path: root/arch/ia64/sn/kernel/sn2/sn2_smp.c
2014-08-26ia64: Replace __get_cpu_var usesChristoph Lameter
__get_cpu_var() is used for multiple purposes in the kernel source. One of them is address calculation via the form &__get_cpu_var(x). This calculates the address for the instance of the percpu variable of the current processor based on an offset. Other use cases are for storing and retrieving data from the current processors percpu area. __get_cpu_var() can be used as an lvalue when writing data or on the right side of an assignment. __get_cpu_var() is defined as : #define __get_cpu_var(var) (*this_cpu_ptr(&(var))) __get_cpu_var() always only does an address determination. However, store and retrieve operations could use a segment prefix (or global register on other platforms) to avoid the address calculation. this_cpu_write() and this_cpu_read() can directly take an offset into a percpu area and use optimized assembly code to read and write per cpu variables. This patch converts __get_cpu_var into either an explicit address calculation using this_cpu_ptr() or into a use of this_cpu operations that use the offset. Thereby address calculations are avoided and less registers are used when code is generated. At the end of the patch set all uses of __get_cpu_var have been removed so the macro is removed too. The patch set includes passes over all arches as well. Once these operations are used throughout then specialized macros can be defined in non -x86 arches as well in order to optimize per cpu access by f.e. using a global register that may be set to the per cpu base. Transformations done to __get_cpu_var() 1. Determine the address of the percpu instance of the current processor. DEFINE_PER_CPU(int, y); int *x = &__get_cpu_var(y); Converts to int *x = this_cpu_ptr(&y); 2. Same as #1 but this time an array structure is involved. DEFINE_PER_CPU(int, y[20]); int *x = __get_cpu_var(y); Converts to int *x = this_cpu_ptr(y); 3. Retrieve the content of the current processors instance of a per cpu variable. DEFINE_PER_CPU(int, y); int x = __get_cpu_var(y) Converts to int x = __this_cpu_read(y); 4. Retrieve the content of a percpu struct DEFINE_PER_CPU(struct mystruct, y); struct mystruct x = __get_cpu_var(y); Converts to memcpy(&x, this_cpu_ptr(&y), sizeof(x)); 5. Assignment to a per cpu variable DEFINE_PER_CPU(int, y) __get_cpu_var(y) = x; Converts to __this_cpu_write(y, x); 6. Increment/Decrement etc of a per cpu variable DEFINE_PER_CPU(int, y); __get_cpu_var(y)++ Converts to __this_cpu_inc(y) Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64@vger.kernel.org Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-28Disintegrate asm/system.h for IA64David Howells
Disintegrate asm/system.h for IA64. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> cc: linux-ia64@vger.kernel.org
2009-10-29percpu: make percpu symbols in ia64 uniqueTejun Heo
This patch updates percpu related symbols in ia64 such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * arch/ia64/kernel/setup.c: s/cpu_info/ia64_cpu_info/ Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64@vger.kernel.org
2009-04-01[IA64] Fix typo/thinko in arch/ia64/sn/kernel/sn2/sn2_smp.cRandy Dunlap
sn2_ptc_init() has what looks like a cut-n-paste error. Fix it. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-03-16cpumask: use mm_cpumask() wrapper: ia64Rusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask. It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-16cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: ia64Rusty Russell
Impact: cleanup, futureproof In fact, all cpumask ops will only be valid (in general) for bit numbers < nr_cpu_ids. So use that instead of NR_CPUS in various places. This is always safe: no cpu number can be >= nr_cpu_ids, and nr_cpu_ids is initialized to NR_CPUS at boot. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-06-24[IA64] Handle count==0 in sn2_ptc_proc_write()Cliff Wickman
The fix applied in e0c6d97c65e0784aade7e97b9411f245a6c543e7 "security hole in sn2_ptc_proc_write" didn't take into account the case where count==0 (which results in a buffer underrun when adding the trailing '\0'). Thanks to Andi Kleen for pointing this out. Signed-off-by: Cliff Wickman <cpw@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-20[IA64] SN2: security hole in sn2_ptc_proc_writeCliff Wickman
Security hole in sn2_ptc_proc_write It is possible to overrun a buffer with a write to this /proc file. Signed-off-by: Cliff Wickman <cpw@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29ia64: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[IA64] constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-09-01[IA64] SN: Add support for CPU disableJohn Keller
