
