Sparse complains about wrong address space used in __acpi_map_table()
and in __acpi_unmap_table().
arch/x86/kernel/acpi/boot.c:127:29: warning: incorrect type in return expression (different address spaces)
arch/x86/kernel/acpi/boot.c:127:29: expected char *
arch/x86/kernel/acpi/boot.c:127:29: got void [noderef] <asn:2>*
arch/x86/kernel/acpi/boot.c:135:23: warning: incorrect type in argument 1 (different address spaces)
arch/x86/kernel/acpi/boot.c:135:23: expected void [noderef] <asn:2>*addr
arch/x86/kernel/acpi/boot.c:135:23: got char *map
Correct address space to be in align of type of returned and passed
parameter.
Reviewed-by: Hanjun Guo <guohanjun@huawei.com>
We may or may not have all possible CPUs in MADT on boot but in any
case we're overwriting x86_cpu_to_acpiid mapping with U32_MAX when
acpi_register_lapic() is called again on the CPU hotplug path:
acpi_processor_hotadd_init()
-> acpi_map_cpu()
-> acpi_register_lapic()
As we have the required acpi_id information in acpi_processor_hotadd_init()
propagate it to acpi_map_cpu() to always keep x86_cpu_to_acpiid
mapping valid.
Reported-by: Andrew Jones <drjones@redhat.com>
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
The whole patch-set aims at making cpuid <-> nodeid mapping persistent. So that,
when node online/offline happens, cache based on cpuid <-> nodeid mapping such as
wq_numa_possible_cpumask will not cause any problem.
It contains 4 steps:
1. Enable apic registeration flow to handle both enabled and disabled cpus.
2. Introduce a new array storing all possible cpuid <-> apicid mapping.
3. Enable _MAT and MADT relative apis to return non-present or disabled cpus' apicid.
4. Establish all possible cpuid <-> nodeid mapping.
This patch finishes step 4.
This patch set the persistent cpuid <-> nodeid mapping for all enabled/disabled
processors at boot time via an additional acpi namespace walk for processors.
[ tglx: Remove the unneeded exports ]
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Signed-off-by: Zhu Guihua <zhugh.fnst@cn.fujitsu.com>
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: mika.j.penttila@gmail.com
Cc: len.brown@intel.com
Cc: rafael@kernel.org
Cc: rjw@rjwysocki.net
Cc: yasu.isimatu@gmail.com
Cc: linux-mm@kvack.org
Cc: linux-acpi@vger.kernel.org
Cc: isimatu.yasuaki@jp.fujitsu.com
Cc: gongzhaogang@inspur.com
Cc: tj@kernel.org
Cc: izumi.taku@jp.fujitsu.com
Cc: cl@linux.com
Cc: chen.tang@easystack.cn
Cc: akpm@linux-foundation.org
Cc: kamezawa.hiroyu@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1472114120-3281-6-git-send-email-douly.fnst@cn.fujitsu.com
Since acpi_numa_arch_fixup() is only used in arch ia64, move it there
to make a generic interface easier. This avoids empty function stubs
or some complex kconfig options for x86 and arm64.
Signed-off-by: Robert Richter <rrichter@cavium.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: David Daney <david.daney@cavium.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull initial ACPI support for arm64 from Will Deacon:
"This series introduces preliminary ACPI 5.1 support to the arm64
kernel using the "hardware reduced" profile. We don't support any
peripherals yet, so it's fairly limited in scope:
- MEMORY init (UEFI)
- ACPI discovery (RSDP via UEFI)
- CPU init (FADT)
- GIC init (MADT)
- SMP boot (MADT + PSCI)
- ACPI Kconfig options (dependent on EXPERT)
ACPI for arm64 has been in development for a while now and hardware
has been available that can boot with either FDT or ACPI tables. This
has been made possible by both changes to the ACPI spec to cater for
ARM-based machines (known as "hardware-reduced" in ACPI parlance) but
also a Linaro-driven effort to get this supported on top of the Linux
kernel. This pull request is the result of that work.
These changes allow us to initialise the CPUs, interrupt controller,
and timers via ACPI tables, with memory information and cmdline coming
from EFI. We don't support a hybrid ACPI/FDT scheme. Of course,
there is still plenty of work to do (a serial console would be nice!)
but I expect that to happen on a per-driver basis after this core
series has been merged.
