[ Upstream commit 173a3efd3edb2ef6ef07471397c5f542a360e9c1 ]
Looking at functions with large stack frames across all architectures
led me discovering that BUG() suffers from the same problem as
fortify_panic(), which I've added a workaround for already.
In short, variables that go out of scope by calling a noreturn function
or __builtin_unreachable() keep using stack space in functions
afterwards.
A workaround that was identified is to insert an empty assembler
statement just before calling the function that doesn't return. I'm
adding a macro "barrier_before_unreachable()" to document this, and
insert calls to that in all instances of BUG() that currently suffer
from this problem.
The files that saw the largest change from this had these frame sizes
before, and much less with my patch:
fs/ext4/inode.c:82:1: warning: the frame size of 1672 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/namei.c:434:1: warning: the frame size of 904 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/super.c:2279:1: warning: the frame size of 1160 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/xattr.c:146:1: warning: the frame size of 1168 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/f2fs/inode.c:152:1: warning: the frame size of 1424 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:1195:1: warning: the frame size of 1068 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:395:1: warning: the frame size of 1084 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:298:1: warning: the frame size of 928 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:418:1: warning: the frame size of 908 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_lblcr.c:718:1: warning: the frame size of 960 bytes is larger than 800 bytes [-Wframe-larger-than=]
drivers/net/xen-netback/netback.c:1500:1: warning: the frame size of 1088 bytes is larger than 800 bytes [-Wframe-larger-than=]
In case of ARC and CRIS, it turns out that the BUG() implementation
actually does return (or at least the compiler thinks it does),
resulting in lots of warnings about uninitialized variable use and
leaving noreturn functions, such as:
block/cfq-iosched.c: In function 'cfq_async_queue_prio':
block/cfq-iosched.c:3804:1: error: control reaches end of non-void function [-Werror=return-type]
include/linux/dmaengine.h: In function 'dma_maxpq':
include/linux/dmaengine.h:1123:1: error: control reaches end of non-void function [-Werror=return-type]
This makes them call __builtin_trap() instead, which should normally
dump the stack and kill the current process, like some of the other
architectures already do.
I tried adding barrier_before_unreachable() to panic() and
fortify_panic() as well, but that had very little effect, so I'm not
submitting that patch.
Vineet said:
: For ARC, it is double win.
: 1. Fixes 3 -Wreturn-type warnings
: | ../net/core/ethtool.c:311:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../kernel/sched/core.c:3246:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../include/linux/sunrpc/svc_xprt.h:180:1: warning: control reaches end of
: non-void function [-Wreturn-type]
: 2. bloat-o-meter reports code size improvements as gcc elides the
: generated code for stack return.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82365
Link: http://lkml.kernel.org/r/20171219114112.939391-1-arnd@arndb.de
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Tested-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Pull x86 fixes from Ingo Molnar:
"Two fixes:
- A PCID related revert that fixes power management and performance
regressions.
- The module loader robustization and sanity check commit is rather
fresh, but it looked like a good idea to apply because of the
hidden data corruption problem such invalid modules could cause"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/module: Detect and skip invalid relocations
Revert "x86/mm: Stop calling leave_mm() in idle code"
This reverts commit 43858b4f25cf0adc5c2ca9cf5ce5fdf2532941e5.
The reason I removed the leave_mm() calls in question is because the
heuristic wasn't needed after that patch. With the original version
of my PCID series, we never flushed a "lazy cpu" (i.e. a CPU running
kernel thread) due a flush on the loaded mm.
Unfortunately, that caused architectural issues, so now I've
reinstated these flushes on non-PCID systems in:
commit b956575bed91 ("x86/mm: Flush more aggressively in lazy TLB mode").
That, in turn, gives us a power management and occasionally
performance regression as compared to old kernels: a process that
goes into a deep idle state on a given CPU and gets its mm flushed
due to activity on a different CPU will wake the idle CPU.
Reinstate the old ugly heuristic: if a CPU goes into ACPI C3 or an
intel_idle state that is likely to cause a TLB flush gets its mm
switched to init_mm before going idle.
FWIW, this heuristic is lousy. Whether we should change CR3 before
idle isn't a good hint except insofar as the performance hit is a bit
lower if the TLB is getting flushed by the idle code anyway. What we
really want to know is whether we anticipate being idle long enough
that the mm is likely to be flushed before we wake up. This is more a
matter of the expected latency than the idle state that gets chosen.
