path: root/arch/ia64/mm
2008-05-15[IA64] fix personality(PER_LINUX32) performance issueHuang, Xiaolan
The patch aims to fix a performance issue for the syscall personality(PER_LINUX32). On IA-64 box, the syscall personality (PER_LINUX32) has poor performance because it failed to find the Linux/x86 execution domain. Then it tried to load the kernel module however it failed always and it used the default execution domain PER_LINUX instead. Requesting kernel modules is very expensive. It caused the performance issue. (see the function lookup_exec_domain in kernel/exec_domain.c). To resolve the issue, execution domain Linux/x86 is always registered in initialization time for IA-64 architecture. Signed-off-by: Xiaolan Huang <xiaolan.huang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29[IA64] bugfix: nptcg breaks cpu-hotaddHidetoshi Seto
If "max_purges" from PAL is 0, it actually means 1. However it was not handled later when a hot-added cpu pass the max_purges from PAL. This makes systems easy to go BUG_ON(). Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-28hotplug-memory: make online_page() commonJeremy Fitzhardinge
All architectures use an effectively identical definition of online_page(), so just make it common code. x86-64, ia64, powerpc and sh are actually identical; x86-32 is slightly different. x86-32's differences arise because it puts its hotplug pages in the highmem zone. We can handle this in the generic code by inspecting the page to see if its in highmem, and update the totalhigh_pages count appropriately. This leaves init_32.c:free_new_highpage with a single caller, so I folded it into add_one_highpage_init. I also removed an incorrect comment referring to the NUMA case; any NUMA details have already been dealt with by the time online_page() is called. [akpm@linux-foundation.org: fix indenting] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Tested-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Christoph Lameter <clameter@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Pull miscellaneous into release branchTony Luck
Conflicts: arch/ia64/kernel/mca.c
2008-04-17Pull nptcg into release branchTony Luck
Conflicts: arch/ia64/mm/tlb.c
2008-04-17Pull kvm-patches into release branchTony Luck
2008-04-11[IA64] Fix NUMA configuration issueZoltan Menyhart
There is a NUMA memory configuration issue in 2.6.24: A 2-node machine of ours has got the following memory layout: Node 0: 0 - 2 Gbytes Node 0: 4 - 8 Gbytes Node 1: 8 - 16 Gbytes Node 0: 16 - 18 Gbytes "efi_memmap_init()" merges the three last ranges into one. "register_active_ranges()" is called as follows: efi_memmap_walk(register_active_ranges, NULL); i.e. once for the 4 - 18 Gbytes range. It picks up the node number from the start address, and registers all the memory for the node #0. "register_active_ranges()" should be called as follows to make sure there is no merged address range at its entry: efi_memmap_walk(filter_memory, register_active_ranges); "filter_memory()" is similar to "filter_rsvd_memory()", but the reserved memory ranges are not filtered out. Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] Untangle sync_icache_dcache() page size determinationChristoph Lameter
Untangle the chaos of page size determination in this function by simply using PAGE_SIZE << compound_order(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] remove redundant display of free swap space in show_mem()Johannes Weiner
show_mem() has no need to print the amount of free swap space manually because show_free_areas() does this already and is called by the former. The two outputs only differ in text formatting: printk("Free swap = %lukB\n", ...); printk("Free swap: %6ldkB\n", ...); Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Minimize per_cpu reservations.holt@sgi.com
This attached patch significantly shrinks boot memory allocation on ia64. It does this by not allocating per_cpu areas for cpus that can never exist. In the case where acpi does not have any numa node description of the cpus, I defaulted to assigning the first 32 round-robin on the known nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Correct pernodesize calculation.holt@sgi.com
A simple fix. The existing pernodesize reservation is not taking into account a second array of pg_data_t structures. This is normally not important because the PAGE_ALIGN macro reserves adequate space. I made the compute_pernodesize steps in the same order as the fill_pernode steps to make the correlation more clear. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Kernel parameter for max number of concurrent global TLB purgesFenghua Yu
The patch defines kernel parameter "nptcg=". The parameter overrides max number of concurrent global TLB purges which is reported from either PAL_VM_SUMMARY or SAL PALO. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Multiple outstanding ptc.g instruction supportFenghua Yu
According to SDM2.2, Itanium supports multiple outstanding ptc.g instructions. But current kernel function ia64_global_tlb_purge() uses a spinlock to serialize ptc.g instructions issued by multiple processors. This serialization might have scalability issue on a big SMP machine where many processors could purge TLB in parallel. The patch fixes this problem by issuing multiple ptc.g instructions in ia64_global_tlb_purge(). It also adds support for the "PALO" table to get a platform view of the max number of outstanding ptc.g instructions (which may be different from the processor view found from PAL_VM_SUMMARY). PALO specification can be found at: http://www.dig64.org/home/DIG64_PALO_R1_0.pdf spinaphore implementation by Matthew Wilcox. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-03[IA64] Add API for allocating Dynamic TR resource.Xiantao Zhang
Dynamic TR resource should be managed in the uniform way. Add two interfaces for kernel: ia64_itr_entry: Allocate a (pair of) TR for caller. ia64_ptr_entry: Purge a (pair of ) TR by caller. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] kprobes arch consolidation build fixHarvey Harrison
ia64 named their handler kprobes_fault_handler while all other arches used kprobe_fault_handler. Change the function definition and header declaration. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Long lines have been kept where they exist, some small spacing changes have been done. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05[IA64] honor notify_die() returning NOTIFY_STOPJan Beulich
This requires making die() and die_if_kernel() return a value, and their callers to honor this (and be prepared that it returns). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] Avoid unnecessary TLB flushes when allocating memoryde Dinechin, Christophe (Integrity VM)
Improve performance of memory allocations on ia64 by avoiding a global TLB purge to purge a single page from the file cache. This happens whenever we evict a page from the buffer cache to make room for some other allocation. Test case: Run 'find /usr -type f | xargs cat > /dev/null' in the background to fill the buffer cache, then run something that uses memory, e.g. 'gmake -j50 install'. Instrumentation showed that the number of global TLB purges went from a few millions down to about 170 over a 12 hours run of the above. The performance impact is particularly noticeable under virtualization, because a virtual TLB is generally both larger and slower to purge than a physical one. Signed-off-by: Christophe de Dinechin <ddd@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-07[IA64] Add missing "space" to concatenated stringsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-11-06[IA64] Fix section mismatch in contig.c version of per_cpu_init()Tony Luck
There is a section mismatch when building CONFIG_FLATMEM=y kernels that also have CONFIG_HOTPLUG_CPU=y WARNING: vmlinux.o(.text+0x5a902): Section mismatch: reference to \ .init.text:__alloc_bootmem (between 'per_cpu_init' and 'count_pages') The issue occurs because per_cpu_init() in mm/contig.c is marked __cpuinit (which is #define'd to nothing on a hot plug cpu configuration) call __alloc_bootmem() (which is an __init function). The usage is actually safe because the __alloc_bootmem() is inside an "if (first_time)" test so that the call is only made while it is still legal to do so. But the warning is irritating. Move the allocation to find_memory(). Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-29[IA64] ia64/mm/init.c: fix section mismatchesAdrian Bunk
This patch fixes the following section mismatches: <-- snip --> ... WARNING: vmlinux.o(.text+0x5b5c2): Section mismatch: reference to .init.text:memmap_init_zone (between 'memmap_init' and 'virtual_memmap_init') WARNING: vmlinux.o(.text+0x5b842): Section mismatch: reference to .init.text:memmap_init_zone (between 'virtual_memmap_init' and 'ia64_mmu_init') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19setup vma->vm_page_prot by vm_get_page_prot()Coly Li
This patch uses vm_get_page_prot() to setup vma->vm_page_prot. Though inside vm_get_page_prot() the protection flags is AND with (VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code. Signed-off-by: Coly Li <coyli@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add vmcoreinfoKen'ichi Ohmichi
