path: root/arch/ia64
2013-05-07Wrong asm register contraints in the kvm implementationStephan Schreiber
commit de53e9caa4c6149ef4a78c2f83d7f5b655848767 upstream. The Linux Kernel contains some inline assembly source code which has wrong asm register constraints in arch/ia64/kvm/vtlb.c. I observed this on Kernel 3.2.35 but it is also true on the most recent Kernel 3.9-rc1. File arch/ia64/kvm/vtlb.c: u64 guest_vhpt_lookup(u64 iha, u64 *pte) { u64 ret; struct thash_data *data; data = __vtr_lookup(current_vcpu, iha, D_TLB); if (data != NULL) thash_vhpt_insert(current_vcpu, data->page_flags, data->itir, iha, D_TLB); asm volatile ( "rsm psr.ic|psr.i;;" "srlz.d;;" "ld8.s r9=[%1];;" "tnat.nz p6,p7=r9;;" "(p6) mov %0=1;" "(p6) mov r9=r0;" "(p7) extr.u r9=r9,0,53;;" "(p7) mov %0=r0;" "(p7) st8 [%2]=r9;;" "ssm psr.ic;;" "srlz.d;;" "ssm psr.i;;" "srlz.d;;" : "=r"(ret) : "r"(iha), "r"(pte):"memory"); return ret; } The list of output registers is : "=r"(ret) : "r"(iha), "r"(pte):"memory"); The constraint "=r" means that the GCC has to maintain that these vars are in registers and contain valid info when the program flow leaves the assembly block (output registers). But "=r" also means that GCC can put them in registers that are used as input registers. Input registers are iha, pte on the example. If the predicate p7 is true, the 8th assembly instruction "(p7) mov %0=r0;" is the first one which writes to a register which is maintained by the register constraints; it sets %0. %0 means the first register operand; it is ret here. This instruction might overwrite the %2 register (pte) which is needed by the next instruction: "(p7) st8 [%2]=r9;;" Whether it really happens depends on how GCC decides what registers it uses and how it optimizes the code. The attached patch fixes the register operand constraints in arch/ia64/kvm/vtlb.c. The register constraints should be : "=&r"(ret) : "r"(iha), "r"(pte):"memory"); The & means that GCC must not use any of the input registers to place this output register in. This is Debian bug#702639 (http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=702639). The patch is applicable on Kernel 3.9-rc1, 3.2.35 and many other versions. Signed-off-by: Stephan Schreiber <info@fs-driver.org> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07Wrong asm register contraints in the futex implementationStephan Schreiber
commit 136f39ddc53db3bcee2befbe323a56d4fbf06da8 upstream. The Linux Kernel contains some inline assembly source code which has wrong asm register constraints in arch/ia64/include/asm/futex.h. I observed this on Kernel 3.2.23 but it is also true on the most recent Kernel 3.9-rc1. File arch/ia64/include/asm/futex.h: static inline int futex_atomic_cmpxchg_inatomic(u32 *uval, u32 __user *uaddr, u32 oldval, u32 newval) { if (!access_ok(VERIFY_WRITE, uaddr, sizeof(u32))) return -EFAULT; { register unsigned long r8 __asm ("r8"); unsigned long prev; __asm__ __volatile__( " mf;; \n" " mov %0=r0 \n" " mov ar.ccv=%4;; \n" "[1:] cmpxchg4.acq %1=[%2],%3,ar.ccv \n" " .xdata4 \"__ex_table\", 1b-., 2f-. \n" "[2:]" : "=r" (r8), "=r" (prev) : "r" (uaddr), "r" (newval), "rO" ((long) (unsigned) oldval) : "memory"); *uval = prev; return r8; } } The list of output registers is : "=r" (r8), "=r" (prev) The constraint "=r" means that the GCC has to maintain that these vars are in registers and contain valid info when the program flow leaves the assembly block (output registers). But "=r" also means that GCC can put them in registers that are used as input registers. Input registers are uaddr, newval, oldval on the example. The second assembly instruction " mov %0=r0 \n" is the first one which writes to a register; it sets %0 to 0. %0 means the first register operand; it is r8 here. (The r0 is read-only and always 0 on the Itanium; it can be used if an immediate zero value is needed.) This instruction might overwrite one of the other registers which are still needed. Whether it really happens depends