Anyway, the diff stat here is fairly horrible, but splitting this up
and merging it via all the different subsystems would have been
extremely painful. Instead, we've got all the relevant Acks in place
and I've not seen anything other than trivial (Kconfig) conflicts in
-next (for completeness, I've included my resolution below). Nearly
half of the insertions fall under Documentation/.
So, we'll see how this goes. Right now, it all depends on EXPERT and
I fully expect people to use FDT by default for the immediate future"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (31 commits)
ARM64 / ACPI: make acpi_map_gic_cpu_interface() as void function
ARM64 / ACPI: Ignore the return error value of acpi_map_gic_cpu_interface()
ARM64 / ACPI: fix usage of acpi_map_gic_cpu_interface
ARM64: kernel: acpi: honour acpi=force command line parameter
ARM64: kernel: acpi: refactor ACPI tables init and checks
ARM64: kernel: psci: let ACPI probe PSCI version
ARM64: kernel: psci: factor out probe function
ACPI: move arm64 GSI IRQ model to generic GSI IRQ layer
ARM64 / ACPI: Don't unflatten device tree if acpi=force is passed
ARM64 / ACPI: additions of ACPI documentation for arm64
Documentation: ACPI for ARM64
ARM64 / ACPI: Enable ARM64 in Kconfig
XEN / ACPI: Make XEN ACPI depend on X86
ARM64 / ACPI: Select ACPI_REDUCED_HARDWARE_ONLY if ACPI is enabled on ARM64
clocksource / arch_timer: Parse GTDT to initialize arch timer
irqchip: Add GICv2 specific ACPI boot support
ARM64 / ACPI: Introduce ACPI_IRQ_MODEL_GIC and register device's gsi
ACPI / processor: Make it possible to get CPU hardware ID via GICC
ACPI / processor: Introduce phys_cpuid_t for CPU hardware ID
ARM64 / ACPI: Parse MADT for SMP initialization
CPU hardware ID (phys_id) is defined as u32 in structure acpi_processor,
but phys_id is used as int in acpi processor driver, so it will lead to
some inconsistence for the drivers.
Furthermore, to cater for ACPI arch ports that implement 64 bits CPU
ids a generic CPU physical id type is required.
So introduce typedef u32 phys_cpuid_t in a common file, and introduce
a macro PHYS_CPUID_INVALID as (phys_cpuid_t)(-1) if it's not defined
by other archs, this will solve the inconsistence in acpi processor driver,
and will prepare for the ACPI on ARM64 for the 64 bit CPU hardware ID
in the following patch.
CC: Rafael J Wysocki <rjw@rjwysocki.net>
Suggested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
[hj: reworked cpu physid map return codes]
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Thanks to spatch, then a sweep for for_each_cpu_mask => for_each_cpu.
Cc: linux-ia64@vger.kernel.org
In acpi_table_parse(), pointer of the table to pass to handler() is
checked before handler() called, so remove all the duplicate NULL
check in the handler function.
CC: Tony Luck <tony.luck@intel.com>
CC: Thomas Gleixner <tglx@linutronix.de>
acpi_map_lsapic() will allocate a logical CPU number and map it to
physical CPU id (such as APIC id) for the hot-added CPU, it will also
do some mapping for NUMA node id and etc, acpi_unmap_lsapic() will
do the reverse.
We can see that the name of the function is a little bit confusing and
arch (IA64) dependent so rename them as acpi_(un)map_cpu() to make arch
agnostic and explicit.
This variable was defined and assigned in x86, is used to indicate
whether LAPIC exists in MADT. Now introduce it into ia64 to help
make correct judgment when get information for ACPI processor later.
Signed-off-by: Baoquan He <bhe@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Increment max correctly in pci_scan_bridge() (Andreas Noever)
- Clarify the "scan anyway" comment in pci_scan_bridge() (Andreas Noever)
- Assign CardBus bus number only during the second pass (Andreas Noever)
- Use request_resource_conflict() instead of insert_ for bus numbers (Andreas Noever)
- Make sure bus number resources stay within their parents bounds (Andreas Noever)
- Remove pci_fixup_parent_subordinate_busnr() (Andreas Noever)
- Check for child busses which use more bus numbers than allocated (Andreas Noever)
- Don't scan random busses in pci_scan_bridge() (Andreas Noever)
- x86: Drop pcibios_scan_root() check for bus already scanned (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_with_sysdata() (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_on_node() (Bjorn Helgaas)
- x86: Merge pci_scan_bus_on_node() into pcibios_scan_root() (Bjorn Helgaas)
- x86: Drop return value of pcibios_scan_root() (Bjorn Helgaas)
NUMA
- x86: Add x86_pci_root_bus_node() to look up NUMA node from PCI bus (Bjorn Helgaas)
- x86: Use x86_pci_root_bus_node() instead of get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Remove mp_bus_to_node[], set_mp_bus_to_node(), get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Use NUMA_NO_NODE, not -1, for unknown node (Bjorn Helgaas)
- x86: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ia64: Use NUMA_NO_NODE, not MAX_NUMNODES, for unknown node (Bjorn Helgaas)
- ia64: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ACPI: Fix acpi_get_node() prototype (Bjorn Helgaas)
Resource management
- i2o: Fix and refactor PCI space allocation (Bjorn Helgaas)
- Add resource_contains() (Bjorn Helgaas)
- Add %pR support for IORESOURCE_UNSET (Bjorn Helgaas)
- Mark resources as IORESOURCE_UNSET if we can't assign them (Bjorn Helgaas)
- Don't clear IORESOURCE_UNSET when updating BAR (Bjorn Helgaas)
- Check IORESOURCE_UNSET before updating BAR (Bjorn Helgaas)
- Don't try to claim IORESOURCE_UNSET resources (Bjorn Helgaas)
- Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit (Bjorn Helgaas)
- Don't enable decoding if BAR hasn't been assigned an address (Bjorn Helgaas)
- Add "weak" generic pcibios_enable_device() implementation (Bjorn Helgaas)
- alpha, microblaze, sh, sparc, tile: Use default pcibios_enable_device() (Bjorn Helgaas)
- s390: Use generic pci_enable_resources() (Bjorn Helgaas)
- Don't check resource_size() in pci_bus_alloc_resource() (Bjorn Helgaas)
- Set type in __request_region() (Bjorn Helgaas)
- Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region() (Bjorn Helgaas)
- Change pci_bus_alloc_resource() type_mask to unsigned long (Bjorn Helgaas)
- Log IDE resource quirk in dmesg (Bjorn Helgaas)
- Revert "[PATCH] Insert GART region into resource map" (Bjorn Helgaas)
PCI device hotplug
- Make check_link_active() non-static (Rajat Jain)
- Use link change notifications for hot-plug and removal (Rajat Jain)
- Enable link state change notifications (Rajat Jain)
- Don't disable the link permanently during removal (Rajat Jain)
- Don't check adapter or latch status while disabling (Rajat Jain)
- Disable link notification across slot reset (Rajat Jain)
- Ensure very fast hotplug events are also processed (Rajat Jain)
- Add hotplug_lock to serialize hotplug events (Rajat Jain)
- Remove a non-existent card, regardless of "surprise" capability (Rajat Jain)
- Don't turn slot off when hot-added device already exists (Yijing Wang)
MSI
- Keep pci_enable_msi() documentation (Alexander Gordeev)
- ahci: Fix broken single MSI fallback (Alexander Gordeev)
- ahci, vfio: Use pci_enable_msi_range() (Alexander Gordeev)
- Check kmalloc() return value, fix leak of name (Greg Kroah-Hartman)
- Fix leak of msi_attrs (Greg Kroah-Hartman)
- Fix pci_msix_vec_count() htmldocs failure (Masanari Iida)
Virtualization
- Device-specific ACS support (Alex Williamson)
Freescale i.MX6
- Wait for retraining (Marek Vasut)
Marvell MVEBU
- Use Device ID and revision from underlying endpoint (Andrew Lunn)
- Fix incorrect size for PCI aperture resources (Jason Gunthorpe)
- Call request_resource() on the apertures (Jason Gunthorpe)
- Fix potential issue in range parsing (Jean-Jacques Hiblot)
Renesas R-Car
- Check platform_get_irq() return code (Ben Dooks)
- Add error interrupt handling (Ben Dooks)
- Fix bridge logic configuration accesses (Ben Dooks)
- Register each instance independently (Magnus Damm)
- Break out window size handling (Magnus Damm)
- Make the Kconfig dependencies more generic (Magnus Damm)
Synopsys DesignWare
- Fix RC BAR to be single 64-bit non-prefetchable memory (Mohit Kumar)
Miscellaneous
- Remove unused SR-IOV VF Migration support (Bjorn Helgaas)
- Enable INTx if BIOS left them disabled (Bjorn Helgaas)
- Fix hex vs decimal typo in cpqhpc_probe() (Dan Carpenter)
- Clean up par-arch object file list (Liviu Dudau)
