Hand-fixed conflicts:
include/asm-ia64/machvec_sn2.h
Signed-off-by: Tony Luck <tony.luck@intel.com>
This stuff is all in the generic ia64 kernel, and the new initcall error
reporting complains about them.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
General SN2 code cleanup:
- Do not initialize global variables to zero
- Use kzalloc instead of kmalloc+memset
- Check kmalloc return values
- Do not obfuscate spin lock calls
- Remove some unused code
- Various formatting cleanups
Signed-off-by: Jes Sorensen <jes@sgi.com>
On SN2, MMIO writes which are issued from separate processors are not
guaranteed to arrive in any particular order at the IO hardware. When
performing such writes from the kernel this is not a problem, as a
kernel thread will not migrate to another CPU during execution, and
mmiowb() calls can guarantee write ordering when control of the IO
resource is allowed to move between threads.
However, when MMIO writes can be performed from user space (e.g. DRM)
there are no such guarantees and mechanisms, as the process may
context-switch at any time, and may migrate to a different CPU as part
of the switch. For such programs/hardware to operate correctly, it is
required that the MMIO writes from the old CPU be accepted by the IO
hardware before subsequent writes from the new CPU can be issued.
The following patch implements this behavior on SN2 by waiting for a
Shub register to indicate that these writes have been accepted. This
is placed in the context switch-in path, and only performs the wait
when the newly scheduled task changes CPUs.
Signed-off-by: Prarit Bhargava <prarit@sgi.com>
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
This patch finishes support for SHUB2 (the new chipset). Most of the
changes are performance related. A few changes are workarounds for
"interesting" chipset features.
Some temporary debugging code has also been deleted.
Signed-off-by: Jack Steiner <steiner@sgi.com>
I see why the problem exists only on SN. SN uses a different hardware
mechanism to purge TLB entries across nodes.
It looks like there is a bug in the SN TLB flushing code. During context switch,
kernel threads inherit the mm of the task that was previously running on the
cpu. This confuses the code in sn2_global_tlb_purge().
The result is a missed TLB purge for the task that owns the "borrowed" mm.
(I hit the problem running heavy stress where kswapd was purging code pages of
a user task that woke kswapd. The user task took a SIGILL fault trying to
execute code in the page that had been ripped out from underneath it).
Patch to prevent sn2_ptc_init code from attempting to load on non-sn2 systems
when sn2_smp.c is built-in to generic kernel.
flush_tlb_all() can be a scaling issue on large SGI Altix systems
since it uses the global call_lock and always executes on all cpus.
When a process enters flush_tlb_range() to purge TLBs for another
process, it is possible to avoid flush_tlb_all() and instead allow
sn2_global_tlb_purge() to purge TLBs only where necessary.
This patch modifies flush_tlb_range() so that this case can be handled
by platform TLB purge functions and updates ia64_global_tlb_purge()
accordingly. sn2_global_tlb_purge() now calculates the region register
value from the mm argument introduced with this patch.
Signed-off-by: Dean Roe <roe@sgi.com>
Shub2 provides a much improved mechanism for issuing internode
TLB purges. Add code to support the newer mechanism. There is also
some debug code (disabled) that is useful for testing.
Collect statistics on the number, type & duration of TLB purges.
This data will be useful for making future improvements in the algorithms.
infrastructure for it.
Let it rip!