on how GCC decides what registers it uses and how it optimizes the code. The objdump utility can give us disassembly. The futex_atomic_cmpxchg_inatomic() function is inline, so we have to look for a module that uses the funtion. This is the cmpxchg_futex_value_locked() function in kernel/futex.c: static int cmpxchg_futex_value_locked(u32 *curval, u32 __user *uaddr, u32 uval, u32 newval) { int ret; pagefault_disable(); ret = futex_atomic_cmpxchg_inatomic(curval, uaddr, uval, newval); pagefault_enable(); return ret; } Now the disassembly. At first from the Kernel package 3.2.23 which has been compiled with GCC 4.4, remeber this Kernel seemed to work: objdump -d linux-3.2.23/debian/build/build_ia64_none_mckinley/kernel/futex.o 0000000000000230 <cmpxchg_futex_value_locked>: 230: 0b 18 80 1b 18 21 [MMI] adds r3=3168,r13;; 236: 80 40 0d 00 42 00 adds r8=40,r3 23c: 00 00 04 00 nop.i 0x0;; 240: 0b 50 00 10 10 10 [MMI] ld4 r10=[r8];; 246: 90 08 28 00 42 00 adds r9=1,r10 24c: 00 00 04 00 nop.i 0x0;; 250: 09 00 00 00 01 00 [MMI] nop.m 0x0 256: 00 48 20 20 23 00 st4 [r8]=r9 25c: 00 00 04 00 nop.i 0x0;; 260: 08 10 80 06 00 21 [MMI] adds r2=32,r3 266: 00 00 00 02 00 00 nop.m 0x0 26c: 02 08 f1 52 extr.u r16=r33,0,61 270: 05 40 88 00 08 e0 [MLX] addp4 r8=r34,r0 276: ff ff 0f 00 00 e0 movl r15=0xfffffffbfff;; 27c: f1 f7 ff 65 280: 09 70 00 04 18 10 [MMI] ld8 r14=[r2] 286: 00 00 00 02 00 c0 nop.m 0x0 28c: f0 80 1c d0 cmp.ltu p6,p7=r15,r16;; 290: 08 40 fc 1d 09 3b [MMI] cmp.eq p8,p9=-1,r14 296: 00 00 00 02 00 40 nop.m 0x0 29c: e1 08 2d d0 cmp.ltu p10,p11=r14,r33 2a0: 56 01 10 00 40 10 [BBB] (p10) br.cond.spnt.few 2e0 <cmpxchg_futex_value_locked+0xb0> 2a6: 02 08 00 80 21 03 (p08) br.cond.dpnt.few 2b0 <cmpxchg_futex_value_locked+0x80> 2ac: 40 00 00 41 (p06) br.cond.spnt.few 2e0 <cmpxchg_futex_value_locked+0xb0> 2b0: 0a 00 00 00 22 00 [MMI] mf;; 2b6: 80 00 00 00 42 00 mov r8=r0 2bc: 00 00 04 00 nop.i 0x0 2c0: 0b 00 20 40 2a 04 [MMI] mov.m ar.ccv=r8;; 2c6: 10 1a 85 22 20 00 cmpxchg4.acq r33=[r33],r35,ar.ccv 2cc: 00 00 04 00 nop.i 0x0;; 2d0: 10 00 84 40 90 11 [MIB] st4 [r32]=r33 2d6: 00 00 00 02 00 00 nop.i 0x0 2dc: 20 00 00 40 br.few 2f0 <cmpxchg_futex_value_locked+0xc0> 2e0: 09 40 c8 f9 ff 27 [MMI] mov r8=-14 2e6: 00 00 00 02 00 00 nop.m 0x0 2ec: 00 00 04 00 nop.i 0x0;; 2f0: 0b 58 20 1a 19 21 [MMI] adds r11=3208,r13;; 2f6: 20 01 2c 20 20 00 ld4 r18=[r11] 2fc: 00 00 04 00 nop.i 0x0;; 300: 0b 88 fc 25 3f 23 [MMI] adds r17=-1,r18;; 306: 00 88 2c 20 23 00 st4 [r11]=r17 30c: 00 00 04 00 nop.i 0x0;; 310: 11 00 00 00 01 00 [MIB] nop.m 0x0 316: 00 00 00 02 00 80 nop.i 0x0 31c: 08 00 84 00 br.ret.sptk.many b0;; The lines 2b0: 0a 00 00 00 22 00 [MMI] mf;; 2b6: 80 00 00 00 42 00 mov r8=r0 2bc: 00 00 04 00 nop.i 0x0 2c0: 0b 00 20 40 2a 04 [MMI] mov.m ar.ccv=r8;; 2c6: 10 1a 85 22 20 00 cmpxchg4.acq r33=[r33],r35,ar.ccv 2cc: 00 00 04 00 nop.i 0x0;; are the instructions of the assembly block. The line 2b6: 80 00 00 00 42 00 mov r8=r0 sets the r8 register to 0 and after that 2c0: 0b 00 20 40 2a 04 [MMI] mov.m ar.ccv=r8;; prepares the 'oldvalue' for the cmpxchg but it takes it from r8. This is wrong. What happened here is what I explained above: An input register is overwritten which is still needed. The register operand constraints in futex.h are wrong. (The problem doesn't occur when the Kernel is compiled with GCC 4.6.) The attached patch fixes the register operand constraints in futex.h. The code after patching of it: static inline int futex_atomic_cmpxchg_inatomic(u32 *uval, u32 __user *uaddr, u32 oldval, u32 newval) { if (!access_ok(VERIFY_WRITE, uaddr, sizeof(u32))) return -EFAULT; { register unsigned long r8 __asm ("r8") = 0; unsigned long prev; __asm__ __volatile__( " mf;; \n" " mov ar.ccv=%4;; \n" "[1:] cmpxchg4.acq %1=[%2],%3,ar.ccv \n" " .xdata4 \"__ex_table\", 1b-., 2f-. \n" "[2:]" : "+r" (r8), "=&r" (prev) : "r" (uaddr), "r" (newval), "rO" ((long) (unsigned) oldval) : "memory"); *uval = prev; return r8; } } I also initialized