- Set IORESOURCE_ROM_SHADOW only for the default VGA device (Sander Eikelenboom)
- ACPI, ARM, drm, powerpc, pcmcia, PCI: Use list_for_each_entry() for bus traversal (Yijing Wang)
- Fix pci_bus_b() build failure (Paul Gortmaker)"
* tag 'pci-v3.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (108 commits)
PCI: Log IDE resource quirk in dmesg
PCI: Change pci_bus_alloc_resource() type_mask to unsigned long
PCI: Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region()
resources: Set type in __request_region()
PCI: Don't check resource_size() in pci_bus_alloc_resource()
s390/PCI: Use generic pci_enable_resources()
tile PCI RC: Use default pcibios_enable_device()
sparc/PCI: Use default pcibios_enable_device() (Leon only)
sh/PCI: Use default pcibios_enable_device()
microblaze/PCI: Use default pcibios_enable_device()
alpha/PCI: Use default pcibios_enable_device()
PCI: Add "weak" generic pcibios_enable_device() implementation
PCI: Don't enable decoding if BAR hasn't been assigned an address
PCI: Enable INTx in pci_reenable_device() only when MSI/MSI-X not enabled
PCI: Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit
PCI: Don't try to claim IORESOURCE_UNSET resources
PCI: Check IORESOURCE_UNSET before updating BAR
PCI: Don't clear IORESOURCE_UNSET when updating BAR
PCI: Mark resources as IORESOURCE_UNSET if we can't assign them
arch/x86/include/asm/topology.h
drivers/ata/ahci.c
BAD_MADT_ENTRY() is arch independent and will be used for all
architectures which parse MADT, so move it to linux/acpi.h to
reduce code duplication.
The IOMMU, LSAPIC, IOSAPIC, and PCI host bridge code doesn't care about
_PXM values directly; it only needs to know what NUMA node the hardware is
on.
This uses acpi_get_node() directly and removes the _PXM stuff.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
This change adds a runtime option that will force ACPICA to use the
RSDT instead of the XSDT. Although the ACPI spec requires that an XSDT
be used instead of the RSDT, the XSDT has been found to be corrupt or
ill-formed on some machines.
This option is already in the Linux kernel. When it is back ported to
ACPICA, code is re-written to follow ACPICA coding style. This patch
is the generation of the integration.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
ia64 has not been supported by Xen since 4.2 so it's time to drop
Xen/ia64 from Linux as well.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Since APIC id is saved in processor struct, just use it and
remove the duplicated _MAT evaluation.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the ia64 uses of the __cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
These functions might be called from modules as well so make sure
they are exported.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Otherwise you could run into:
WARN_ON in numa_register_memblks(), because node_possible_map is zero
References: https://bugzilla.novell.com/show_bug.cgi?id=757888
On this machine (ProLiant ML570 G3) the SRAT table contains:
- No processor affinities
- One memory affinity structure (which is set disabled)
CC: Per Jessen <per@opensuse.org>
CC: Andi Kleen <andi@firstfloor.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Len Brown <len.brown@intel.com>
This has been obsolescent for a while, fix documentation and
misc comments.
Merge third batch of patches from Andrew Morton:
- Some MM stragglers
- core SMP library cleanups (on_each_cpu_mask)
- Some IPI optimisations
- kexec
- kdump
- IPMI
- the radix-tree iterator work
- various other misc bits.
"That'll do for -rc1. I still have ~10 patches for 3.4, will send
those along when they've baked a little more."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
backlight: fix typo in tosa_lcd.c
crc32: add help text for the algorithm select option
mm: move hugepage test examples to tools/testing/selftests/vm
mm: move slabinfo.c to tools/vm
mm: move page-types.c from Documentation to tools/vm
selftests/Makefile: make `run_tests' depend on `all'
selftests: launch individual selftests from the main Makefile
radix-tree: use iterators in find_get_pages* functions
radix-tree: rewrite gang lookup using iterator
radix-tree: introduce bit-optimized iterator
fs/proc/namespaces.c: prevent crash when ns_entries[] is empty
nbd: rename the nbd_device variable from lo to nbd
pidns: add reboot_pid_ns() to handle the reboot syscall
sysctl: use bitmap library functions
ipmi: use locks on watchdog timeout set on reboot
ipmi: simplify locking
ipmi: fix message handling during panics
ipmi: use a tasklet for handling received messages
ipmi: increase KCS timeouts
ipmi: decrease the IPMI message transaction time in interrupt mode
This was marked as obsolete for quite a while now.. Now it is time to
remove it altogether. And while doing this, get rid of first_cpu() as
well. Also, remove the redundant setting of cpu_online_mask in
smp_prepare_cpus() because the generic code would have already set cpu 0
in cpu_online_mask.
