All the ia64 pvops code is now dead code since both
xen and kvm support have been ripped out [0] [1]. Just
that no one had troubled to rip this stuff out. The only
useful remaining pieces were the old pvops docs but that
was recently also generalized and moved out from ia64 [2].
This has been run time tested on an ia64 Madison system.
[0] 003f7de625890 "KVM: ia64: remove" since v3.19-rc1
[1] d52eefb47d4eb "ia64/xen: Remove Xen support for ia64" since v3.14-rc1
[2] "virtual: Documentation: simplify and generalize paravirt_ops.txt"
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Thanks to spatch, then a sweep for for_each_cpu_mask => for_each_cpu.
Cc: linux-ia64@vger.kernel.org
This patch adds a new interface to decode memory device (type 17)
to help error reporting on DIMMs.
Original-author: Tony Luck <tony.luck@intel.com>
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the ia64 uses of the __cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
x86 and ia64 can acquire extra hardware identification information
from DMI and print it along with task dumps; however, the usage isn't
consistent.
* x86 show_regs() collects vendor, product and board strings and print
them out with PID, comm and utsname. Some of the information is
printed again later in the same dump.
* warn_slowpath_common() explicitly accesses the DMI board and prints
it out with "Hardware name:" label. This applies to both x86 and
ia64 but is irrelevant on all other archs.
* ia64 doesn't show DMI information on other non-WARN dumps.
This patch introduces arch-specific hardware description used by
dump_stack(). It can be set by calling dump_stack_set_arch_desc()
during boot and, if exists, printed out in a separate line with
dmi_set_dump_stack_arch_desc() is added which sets arch-specific
description from DMI data. It uses dmi_ids_string[] which is set from
dmi_present() used for DMI debug message. It is superset of the
information x86 show_regs() is using. The function is called from x86
and ia64 boot code right after dmi_scan_machine().
This makes the explicit DMI handling in warn_slowpath_common()
unnecessary. Removed.
show_regs() isn't yet converted to use generic debug information
printing and this patch doesn't remove the duplicate DMI handling in
x86 show_regs(). The next patch will unify show_regs() handling and
remove the duplication.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #3
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f500 ffffffff82228240 0000000000000040 ffffffff8234a08e
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f500>] warn_slowpath_common+0x70/0xa0
[<ffffffff8108f54a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a0c3>] init_workqueues+0x35/0x505
v2: Use the same string as the debug message from dmi_present() which
also contains BIOS information. Move hardware name into its own
line as warn_slowpath_common() did. This change was suggested by
Bjorn Helgaas.
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
pm_idle() on ia64 was a synonym for default_idle().
So simply invoke default_idle() directly.
Signed-off-by: Len Brown <len.brown@intel.com>
Merge third batch of patches from Andrew Morton:
- Some MM stragglers
- core SMP library cleanups (on_each_cpu_mask)
- Some IPI optimisations
- kexec
- kdump
- IPMI
- the radix-tree iterator work
- various other misc bits.
"That'll do for -rc1. I still have ~10 patches for 3.4, will send
those along when they've baked a little more."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
backlight: fix typo in tosa_lcd.c
crc32: add help text for the algorithm select option
mm: move hugepage test examples to tools/testing/selftests/vm
mm: move slabinfo.c to tools/vm
mm: move page-types.c from Documentation to tools/vm
selftests/Makefile: make `run_tests' depend on `all'
selftests: launch individual selftests from the main Makefile
radix-tree: use iterators in find_get_pages* functions
radix-tree: rewrite gang lookup using iterator
radix-tree: introduce bit-optimized iterator
fs/proc/namespaces.c: prevent crash when ns_entries[] is empty
nbd: rename the nbd_device variable from lo to nbd
pidns: add reboot_pid_ns() to handle the reboot syscall
sysctl: use bitmap library functions
ipmi: use locks on watchdog timeout set on reboot
ipmi: simplify locking
ipmi: fix message handling during panics
ipmi: use a tasklet for handling received messages
ipmi: increase KCS timeouts
ipmi: decrease the IPMI message transaction time in interrupt mode
This was marked as obsolete for quite a while now.. Now it is time to
remove it altogether. And while doing this, get rid of first_cpu() as
well. Also, remove the redundant setting of cpu_online_mask in
smp_prepare_cpus() because the generic code would have already set cpu 0
in cpu_online_mask.