the 'r8' var with the C programming language. The _asm qualifier on the definition of the 'r8' var forces GCC to use the r8 processor register for it. I don't believe that we should use inline assembly for zeroing out a local variable. The constraint is "+r" (r8) what means that it is both an input register and an output register. Note that the page fault handler will modify the r8 register which will be the return value of the function. The real fix is "=&r" (prev) The & means that GCC must not use any of the input registers to place this output register in. Patched the Kernel 3.2.23 and compiled it with GCC4.4: 0000000000000230 <cmpxchg_futex_value_locked>: 230: 0b 18 80 1b 18 21 [MMI] adds r3=3168,r13;; 236: 80 40 0d 00 42 00 adds r8=40,r3 23c: 00 00 04 00 nop.i 0x0;; 240: 0b 50 00 10 10 10 [MMI] ld4 r10=[r8];; 246: 90 08 28 00 42 00 adds r9=1,r10 24c: 00 00 04 00 nop.i 0x0;; 250: 09 00 00 00 01 00 [MMI] nop.m 0x0 256: 00 48 20 20 23 00 st4 [r8]=r9 25c: 00 00 04 00 nop.i 0x0;; 260: 08 10 80 06 00 21 [MMI] adds r2=32,r3 266: 20 12 01 10 40 00 addp4 r34=r34,r0 26c: 02 08 f1 52 extr.u r16=r33,0,61 270: 05 40 00 00 00 e1 [MLX] mov r8=r0 276: ff ff 0f 00 00 e0 movl r15=0xfffffffbfff;; 27c: f1 f7 ff 65 280: 09 70 00 04 18 10 [MMI] ld8 r14=[r2] 286: 00 00 00 02 00 c0 nop.m 0x0 28c: f0 80 1c d0 cmp.ltu p6,p7=r15,r16;; 290: 08 40 fc 1d 09 3b [MMI] cmp.eq p8,p9=-1,r14 296: 00 00 00 02 00 40 nop.m 0x0 29c: e1 08 2d d0 cmp.ltu p10,p11=r14,r33 2a0: 56 01 10 00 40 10 [BBB] (p10) br.cond.spnt.few 2e0 <cmpxchg_futex_value_locked+0xb0> 2a6: 02 08 00 80 21 03 (p08) br.cond.dpnt.few 2b0 <cmpxchg_futex_value_locked+0x80> 2ac: 40 00 00 41 (p06) br.cond.spnt.few 2e0 <cmpxchg_futex_value_locked+0xb0> 2b0: 0b 00 00 00 22 00 [MMI] mf;; 2b6: 00 10 81 54 08 00 mov.m ar.ccv=r34 2bc: 00 00 04 00 nop.i 0x0;; 2c0: 09 58 8c 42 11 10 [MMI] cmpxchg4.acq r11=[r33],r35,ar.ccv 2c6: 00 00 00 02 00 00 nop.m 0x0 2cc: 00 00 04 00 nop.i 0x0;; 2d0: 10 00 2c 40 90 11 [MIB] st4 [r32]=r11 2d6: 00 00 00 02 00 00 nop.i 0x0 2dc: 20 00 00 40 br.few 2f0 <cmpxchg_futex_value_locked+0xc0> 2e0: 09 40 c8 f9 ff 27 [MMI] mov r8=-14 2e6: 00 00 00 02 00 00 nop.m 0x0 2ec: 00 00 04 00 nop.i 0x0;; 2f0: 0b 88 20 1a 19 21 [MMI] adds r17=3208,r13;; 2f6: 30 01 44 20 20 00 ld4 r19=[r17] 2fc: 00 00 04 00 nop.i 0x0;; 300: 0b 90 fc 27 3f 23 [MMI] adds r18=-1,r19;; 306: 00 90 44 20 23 00 st4 [r17]=r18 30c: 00 00 04 00 nop.i 0x0;; 310: 11 00 00 00 01 00 [MIB] nop.m 0x0 316: 00 00 00 02 00 80 nop.i 0x0 31c: 08 00 84 00 br.ret.sptk.many b0;; Much better. There is a 270: 05 40 00 00 00 e1 [MLX] mov r8=r0 which was generated by C code r8 = 0. Below 2b6: 00 10 81 54 08 00 mov.m ar.ccv=r34 what means that oldval is no longer overwritten. This is Debian bug#702641 (http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=702641). The patch is applicable on Kernel 3.9-rc1, 3.2.23 and many other versions. Signed-off-by: Stephan Schreiber <info@fs-driver.org> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07Fix initialization of CMCI/CMCP interruptsTony Luck
commit d303e9e98fce56cdb3c6f2ac92f626fc2bd51c77 upstream. Back 2010 during a revamp of the irq code some initializations were moved from ia64_mca_init() to ia64_mca_late_init() in commit c75f2aa13f5b268aba369b5dc566088b5194377c Cannot use register_percpu_irq() from ia64_mca_init() But this was hideously wrong. First of all these initializations are now down far too late. Specifically after all the other cpus have been brought up and initialized their own CMC vectors from smp_callin(). Also ia64_mca_late_init() may be called from any cpu so the line: ia64_mca_cmc_vector_setup(); /* Setup vector on BSP */ is generally not executed on the BSP, and so the CMC vector isn't setup at all on that processor. Make use of the arch_early_irq_init() hook to get this code executed at just the right moment: not too early, not too late. Reported-by: Fred Hartnett <fred.hartnett@hp.com> Tested-by: Fred Hartnett <fred.hartnett@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ia64: Add missing RCU idle APIs on idle loopPaul E. McKenney