This heuristic also completely fails on systems that don't know
whether the TLB will be flushed (e.g. AMD systems?). OTOH it may be a
bit obsolete anyway -- PCID systems don't presently benefit from this
heuristic at all.
We also shouldn't do this callback from innermost bit of the idle code
due to the RCU nastiness it causes. All the information need is
available before rcu_idle_enter() needs to happen.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Fixes: 43858b4f25cf "x86/mm: Stop calling leave_mm() in idle code"
Link: http://lkml.kernel.org/r/c513bbd4e653747213e05bc7062de000bf0202a5.1509793738.git.luto@kernel.org
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
compliance tools to determine the correct license.
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
Pull x86 mm changes from Ingo Molnar:
"PCID support, 5-level paging support, Secure Memory Encryption support
The main changes in this cycle are support for three new, complex
hardware features of x86 CPUs:
- Add 5-level paging support, which is a new hardware feature on
upcoming Intel CPUs allowing up to 128 PB of virtual address space
and 4 PB of physical RAM space - a 512-fold increase over the old
limits. (Supercomputers of the future forecasting hurricanes on an
ever warming planet can certainly make good use of more RAM.)
Many of the necessary changes went upstream in previous cycles,
v4.14 is the first kernel that can enable 5-level paging.
This feature is activated via CONFIG_X86_5LEVEL=y - disabled by
default.
(By Kirill A. Shutemov)
- Add 'encrypted memory' support, which is a new hardware feature on
upcoming AMD CPUs ('Secure Memory Encryption', SME) allowing system
RAM to be encrypted and decrypted (mostly) transparently by the
CPU, with a little help from the kernel to transition to/from
encrypted RAM. Such RAM should be more secure against various
attacks like RAM access via the memory bus and should make the
radio signature of memory bus traffic harder to intercept (and
decrypt) as well.
This feature is activated via CONFIG_AMD_MEM_ENCRYPT=y - disabled
by default.
(By Tom Lendacky)
- Enable PCID optimized TLB flushing on newer Intel CPUs: PCID is a
hardware feature that attaches an address space tag to TLB entries
and thus allows to skip TLB flushing in many cases, even if we
switch mm's.
(By Andy Lutomirski)
All three of these features were in the works for a long time, and
it's coincidence of the three independent development paths that they
are all enabled in v4.14 at once"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (65 commits)
x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y)
x86/mm: Use pr_cont() in dump_pagetable()
x86/mm: Fix SME encryption stack ptr handling
kvm/x86: Avoid clearing the C-bit in rsvd_bits()
x86/CPU: Align CR3 defines
x86/mm, mm/hwpoison: Clear PRESENT bit for kernel 1:1 mappings of poison pages
acpi, x86/mm: Remove encryption mask from ACPI page protection type
x86/mm, kexec: Fix memory corruption with SME on successive kexecs
x86/mm/pkeys: Fix typo in Documentation/x86/protection-keys.txt
x86/mm/dump_pagetables: Speed up page tables dump for CONFIG_KASAN=y
x86/mm: Implement PCID based optimization: try to preserve old TLB entries using PCID
x86: Enable 5-level paging support via CONFIG_X86_5LEVEL=y
x86/mm: Allow userspace have mappings above 47-bit
x86/mm: Prepare to expose larger address space to userspace
x86/mpx: Do not allow MPX if we have mappings above 47-bit
x86/mm: Rename tasksize_32bit/64bit to task_size_32bit/64bit()
x86/xen: Redefine XEN_ELFNOTE_INIT_P2M using PUD_SIZE * PTRS_PER_PUD
x86/mm/dump_pagetables: Fix printout of p4d level
x86/mm/dump_pagetables: Generalize address normalization
x86/boot: Fix memremap() related build failure
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/refcounts, x86/asm: Implement fast refcount overflow protection
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
arch/x86/kernel/head64.c
arch/x86/mm/mmap.c
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Removal of spin_unlock_wait()
- SRCU updates
- Torture-test updates
- Documentation updates
- Miscellaneous fixes
- CPU-hotplug fixes
- Miscellaneous non-RCU fixes
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes the underlying arch-specific
arch_spin_unlock_wait() for all architectures providing them.
Cc: <linux-arch@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
Nadav reported parallel MADV_DONTNEED on same range has a stale TLB
problem and Mel fixed it[1] and found same problem on MADV_FREE[2].
Quote from Mel Gorman:
"The race in question is CPU 0 running madv_free and updating some PTEs
while CPU 1 is also running madv_free and looking at the same PTEs.