Add additional support for CPU disable on SN platforms. Correctly setup the smp_affinity mask for I/O error IRQs. Restrict the use of the feature to Altix 4000 and 450 systems running with a CPU disable capable PROM, and do not allow disabling of CPU 0. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-08[IA64] Optional method to purge the TLB on SN systemsJack Steiner
This patch adds an optional method for purging the TLB on SN IA64 systems. The change should not affect any non-SN system. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-21Pull sn2-mmio-writes into release branchTony Luck
Hand-fixed conflicts: include/asm-ia64/machvec_sn2.h Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-07[IA64] don't report !sn2 or !summit hardware as an errorBjorn Helgaas
This stuff is all in the generic ia64 kernel, and the new initcall error reporting complains about them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-15[IA64-SGI] sn2 minor fixes and cleanupsJes Sorensen
General SN2 code cleanup: - Do not initialize global variables to zero - Use kzalloc instead of kmalloc+memset - Check kmalloc return values - Do not obfuscate spin lock calls - Remove some unused code - Various formatting cleanups Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-26[IA64] hooks to wait for mmio writes to drain when migrating processesBrent Casavant
On SN2, MMIO writes which are issued from separate processors are not guaranteed to arrive in any particular order at the IO hardware. When performing such writes from the kernel this is not a problem, as a kernel thread will not migrate to another CPU during execution, and mmiowb() calls can guarantee write ordering when control of the IO resource is allowed to move between threads. However, when MMIO writes can be performed from user space (e.g. DRM) there are no such guarantees and mechanisms, as the process may context-switch at any time, and may migrate to a different CPU as part of the switch. For such programs/hardware to operate correctly, it is required that the MMIO writes from the old CPU be accepted by the IO hardware before subsequent writes from the new CPU can be issued. The following patch implements this behavior on SN2 by waiting for a Shub register to indicate that these writes have been accepted. This is placed in the context switch-in path, and only performs the wait when the newly scheduled task changes CPUs. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com>
2006-01-26[IA64-SGI] Update TLB flushing code for SN platformJack Steiner
This patch finishes support for SHUB2 (the new chipset). Most of the changes are performance related. A few changes are workarounds for "interesting" chipset features. Some temporary debugging code has also been deleted. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-12-16[IA64-SGI] Missed TLB flushJack Steiner
I see why the problem exists only on SN. SN uses a different hardware mechanism to purge TLB entries across nodes. It looks like there is a bug in the SN TLB flushing code. During context switch, kernel threads inherit the mm of the task that was previously running on the cpu. This confuses the code in sn2_global_tlb_purge(). The result is a missed TLB purge for the task that owns the "borrowed" mm. (I hit the problem running heavy stress where kswapd was purging code pages of a user task that woke kswapd. The user task took a SIGILL fault trying to execute code in the page that had been ripped out from underneath it). Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-11-21[IA64] Prevent sn2 ptc code from executing on all ia64 subarchesPrarit Bhargava
Patch to prevent sn2_ptc_init code from attempting to load on non-sn2 systems when sn2_smp.c is built-in to generic kernel. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-10-27[IA64] - Avoid slow TLB purges on SGI Altix systemsDean Roe
flush_tlb_all() can be a scaling issue on large SGI Altix systems since it uses the global call_lock and always executes on all cpus. When a process enters flush_tlb_range() to purge TLBs for another process, it is possible to avoid flush_tlb_all() and instead allow sn2_global_tlb_purge() to purge TLBs only where necessary. This patch modifies flush_tlb_range() so that this case can be handled by platform TLB purge functions and updates ia64_global_tlb_purge() accordingly. sn2_global_tlb_purge() now calculates the region register value from the mm argument introduced with this patch. Signed-off-by: Dean Roe <roe@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-08-17[IA64-SGI] - New SN hardware support - ptc_fixesJack Steiner
Shub2 provides a much improved mechanism for issuing internode TLB purges. Add code to support the newer mechanism. There is also some debug code (disabled) that is useful for testing. Collect statistics on the number, type & duration of TLB purges. This data will be useful for making future improvements in the algorithms. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
