path: root/arch/ia64/kernel
2009-09-02[IA64] Fix warning in dma-mapping.cLuck, Tony
arch/ia64/kernel/dma-mapping.c:14: warning: control reaches end of non-void function arch/ia64/kernel/dma-mapping.c:14: warning: no return statement in function returning non-void This warning was introduced by commit: 390bd132b2831a2ad0268e84bffbfc0680debfe5 Add dma_debug_init() for ia64 Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-08-11arch/ia64/kernel/iosapic: missing test after ioremap()Roel Kluin
Missing test after ioremap() Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Fenghua Yu <fenghua.yu@intel.com>
2009-08-11ia64/topology.c: exit cache_add_dev when kobject_init_and_add failsFenghua Yu
Make cache_add_dev exit sysfs when kobject_init_and_add returns an error. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
2009-08-11IA64: includecheck fix: ia64, ia64_ksyms.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/ia64/kernel/ia64_ksyms.c: asm/page.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Fenghua Yu <fenghua.yu@intel.com>
2009-08-11Bug Fix arch/ia64/kernel/pci-dma.c: fix recursive dma_supported() call in ↵Fenghua Yu
iommu_dma_supported() In commit 160c1d8e40866edfeae7d68816b7005d70acf391, dma_ops->dma_supported = iommu_dma_supported; This dma_ops->dma_supported is first called in platform_dma_init() during kernel boot. Then dma_ops->dma_supported will be called recursively in iommu_dma_supported. Kernel can not boot because kernel can not get out of iommu_dma_supported until it runs out of stack memory. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
2009-07-17Add dma_debug_init() for ia64fujita
The commit 9916219579d078c80377dd3988c2cc213536d868 was supposed to add CONFIG_DMA_API_DEBUG support to IA64 however I forgot to add dma_debug_init(). Signed-off-by: fujita <fujita@tulip.osrg.net> Acked-by: Fenghua Yu <fenghua.yu@intel.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30[IA64] address compiler warnings perfmon.c/salinfo.cJan Beulich
perfmon.c has a dubious cast directly from "int" to "void *". Add an intermediate cast to "long" to keep gcc happy. salinfo.c uses "down_trylock()" in a highly creative way (explained in the comments in the file) ... but it does kick out this warning: arch/ia64/kernel/salinfo.c:195: warning: ignoring return value of 'down_trylock' which people occasionally try to "fix" in ways that do not work. Use some casts to keep gcc quiet. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-30[IA64] Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
2009-06-22Merge git://git.infradead.org/~dwmw2/iommu-2.6.31Linus Torvalds
* git://git.infradead.org/~dwmw2/iommu-2.6.31: intel-iommu: Fix one last ia64 build problem in Pass Through Support VT-d: support the device IOTLB VT-d: cleanup iommu_flush_iotlb_psi and flush_unmaps VT-d: add device IOTLB invalidation support VT-d: parse ATSR in DMA Remapping Reporting Structure PCI: handle Virtual Function ATS enabling PCI: support the ATS capability intel-iommu: dmar_set_interrupt return error value intel-iommu: Tidy up iommu->gcmd handling intel-iommu: Fix tiny theoretical race in write-buffer flush. intel-iommu: Clean up handling of "caching mode" vs. IOTLB flushing. intel-iommu: Clean up handling of "caching mode" vs. context flushing. VT-d: fix invalid domain id for KVM context flush Fix !CONFIG_DMAR build failure introduced by Intel IOMMU Pass Through Support Intel IOMMU Pass Through Support Fix up trivial conflicts in drivers/pci/{intel-iommu.c,intr_remapping.c}
2009-06-20ACPI: pdc init related memory leak with physical CPU hotplugPallipadi, Venkatesh
arch_acpi_processor_cleanup_pdc() in x86 and ia64 results in memory allocated for _PDC objects that is never freed and will cause memory leak in case of physical CPU remove and add. Patch fixes the memory leak by freeing the objects soon after _PDC is evaluated. Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17Pull for-2.6.31 into releaseTony Luck
2009-06-17[IA64] Convert ia64 to use int-ll64.hMatthew Wilcox
It is generally agreed that it would be beneficial for u64 to be an unsigned long long on all architectures. ia64 (in common with several other 64-bit architectures) currently uses unsigned long. Migrating piecemeal is too painful; this giant patch fixes all compilation warnings and errors that come as a result of switching to use int-ll64.h. Note that userspace will still see __u64 defined as unsigned long. This is important as it affects C++ name mangling. [Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use u64 for start/end rather than unsigned long] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-17[IA64] Fix build error in paravirt_patchlist.cJes Sorensen