Reported-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for IA64.
cc: linux-ia64@vger.kernel.org
When handling Interrupt Source Override in MADT table, the default
ISA IRQ trigger model and polarity should be edge-rising.
Current IA64 implmentation doesn't follow the specification and
set default ISA IRQ trigger model as level-low. With that wrong
configuration and when system runs out of interrupt vectors,
it will cause vector sharing among edge triggered ISA IRQ and
level triggered PCI IRQ, then interrupt storm. So change the code
to follow the specification.
Signed-off-by: Liu Jiang <jiang.liu@huawei.com>
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides
32bits for these. The new fields were reserved before.
According to the ACPI spec, the OS must disregrard reserved fields.
ia64 did handle the PXM fields almost consistently, but depending on
sgi's sn2 platform. This patch leaves the sn2 logic in, but does also
use 16/32 bits for PXM if the SRAT has rev 2 or higher.
The patch also adds __init to the two pxm accessor functions, as they
access __initdata now and are called from an __init function only anyway.
Note that the code only uses 16 bits for the PXM field in the processor
proximity field; the patch does not address this as 16 bits are more than
enough.
Signed-off-by: Kurt Garloff <kurt@garloff.de>
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent
with the other IOMMU options.
Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the
irq subsystem name.
And define the CONFIG_DMAR_TABLE for the common ACPI DMAR
routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: youquan.song@intel.com
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com
Once acpi_map_lsapic() in ia64 follows how x86 treats it wrt section
placement, the whole tree from acpi_processor_set_pdc() can become
__cpuinit.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
The function do_suspend_lowlevel() is specific to x86 and defined in
assembly code, so it should be called from the x86 low-level suspend
code rather than from acpi_suspend_enter().
Merge do_suspend_lowlevel() into the x86's acpi_save_state_mem() and
change the name of the latter to acpi_suspend_lowlevel(), so that the
function's purpose is better reflected by its name.
The function acpi_restore_state_mem() has never been and most likely
never will be used, so remove it.
arch/ia64/kernel/acpi.c:481: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘long unsigned int’
Introduced by commit 05f2f274c8a8747bbfb13ac8ee0c27d5f2ad8510
[IA64] Avoid array overflow if there are too many cpus in SRAT table
acpi_numa_init() has to parse the whole SRAT table, even if the
kernel wants to limit the number of cpus it will use (because the
ones it is going to use may be described by entries at the end of
the SRAT table). Avoid overflowing the node_cpuid array.
Reported-by: Yinghai Lu <yinghai@kernel.org>
There are a number of cases where the current code makes the assumption
that isa irqs identity map to the first 16 acpi global system intereupts.
In most instances that assumption is correct as that is the required
behaviour in dual i8259 mode and the default behavior in ioapic mode.
However there are some systems out there that take advantage of acpis
interrupt remapping for the isa irqs to have a completely different
mapping of isa_irq to gsi.
Introduce acpi_isa_irq_to_gsi to perform this mapping explicitly in the
code that needs it. Initially this will be just the current assumed
identity mapping to ensure it's introduction does not cause regressions.
LKML-Reference: <1269936436-7039-1-git-send-email-ebiederm@xmission.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Now that the early _PDC evaluation path knows how to correctly
evaluate _PDC on only physically present processors, there's no
need for the processor driver to evaluate it later when it loads.
To cover the hotplug case, push _PDC evaluation down into the
hotplug paths.
Cc: x86@kernel.org
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
x86: Fix out of order of gsi
x86: apic: Fix mismerge, add arch_probe_nr_irqs() again
x86, irq: Keep chip_data in create_irq_nr and destroy_irq
xen: Remove unnecessary arch specific xen irq functions.
smp: Use nr_cpus= to set nr_cpu_ids early
x86, irq: Remove arch_probe_nr_irqs
sparseirq: Use radix_tree instead of ptrs array
sparseirq: Change irq_desc_ptrs to static
init: Move radix_tree_init() early
irq: Remove unnecessary bootmem code
x86: Add iMac9,1 to pci_reboot_dmi_table
x86: Convert i8259_lock to raw_spinlock
x86: Convert nmi_lock to raw_spinlock
x86: Convert ioapic_lock and vector_lock to raw_spinlock
x86: Avoid race condition in pci_enable_msix()
x86: Fix SCI on IOAPIC != 0
x86, ia32_aout: do not kill argument mapping
x86, irq: Move __setup_vector_irq() before the first irq enable in cpu online path
x86, irq: Update the vector domain for legacy irqs handled by io-apic
x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu's
The following commit broke the ia64 sim_defconfig build:
3b2b84c0b81108a9a869a88bf2beeb5a95d81dd1
ACPI: processor: driver doesn't need to evaluate _PDC
This is because it added:
+#include <acpi/processor.h>
To arch/ia64/kernel/acpi.c. Unfortunately, the ia64_simdefconfig does
not turn on CONFIG_ACPI, and we get build errors.
The fix described in $subject seems to be the most sensible way to
untangle the mess.
The other issue is that acpi_get_sysname() is required for all configs,
most of which define CONFIG_ACPI, but are not CONFIG_IA64_GENERIC. Turn
it into an inline to cover the "non generic" ia64 configs; to prevent
a duplicate definition build error, we need to wrap the definition in
acpi.o inside an #ifdef.
Finally, move the pm_idle and pm_power_off exports into process.c (which
is always built), similar to other architectures, and allow the sim
defconfig to link.
On x86, before prefill_possible_map(), nr_cpu_ids will be NR_CPUS aka
CONFIG_NR_CPUS.
Add nr_cpus= to set nr_cpu_ids. so we can simulate cpus <=8 are installed on
normal config.
-v2: accordging to Christoph, acpi_numa_init should use nr_cpu_ids in stead of
NR_CPUS.
-v3: add doc in kernel-parameters.txt according to Andrew.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1265793639-15071-34-git-send-email-yinghai@kernel.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
All information necessary to initialize cpu possible and present maps
are available once early_acpi_boot_init() is complete. Reorganize
setup_arch() and acpi init functions such that,
* CPU information is printed after LAPIC entries are parsed in
early_acpi_boot_init().
* smp_build_cpu_map() is called by setup_arch() instead of acpi
functions.
* smp_build_cpu_map() is called once all CPU related information is
available before memory is initialized.
This is primarily to allow find_memory() to use cpu maps but is also a
general cleanup. Please note that with this change, the somewhat
ad-hoc early_cpu_possible_map defined and used for NUMA configurations
is probably unnecessary. Something to clean up another day.
Cc: linux-ia64 <linux-ia64@vger.kernel.org>
We want to use dev_to_node() later on, to be aware of the 'home node'
of the GSI in question.
[ Impact: cleanup, prepare the IRQ code to be more NUMA aware ]
Acked-by: Len Brown <lenb@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
LKML-Reference: <49F65560.20904@kernel.org>
Impact: use new API
Use the accessors rather than frobbing bits directly. Most of this is
in arch code I haven't even compiled, but is straightforward.
Signed-off-by: Mike Travis <travis@sgi.com>
Impact: cleanup, futureproof
In fact, all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in various
places.
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Impact: fix build error
to fix:
tip/arch/ia64/kernel/acpi.c:203: error: conflicting types for '__acpi_unmap_table'
tip/include/linux/acpi.h:82: error: previous declaration of '__acpi_unmap_table' was here
to prevent wrongly overwriting fixmap that still want to use.
ACPI used to rely on low mappings being all linearly mapped and
grew a habit: it never really unmapped certain kinds of tables
after use.
This can cause problems - for example the hypothetical case
when some spurious access still references it.
v2: remove prev_map and prev_size in __apci_map_table
v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to
early_acpi_os_unmap_memory
v4: fix typo in one acpi_get_table_with_size calling
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Acked-by: Len Brown <len.brown@intel.com>
On some boxes there exist both RSDT and XSDT table. But unfortunately
sometimes there exists the following error when XSDT table is used:
a. 32/64X address mismatch
b. The 32/64X FACS address mismatch
In such case the boot option of "acpi=rsdt" is provided so that
RSDT is tried instead of XSDT table when the system can't work well.
http://bugzilla.kernel.org/show_bug.cgi?id=8246
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
cc:Thomas Renninger <trenn@suse.de>