CPU 1 may have writable TLB entries for a page but fail the pte_dirty
check (because CPU 0 has updated it already) and potentially fail to
flush.
Hence, when madv_free on CPU 1 returns, there are still potentially
writable TLB entries and the underlying PTE is still present so that a
subsequent write does not necessarily propagate the dirty bit to the
underlying PTE any more. Reclaim at some unknown time at the future
may then see that the PTE is still clean and discard the page even
though a write has happened in the meantime. I think this is possible
but I could have missed some protection in madv_free that prevents it
happening."
This patch aims for solving both problems all at once and is ready for
other problem with KSM, MADV_FREE and soft-dirty story[3].
TLB batch API(tlb_[gather|finish]_mmu] uses [inc|dec]_tlb_flush_pending
and mmu_tlb_flush_pending so that when tlb_finish_mmu is called, we can
catch there are parallel threads going on. In that case, forcefully,
flush TLB to prevent for user to access memory via stale TLB entry
although it fail to gather page table entry.
I confirmed this patch works with [4] test program Nadav gave so this
patch supersedes "mm: Always flush VMA ranges affected by zap_page_range
v2" in current mmotm.
NOTE:
This patch modifies arch-specific TLB gathering interface(x86, ia64,
s390, sh, um). It seems most of architecture are straightforward but
s390 need to be careful because tlb_flush_mmu works only if
mm->context.flush_mm is set to non-zero which happens only a pte entry
really is cleared by ptep_get_and_clear and friends. However, this
problem never changes the pte entries but need to flush to prevent
memory access from stale tlb.
[1] http://lkml.kernel.org/r/20170725101230.5v7gvnjmcnkzzql3@techsingularity.net
[2] http://lkml.kernel.org/r/20170725100722.2dxnmgypmwnrfawp@suse.de
[3] http://lkml.kernel.org/r/BD3A0EBE-ECF4-41D4-87FA-C755EA9AB6BD@gmail.com
[4] https://patchwork.kernel.org/patch/9861621/
[minchan@kernel.org: decrease tlb flush pending count in tlb_finish_mmu]
Link: http://lkml.kernel.org/r/20170808080821.GA31730@bbox
Link: http://lkml.kernel.org/r/20170802000818.4760-7-namit@vmware.com
Signed-off-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Nadav Amit <namit@vmware.com>
Reported-by: Nadav Amit <namit@vmware.com>
Reported-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
This patch is a preparatory patch for solving race problems caused by
TLB batch. For that, we will increase/decrease TLB flush pending count
of mm_struct whenever tlb_[gather|finish]_mmu is called.
Before making it simple, this patch separates architecture specific part
and rename it to arch_tlb_[gather|finish]_mmu and generic part just
calls it.
It shouldn't change any behavior.
Link: http://lkml.kernel.org/r/20170802000818.4760-5-namit@vmware.com
The send call ignores unknown flags. Legacy applications may already
unwittingly pass MSG_ZEROCOPY. Continue to ignore this flag unless a
socket opts in to zerocopy.
Introduce socket option SO_ZEROCOPY to enable MSG_ZEROCOPY processing.
Processes can also query this socket option to detect kernel support
for the feature. Older kernels will return ENOPROTOOPT.
Signed-off-by: Willem de Bruijn <willemb@google.com>
struct siginfo is a union and the kernel since 2.4 has been hiding a union
tag in the high 16bits of si_code using the values:
__SI_KILL
__SI_TIMER
__SI_POLL
__SI_FAULT
__SI_CHLD
__SI_RT
__SI_MESGQ
__SI_SYS
While this looks plausible on the surface, in practice this situation has
not worked well.
- Injected positive signals are not copied to user space properly
unless they have these magic high bits set.
- Injected positive signals are not reported properly by signalfd
- These kernel internal values leaked to userspace via ptrace_peek_siginfo
- It was possible to inject these kernel internal values and cause the
the kernel to misbehave.
- Kernel developers got confused and expected these kernel internal values
in userspace in kernel self tests.
- Kernel developers got confused and set si_code to __SI_FAULT which
is SI_USER in userspace which causes userspace to think an ordinary user
sent the signal and that it was not kernel generated.
- The values make it impossible to reorganize the code to transform
siginfo_copy_to_user into a plain copy_to_user. As si_code must
be massaged before being passed to userspace.
So remove these kernel internal si codes and make the kernel code simpler
and more maintainable.