commit 93482f4ef1093f5961a63359a34612183d6beea0 upstream. Traditionally, the entire idle task served as an RCU quiescent state. But when RCU read side critical sections started appearing within the idle loop, this traditional strategy became untenable. The fix was to create new RCU APIs named rcu_idle_enter() and rcu_idle_exit(), which must be called by each architecture's idle loop so that RCU can tell when it is safe to ignore a given idle CPU. Unfortunately, this fix was never applied to ia64, a shortcoming remedied by this commit. Reported by: Tony Luck <tony.luck@intel.com> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested by: Tony Luck <tony.luck@intel.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: remove rand_initialize_irq()Theodore Ts'o
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream. With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15Redefine ATOMIC_INIT and ATOMIC64_INIT to drop the castsTony Luck
commit a119365586b0130dfea06457f584953e0ff6481d upstream. The following build error occured during a ia64 build with swap-over-NFS patches applied. net/core/sock.c:274:36: error: initializer element is not constant net/core/sock.c:274:36: error: (near initialization for 'memalloc_socks') net/core/sock.c:274:36: error: initializer element is not constant This is identical to a parisc build error. Fengguang Wu, Mel Gorman and James Bottomley did all the legwork to track the root cause of the problem. This fix and entire commit log is shamelessly copied from them with one extra detail to change a dubious runtime use of ATOMIC_INIT() to atomic_set() in drivers/char/mspec.c Dave Anglin says: > Here is the line in sock.i: > > struct static_key memalloc_socks = ((struct static_key) { .enabled = > ((atomic_t) { (0) }) }); The above line contains two compound literals. It also uses a designated initializer to initialize the field enabled. A compound literal is not a constant expression. The location of the above statement isn't fully clear, but if a compound literal occurs outside the body of a function, the initializer list must consist of constant expressions. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10IA64: Add cmpxchg.h to exported userspace headersmaximilian attems
commit 98e4cff73a18af27f0d40d0b0d37f105dfc1994a upstream. Fixes klibc build on ia64 after 85f8f7759e418c814ee2ceacf73eddb9bed39492. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-09KVM: ia64: fix build due to typoAvi Kivity
s/kcm/kvm/. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-21kill mm argument of vm_munmap()Al Viro
it's always current->mm Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-21perfmon: kill some helpers and argumentsAl Viro
pfm_vm_munmap() is simply vm_munmap() and pfm_remove_smpl_mapping() always get current as the first argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-20VM: add "vm_munmap()" helper functionLinus Torvalds
Like the vm_brk() function, this is the same as "do_munmap()", except it does the VM locking for the caller. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-16ia64: fix futex_atomic_cmpxchg_inatomic()Luck, Tony
Michel Lespinasse cleaned up the futex calling conventions in commit 37a9d912b24f ("futex: Sanitize cmpxchg_futex_value_locked API"). But the ia64 implementation was subtly broken. Gcc does not know that register "r8" will be updated by the fault handler if the cmpxchg instruction takes an exception. So it feels safe in letting the initialization of r8 slide to after the cmpxchg. Result: we always return 0 whether the user address faulted or not. Fix by moving the initialization of r8 into the __asm__ code so gcc won't move it. Reported-by: <emeric.maschino@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42757 Tested-by: <emeric.maschino@gmail.com> Acked-by: Michel Lespinasse <walken@google.com> Cc: stable@vger.kernel.org # v2.6.39+ Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-13ia64: populate the cmpxchg header with appropriate codePaul Gortmaker
