path: root/arch/ia64/kernel/salinfo.c
2008-04-29ia64: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-12[IA64] tree-wide: Misc __cpu{initdata, init, exit} annotationsSatyam Sharma
* palinfo.c: palinfo_cpu_notifier is a CPU hotplug notifier_block, and can be marked __cpuinitdata, and the callback function palinfo_cpu_callback() itself can be marked __cpuinit. create_palinfo_proc_entries() is only called from __cpuinit callback or general __init code, therefore a candidate for __cpuinit itself. remove_palinfo_proc_entries() is only called from __cpuinit callback or general __exit code, therefore a candidate for __cpuexit. * salinfo.c: The CPU hotplug notifier_block can be __cpuinitdata. The callback salinfo_cpu_callback() is incorrectly marked __devinit -- it must be __cpuinit instead. * topology.c: cache_sysfs_init() is only called at device_initcall() time so marking it as __cpuinit is wrong and wasteful. It should be unconditionally __init. Also cleanup reference to hotplug notifier callback function from this function and replace with cache_add_dev(), which could also enable us to use other tricks to replace __cpuinit{data} annotations, as recently discussed on this list. cache_shared_cpu_map_setup() is only ever called from __cpuinit-marked functions hence both its definitions (SMP or !SMP) are candidates for __cpuinit itself. Also all_cpu_cache_info can be __cpuinitdata because only referenced from __cpuinit code. Signed-off-by: Satyam Sharma <satyam@infradead.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert ia64Josef Sipek
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[IA64] printing support for MCA/INITHidetoshi Seto
Printing message to console from MCA/INIT handler is useful, however doing oops_in_progress = 1 in them exactly makes something in kernel wrong. Especially it sounds ugly if system goes wrong after returning from recoverable MCA. This patch adds ia64_mca_printk() function that collects messages into temporary-not-so-large message buffer during in MCA/INIT environment and print them out later, after returning to normal context or when handlers determine to down the system. Also this print function is exported for use in extensional MCA handler. It would be useful to describe detail about recovery. NOTE: I don't think it is sane thing if temporary message buffer is enlarged enough to hold whole stack dumps from INIT, so buffering is disabled during stack dump from INIT-monarch (= default_monarch_init_process). please fix it in future. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-06-27[PATCH] cpu hotplug: use hotplug version of cpu notifier in appropriate placesChandra Seetharaman
Make use the of newly defined hotplug version of cpu_notifier functionality wherever appropriate. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[IA64] Add hotplug cpu to salinfo.c, replace semaphore with mutexKeith Owens
Add hotplug cpu support to salinfo.c. The cpu_event field is a cpumask so use the cpu_* macros consistently, replacing the existing mixture of cpu_* and *_bit macros. Instead of counting the number of outstanding events in a semaphore and trying to track that count over user space context, interrupt context, non-maskable interrupt context and cpu hotplug, replace the semaphore with a test for "any bits set" combined with a mutex. Modify the locking to make the test for "work to do" an atomic operation. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-11[PATCH] capable/capability.h (arch/)Randy Dunlap
arch: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-05[IA64] Allow salinfo_decode to detect signals on readKeith Owens
Return -EINTR instead of -ERESTARTSYS when signals are delivered during a blocked read of /proc/sal/*/event. This allows salinfo_decode to detect signals when it is blocked on a read of those files. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-11[IA64] MCA/INIT: avoid reading INIT record during INIT eventKeith Owens
Reading the INIT record from SAL during the INIT event has proved to be unreliable, and a source of hangs during INIT processing. The new MCA/INIT handlers remove the need to get the INIT record from SAL. Change salinfo.c so mca.c can just flag that a new record is available, without having to read the record during INIT processing. This patch can be applied without the new MCA/INIT handlers. Also clean up some usage of NR_CPUS which should have been using cpu_online(). Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-08-16[IA64] Initialize some spinlocksKeith Owens
Some IA64 spinlocks are not being initialized, make it so. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