To replace these kernel internal magic si_codes introduce the helper
function siginfo_layout, that takes a signal number and an si_code and
computes which union member of siginfo is being used. Have
siginfo_layout return an enumeration so that gcc will have enough
information to warn if a switch statement does not handle all of union
members.
A couple of architectures have a messed up ABI that defines signal
specific duplications of SI_USER which causes more special cases in
siginfo_layout than I would like. The good news is only problem
architectures pay the cost.
Update all of the code that used the previous magic __SI_ values to
use the new SIL_ values and to call siginfo_layout to get those
values. Escept where not all of the cases are handled remove the
defaults in the switch statements so that if a new case is missed in
the future the lack will show up at compile time.
Modify the code that copies siginfo si_code to userspace to just copy
the value and not cast si_code to a short first. The high bits are no
longer used to hold a magic union member.
Fixup the siginfo header files to stop including the __SI_ values in
their constants and for the headers that were missing it to properly
update the number of si_codes for each signal type.
The fixes to copy_siginfo_from_user32 implementations has the
interesting property that several of them perviously should never have
worked as the __SI_ values they depended up where kernel internal.
With that dependency gone those implementations should work much
better.
The idea of not passing the __SI_ values out to userspace and then
not reinserting them has been tested with criu and criu worked without
changes.
Ref: 2.4.0-test1
Setting si_code to __SI_FAULT results in a userspace seeing
an si_code of 0. This is the same si_code as SI_USER. Posix
and common sense requires that SI_USER not be a signal specific
si_code. As such this use of 0 for the si_code is a pretty
horribly broken ABI.
Given that ia64 is on it's last legs I don't know that it is worth
fixing this, but it is worth documenting what is going on so that
no one decides to copy this bad decision.
This was introduced in 2.3.51 so this mess has had a long time for
people to be able to start depending on it.
The SME patches we are about to apply add some E820 logic, so merge in
pending E820 code changes first, to have a single code base.
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
"generic-y += kvm_para.h" is doubled in asm/Kbuild and uapi/asm/Kbuild.
The one in the former should be simply removed because kvm_para.h is
exported.
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
"Reasonably busy this cycle, but perhaps not as busy as in the 4.12
merge window:
1) Several optimizations for UDP processing under high load from
Paolo Abeni.
2) Support pacing internally in TCP when using the sch_fq packet
scheduler for this is not practical. From Eric Dumazet.
3) Support mutliple filter chains per qdisc, from Jiri Pirko.
4) Move to 1ms TCP timestamp clock, from Eric Dumazet.
5) Add batch dequeueing to vhost_net, from Jason Wang.
6) Flesh out more completely SCTP checksum offload support, from
Davide Caratti.
7) More plumbing of extended netlink ACKs, from David Ahern, Pablo
Neira Ayuso, and Matthias Schiffer.
8) Add devlink support to nfp driver, from Simon Horman.
9) Add RTM_F_FIB_MATCH flag to RTM_GETROUTE queries, from Roopa
Prabhu.
10) Add stack depth tracking to BPF verifier and use this information
in the various eBPF JITs. From Alexei Starovoitov.
11) Support XDP on qed device VFs, from Yuval Mintz.
12) Introduce BPF PROG ID for better introspection of installed BPF
programs. From Martin KaFai Lau.
13) Add bpf_set_hash helper for TC bpf programs, from Daniel Borkmann.
14) For loads, allow narrower accesses in bpf verifier checking, from
Yonghong Song.
15) Support MIPS in the BPF selftests and samples infrastructure, the
MIPS eBPF JIT will be merged in via the MIPS GIT tree. From David
Daney.
16) Support kernel based TLS, from Dave Watson and others.
17) Remove completely DST garbage collection, from Wei Wang.
18) Allow installing TCP MD5 rules using prefixes, from Ivan
Delalande.
19) Add XDP support to Intel i40e driver, from Björn Töpel
20) Add support for TC flower offload in nfp driver, from Simon
Horman, Pieter Jansen van Vuuren, Benjamin LaHaise, Jakub
Kicinski, and Bert van Leeuwen.
21) IPSEC offloading support in mlx5, from Ilan Tayari.
22) Add HW PTP support to macb driver, from Rafal Ozieblo.
23) Networking refcount_t conversions, From Elena Reshetova.