commit 93f378883cecb9dcb2cf5b51d9d24175906659da "Fix ia64 build errors (fallout from system.h disintegration)" introduced arch/ia64/include/asm/cmpxchg.h as a temporary build fix and stated: "... leave the migration of xchg() and cmpxchg() to this new header file for a future patch." Migrate the appropriate chunks from asm/intrinsics.h and fix the whitespace issues in the migrated chunk. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-04-02Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Pull cpumask cleanups from Rusty Russell: "(Somehow forgot to send this out; it's been sitting in linux-next, and if you don't want it, it can sit there another cycle)" I'm a sucker for things that actually delete lines of code. Fix up trivial conflict in arch/arm/kernel/kprobes.c, where Rusty fixed a user of &cpu_online_map to be cpu_online_mask, but that code got deleted by commit b21d55e98ac2 ("ARM: 7332/1: extract out code patch function from kprobes"). * tag 'for-linus' of git://github.com/rustyrussell/linux: cpumask: remove old cpu_*_map. documentation: remove references to cpu_*_map. drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map. remove references to cpu_*_map in arch/
2012-03-30ia64: Fixup asm/cmpxchg.hDavid Howells
The empty asm/cmpxchg.h file that was provided as a temporary build fix for the asm/system.h disintgration build problem should really include <asm/intrinsics.h> to make definitions of xchg() and cmpxchg() available. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-29Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ia64: vsyscall: Add missing paranthesis alarmtimer: Don't call rtc_timer_init() when CONFIG_RTC_CLASS=n x86: vdso: Put declaration before code x86-64: Inline vdso clock_gettime helpers x86-64: Simplify and optimize vdso clock_gettime monotonic variants kernel-time: fix s/then/than/ spelling errors time: remove no_sync_cmos_clock time: Avoid scary backtraces when warning of > 11% adj alarmtimer: Make sure we initialize the rtctimer ntp: Fix leap-second hrtimer livelock x86, tsc: Skip refined tsc calibration on systems with reliable TSC rtc: Provide flag for rtc devices that don't support UIE ia64: vsyscall: Use seqcount instead of seqlock x86: vdso: Use seqcount instead of seqlock x86: vdso: Remove bogus locking in update_vsyscall_tz() time: Remove bogus comments time: Fix change_clocksource locking time: x86: Fix race switching from vsyscall to non-vsyscall clock
2012-03-29Fix ia64 build errors (fallout from system.h disintegration)Luck, Tony
Fix this build error on ia64: In file included from include/linux/sched.h:92, from arch/ia64/kernel/asm-offsets.c:9: include/linux/llist.h:59:25: error: asm/cmpxchg.h: No such file or directory make[1]: *** [arch/ia64/kernel/asm-offsets.s] Error 1 Right now we don't seem to need any actual contents for the asm/cmpxchg.h to make the build work ... so leave the migration of xchg() and cmpxchg() to this new header file for a future patch. Also process.c needs <asm/switch_to.h> (for definition of pfm_syst_info). Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29documentation: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while, fix documentation and misc comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-28Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge third batch of patches from Andrew Morton: - Some MM stragglers - core SMP library cleanups (on_each_cpu_mask) - Some IPI optimisations - kexec - kdump - IPMI - the radix-tree iterator work - various other misc bits. "That'll do for -rc1. I still have ~10 patches for 3.4, will send those along when they've baked a little more." * emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits) backlight: fix typo in tosa_lcd.c crc32: add help text for the algorithm select option mm: move hugepage test examples to tools/testing/selftests/vm mm: move slabinfo.c to tools/vm mm: move page-types.c from Documentation to tools/vm selftests/Makefile: make `run_tests' depend on `all' selftests: launch individual selftests from the main Makefile radix-tree: use iterators in find_get_pages* functions radix-tree: rewrite gang lookup using iterator radix-tree: introduce bit-optimized iterator fs/proc/namespaces.c: prevent crash when ns_entries[] is empty nbd: rename the nbd_device variable from lo to nbd pidns: add reboot_pid_ns() to handle the reboot syscall sysctl: use bitmap library functions ipmi: use locks on watchdog timeout set on reboot ipmi: simplify locking ipmi: fix message handling during panics ipmi: use a tasklet for handling received messages ipmi: increase KCS timeouts ipmi: decrease the IPMI message transaction time in interrupt mode ...
2012-03-28arch/ia64: remove references to cpu_*_mapSrivatsa S. Bhat
This was marked as obsolete for quite a while now.. Now it is time to remove it altogether. And while doing this, get rid of first_cpu() as well. Also, remove the redundant setting of cpu_online_mask in smp_prepare_cpus() because the generic code would have already set cpu 0 in cpu_online_mask. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Merge branch 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Avi Kivity: "Changes include timekeeping improvements, support for assigning host PCI devices that share interrupt lines, s390 user-controlled guests, a large ppc update, and random fixes." This is with the sign-off's fixed, hopefully next merge window we won't have rebased commits. * 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits) KVM: Convert intx_mask_lock to spin lock KVM: x86: fix kvm_write_tsc() TSC matching thinko x86: kvmclock: abstract save/restore sched_clock_state KVM: nVMX: Fix erroneous exception bitmap check KVM: Ignore the writes to MSR_K7_HWCR(3) KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask KVM: PMU: add proper support for fixed counter 2 KVM: PMU: Fix raw event check KVM: PMU: warn when pin control is set in eventsel msr KVM: VMX: Fix delayed load of shared MSRs KVM: use correct tlbs dirty type in cmpxchg KVM: Allow host IRQ sharing for assigned PCI 2.3 devices KVM: Ensure all vcpus are consistent with in-kernel irqchip settings KVM: x86 emulator: Allow PM/VM86 switch during task switch KVM: SVM: Fix CPL updates KVM: x86 emulator: VM86 segments must have DPL 3 KVM: x86 emulator: Fix task switch privilege checks arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation KVM: mmu_notifier: Flush TLBs before releasing mmu_lock ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for IA64David Howells
Disintegrate asm/system.h for IA64. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> cc: linux-ia64@vger.kernel.org
2012-03-28X86 & IA64: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [removed swiotlb related changes and replaced it with wrappers, merged with IA64 patch to avoid inter-patch dependences in intel-iommu code] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Luck <tony.luck@intel.com>
2012-03-27ia64: vsyscall: Add missing paranthesisThomas Gleixner
commit 74a622b (ia64: vsyscall: Use seqcount instead of seqlock) broke the ia64 build. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-23Merge tag 'ia64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull miscellaneous Itanium patches from Tony Luck. The conflicts in arch/ia64/hp/sim/simserial.c were due to patches to simserial that had alredy been included (with lots of further cleanups) in the serial tree. * tag 'ia64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: Documentation/kernel-parameters: remove inttest parameter [IA64] Fix ISA IRQ trigger model and polarity setting [IA64] Fix a couple of warnings for EXPORT_SYMBOL [IA64] Check return from device_register() in cx_device_register() [IA64] Fix warning from machine_kexec.c [IA64] simserial, bail out when request_irq fails [IA64] hpsim, initialize chip for assigned irqs [IA64] simserial, include some headers [IA64] hpsim, fix SAL handling in fw-emu [IA64] genirq fixup for SGI/SN [IA64] disable interrupts when exiting from ia64_mca_cmc_int_handler()
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-22Merge tag 'stable/for-linus-3.4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull xen updates from Konrad Rzeszutek Wilk: "which has three neat features: - PV multiconsole support, so that there can be hvc1, hvc2, etc; This can be used in HVM and in PV mode. - P-state and C-state power management driver that uploads said power management data to the hypervisor. It also inhibits cpufreq scaling drivers to load so that only the hypervisor can make power management decisions - fixing a weird perf bug. There is one thing in the Kconfig that you won't like: "default y if (X86_ACPI_CPUFREQ = y || X86_POWERNOW_K8 = y)" (note, that it all depends on CONFIG_XEN which depends on CONFIG_PARAVIRT which by default is off). I've a fix to convert that boolean expression into "default m" which I am going to post after the cpufreq git pull - as the two patches to make this work depend on a fix in Dave Jones's tree. - Function Level Reset (FLR) support in the Xen PCI backend. Fixes: - Kconfig dependencies for Xen PV keyboard and video - Compile warnings and constify fixes - Change over to use percpu_xxx instead of this_cpu_xxx" Fix up trivial conflicts in drivers/tty/hvc/hvc_xen.c due to changes to a removed commit. * tag 'stable/for-linus-3.4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen kconfig: relax INPUT_XEN_KBDDEV_FRONTEND deps xen/acpi-processor: C and P-state driver that uploads said data to hypervisor. xen: constify all instances of "struct attribute_group" xen/xenbus: ignore console/0 hvc_xen: introduce HVC_XEN_FRONTEND hvc_xen: implement multiconsole support hvc_xen: support PV on HVM consoles xenbus: don't free other end details too early xen/enlighten: Expose MWAIT and MWAIT_LEAF if hypervisor OKs it. xen/setup/pm/acpi: Remove the call to boot_option_idle_override. xenbus: address compiler warnings xen: use this_cpu_xxx replace percpu_xxx funcs xen/pciback: Support pci_reset_function, aka FLR or D3 support. pci: Introduce __pci_reset_function_locked to be used when holding device_lock. xen: Utilize the restore_msi_irqs hook.
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20Merge tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/ttyLinus Torvalds
Pull TTY/serial patches from Greg KH: "tty and serial merge for 3.4-rc1 Here's the big serial and tty merge for the 3.4-rc1 tree. There's loads of fixes and reworks in here from Jiri for the tty layer, and a number of patches from Alan to help try to wrestle the vt layer into a sane model. Other than that, lots of driver updates and fixes, and other minor stuff, all detailed in the shortlog." * tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits) serial: pxa: add clk_prepare/clk_unprepare calls TTY: Wrong unicode value copied in con_set_unimap() serial: PL011: clear pending interrupts serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset. vt: NULL dereference in vt_do_kdsk_ioctl() tty: serial: vt8500: fix annotations for probe/remove serial: remove back and forth conversions in serial_out_sync serial: use serial_port_in/out vs serial_in/out in 8250 serial: introduce generic port in/out helpers serial: reduce number of indirections in 8250 code serial: delete useless void casts in 8250.c serial: make 8250's serial_in shareable to other drivers. serial: delete last unused traces of pausing I/O in 8250 pch_uart: Add module parameter descriptions pch_uart: Use existing default_baud in setup_console pch_uart: Add user_uartclk parameter pch_uart: Add Fish River Island II uart clock quirks pch_uart: Use uartclk instead of base_baud mpc5200b/uart: select more tolerant uart prescaler on low baudrates tty: moxa: fix bit test in moxa_start() ...