This patch set frees the restriction that makedumpfile users should install a vmlinux file (including the debugging information) into each system. makedumpfile command is the dump filtering feature for kdump. It creates a small dumpfile by filtering unnecessary pages for the analysis. To distinguish unnecessary pages, it needs a vmlinux file including the debugging information. These days, the debugging package becomes a huge file, and it is hard to install it into each system. To solve the problem, kdump developers discussed it at lkml and kexec-ml. As the result, we reached the conclusion that necessary information for dump filtering (called "vmcoreinfo") should be embedded into the first kernel file and it should be accessed through /proc/vmcore during the second kernel. (http://www.uwsg.iu.edu/hypermail/linux/kernel/0707.0/1806.html) Dan Aloni created the patch set for the above implementation. (http://www.uwsg.iu.edu/hypermail/linux/kernel/0707.1/1053.html) And I updated it for multi architectures and memory models. (http://lists.infradead.org/pipermail/kexec/2007-August/000479.html) Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix memory hot remove not configured case.KAMEZAWA Hiroyuki
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess. This patch cleans up them. This is against 2.6.23-rc6-mm1. - fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case. - For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(), which returns -EINVAL. - removed remove_pages() only used in powerpc. - removed no-op remove_memory() in i386, sh, sparc64, x86_64. - only powerpc returns -ENOSYS at memory hot remove(no-op). changes it to return -EINVAL. Note: Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other archs if there are requirements and testers. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: ia64 interfaceKAMEZAWA Hiroyuki
IA64 memory unplug interface. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Do not depend on MAX_ORDER when grouping pages by mobilityMel Gorman
Currently mobility grouping works at the MAX_ORDER_NR_PAGES level. This makes sense for the majority of users where this is also the huge page size. However, on platforms like ia64 where the huge page size is runtime configurable it is desirable to group at a lower order. On x86_64 and occasionally on x86, the hugepage size may not always be MAX_ORDER_NR_PAGES. This patch groups pages together based on the value of HUGETLB_PAGE_ORDER. It uses a compile-time constant if possible and a variable where the huge page size is runtime configurable. It is assumed that grouping should be done at the lowest sensible order and that the user would not want to override this. If this is not true, page_block order could be forced to a variable initialised via a boot-time kernel parameter. One potential issue with this patch is that IA64 now parses hugepagesz with early_param() instead of __setup(). __setup() is called after the memory allocator has been initialised and the pageblock bitmaps already setup. In tests on one IA64 there did not seem to be any problem with using early_param() and in fact may be more correct as it guarantees the parameter is handled before the parsing of hugepages=. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16flush icache before set_pte() on ia64: flush icache at set_pteKAMEZAWA Hiroyuki
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after* set_pte(). This is too late. This patch removes lazy_mmu_prot_update and add modfied set_pte() for flushing if necessary. This patch flush icache of a page when new pte has exec bit. && new pte has present bit && new pte is user's page. && (old *ptep is not present || new pte's pfn is not same to old *ptep's ptn) && new pte's page has no Pg_arch_1 bit. Pg_arch_1 is set when a page is cache consistent. I think this condition checks are much easier to understand than considering "Where sync_icache_dcache() should be inserted ?". pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as clean-up. So, I added it again. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16IA64: SPARSEMEM_VMEMMAP 16K page size supportChristoph Lameter
Equip IA64 sparsemem with a virtual memmap. This is similar to the existing CONFIG_VIRTUAL_MEM_MAP functionality for DISCONTIGMEM. It uses a PAGE_SIZE mapping. This is provided as a minimally intrusive solution. We split the 128TB VMALLOC area into two 64TB areas and use one for the virtual memmap. This should replace CONFIG_VIRTUAL_MEM_MAP long term. [apw@shadowen.org: convert to new helper based initialisation] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
2007-09-01[IA64] Stop bogus NMI & softlockup warnings in ia64 show_memPrarit Bhargava