Reported-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Disintegrate asm/system.h for IA64.
Acked-by: Tony Luck <tony.luck@intel.com>
cc: linux-ia64@vger.kernel.org
While working on the upcoming SLES11 SP2, I ran into an issue with booting the
panic kernel on a kernel crash. In the first iteration I found out that the
initial register backing store gets overwritten with zeroes, causing a kernel
crash shortly afterwards.
Further investigation revealed that rsvd_region[] contains overlapping
entries: find_memmap_space() returns a pointer which lies between KERNEL_START
and _end. This is correct with the EFI memmap as patched by the kexec
purgatory code. That code removes vmlinux LOAD segments from the usable map,
but there is a pretty large hole between the gate section and the per-cpu
section.
This happens because reserve_memory() blindly marks [KERNEL_START, __end]
as reserved, even though there is a free block in the middle in the kexec
case because it noticed a large gap between sections and modified the
efi_memory_map to account for this.
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
setup_elfcorehdr and saved_max_pfn
The Xen PV drivers in a crashed HVM guest can not connect to the dom0
backend drivers because both frontend and backend drivers are still in
connected state. To run the connection reset function only in case of a
crashdump, the is_kdump_kernel() function needs to be available for the PV
driver modules.
Consolidate elfcorehdr_addr, setup_elfcorehdr and saved_max_pfn into
kernel/crash_dump.c Also export elfcorehdr_addr to make is_kdump_kernel()
usable for modules.
Leave 'elfcorehdr' as early_param(). This changes powerpc from __setup()
to early_param(). It adds an address range check from x86 also on ia64
and powerpc.
[akpm@linux-foundation.org: additional #includes]
[akpm@linux-foundation.org: remove elfcorehdr_addr export]
[akpm@linux-foundation.org: fix for Tejun's mm/nobootmem.c changes]
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Thomas Gleixner is cleaning up the generic irq code, and ia64 ran
into problems because it calls register_intr() before early_irq_init()
is called. Move the call to acpi_boot_init() from setup_arch() to
init_IRQ().
As a bonus - moving the call later means we no longer need the
hacks in iosapic.c to switch between the bootmem and regular
allocator - we can just used kzalloc() for allocation.
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: <linux-arch@vger.kernel.org>
This has been broken since May 2008 when Al Viro killed altroot support.
Since nobody has complained, it would appear that there are no users of
this code (A plausible theory since the main OSVs that support ia64 prefer
to use the IA32-EL software emulation).
This patch updates percpu related symbols in ia64 such that percpu
symbols are unique and don't clash with local symbols. This serves
two purposes of decreasing the possibility of global percpu symbol
collision and allowing dropping per_cpu__ prefix from percpu symbols.
* arch/ia64/kernel/setup.c: s/cpu_info/ia64_cpu_info/
Partly based on Rusty Russell's "alloc_percpu: rename percpu vars
which cause name clashes" patch.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Unlike other archs, ia64 reserves space for percpu areas during early
memory initialization. These areas occupy a contiguous region indexed
by cpu number on contiguous memory model or are grouped by node on
discontiguous memory model.
As allocation and initialization are done by the arch code, all that
setup_per_cpu_areas() needs to do is communicating the determined
layout to the percpu allocator. This patch implements
setup_per_cpu_areas() for both contig and discontig memory models and
drops HAVE_LEGACY_PER_CPU_AREA.
Please note that for contig model, the allocation itself is modified
only to allocate for possible cpus instead of NR_CPUS. As dynamic
percpu allocator can handle non-direct mapping, there's no reason to
allocate memory for cpus which aren't possible.
Cc: linux-ia64 <linux-ia64@vger.kernel.org>
All information necessary to initialize cpu possible and present maps
are available once early_acpi_boot_init() is complete. Reorganize
setup_arch() and acpi init functions such that,
* CPU information is printed after LAPIC entries are parsed in
early_acpi_boot_init().
* smp_build_cpu_map() is called by setup_arch() instead of acpi
functions.
* smp_build_cpu_map() is called once all CPU related information is
available before memory is initialized.
This is primarily to allow find_memory() to use cpu maps but is also a
general cleanup. Please note that with this change, the somewhat
ad-hoc early_cpu_possible_map defined and used for NUMA configurations
is probably unnecessary. Something to clean up another day.
Fix ia64 build setup_per_cpu_areas() redifinition issue in UP
configuration. When compiling ia64 kernel in UP configuration, the
following compilation errors are reported:
arch/ia64/kernel/setup.c:860: error: redefinition of 'setup_per_cpu_areas'
include/linux/percpu.h:185: error: previous definition of 'setup_per_cpu_areas' was here
The patch fixes the issue in arch/ia64/kernel/setup.c
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
It is generally agreed that it would be beneficial for u64 to be an
unsigned long long on all architectures. ia64 (in common with several
other 64-bit architectures) currently uses unsigned long. Migrating
piecemeal is too painful; this giant patch fixes all compilation warnings
and errors that come as a result of switching to use int-ll64.h.
Note that userspace will still see __u64 defined as unsigned long. This
is important as it affects C++ name mangling.
[Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use
u64 for start/end rather than unsigned long]
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Replace:
if (test)
BUG();
with
BUG_ON(test);
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com>
implement binary patching optimization for pv_cpu_ops.
With this optimization, indirect call for pv_cpu_ops methods can be
converted into inline execution or direct call.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
Impact: cleanup, futureproof
In fact, all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in various
places.
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Signed-off-by: Mike Travis <travis@sgi.com>
IA64 kdump kernel failed to initialize /proc/vmcore in 2.6.28-rc2.
A bug was introduced in this patch commit:
d9a9855d0b06ca6d6cc92596fedcc03f8512e062
always reserve elfcore header memory in crash kernel
The problem was that the call to reserve_elfcorehdr() should be placed
in CONFIG_CRASH_DUMP rather than in CONFIG_CRASH_KERNEL, which does
not exist.
Signed-off-by: Jay Lan <jlan@sgi.com>
Acked-by: Simon Hormon <horms@verge.net.au>
This fixes a regression introduced by 2c6e6db41f01b6b4eb98809350827c9678996698
"Minimize per_cpu reservations." That patch incorrectly used information about
what CPUs are possible that was not yet initialized by ACPI. The end result
was that per_cpu structures for offline CPUs were not initialized causing a
NULL pointer reference.
Since we cannot do the full acpi_boot_init() call any earlier, the simplest
fix is to just parse the MADT for SAPIC entries early to find the CPU
info. This should also allow for some cleanup of the code added by the
"Minimize per_cpu reservations". This patch just fixes the regressions, the
cleanup will come in a later patch.
Signed-off-by: Doug Chapman <doug.chapman@hp.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
CC: Robin Holt <holt@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (41 commits)
[IA64] Fix annoying IA64_TR_ALLOC_MAX message.
[IA64] kill sys32_pipe
[IA64] remove sys32_pause
[IA64] Add Variable Page Size and IA64 Support in Intel IOMMU
ia64/pv_ops: paravirtualized instruction checker.
ia64/xen: a recipe for using xen/ia64 with pv_ops.
ia64/pv_ops: update Kconfig for paravirtualized guest and xen.
ia64/xen: preliminary support for save/restore.
ia64/xen: define xen machine vector for domU.
ia64/pv_ops/xen: implement xen pv_time_ops.
ia64/pv_ops/xen: implement xen pv_irq_ops.
ia64/pv_ops/xen: define the nubmer of irqs which xen needs.
ia64/pv_ops/xen: implement xen pv_iosapic_ops.
ia64/pv_ops/xen: paravirtualize entry.S for ia64/xen.
ia64/pv_ops/xen: paravirtualize ivt.S for xen.
ia64/pv_ops/xen: paravirtualize DO_SAVE_MIN for xen.
ia64/pv_ops/xen: define xen paravirtualized instructions for hand written assembly code
ia64/pv_ops/xen: define xen pv_cpu_ops.
ia64/pv_ops/xen: define xen pv_init_ops for various xen initialization.
ia64/pv_ops/xen: elf note based xen startup.
elfcore header memory needs to be reserved in a crash kernel. This means
that the relevant code should be protected by CONFIG_CRASH_DUMP rather
than CONFIG_PROC_VMCORE.