24) Add sock_ops support to BPF, from Lawrence Brako. This is useful
for tuning the TCP sockopt settings of a group of applications,
currently via CGROUPs"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1899 commits)
net: phy: dp83867: add workaround for incorrect RX_CTRL pin strap
dt-bindings: phy: dp83867: provide a workaround for incorrect RX_CTRL pin strap
cxgb4: Support for get_ts_info ethtool method
cxgb4: Add PTP Hardware Clock (PHC) support
cxgb4: time stamping interface for PTP
nfp: default to chained metadata prepend format
nfp: remove legacy MAC address lookup
nfp: improve order of interfaces in breakout mode
net: macb: remove extraneous return when MACB_EXT_DESC is defined
bpf: add missing break in for the TCP_BPF_SNDCWND_CLAMP case
bpf: fix return in load_bpf_file
mpls: fix rtm policy in mpls_getroute
net, ax25: convert ax25_cb.refcount from atomic_t to refcount_t
net, ax25: convert ax25_route.refcount from atomic_t to refcount_t
net, ax25: convert ax25_uid_assoc.refcount from atomic_t to refcount_t
net, sctp: convert sctp_ep_common.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_transport.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_chunk.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_datamsg.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_auth_bytes.refcnt from atomic_t to refcount_t
Now that lazy TLB suppresses all flush IPIs (as opposed to all but
the first), there's no need to leave_mm() when going idle.
This means we can get rid of the rcuidle hack in
switch_mm_irqs_off() and we can unexport leave_mm().
This also removes acpi_unlazy_tlb() from the x86 and ia64 headers,
since it has no callers any more.
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/03c699cfd6021e467be650d6b73deaccfe4b4bd7.1498751203.git.luto@kernel.org
Pull documentation updates from Jonathan Corbet:
"There has been a fair amount of activity in the docs tree this time
around. Highlights include:
- Conversion of a bunch of security documentation into RST
- The conversion of the remaining DocBook templates by The Amazing
Mauro Machine. We can now drop the entire DocBook build chain.
- The usual collection of fixes and minor updates"
* tag 'docs-4.13' of git://git.lwn.net/linux: (90 commits)
scripts/kernel-doc: handle DECLARE_HASHTABLE
Documentation: atomic_ops.txt is core-api/atomic_ops.rst
Docs: clean up some DocBook loose ends
Make the main documentation title less Geocities
Docs: Use kernel-figure in vidioc-g-selection.rst
Docs: fix table problems in ras.rst
Docs: Fix breakage with Sphinx 1.5 and upper
Docs: Include the Latex "ifthen" package
doc/kokr/howto: Only send regression fixes after -rc1
docs-rst: fix broken links to dynamic-debug-howto in kernel-parameters
doc: Document suitability of IBM Verse for kernel development
Doc: fix a markup error in coding-style.rst
docs: driver-api: i2c: remove some outdated information
Documentation: DMA API: fix a typo in a function name
Docs: Insert missing space to separate link from text
doc/ko_KR/memory-barriers: Update control-dependencies example
Documentation, kbuild: fix typo "minimun" -> "minimum"
docs: Fix some formatting issues in request-key.rst
doc: ReSTify keys-trusted-encrypted.txt
doc: ReSTify keys-request-key.txt
Pull timer updates from Thomas Gleixner:
"A rather large update for timers/timekeeping:
- compat syscall consolidation (Al Viro)
- Posix timer consolidation (Christoph Helwig / Thomas Gleixner)
- Cleanup of the device tree based initialization for clockevents and
clocksources (Daniel Lezcano)
- Consolidation of the FTTMR010 clocksource/event driver (Linus
Walleij)
- The usual set of small fixes and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (93 commits)
timers: Make the cpu base lock raw
clocksource/drivers/mips-gic-timer: Fix an error code in 'gic_clocksource_of_init()'
clocksource/drivers/fsl_ftm_timer: Unmap region obtained by of_iomap
clocksource/drivers/tcb_clksrc: Make IO endian agnostic
clocksource/drivers/sun4i: Switch to the timer-of common init
clocksource/drivers/timer-of: Fix invalid iomap check
Revert "ktime: Simplify ktime_compare implementation"
clocksource/drivers: Fix uninitialized variable use in timer_of_init
kselftests: timers: Add test for frequency step
kselftests: timers: Fix inconsistency-check to not ignore first timestamp
time: Add warning about imminent deprecation of CONFIG_GENERIC_TIME_VSYSCALL_OLD
time: Clean up CLOCK_MONOTONIC_RAW time handling
posix-cpu-timers: Make timespec to nsec conversion safe
itimer: Make timeval to nsec conversion range limited
timers: Fix parameter description of try_to_del_timer_sync()
clocksource/drivers/fttmr010: Factor out clock read code
clocksource/drivers/fttmr010: Implement delay timer
clocksource/drivers: Add timer-of common init routine
clocksource/drivers/tcb_clksrc: Save timer context on suspend/resume
no users left
A set of overlapping changes in macvlan and the rocker
driver, nothing serious.