Andrew cleaned up some #include tangles in: commit 0d9c25dde878a636ee9a9b53923569171bf9a55b headers: move module_bug_finalize()/module_bug_cleanup() definitions into module.h which resulted in this build error for ia64: CC arch/ia64/kernel/paravirt_patchlist.o arch/ia64/kernel/paravirt_patchlist.c:43: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__initdata' arch/ia64/kernel/paravirt_patchlist.c:54: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'paravirt_get_gate_patchlist' arch/ia64/kernel/paravirt_patchlist.c:76: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'paravirt_get_gate_section' make[1]: *** [arch/ia64/kernel/paravirt_patchlist.o] Error 1 The problem was that paravirt_patchlist.c was relying on some of the nested includes (specifically that linux/bug.h included linux/module.h Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-16remove put_cpu_no_resched()Thomas Gleixner
put_cpu_no_resched() is an optimization of put_cpu() which unfortunately can cause high latencies. The nfs iostats code uses put_cpu_no_resched() in a code sequence where a reschedule request caused by an interrupt between the get_cpu() and the put_cpu_no_resched() can delay the reschedule for at least HZ. The other users of put_cpu_no_resched() optimize correctly in interrupt code, but there is no real harm in using the put_cpu() function which is an alias for preempt_enable(). The extra check of the preemmpt count is not as critical as the potential source of missing a reschedule. Debugged in the preempt-rt tree and verified in mainline. Impact: remove a high latency source [akpm@linux-foundation.org: build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not check NUMA node ID when the caller knows the node is ↵Mel Gorman
valid Callers of alloc_pages_node() can optionally specify -1 as a node to mean "allocate from the current node". However, a number of the callers in fast paths know for a fact their node is valid. To avoid a comparison and branch, this patch adds alloc_pages_exact_node() that only checks the nid with VM_BUG_ON(). Callers that know their node is valid are then converted. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> [for the SLOB NUMA bits] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16[IA64] hook up new rt_tgsigqueueinfo syscallTony Luck
Assign syscall #1321 for rt_tgsigqueueinfo. Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-15[IA64] msi_ia64.c dmar_msi_type should be staticJaswinder Singh Rajput
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-15[IA64] remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-15[IA64] remove obsolete irq_desc_t typedefThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users and remove the typedef. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-15[IA64] remove obsolete no_irq_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup convert the last remaining users to no_irq_chip Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-11Merge branch 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits) KVM: Prevent overflow in largepages calculation KVM: Disable large pages on misaligned memory slots KVM: Add VT-x machine check support KVM: VMX: Rename rmode.active to rmode.vm86_active KVM: Move "exit due to NMI" handling into vmx_complete_interrupts() KVM: Disable CR8 intercept if tpr patching is active KVM: Do not migrate pending software interrupts. KVM: inject NMI after IRET from a previous NMI, not before. KVM: Always request IRQ/NMI window if an interrupt is pending KVM: Do not re-execute INTn instruction. KVM: skip_emulated_instruction() decode instruction if size is not known KVM: Remove irq_pending bitmap KVM: Do not allow interrupt injection from userspace if there is a pending event. KVM: Unprotect a page if #PF happens during NMI injection. KVM: s390: Verify memory in kvm run KVM: s390: Sanity check on validity intercept KVM: s390: Unlink vcpu on destroy - v2 KVM: s390: optimize float int lock: spin_lock_bh --> spin_lock KVM: s390: use hrtimer for clock wakeup from idle - v2 KVM: s390: Fix memory slot versus run - v3 ...
2009-06-10KVM: use smp_send_reschedule in kvm_vcpu_kickMarcelo Tosatti
KVM uses a function call IPI to cause the exit of a guest running on a physical cpu. For virtual interrupt notification there is no need to wait on IPI receival, or to execute any function. This is exactly what the reschedule IPI does, without the overhead of function IPI. So use it instead of smp_call_function_single in kvm_vcpu_kick. Also change the "guest_mode" variable to a bit in vcpu->requests, and use that to collapse multiple IPI's that would be issued between the first one and zeroing of guest mode. This allows kvm_vcpu_kick to called with interrupts disabled. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-05-01Fix !CONFIG_DMAR build failure introduced by Intel IOMMU Pass Through SupportFenghua Yu
This updated patch should fix the compiling errors and remove the extern iommu_pass_through from drivers/pci/intel-iommu.c file. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-29Intel IOMMU Pass Through SupportFenghua Yu
The patch adds kernel parameter intel_iommu=pt to set up pass through mode in context mapping entry. This disables DMAR in linux kernel; but KVM still runs on VT-d and interrupt remapping still works. In this mode, kernel uses swiotlb for DMA API functions but other VT-d functionalities are enabled for KVM. KVM always uses multi level translation page table in VT-d. By default, pass though mode is disabled in kernel. This is useful when people don't want to enable VT-d DMAR in kernel but still want to use KVM and interrupt remapping for reasons like DMAR performance concern or debug purpose. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Weidong Han <weidong@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-28irq: change ACPI GSI APIs to also take a device argumentYinghai Lu
We want to use dev_to_node() later on, to be aware of the 'home node' of the GSI in question. [ Impact: cleanup, prepare the IRQ code to be more NUMA aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Len Brown <lenb@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-acpi@vger.kernel.org Cc: linux-ia64@vger.kernel.org LKML-Reference: <49F65560.20904@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28irq: change ->set_affinity() to return statusYinghai Lu
according to Ingo, change set_affinity() in irq_chip should return int, because that way we can handle failure cases in a much cleaner way, in the genirq layer. v2: fix two typos [ Impact: extend API ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-arch@vger.kernel.org LKML-Reference: <49F654E9.4070809@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-16[IA64] smp_flush_tlb_mm() should only send IPI's to cpus in cpu_vm_maskDimitri Sivanich
Having flush_tlb_mm->smp_flush_tlb_mm() send an IPI to every cpu on the system is occasionally triggering spin_lock contention in generic_smp_call_function_interrupt(). Follow x86 arch's lead and only sends IPIs to the cpus in mm->cpu_vm_mask. Experiments with this change have shown significant improvement in this contention issue. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-16[IA64] export smp_send_rescheduleMarcelo Tosatti
KVM will use smp_send_reschedule to force a cpu out of guest mode. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-13Replace all DMA_nBIT_MASK macro with DMA_BIT_MASK(n)Yang Hongyang
This is the second go through of the old DMA_nBIT_MASK macro,and there're not so many of them left,so I put them into one patch.I hope this is the last round. After this the definition of the old DMA_nBIT_MASK macro could be removed. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Lindgren <tony@atomide.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Greg KH <greg@kroah.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08[IA64] wire up preadv/pwritev system callsTony Luck
Gerd Hoffmann added these to Linux. Let ia64 use them. Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-07dma-mapping: replace all DMA_24BIT_MASK macro with DMA_BIT_MASK(24)Yang Hongyang