Signed-off-by: Simon Horman <horms@verge.net.au>
Cc: Vivek Goyal <vgoyal@redhat.com>
The usage of elfcorehdr_addr has changed recently such that being set to
ELFCORE_ADDR_MAX is used by is_kdump_kernel() to indicate if the code is
executing in a kernel executed as a crash kernel.
However, arch/ia64/kernel/setup.c:reserve_elfcorehdr will rest
elfcorehdr_addr to ELFCORE_ADDR_MAX on error, which means any subsequent
calls to is_kdump_kernel() will return 0, even though they should return
1.
Ok, at this point in time there are no subsequent calls, but I think its
fair to say that there is ample scope for error or at the very least
confusion.
This patch add an extra state, ELFCORE_ADDR_ERR, which indicates that
elfcorehdr_addr was passed on the command line, and thus execution is
taking place in a crashdump kernel, but vmcore can't be used for some
reason. This is tested for using is_vmcore_usable() and set using
vmcore_unusable(). A subsequent patch makes use of this new code.
To summarise, the states that elfcorehdr_addr can now be in are as follows:
ELFCORE_ADDR_MAX: not a crashdump kernel
ELFCORE_ADDR_ERR: crashdump kernel but vmcore is unusable
any other value: crash dump kernel and vmcore is usable
o elfcorehdr_addr is used by not only the code under CONFIG_PROC_VMCORE
but also by the code which is not inside CONFIG_PROC_VMCORE. For
example, is_kdump_kernel() is used by powerpc code to determine if
kernel is booting after a panic then use previous kernel's TCE table.
So even if CONFIG_PROC_VMCORE is not set in second kernel, one should be
able to correctly determine that we are booting after a panic and setup
calgary iommu accordingly.
o So remove the assumption that elfcorehdr_addr is under
CONFIG_PROC_VMCORE.
o Move definition of elfcorehdr_addr to arch dependent crash files.
(Unfortunately crash dump does not have an arch independent file
otherwise that would have been the best place).
o kexec.c is not the right place as one can Have CRASH_DUMP enabled in
second kernel without KEXEC being enabled.
o I don't see sh setup code parsing the command line for
elfcorehdr_addr. I am wondering how does vmcore interface work on sh.
Anyway, I am atleast defining elfcoredhr_addr so that compilation is not
broken on sh.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Simon Horman <horms@verge.net.au>
Acked-by: Paul Mundt <lethal@linux-sh.org>
The patch contains Intel IOMMU IA64 specific code. It defines new
machvec dig_vtd, hooks for IOMMU, DMAR table detection, cache line flush
function, etc.
For a generic kernel with CONFIG_DMAR=y, if Intel IOMMU is detected,
dig_vtd is used for machinve vector. Otherwise, kernel falls back to
dig machine vector. Kernel parameter "machvec=dig" or "intel_iommu=off"
can be used to force kernel to boot dig machine vector.
Peter Chubb reported that commit 3463a93def55c309f3c0d0a8aaf216be3be42d64
(Update check_sal_cache_flush to use platform_send_ipi()) broke
Ski because it does not implement IPIs.
Tony Luck suggested we just #ifndef out the call (since the simulator
does not have the SAL bug that this code is attempting to detect and
workaround)
ia64 handles per-cpu variables a litle differently from other architectures
in that it maps the physical memory allocated for each cpu at a constant
virtual address (0xffffffffffff0000). This mapping is not enabled until
the architecture specific cpu_init() function is run, which causes problems
since some generic code is run before this point. In particular when
CONFIG_PRINTK_TIME is enabled, the boot cpu will trap on the access to
per-cpu memory at the first printk() call so the boot will fail without
the kernel printing anything to the console.