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
This adds the new getsockopt(2) option SO_PEERGROUPS on SOL_SOCKET to
retrieve the auxiliary groups of the remote peer. It is designed to
naturally extend SO_PEERCRED. That is, the underlying data is from the
same credentials. Regarding its syntax, it is based on SO_PEERSEC. That
is, if the provided buffer is too small, ERANGE is returned and @optlen
is updated. Otherwise, the information is copied, @optlen is set to the
actual size, and 0 is returned.
While SO_PEERCRED (and thus `struct ucred') already returns the primary
group, it lacks the auxiliary group vector. However, nearly all access
controls (including kernel side VFS and SYSVIPC, but also user-space
polkit, DBus, ...) consider the entire set of groups, rather than just
the primary group. But this is currently not possible with pure
SO_PEERCRED. Instead, user-space has to work around this and query the
system database for the auxiliary groups of a UID retrieved via
SO_PEERCRED.
Unfortunately, there is no race-free way to query the auxiliary groups
of the PID/UID retrieved via SO_PEERCRED. Hence, the current user-space
solution is to use getgrouplist(3p), which itself falls back to NSS and
whatever is configured in nsswitch.conf(3). This effectively checks
which groups we *would* assign to the user if it logged in *now*. On
normal systems it is as easy as reading /etc/group, but with NSS it can
resort to quering network databases (eg., LDAP), using IPC or network
communication.
Long story short: Whenever we want to use auxiliary groups for access
checks on IPC, we need further IPC to talk to the user/group databases,
rather than just relying on SO_PEERCRED and the incoming socket. This
is unfortunate, and might even result in dead-locks if the database
query uses the same IPC as the original request.
So far, those recursions / dead-locks have been avoided by using
primitive IPC for all crucial NSS modules. However, we want to avoid
re-inventing the wheel for each NSS module that might be involved in
user/group queries. Hence, we would preferably make DBus (and other IPC
that supports access-management based on groups) work without resorting
to the user/group database. This new SO_PEERGROUPS ioctl would allow us
to make dbus-daemon work without ever calling into NSS.
Cc: Michal Sekletar <msekleta@redhat.com>
Cc: Simon McVittie <simon.mcvittie@collabora.co.uk>
Reviewed-by: Tom Gundersen <teg@jklm.no>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
All ia64 dma_mapping_ops instances already have a mapping_error member.
By moving the kernel side __SI_* defintions right next to the userspace
ones we can kill the non-uapi versions of <asm/siginfo.h> include
include/asm-generic/siginfo.h and untangle the unholy mess of includes.
[ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ]
Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
Since ia64 defines __ARCH_SI_PREAMBLE_SIZE it can just use the generic
copy_siginfo implementation, which is identical to the architecture
specific one.
With that support for HAVE_ARCH_COPY_SIGINFO can go away entirely.
Link: http://lkml.kernel.org/r/20170603190102.28866-3-hch@lst.de
A definition was only provided for asm-generic/socket.h
using platforms, define it for the others as well
Mauro says:
This patch series convert the remaining DocBooks to ReST.
The first version was originally
send as 3 patch series:
[PATCH 00/36] Convert DocBook documents to ReST
[PATCH 0/5] Convert more books to ReST
[PATCH 00/13] Get rid of DocBook
The lsm book was added as if it were a text file under
Documentation. The plan is to merge it with another file
under Documentation/security, after both this series and
a security Documentation patch series gets merged.
It also adjusts some Sphinx-pedantic errors/warnings on
some kernel-doc markups.
I also added some patches here to add PDF output for all
existing ReST books.
The book is now at Documentation/driver-api/device-io.rst.
Update such references.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
no callers, no consistent semantics, no sane way to use it...
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Mark Salter <msalter@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add framework for supporting PCIe devices in Endpoint mode (Kishon
Vijay Abraham I)
- use non-postable PCI config space mappings when possible (Lorenzo
Pieralisi)
- clean up and unify mmap of PCI BARs (David Woodhouse)
- export and unify Function Level Reset support (Christoph Hellwig)
- avoid FLR for Intel 82579 NICs (Sasha Neftin)
- add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig)
- short-circuit config access failures for disconnected devices (Keith
Busch)
- remove D3 sleep delay when possible (Adrian Hunter)
- freeze PME scan before suspending devices (Lukas Wunner)
- stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava)
- disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann)
- add arch-specific alignment control to improve device passthrough by
avoiding multiple BARs in a page (Yongji Xie)
- add sysfs sriov_drivers_autoprobe to control VF driver binding
(Bodong Wang)
- allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas)
- fix crashes when unbinding host controllers that don't support
removal (Brian Norris)
- add driver for MicroSemi Switchtec management interface (Logan
Gunthorpe)
- add driver for Faraday Technology FTPCI100 host bridge (Linus
Walleij)
- add i.MX7D support (Andrey Smirnov)
- use generic MSI support for Aardvark (Thomas Petazzoni)
- make Rockchip driver modular (Brian Norris)
- advertise 128-byte Read Completion Boundary support for Rockchip
(Shawn Lin)
- advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin)
- convert atomic_t to refcount_t in HV driver (Elena Reshetova)
- add CPU IRQ affinity in HV driver (K. Y. Srinivasan)
- fix PCI bus removal in HV driver (Long Li)
- add support for ThunderX2 DMA alias topology (Jayachandran C)
- add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki)
- add ITE 8893 bridge DMA alias quirk (Jarod Wilson)
- restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices
(Manish Jaggi)
* tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits)
PCI: Don't allow unbinding host controllers that aren't prepared
ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP
MAINTAINERS: Add PCI Endpoint maintainer
Documentation: PCI: Add userguide for PCI endpoint test function
tools: PCI: Add sample test script to invoke pcitest
tools: PCI: Add a userspace tool to test PCI endpoint
Documentation: misc-devices: Add Documentation for pci-endpoint-test driver
misc: Add host side PCI driver for PCI test function device
PCI: Add device IDs for DRA74x and DRA72x
dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access
PCI: dwc: dra7xx: Workaround for errata id i870
dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode
PCI: dwc: dra7xx: Add EP mode support
PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently
dt-bindings: PCI: Add DT bindings for PCI designware EP mode
PCI: dwc: designware: Add EP mode support
Documentation: PCI: Add binding documentation for pci-test endpoint function
ixgbe: Use pcie_flr() instead of duplicating it
IB/hfi1: Use pcie_flr() instead of duplicating it
PCI: imx6: Fix spelling mistake: "contol" -> "control"
Pull networking updates from David Millar:
"Here are some highlights from the 2065 networking commits that
happened this development cycle:
1) XDP support for IXGBE (John Fastabend) and thunderx (Sunil Kowuri)
2) Add a generic XDP driver, so that anyone can test XDP even if they
lack a networking device whose driver has explicit XDP support
(me).
3) Sparc64 now has an eBPF JIT too (me)
4) Add a BPF program testing framework via BPF_PROG_TEST_RUN (Alexei
Starovoitov)
5) Make netfitler network namespace teardown less expensive (Florian
Westphal)
6) Add symmetric hashing support to nft_hash (Laura Garcia Liebana)
7) Implement NAPI and GRO in netvsc driver (Stephen Hemminger)
8) Support TC flower offload statistics in mlxsw (Arkadi Sharshevsky)
9) Multiqueue support in stmmac driver (Joao Pinto)
10) Remove TCP timewait recycling, it never really could possibly work
well in the real world and timestamp randomization really zaps any
hint of usability this feature had (Soheil Hassas Yeganeh)
11) Support level3 vs level4 ECMP route hashing in ipv4 (Nikolay
Aleksandrov)
12) Add socket busy poll support to epoll (Sridhar Samudrala)
13) Netlink extended ACK support (Johannes Berg, Pablo Neira Ayuso,
and several others)
14) IPSEC hw offload infrastructure (Steffen Klassert)"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2065 commits)
tipc: refactor function tipc_sk_recv_stream()
tipc: refactor function tipc_sk_recvmsg()
net: thunderx: Optimize page recycling for XDP
net: thunderx: Support for XDP header adjustment
net: thunderx: Add support for XDP_TX
net: thunderx: Add support for XDP_DROP
net: thunderx: Add basic XDP support
net: thunderx: Cleanup receive buffer allocation
net: thunderx: Optimize CQE_TX handling
net: thunderx: Optimize RBDR descriptor handling
net: thunderx: Support for page recycling
ipx: call ipxitf_put() in ioctl error path
net: sched: add helpers to handle extended actions
qed*: Fix issues in the ptp filter config implementation.
