path: root/arch/ia64/sn/kernel/bte_error.c
2007-12-19[IA64] Fix Altix BTE error return statusRuss Anderson
The Altix shub2 BTE error detail bits are in a different location than on shub1. The current code does not take this into account resulting in all shub2 BTE failures mapping to "unknown". This patch reads the error detail bits from the proper location, so the correct BTE failure reason is returned for both shub1 and shub2. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-04-06[IA64] BTE error timer fixRuss Anderson
The bte recovery_timer was not being set correctly. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-13[IA64-SGI] Altix BTE error handling fixesRuss Anderson
Altix (shub2) pushes the BTE clean-up into SAL. This patch correctly interfaces with the now implemented SAL call. It also fixes a bug when delaying clean-up to allow busy BTEs to complete (or error out). Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-25[IA64-SGI] Shub2 BTE support - BTE recovery codeRuss Anderson
patch 2: Shub2 BTE recovery code will be implemented in SAL. Define the SAL interface. Modify bte_error to call SAL for shub2. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
