path: root/arch/ia64
2008-06-20[IA64] SN2: security hole in sn2_ptc_proc_writeCliff Wickman
Security hole in sn2_ptc_proc_write It is possible to overrun a buffer with a write to this /proc file. Signed-off-by: Cliff Wickman <cpw@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix CONFIG_IA64_SGI_UV build error [IA64] Update check_sal_cache_flush to use platform_send_ipi() [IA64] perfmon: fix async exit bug
2008-06-16[IA64] Fix CONFIG_IA64_SGI_UV build errorJack Steiner
Fix build error in CONFIG_IA64_SGI_UV config. (GENERIC builds are ok). Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits) ACPICA: fix stray va_end() caused by mis-merge ACPI: Reject below-freezing temperatures as invalid critical temperatures ACPICA: Fix for access to deleted object <regression> ACPICA: Fix to make _SST method optional ACPICA: Fix for Load operator, load table at the namespace root ACPICA: Ignore ACPI table signature for Load() operator ACPICA: Fix to allow zero-length ASL field declarations ACPI: use memory_read_from_buffer() bay: exit if notify handler cannot be installed dock.c remove trailing printk whitespace proper prototype for acpi_processor_tstate_has_changed() ACPI: handle invalid ACPI SLIT table PNPACPI: use _CRS IRQ descriptor length for _SRS pnpacpi: fix shareable IRQ encode/decode pnpacpi: fix IRQ flag decoding MAINTAINERS: update ACPI homepage ACPI 2.6.26-rc2: Add missing newline to DSDT/SSDT warning message ACPI: EC: Use msleep instead of udelay while waiting for event. thinkpad-acpi: fix LED handling on older ThinkPads thinkpad-acpi: fix initialization error paths ...
2008-06-11[IA64] Update check_sal_cache_flush to use platform_send_ipi()Alex Chiang
check_sal_cache_flush is used to detect broken firmware that drops pending interrupts. The old implementation schedules a timer interrupt for itself in the future by getting the current value of the Interval Timer Counter + 1000 cycles, waits for the interrupt to be pended, calls SAL_CACHE_FLUSH, and finally checks to see if the interrupt is still pending. This implementation can cause problems for virtual machine code if the process of scheduling the timer interrupt takes more than 1000 cycles; the virtual machine can end up sleeping for several hundred years while waiting for the ITC to wrap around. The fix is to use platform_send_ipi. The processor will still send an interrupt to itself, using the IA64_IPI_DM_INT delivery mode, which causes the IPI to look like an external interrupt. The rest of the SAL_CACHE_FLUSH + checking to see if the interrupt is still pending remains unchanged. This fix has been boot tested successfully on: - intel tiger2 - hp rx6600 - hp rx5670 The rx5670 has known buggy firmware, where SAL_CACHE_FLUSH drops pending interrupts. A boot test on this machine showed this message on the console: SAL: SAL_CACHE_FLUSH drops interrupts; PAL_CACHE_FLUSH will be used instead Which proves that the self-inflicted IPI approach is viable. And as expected, the other tested platforms correctly did not display the warning. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-11ACPI: handle invalid ACPI SLIT tableFenghua Yu
This is a SLIT sanity checking patch. It moves slit_valid() function to generic ACPI code and does sanity checking for both x86 and ia64. It sets up node_distance with LOCAL_DISTANCE and REMOTE_DISTANCE when hitting invalid SLIT table on ia64. It also cleans up unused variable localities in acpi_parse_slit() on x86. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11[IA64] perfmon: fix async exit bugstephane eranian
Move the cleanup of the async queue to the close callback from the flush callback. This avoids losing asynchronous overflow notifications when the file descriptor is shared by multiple processes and one terminates. Signed-off-by: Stephane Eranian <eranian@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-06KVM: ia64: fix zero extending for mmio ld1/2/4 emulation in KVMJes Sorensen
Only copy in the data actually requested by the instruction emulation and zero pad the destination register first. This avoids the problem where emulated mmio access got garbled data from ld2.acq instructions in the vga console driver. Signed-off-by: Jes Sorensen <jes@sgi.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-27[IA64] Workaround for RSE issueTony Luck
