path: root/arch/ia64/mm/init.c
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-08[IA64] Remove COMPAT_IA32 supportTony Luck
This has been broken since May 2008 when Al Viro killed altroot support. Since nobody has complained, it would appear that there are no users of this code (A plausible theory since the main OSVs that support ia64 prefer to use the IA32-EL software emulation). Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-01-06[IA64] use helpers for rlimitsJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in 3e10e716abf3c71bdb5d86b8f507f9e72236c9cd or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-02ia64: don't alias VMALLOC_END to vmalloc_endTejun Heo
If CONFIG_VIRTUAL_MEM_MAP is enabled, ia64 defines macro VMALLOC_END as unsigned long variable vmalloc_end which is adjusted to prepare room for vmemmap. This becomes probnlematic if a local variables vmalloc_end is defined in some function (not very unlikely) and VMALLOC_END is used in the function - the function thinks its referencing the global VMALLOC_END value but would be referencing its own local vmalloc_end variable. There's no reason VMALLOC_END should be a macro. Just define it as an unsigned long variable if CONFIG_VIRTUAL_MEM_MAP is set to avoid nasty surprises. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64 <linux-ia64@vger.kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org>
2009-09-23kcore: use registerd physmem informationKAMEZAWA Hiroyuki
For /proc/kcore, each arch registers its memory range by kclist_add(). In usual, - range of physical memory - range of vmalloc area - text, etc... are registered but "range of physical memory" has some troubles. It doesn't updated at memory hotplug and it tend to include unnecessary memory holes. Now, /proc/iomem (kernel/resource.c) includes required physical memory range information and it's properly updated at memory hotplug. Then, it's good to avoid using its own code(duplicating information) and to rebuild kclist for physical memory based on /proc/iomem. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register text area in generic wayKAMEZAWA Hiroyuki
Some 64bit arch has special segment for mapping kernel text. It should be entried to /proc/kcore in addtion to direct-linear-map, vmalloc area. This patch unifies KCORE_TEXT entry scattered under x86 and ia64. I'm not familiar with other archs (mips has its own even after this patch) but range of [_stext ..._end) is a valid area of text and it's not in direct-map area, defining CONFIG_ARCH_PROC_KCORE_TEXT is only a necessary thing to do. Note: I left mips as it is now. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmalloc area in generic wayKAMEZAWA Hiroyuki
For /proc/kcore, vmalloc areas are registered per arch. But, all of them registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies them. By this. archs which have no kclist_add() hooks can see vmalloc area correctly. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17[IA64] Convert ia64 to use int-ll64.hMatthew Wilcox
It is generally agreed that it would be beneficial for u64 to be an unsigned long long on all architectures. ia64 (in common with several other 64-bit architectures) currently uses unsigned long. Migrating piecemeal is too painful; this giant patch fixes all compilation warnings and errors that come as a result of switching to use int-ll64.h. Note that userspace will still see __u64 defined as unsigned long. This is important as it affects C++ name mangling. [Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use u64 for start/end rather than unsigned long] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-01[IA64] BUG to BUG_ON changesStoyan Gaydarov
Replace: if (test) BUG(); with BUG_ON(test); Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-03-26ia64/pv_ops: gate page paravirtualization.Isaku Yamahata
paravirtualize gate page by allowing each pv_ops instances to define its own gate page. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-03-26ia64/pv_ops: add hooks to paravirtualize fsyscall implementation.Isaku Yamahata
Add two hooks, paravirt_get_fsyscall_table() and paravirt_get_fsys_bubble_doen() to paravirtualize fsyscall implementation. This patch just add the hooks fsyscall and don't paravirtualize it. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-01-06mm: show node to memory section relationship with symlinks in sysfsGary Hade
Show node to memory section relationship with symlinks in sysfs Add /sys/devices/system/node/nodeX/memoryY symlinks for all the memory sections located on nodeX. For example: /sys/devices/system/node/node1/memory135 -> ../../memory/memory135 indicates that memory section 135 resides on node1. Also revises documentation to cover this change as well as updating Documentation/ABI/testing/sysfs-devices-memory to include descriptions of memory hotremove files 'phys_device', 'phys_index', and 'state' that were previously not described there. In addition to it always being a good policy to provide users with the maximum possible amount of physical location information for resources that can be hot-added and/or hot-removed, the following are some (but likely not all) of the user benefits provided by this change. Immediate: - Provides information needed to determine the specific node on which a defective DIMM is located. This will reduce system downtime when the node or defective DIMM is swapped out. - Prevents unintended onlining of a memory section that was previously offlined due to a defective DIMM. This could happen during node hot-add when the user or node hot-add assist script onlines _all_ offlined sections due to user or script inability to identify the specific memory sections located on the hot-added node. The consequences of reintroducing the defective memory could be ugly. - Provides information needed to vary the amount and distribution of memory on specific nodes for testing or debugging purposes. Future: - Will provide information needed to identify the memory sections that need to be offlined prior to physical removal of a specific node. Symlink creation during boot was tested on 2-node x86_64, 2-node ppc64, and 2-node ia64 systems. Symlink creation during physical memory hot-add tested on a 2-node x86_64 system. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: cleanup to make remove_memory() arch-neutralBadari Pulavarty
There is nothing architecture specific about remove_memory(). remove_memory() function is common for all architectures which support hotplug memory remove. Instead of duplicating it in every architecture, collapse them into arch neutral function. [akpm@linux-foundation.org: fix the export] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Gary Hade <garyhade@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-05-15[IA64] fix personality(PER_LINUX32) performance issueHuang, Xiaolan
The patch aims to fix a performance issue for the syscall personality(PER_LINUX32). On IA-64 box, the syscall personality (PER_LINUX32) has poor performance because it failed to find the Linux/x86 execution domain. Then it tried to load the kernel module however it failed always and it used the default execution domain PER_LINUX instead. Requesting kernel modules is very expensive. It caused the performance issue. (see the function lookup_exec_domain in kernel/exec_domain.c). To resolve the issue, execution domain Linux/x86 is always registered in initialization time for IA-64 architecture. Signed-off-by: Xiaolan Huang <xiaolan.huang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-28hotplug-memory: make online_page() commonJeremy Fitzhardinge
All architectures use an effectively identical definition of online_page(), so just make it common code. x86-64, ia64, powerpc and sh are actually identical; x86-32 is slightly different. x86-32's differences arise because it puts its hotplug pages in the highmem zone. We can handle this in the generic code by inspecting the page to see if its in highmem, and update the totalhigh_pages count appropriately. This leaves init_32.c:free_new_highpage with a single caller, so I folded it into add_one_highpage_init. I also removed an incorrect comment referring to the NUMA case; any NUMA details have already been dealt with by the time online_page() is called. [akpm@linux-foundation.org: fix indenting] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Tested-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Christoph Lameter <clameter@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11[IA64] Fix NUMA configuration issueZoltan Menyhart
There is a NUMA memory configuration issue in 2.6.24: A 2-node machine of ours has got the following memory layout: Node 0: 0 - 2 Gbytes Node 0: 4 - 8 Gbytes Node 1: 8 - 16 Gbytes Node 0: 16 - 18 Gbytes "efi_memmap_init()" merges the three last ranges into one. "register_active_ranges()" is called as follows: efi_memmap_walk(register_active_ranges, NULL); i.e. once for the 4 - 18 Gbytes range. It picks up the node number from the start address, and registers all the memory for the node #0. "register_active_ranges()" should be called as follows to make sure there is no merged address range at its entry: efi_memmap_walk(filter_memory, register_active_ranges); "filter_memory()" is similar to "filter_rsvd_memory()", but the reserved memory ranges are not filtered out. Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] Untangle sync_icache_dcache() page size determinationChristoph Lameter
Untangle the chaos of page size determination in this function by simply using PAGE_SIZE << compound_order(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Long lines have been kept where they exist, some small spacing changes have been done. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-29[IA64] ia64/mm/init.c: fix section mismatchesAdrian Bunk
This patch fixes the following section mismatches: <-- snip --> ... WARNING: vmlinux.o(.text+0x5b5c2): Section mismatch: reference to .init.text:memmap_init_zone (between 'memmap_init' and 'virtual_memmap_init') WARNING: vmlinux.o(.text+0x5b842): Section mismatch: reference to .init.text:memmap_init_zone (between 'virtual_memmap_init' and 'ia64_mmu_init') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-19setup vma->vm_page_prot by vm_get_page_prot()Coly Li
This patch uses vm_get_page_prot() to setup vma->vm_page_prot. Though inside vm_get_page_prot() the protection flags is AND with (VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code. Signed-off-by: Coly Li <coyli@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix memory hot remove not configured case.KAMEZAWA Hiroyuki
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess. This patch cleans up them. This is against 2.6.23-rc6-mm1. - fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case. - For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(), which returns -EINVAL. - removed remove_pages() only used in powerpc. - removed no-op remove_memory() in i386, sh, sparc64, x86_64. - only powerpc returns -ENOSYS at memory hot remove(no-op). changes it to return -EINVAL. Note: Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other archs if there are requirements and testers. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: ia64 interfaceKAMEZAWA Hiroyuki