qede: Fix concurrency issue in PTP Tx path processing.
stmmac: Add support for SIMATIC IOT2000 platform
net: hns: fix ethtool_get_strings overflow in hns driver
tcp: fix wraparound issue in tcp_lp
bpf, arm64: fix jit branch offset related to ldimm64
bpf, arm64: implement jiting of BPF_XADD
Pull uaccess unification updates from Al Viro:
"This is the uaccess unification pile. It's _not_ the end of uaccess
work, but the next batch of that will go into the next cycle. This one
mostly takes copy_from_user() and friends out of arch/* and gets the
zero-padding behaviour in sync for all architectures.
Dealing with the nocache/writethrough mess is for the next cycle;
fortunately, that's x86-only. Same for cleanups in iov_iter.c (I am
sold on access_ok() in there, BTW; just not in this pile), same for
reducing __copy_... callsites, strn*... stuff, etc. - there will be a
pile about as large as this one in the next merge window.
This one sat in -next for weeks. -3KLoC"
* 'work.uaccess' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (96 commits)
HAVE_ARCH_HARDENED_USERCOPY is unconditional now
CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional now
m32r: switch to RAW_COPY_USER
hexagon: switch to RAW_COPY_USER
microblaze: switch to RAW_COPY_USER
get rid of padding, switch to RAW_COPY_USER
ia64: get rid of copy_in_user()
ia64: sanitize __access_ok()
ia64: get rid of 'segment' argument of __do_{get,put}_user()
ia64: get rid of 'segment' argument of __{get,put}_user_check()
ia64: add extable.h
powerpc: get rid of zeroing, switch to RAW_COPY_USER
esas2r: don't open-code memdup_user()
alpha: fix stack smashing in old_adjtimex(2)
don't open-code kernel_setsockopt()
mips: switch to RAW_COPY_USER
mips: get rid of tail-zeroing in primitives
mips: make copy_from_user() zero tail explicitly
mips: clean and reorder the forest of macros...
mips: consolidate __invoke_... wrappers
'uaccess.arm64', 'uaccess.avr32', 'uaccess.bfin', 'uaccess.c6x', 'uaccess.cris', 'uaccess.frv', 'uaccess.h8300', 'uaccess.hexagon', 'uaccess.ia64', 'uaccess.m32r', 'uaccess.m68k', 'uaccess.metag', 'uaccess.microblaze', 'uaccess.mips', 'uaccess.mn10300', 'uaccess.nios2', 'uaccess.openrisc', 'uaccess.parisc', 'uaccess.powerpc', 'uaccess.s390', 'uaccess.score', 'uaccess.sh', 'uaccess.sparc', 'uaccess.tile', 'uaccess.um', 'uaccess.unicore32', 'uaccess.x86' and 'uaccess.xtensa' into work.uaccess
Now that we eliminated the different behaviour in separately-reviewable
commits, we can switch IA64 to the generic implementation.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Tested-by: Tony Luck <tony.luck@intel.com>
We can declare it <linux/pci.h> even on platforms where it isn't going to
be defined. There's no need to have it littered through the various
<asm/pci.h> files.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Most of the almost-identical versions of pci_mmap_page_range() silently
ignore the 'write_combine' argument and give uncached mappings.
Yet we allow the PCIIOC_WRITE_COMBINE ioctl in /proc/bus/pci, expose the
'resourceX_wc' file in sysfs, and allow an attempted mapping to apparently
succeed.
To fix this, introduce a macro arch_can_pci_mmap_wc() which indicates
whether the platform can do a write-combining mapping. On x86 this ends up
being pat_enabled(), while the few other platforms that support it can just
set it to a literal '1'.
Conflicts were simply overlapping changes. In the net/ipv4/route.c
case the code had simply moved around a little bit and the same fix
was made in both 'net' and 'net-next'.
In the net/sched/sch_generic.c case a fix in 'net' happened at
the same time that a new argument was added to qdisc_hash_add().
The ia64 build generates many warnings like this:
WARNING: EXPORT symbol "empty_zero_page" [vmlinux] version generation failed, symbol will not be versioned.
Besides adding the necessary header this also requires fiddling with
some explicit .S -> .o rules.
Cc: IA64-ML <linux-ia64@vger.kernel.org>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