Replace all DMA_24BIT_MASK macro with DMA_BIT_MASK(24) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_40BIT_MASK macro with DMA_BIT_MASK(40)Yang Hongyang
Replace all DMA_40BIT_MASK macro with DMA_BIT_MASK(40) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-02Simplify copy_thread()Alexey Dobriyan
First argument unused since 2.3.11. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (29 commits) [IA64] BUG to BUG_ON changes [IA64] Fix typo/thinko in arch/ia64/sn/kernel/sn2/sn2_smp.c ia64: remove some warnings. ia64/xen: fix the link error. ia64/pv_ops/bp/xen: implemented binary patchable pv_cpu_ops. ia64/pv_ops/binary patch: define paravirt_dv_serialize_data() and suppress false positive warning. ia64/pv_ops/bp/module: support binary patching for kernel module. ia64/pv_ops: implement binary patching optimization for native. ia64/pv_op/binarypatch: add helper functions to support binary patching for paravirt_ops. ia64/pv_ops/xen/gate.S: xen gate page paravirtualization ia64/pv_ops: paravirtualize gate.S. ia64/pv_ops: move down __kernel_syscall_via_epc. ia64/pv_ops/xen: define xen specific gate page. ia64/pv_ops: gate page paravirtualization. ia64/pv_ops/xen/pv_time_ops: implement sched_clock. ia64/pv_ops/pv_time_ops: add sched_clock hook. ia64/pv_ops/xen: paravirtualize read/write ar.itc and ar.itm ia64/pv_ops: paravirtualize mov = ar.itc. ia64/pv_ops/pvchecker: support mov = ar.itc paravirtualization ia64/pv_ops: paravirtualize fsys.S. ...
2009-04-01[IA64] BUG to BUG_ON changesStoyan Gaydarov
Replace: if (test) BUG(); with BUG_ON(test); Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-01rtc: add platform driver for EFIdann frazier
Munge Stephane Eranian's efirtc.c code into an rtc platform driver [akpm@linux-foundation.org: use is_leap_year()] Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: stephane eranian <eranian@googlemail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Pull pvops into release branchTony Luck
2009-03-31Pull cpumask into release branchTony Luck
2009-03-30Merge branch 'proc-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: Revert "proc: revert /proc/uptime to ->read_proc hook" proc 2/2: remove struct proc_dir_entry::owner proc 1/2: do PDE usecounting even for ->read_proc, ->write_proc proc: fix sparse warnings in pagemap_read() proc: move fs/proc/inode-alloc.txt comment into a source file
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-28Merge branch 'linus' into core/iommuIngo Molnar
Conflicts: arch/x86/Kconfig
2009-03-28Merge branch 'percpu-cpumask-x86-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'percpu-cpumask-x86-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (682 commits) percpu: fix spurious alignment WARN in legacy SMP percpu allocator percpu: generalize embedding first chunk setup helper percpu: more flexibility for @dyn_size of pcpu_setup_first_chunk() percpu: make x86 addr <-> pcpu ptr conversion macros generic linker script: define __per_cpu_load on all SMP capable archs x86: UV: remove uv_flush_tlb_others() WARN_ON percpu: finer grained locking to break deadlock and allow atomic free percpu: move fully free chunk reclamation into a work percpu: move chunk area map extension out of area allocation percpu: replace pcpu_realloc() with pcpu_mem_alloc() and pcpu_mem_free() x86, percpu: setup reserved percpu area for x86_64 percpu, module: implement reserved allocation and use it for module percpu variables percpu: add an indirection ptr for chunk page map access x86: make embedding percpu allocator return excessive free space percpu: use negative for auto for pcpu_setup_first_chunk() arguments percpu: improve first chunk initial area map handling percpu: cosmetic renames in pcpu_setup_first_chunk() percpu: clean up percpu constants x86: un-__init fill_pud/pmd/pte x86: remove vestigial fix_ioremap prototypes ... Manually merge conflicts in arch/ia64/kernel/irq_ia64.c
2009-03-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix kstat_this_cpu build breakage