Fix this by allocating percpu memory for cpu0 in the kernel data section
and doing all initialization to enable percpu access in head.S before
calling any generic code.
Other cpus must take care not to access per-cpu variables too early, but
their code path from start_secondary() to cpu_init() is all in arch/ia64
After moving the the include files there were a few clean-ups:
1) Some files used #include <asm-ia64/xyz.h>, changed to <asm/xyz.h>
2) Some comments alerted maintainers to look at various header files to
make matching updates if certain code were to be changed. Updated these
comments to use the new include paths.
3) Some header files mentioned their own names in initial comments. Just
deleted these self references.
On a system where there are no hot pluggable cpus "additional_cpus"
is still set to -1 at the point where we call per_cpu_scan_finalize().
If we didn't find an SRAT table and so pick the default "32" for the
number of cpus, when we get to:
high_cpu = min(high_cpu + reserve_cpus, NR_CPUS);
we will end up initializing for just 31 cpus ... and so we will
die horribly when bringing up cpu#32.
Problem introduced by: 2c6e6db41f01b6b4eb98809350827c9678996698
Acked-by: Robin Holt <holt@sgi.com>
Call check_sal_cache_flush() after platform_setup() as
check_sal_cache_flush() now relies on being able to call platform
vector code.
Problem was introduced by: 3463a93def55c309f3c0d0a8aaf216be3be42d64
"Update check_sal_cache_flush to use platform_send_ipi()"
Signed-off-by: Jes Sorensen <jes@sgi.com>
Tested-by: Alex Chiang: <achiang@hp.com>
environment.
define pv_init_ops hooks which represents various initialization
hooks for paravirtualized environment. and add hooks.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
Problem: An application violating the architectural rules regarding
operation dependencies and having specific Register Stack Engine (RSE)
state at the time of the violation, may result in an illegal operation
fault and invalid RSE state. Such faults may initiate a cascade of
repeated illegal operation faults within OS interruption handlers.
The specific behavior is OS dependent.
Implication: An application causing an illegal operation fault with
specific RSE state may result in a series of illegal operation faults
and an eventual OS stack overflow condition.
Workaround: OS interruption handlers that switch to kernel backing
store implement a check for invalid RSE state to avoid the series
of illegal operation faults.
The core of the workaround is the RSE_WORKAROUND code sequence
inserted into each invocation of the SAVE_MIN_WITH_COVER and
SAVE_MIN_WITH_COVER_R19 macros. This sequence includes hard-coded
constants that depend on the number of stacked physical registers
being 96. The rest of this patch consists of code to disable this
workaround should this not be the case (with the presumption that
if a future Itanium processor increases the number of registers, it
would also remove the need for this patch).
Move the start of the RBS up to a mod32 boundary to avoid some
corner cases.
The dispatch_illegal_op_fault code outgrew the spot it was
squatting in when built with this patch and CONFIG_VIRT_CPU_ACCOUNTING=y
Move it out to the end of the ivt.
Some IA64 machines map all cell-local memory above 4 GB (32 bit limit).
However, in most cases, the kernel needs some memory below that limit that is
DMA-capable. So in this machine configuration, the crashkernel will be reserved
above 4 GB.
For machines that use SWIOTLB implementation because they lack an I/O MMU
the low memory is required by the SWIOTLB implementation. In that case,
it doesn't make sense to reserve the crashkernel at all because it's unusable
for kdump.
A special case is the "hpzx1" machine vector. In theory, it has a I/O MMU, so
it can be booted above 4 GB. However, in the kdump case that is not possible
because of changeset 51b58e3e26ebfb8cd56825c4b396ed251f51dec9:
On HP zx1 machines, the 'machvec=dig' parameter is needed for the kdump
kernel to avoid problems with the HP sba iommu. The problem is that during
the boot of the kdump kernel, the iommu is re-initialized, so in-flight DMA
from improperly shutdown drivers causes an IOTLB miss which leads to an
MCA. With kdump, the idea is to get into the kdump kernel with as little
code as we can, so shutting down drivers properly is not an option.
