path: root/arch/ia64/kernel/audit.c
2007-05-11[PATCH] audit signal recipientsAmy Griffis
When auditing syscalls that send signals, log the pid and security context for each target process. Optimize the data collection by adding a counter for signal-related rules, and avoiding allocating an aux struct unless we have more than one target process. For process groups, collect pid/context data in blocks of 16. Move the audit_signal_info() hook up in check_kill_permission() so we audit attempts where permission is denied. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] add SIGNAL syscall class (v3)Amy Griffis
Add a syscall class for sending signals. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-11[PATCH] audit: AUDIT_PERM supportAl Viro
add support for AUDIT_PERM predicate Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-11[PATCH] audit: more syscall classes addedAl Viro
2006-07-01[PATCH] audit syscall classesAl Viro
Allow to tie upper bits of syscall bitmap in audit rules to kernel-defined sets of syscalls. Infrastructure, a couple of classes (with 32bit counterparts for biarch targets) and actual tie-in on i386, amd64 and ia64. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