IA64 memory unplug interface. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16flush icache before set_pte() on ia64: flush icache at set_pteKAMEZAWA Hiroyuki
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after* set_pte(). This is too late. This patch removes lazy_mmu_prot_update and add modfied set_pte() for flushing if necessary. This patch flush icache of a page when new pte has exec bit. && new pte has present bit && new pte is user's page. && (old *ptep is not present || new pte's pfn is not same to old *ptep's ptn) && new pte's page has no Pg_arch_1 bit. Pg_arch_1 is set when a page is cache consistent. I think this condition checks are much easier to understand than considering "Where sync_icache_dcache() should be inserted ?". pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as clean-up. So, I added it again. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[IA64] Quicklist support for IA64Christoph Lameter
IA64 is the origin of the quicklist implementation. So cut out the pieces that are now in core code and modify the functions called. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] update memory attribute aliasing documentation & test cases [IA64] fail mmaps that span areas with incompatible attributes [IA64] allow WB /sys/.../legacy_mem mmaps [IA64] make ioremap avoid unsupported attributes [IA64] rename ioremap variables to match i386 [IA64] relax per-cpu TLB requirement to DTC [IA64] remove per-cpu ia64_phys_stacked_size_p8 [IA64] Fix example error injection program [IA64] Itanium MC Error Injection Tool: pal_mc_error_inject() interface [IA64] Itanium MC Error Injection Tool: Makefile changes [IA64] Itanium MC Error Injection Tool: Driver sysfs interface [IA64] Itanium MC Error Injection Tool: Doc and sample application [IA64] Itanium MC Error Injection Tool: Kernel configuration
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Pull percpu-dtc into release branchTony Luck
2007-03-29[IA64] bugfix stack layout upside-downKAMEZAWA Hiroyuki
ia64 expects following vm layout: == low memory [register-stack grows up] [memory-stack grows down] == high memory But the code assigns the base of the register stack at the maximum stack size offset from the fixed address where the stack *might* start. Stack randomization will result in the memory stack starting at a lower address than this, and if the user has set a low stack limit with "ulimit -s", then you can end up with the register stack above the memory stack (or if you were very unlucky right on top of it!). Fix: Calculate the base address for the register stack starting from the actual address of the memory stack. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-20[IA64] min_low_pfn and max_low_pfn calculation fixZou Nan hai
We have seen bad_pte_print when testing crashdump on an SN machine in recent 2.6.20 kernel. There are tons of bad pte print (pfn < max_low_pfn) reports when the crash kernel boots up, all those reported bad pages are inside initmem range; That is because if the crash kernel code and data happens to be at the beginning of the 1st node. build_node_maps in discontig.c will bypass reserved regions with filter_rsvd_memory. Since min_low_pfn is calculated in build_node_map, so in this case, min_low_pfn will be greater than kernel code and data. Because pages inside initmem are freed and reused later, we saw pfn_valid check fail on those pages. I think this theoretically happen on a normal kernel. When I check min_low_pfn and max_low_pfn calculation in contig.c and discontig.c. I found more issues than this. 1. min_low_pfn and max_low_pfn calculation is inconsistent between contig.c and discontig.c, min_low_pfn is calculated as the first page number of boot memmap in contig.c (Why? Though this may work at the most of the time, I don't think it is the right logic). It is calculated as the lowest physical memory page number bypass reserved regions in discontig.c. max_low_pfn is calculated include reserved regions in contig.c. It is calculated exclude reserved regions in discontig.c. 2. If kernel code and data region is happen to be at the begin or the end of physical memory, when min_low_pfn and max_low_pfn calculation is bypassed kernel code and data, pages in initmem will report bad. 3. initrd is also in reserved regions, if it is at the begin or at the end of physical memory, kernel will refuse to reuse the memory. Because the virt_addr_valid check in free_initrd_mem. So it is better to fix and clean up those issues. Calculate min_low_pfn and max_low_pfn in a consistent way. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Acked-by: Jay Lan <jlan@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop nr_free_pages_pgdat()Christoph Lameter
Function is unnecessary now. We can use the summing features of the ZVCs to get the values we need. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[IA64] relax per-cpu TLB requirement to DTCChen, Kenneth W