The workaround is to add 'machvec=dig' to the kdump kernel boot parameters.
This makes the kdump kernel avoid using the sba iommu altogether, leaving
the IOTLB intact. Any ongoing DMA falls harmlessly outside the kdump
kernel. After the kdump kernel reboots, all devices will have been
shutdown properly and DMA stopped.
This patch pushes that functionality into the sba iommu initialization
code, so that users won't have to find the obscure documentation telling
them about 'machvec=dig'.
This means that also for hpzx1 it's not possible to boot when all
memory is above the 4 GB limit. So the only machine vectors that can handle
this case are "sn2" and "uv".
Signed-off-by: Bernhard Walle <bwalle@suse.de>
arch/ia64/kernel/mca.c
arch/ia64/mm/tlb.c
There is a NUMA memory configuration issue in 2.6.24:
A 2-node machine of ours has got the following memory layout:
Node 0: 0 - 2 Gbytes
Node 0: 4 - 8 Gbytes
Node 1: 8 - 16 Gbytes
Node 0: 16 - 18 Gbytes
"efi_memmap_init()" merges the three last ranges into one.
"register_active_ranges()" is called as follows:
efi_memmap_walk(register_active_ranges, NULL);
i.e. once for the 4 - 18 Gbytes range. It picks up the node
number from the start address, and registers all the memory for
the node #0.
"register_active_ranges()" should be called as follows to
make sure there is no merged address range at its entry:
efi_memmap_walk(filter_memory, register_active_ranges);
"filter_memory()" is similar to "filter_rsvd_memory()",
but the reserved memory ranges are not filtered out.
Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net>
This attached patch significantly shrinks boot memory allocation on ia64.
It does this by not allocating per_cpu areas for cpus that can never
exist.
In the case where acpi does not have any numa node description of the
cpus, I defaulted to assigning the first 32 round-robin on the known
nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu().
Signed-off-by: Robin Holt <holt@sgi.com>
The patch defines kernel parameter "nptcg=". The parameter overrides max number
of concurrent global TLB purges which is reported from either PAL_VM_SUMMARY or
SAL PALO.
According to SDM2.2, Itanium supports multiple outstanding ptc.g instructions.
But current kernel function ia64_global_tlb_purge() uses a spinlock to serialize
ptc.g instructions issued by multiple processors. This serialization might have
scalability issue on a big SMP machine where many processors could purge TLB
in parallel.
The patch fixes this problem by issuing multiple ptc.g instructions in
ia64_global_tlb_purge(). It also adds support for the "PALO" table to get
a platform view of the max number of outstanding ptc.g instructions (which
may be different from the processor view found from PAL_VM_SUMMARY).
PALO specification can be found at: http://www.dig64.org/home/DIG64_PALO_R1_0.pdf
spinaphore implementation by Matthew Wilcox.
__FUNCTION__ is gcc-specific, use __func__
Long lines have been kept where they exist, some small spacing changes
have been done.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
remove remaining printk_clock references from ia64.
Rename _bss to __bss_start as on other architectures. That makes it
possible to use the <linux/sections.h> instead of own declarations. Also
add __bss_stop because that symbol exists on other architectures.
Clean up the process for presenting the "physical id" field in
/proc/cpuinfo.
- remove global smp_num_cpucores, as it is mostly useless
- remove check_for_logical_procs(), since we do the same
functionality in identify_siblings()
- reflow logic in identify_siblings(). If an older CPU
does not implement PAL_LOGICAL_TO_PHYSICAL, we may still
be able to get useful information from SAL_PHYSICAL_ID_INFO
- in identify_siblings(), threads/cores are a property of
the CPU, not the platform
- remove useless printk's about multi-core / thread
capability in identify_siblings(), as that information
is readily available in /proc/cpuinfo, and printing for
the BSP only adds little value
- smp_num_siblings is now meaningful if any CPU in the
system supports threads, not just the BSP
- expose "physical id" field, even on CPUs that are not
multi-core / multi-threaded (as long as we have a valid
value). Now we know what sockets Madisons live in too.