When dumping memory via sysrq-m it is possible to take a bogus NMI watchdog or softlockup watchdog because the dump can take a long time on big memory systems. Occasionally tickle the watchdog when doing the dump. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-08-31hugepage: fix broken check for offset alignment in hugepage mappingsDavid Gibson
For hugepage mappings, the file offset, like the address and size, needs to be aligned to the size of a hugepage. In commit 68589bc353037f233fe510ad9ff432338c95db66, the check for this was moved into prepare_hugepage_range() along with the address and size checks. But since BenH's rework of the get_unmapped_area() paths leading up to commit 4b1d89290b62bb2db476c94c82cf7442aab440c8, prepare_hugepage_range() is only called for MAP_FIXED mappings, not for other mappings. This means we're no longer ever checking for an aligned offset - I've confirmed that mmap() will (apparently) succeed with a misaligned offset on both powerpc and i386 at least. This patch restores the check, removing it from prepare_hugepage_range() and putting it back into hugetlbfs_file_mmap(). I'm putting it there, rather than in the get_unmapped_area() path so it only needs to go in one place, than separately in the half-dozen or so arch-specific implementations of hugetlb_get_unmapped_area(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-16[IA64] Failure to grow RBSAndrew Burgess
There is a bug in the ia64_do_page_fault code that can cause a failure to grow the register backing store, or any mapping that is marked as VM_GROWSUP if the mapping is the highest mapped area of memory. When the address accessed is below the first mapping the previous mapping is returned as NULL, and this case is handled. However, when the address accessed is above the highest mapping the vma returned is NULL, this case is not handled correctly, and it fails to spot that this access might require an existing mapping to grow upwards. Signed-off-by: Andrew Burgess <andrew@transitive.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11[IA64] silence GCC ia64 unused variable warningsJes Sorensen
Tell GCC to stop spewing out unnecessary warnings for unused variables passed to functions as pointers for ia64 files. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-06-26[IA64] is_power_of_2-ia64/mm/hugetlbpage.cvignesh babu
Replacing (n & (n-1)) in the context of power of 2 checks with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-16[IA64] optimize pagefaults a littleChristoph Hellwig
Get rid of the notifier list and call the kprobes code directly if compiled in. This mirrors the changes that recently went into powerpc, s390 and sparc64. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] Quicklist support for IA64Christoph Lameter
IA64 is the origin of the quicklist implementation. So cut out the pieces that are now in core code and modify the functions called. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] wire up pselect, ppoll [IA64] Add TIF_RESTORE_SIGMASK [IA64] unwind did not work for processes born with CLONE_STOPPED [IA64] Optional method to purge the TLB on SN systems [IA64] SPIN_LOCK_UNLOCKED macro cleanup in arch/ia64 [IA64-SN2][KJ] mmtimer.c-kzalloc [IA64] fix stack alignment for ia32 signal handlers [IA64] - Altix: hotplug after intr redirect can crash system [IA64] save and restore cpus_allowed in cpu_idle_wait [IA64] Removal of percpu TR cleanup in kexec code [IA64] Fix some section mismatch errors
2007-05-08[IA64] SPIN_LOCK_UNLOCKED macro cleanup in arch/ia64Milind Arun Choudhary
SPIN_LOCK_UNLOCKED macro cleanup, use __SPIN_LOCK_UNLOCKED instead. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] update memory attribute aliasing documentation & test cases [IA64] fail mmaps that span areas with incompatible attributes [IA64] allow WB /sys/.../legacy_mem mmaps [IA64] make ioremap avoid unsupported attributes [IA64] rename ioremap variables to match i386 [IA64] relax per-cpu TLB requirement to DTC [IA64] remove per-cpu ia64_phys_stacked_size_p8 [IA64] Fix example error injection program [IA64] Itanium MC Error Injection Tool: pal_mc_error_inject() interface [IA64] Itanium MC Error Injection Tool: Makefile changes [IA64] Itanium MC Error Injection Tool: Driver sysfs interface [IA64] Itanium MC Error Injection Tool: Doc and sample application [IA64] Itanium MC Error Injection Tool: Kernel configuration
2007-05-07get_unmapped_area handles MAP_FIXED on ia64Benjamin Herrenschmidt
Handle MAP_FIXED in ia64 arch_get_unmapped_area and hugetlb_get_unmapped_area(), just call prepare_hugepage_range in the later and is_hugepage_only_range() in the former. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: William Irwin <bill.irwin@oracle.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Pull mem-attribute into release branchTony Luck