Instead of pinning per-cpu TLB into a DTR, use DTC. This will free up one TLB entry for application, or even kernel if access pattern to per-cpu data area has high temporal locality. Since per-cpu is mapped at the top of region 7 address, we just need to add special case in alt_dtlb_miss. The physical address of per-cpu data is already conveniently stored in IA64_KR(PER_CPU_DATA). Latency for alt_dtlb_miss is not affected as we can hide all the latency. It was measured that alt_dtlb_miss handler has 23 cycles latency before and after the patch. The performance effect is massive for applications that put lots of tlb pressure on CPU. Workload environment like database online transaction processing or application uses tera-byte of memory would benefit the most. Measurement with industry standard database benchmark shown an upward of 1.6% gain. While smaller workloads like cpu, java also showing small improvement. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb bug fixesJan Beulich
This patch fixes - marking I-cache clean of pages DMAed to now only done for IA64 - broken multiple inclusion in include/asm-x86_64/swiotlb.h - missing call to mark_clean in swiotlb_sync_sg() - a (perhaps only theoretical) issue in swiotlb_dma_supported() when io_tlb_end is exactly at the end of memory Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] register memory ranges in a consistent mannerBob Picco
While pursuing and unrelated issue with 64Mb granules I noticed a problem related to inconsistent use of add_active_range. There doesn't appear any reason to me why FLATMEM versus DISCONTIG_MEM should register memory to add_active_range with different code. So I've changed the code into a common implementation. The other subtle issue fixed by this patch was calling add_active_range in count_node_pages before granule aligning is performed. We were lucky with 16MB granules but not so with 64MB granules. count_node_pages has reserved regions filtered out and as a consequence linked kernel text and data aren't covered by calls to count_node_pages. So linked kernel regions wasn't reported to add_active_regions. This resulted in free_initmem causing numerous bad_page reports. This won't occur with this patch because now all known memory regions are reported by register_active_ranges. Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-01-11[PATCH] Fix sparsemem on CellDave Hansen
Fix an oops experienced on the Cell architecture when init-time functions, early_*(), are called at runtime. It alters the call paths to make sure that the callers explicitly say whether the call is being made on behalf of a hotplug even, or happening at boot-time. It has been compile tested on ppc64, ia64, s390, i386 and x86_64. Acked-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12[IA64] fix arch/ia64/mm/contig.c:235: warning: unused variable `nid'Tony Luck
This warning only shows up with CONFIG_VIRTUAL_MEM_MAP=y and CONFIG_FLATMEM=y. There is only one caller left for register_active_ranges() from the contig.c code ... so it doesn't need to pick up the node number, the node number is always zero. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-09-27[PATCH] Have ia64 use add_active_range() and free_area_init_nodesMel Gorman
Size zones and holes in an architecture independent manner for ia64. [bob.picco@hp.com: fix ia64 FLATMEM+VIRTUAL_MEM_MAP] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03[IA64] fix show_mem for VIRTUAL_MEM_MAP+FLATMEMBob Picco
contig.c (FLATMEM) requires the same optimization as in discontig.c for show_mem when VIRTUAL_MEM_MAP is in use. Otherwise FLATMEM has softlockup timeouts. This was boot tested for memory configuration: SPARSEMEM, DISCONTIG+VIRTUAL_MEM_MAP, FLATMEM, FLATMEM+VIRTUAL_MEM_MAP and FLATMEM+VIRTUAL_MEM_MAP with largest memory gap less than LARGE_GAP by using boot parameter "mem=". This was boot tested and "echo m >/proc/sysrq-trigger" output evaluated for : FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and SPARSEMEM. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-06-27[PATCH] pgdat allocation for new node add (specify node id)Yasunori Goto
Change the name of old add_memory() to arch_add_memory. And use node id to get pgdat for the node at NODE_DATA(). Note: Powerpc's old add_memory() is defined as __devinit. However, add_memory() is usually called only after bootup. I suppose it may be redundant. But, I'm not well known about powerpc. So, I keep it. (But, __meminit is better at least.) Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15ACPI add ia64 exports to build acpi_memhotplug as a moduleKAMEZAWA Hiroyuki
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] ioremap() should prefer WB over UC [IA64] Add __mca_table to the DISCARD list in gate.lds [IA64] Move __mca_table out of the __init section [IA64] simplify some condition checks in iosapic_check_gsi_range [IA64] correct some messages and fixes some minor things [IA64-SGI] fix for-loop in sn_hwperf_geoid_to_cnode() [IA64-SGI] sn_hwperf use of num_online_cpus() [IA64] optimize flush_tlb_range on large numa box [IA64] lazy_mmu_prot_update needs to be aware of huge pages
2006-03-27[IA64] lazy_mmu_prot_update needs to be aware of huge pagesZhang, Yanmin
Function lazy_mmu_prot_update is also used on huge pages when it is called by set_huge_ptep_writable, but it isn't aware of huge pages. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Acked-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-27[PATCH] for_each_online_pgdat: renaming for_each_pgdatKAMEZAWA Hiroyuki
Replace for_each_pgdat() with for_each_online_pgdat(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[IA64] add init declaration - nolwsysChen, Kenneth W
Add __initdata to nolwsys. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