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-15ia64: vsyscall: Use seqcount instead of seqlockThomas Gleixner
The update of the vdso data happens under xtime_lock, so adding a nested lock is pointless. Just use a seqcount to sync the readers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2012-03-14[IA64] Fix ISA IRQ trigger model and polarity settingLiu Jiang
When handling Interrupt Source Override in MADT table, the default ISA IRQ trigger model and polarity should be edge-rising. Current IA64 implmentation doesn't follow the specification and set default ISA IRQ trigger model as level-low. With that wrong configuration and when system runs out of interrupt vectors, it will cause vector sharing among edge triggered ISA IRQ and level triggered PCI IRQ, then interrupt storm. So change the code to follow the specification. Signed-off-by: Liu Jiang <jiang.liu@huawei.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-03-10xen/enlighten: Expose MWAIT and MWAIT_LEAF if hypervisor OKs it.Konrad Rzeszutek Wilk
For the hypervisor to take advantage of the MWAIT support it needs to extract from the ACPI _CST the register address. But the hypervisor does not have the support to parse DSDT so it relies on the initial domain (dom0) to parse the ACPI Power Management information and push it up to the hypervisor. The pushing of the data is done by the processor_harveset_xen module which parses the information that the ACPI parser has graciously exposed in 'struct acpi_processor'. For the ACPI parser to also expose the Cx states for MWAIT, we need to expose the MWAIT capability (leaf 1). Furthermore we also need to expose the MWAIT_LEAF capability (leaf 5) for cstate.c to properly function. The hypervisor could expose these flags when it traps the XEN_EMULATE_PREFIX operations, but it can't do it since it needs to be backwards compatible. Instead we choose to use the native CPUID to figure out if the MWAIT capability exists and use the XEN_SET_PDC query hypercall to figure out if the hypervisor wants us to expose the MWAIT_LEAF capability or not. Note: The XEN_SET_PDC query was implemented in c/s 23783: "ACPI: add _PDC input override mechanism". With this in place, instead of C3 ACPI IOPORT 415 we get now C3:ACPI FFH INTEL MWAIT 0x20 Note: The cpu_idle which would be calling the mwait variants for idling never gets set b/c we set the default pm_idle to be the hypercall variant. Acked-by: Jan Beulich <JBeulich@suse.com> [v2: Fix missing header file include and #ifdef] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-08TTY: simserial, final cleanupJiri Slaby
* remove pointless checks (tty cannot be NULL at that points) * fix some printks (use __func__, print text directly w/o using global strings) * remove some empty lines This is the last patch for simserial. Overall, the driver is 400 lines shorter. Being now at 560 lines. It was tested using ski with a busybox userspace. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, reindent some codeJiri Slaby
Make the code to conform to the standard. Also make it readable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, fix includesJiri Slaby
Use headers from linux/* instead of asm/. Remove declaration of console_drivers, it's in linux/console.h already. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, remove useless commentsJiri Slaby
Or the obsolete ones like: "Let's have a little bit of fun" I have never had fun with software. For fun, one needs hard-ware. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, use tty_port_hangupJiri Slaby
Convert shutdown to be tty_port_operations->shutdown. Then we can use tty_port_hangup. (And we have to use tty_port_close.) This means we no longer touch ASYNC_INITIALIZED, TTY_IO_ERROR. Also we do not need to do any peculiar TTY logic in the file now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, use tty_port_openJiri Slaby
So now we convert startup to be ->activate of tty_port. This means we no longer care about INITIALIZED and TTY_IO_ERROR flags. After we have ->activate much of the code may go as it duplicates what tty_port_open does. In this case tty_port_open adds block_til_ready to the path. But we do not define carrier hooks, so it is a noop. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, properly refcount tty_port->ttyJiri Slaby
So that we will not be surprised in the ISR anymore. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, use tty_port_close_startJiri Slaby
I.e. remove more copied bloat. The only change is that we wait_until_sent now. Which is what we really should do. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, use tty_port_close_endJiri Slaby
The code is identical except locking. But added locks to protect counts do not hurt here. Rather the contrary. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, remove some tty opsJiri Slaby
All ->start, ->stop and ->wait_until_sent are empty and need not be defined. The time to remove them is now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial, define local tty_port pointerJiri Slaby
And use it to make the code more readable. Since tport doesn't conflict with port anymore and there are not many tport accessors left, do also s/\<tport\>/port/g. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial no longer needs serialPJiri Slaby
Let's do a spin-off of serial_state structure with only needed elements. And remove serialP crap from includes. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