Problem: An application violating the architectural rules regarding operation dependencies and having specific Register Stack Engine (RSE) state at the time of the violation, may result in an illegal operation fault and invalid RSE state. Such faults may initiate a cascade of repeated illegal operation faults within OS interruption handlers. The specific behavior is OS dependent. Implication: An application causing an illegal operation fault with specific RSE state may result in a series of illegal operation faults and an eventual OS stack overflow condition. Workaround: OS interruption handlers that switch to kernel backing store implement a check for invalid RSE state to avoid the series of illegal operation faults. The core of the workaround is the RSE_WORKAROUND code sequence inserted into each invocation of the SAVE_MIN_WITH_COVER and SAVE_MIN_WITH_COVER_R19 macros. This sequence includes hard-coded constants that depend on the number of stacked physical registers being 96. The rest of this patch consists of code to disable this workaround should this not be the case (with the presumption that if a future Itanium processor increases the number of registers, it would also remove the need for this patch). Move the start of the RBS up to a mod32 boundary to avoid some corner cases. The dispatch_illegal_op_fault code outgrew the spot it was squatting in when built with this patch and CONFIG_VIRT_CPU_ACCOUNTING=y Move it out to the end of the ivt. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-18KVM: ia64: fix GVMM module including position-dependent objectsXiantao Zhang
The GVMM module is position independent since it is relocated to the guest address space. Commit ea696f9cf ("ia64 kvm fixes for O=... builds") broke this by linking GVMM with non-PIC objects. Fix by creating two files: memset.S and memcpy.S which just include the files under arch/ia64/lib/{memset.S, memcpy.S} respectively. [akpm: don't delete files which we need] Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-15[IA64] fix personality(PER_LINUX32) performance issueHuang, Xiaolan
The patch aims to fix a performance issue for the syscall personality(PER_LINUX32). On IA-64 box, the syscall personality (PER_LINUX32) has poor performance because it failed to find the Linux/x86 execution domain. Then it tried to load the kernel module however it failed always and it used the default execution domain PER_LINUX instead. Requesting kernel modules is very expensive. It caused the performance issue. (see the function lookup_exec_domain in kernel/exec_domain.c). To resolve the issue, execution domain Linux/x86 is always registered in initialization time for IA-64 architecture. Signed-off-by: Xiaolan Huang <xiaolan.huang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] Properly unregister legacy interruptsPrarit Bhargava
acpi_unregister_gsi() should "undo" what acpi_register_gsi() does. On systems that have legacy interrupts, acpi_unregister_gsi erroneously calls iosapci_unregister_intr() which is wrong to do and causes a loud warning. acpi_unregister_gsi() should just return in these cases. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] Remove NULL pointer check for argument never passed as NULL.Simon Holm Thøgersen
There is only palinfo_handle_smp as (indirect) user of palinfo_smp_call (by way of smp_call_function_single) and surely palinfo_handle_smp never pass NULL as parameter for info. Signed-off-by: Simon Holm Thøgersen <odie@cs.aau.dk> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] trivial cleanup for perfmon.cHidetoshi Seto
Fix a typo, and coding style cleanups for pfm_handle_work(). Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] trivial cleanup for entry.SHidetoshi Seto
This patch does: - make comment at next to resched check more robust - move "re-check" comments to next to where change predicate regs Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] fix interrupt masking for pending works on kernel leaveHidetoshi Seto
[Bug-fix for "[BUG?][2.6.25-mm1] sleeping during IRQ disabled"] This patch does: - enable interrupts before calling schedule() as same as others, ex. x86 - enable interrupts during ia64_do_signal() and ia64_sync_krbs() - do_notify_resume_user() is still called with interrupts disabled, since we can take short path of fsys_mode if-statement quickly. - pfm_handle_work() is also called with interrupts disabled, since it can deal interrupt mask within itself. - fix/add some comments/notes Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] allow user to force_pal_cache_flushAlex Chiang
The sequence executed in check_sal_cache_flush: - pend a timer interrupt - call SAL_CACHE_FLUSH - see if interrupt is still pending can hang HP machines with buggy SAL_CACHE_FLUSH implementations. Provide a kernel command-line argument to allow users skip this check if desired. Using this parameter will force ia64_sal_cache_flush to call ia64_pal_cache_flush() instead of SAL_CACHE_FLUSH. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] Don't reserve crashkernel memory > 4 GBBernhard Walle
Some IA64 machines map all cell-local memory above 4 GB (32 bit limit). However, in most cases, the kernel needs some memory below that limit that is DMA-capable. So in this machine configuration, the crashkernel will be reserved above 4 GB. For machines that use SWIOTLB implementation because they lack an I/O MMU the low memory is required by the SWIOTLB implementation. In that case, it doesn't make sense to reserve the crashkernel at all because it's unusable for kdump. A special case is the "hpzx1" machine vector. In theory, it has a I/O MMU, so it can be booted above 4 GB. However, in the kdump case that is not possible because of changeset 51b58e3e26ebfb8cd56825c4b396ed251f51dec9: On HP zx1 machines, the 'machvec=dig' parameter is needed for the kdump kernel to avoid problems with the HP sba iommu. The problem is that during the boot of the kdump kernel, the iommu is re-initialized, so in-flight DMA from improperly shutdown drivers causes an IOTLB miss which leads to an MCA. With kdump, the idea is to get into the kdump kernel with as little code as we can, so shutting down drivers properly is not an option. The workaround is to add 'machvec=dig' to the kdump kernel boot parameters. This makes the kdump kernel avoid using the sba iommu altogether, leaving the IOTLB intact. Any ongoing DMA falls harmlessly outside the kdump kernel. After the kdump kernel reboots, all devices will have been shutdown properly and DMA stopped. This patch pushes that functionality into the sba iommu initialization code, so that users won't have to find the obscure documentation telling them about 'machvec=dig'. This means that also for hpzx1 it's not possible to boot when all memory is above the 4 GB limit. So the only machine vectors that can handle this case are "sn2" and "uv". Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] machvec support for SGI UV platformJack Steiner
This patch adds the basic IA64 machvec infrastructure to support the SGI "UV" platform. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-02Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix file and descriptor handling in perfmon [IA64] TS_RESTORE_SIGMASK [IA64] smp.c coding style fix [IA64] fix section mismatch in arch/ia64/kernel/topology.c [IA64] fix section mismatch in arch/ia64/kernel/palinfo.c [IA64] fix section mismatch in arch/ia64/kernel/irq.c [IA64] fix section mismatch in arch/ia64/kernel/acpi.c
2008-05-01[IA64] fix file and descriptor handling in perfmonAl Viro
Races galore... General rule: as soon as it's in descriptor table, it's over; another thread might have started IO on it/dup2() it elsewhere/dup2() something *over* it/etc. fd_install() is the very last step one should take - it's a point of no return. Besides, the damn thing leaked on failure exits... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-01[IA64] TS_RESTORE_SIGMASKRoland McGrath
Replace TIF_RESTORE_SIGMASK with TS_RESTORE_SIGMASK and define our own set_restore_sigmask() function. This saves the costly SMP-safe set_bit operation, which we do not need for the sigmask flag since TIF_SIGPENDING always has to be set too. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-01[IA64] smp.c coding style fixHidetoshi Seto
Fix indenting of switch statement to follow CodingStyle, and pull out handling of call_data into an inlined function. I confirmed that applying this fix doesn't affect assembled code. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30[IA64] fix section mismatch in arch/ia64/kernel/topology.cHidetoshi Seto
This patch silences: WARNING: vmlinux.o(.text+0x44672): Section mismatch in reference from the function arch_register_cpu() to the function .cpuinit.text:register_cpu() