path: root/arch/ia64/kernel/sal.c
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-12[PATCH] Dynamic kernel command-line: fixupsAlon Bar-Lev
Remove in-source externs, linux/init.h is included in all cases. This is a fixups for "Dynamic kernel command-line" patch. It also includes some uml __init fixups so that we can __initdata also its command_line. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Dynamic kernel command-line: ia64Alon Bar-Lev
1. Rename saved_command_line into boot_command_line. 2. Set command_line as __initdata. [akpm@osdl.org: move some declarations to the right place] Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-31[IA64] move SAL_CACHE_FLUSH check later in bootTroy Heber
The check to see if the firmware drops interrupts during a SAL_CACHE_FLUSH is done to early in the boot. SAL_CACHE_FLUSH expects to be able to make PAL calls in virtual mode, on some cell based machines a fault occurs causing a MCA. This patch moves the check after mmu_context_init so the TLB and VHPT are properly setup. Signed-off-by Troy Heber <troy.heber@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-06-21[IA64] SKI Simulator bootIan Wienand
Sorry I didn't notice earlier, but that BUG_ON triggers for me on the simulator. AFAICS the mask for itv is set in cpu_init(), which comes after sal_init(). Consequently on the simulator the itv still has its start value of zero. I've probably missed something, but I wonder why at this stage of the boot you even need to save and restore the itv? Signed-Off-By: Ian Wienand <ianw@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-02[IA64] avoid broken SAL_CACHE_FLUSH implementationsBjorn Helgaas
If SAL_CACHE_FLUSH drops interrupts, complain about it and fall back to using PAL_CACHE_FLUSH instead. This is to work around a defect in HP rx5670 firmware: when an interrupt occurs during SAL_CACHE_FLUSH, SAL drops the interrupt but leaves it marked "in-service", which leaves the interrupt (and others of equal or lower priority) masked. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
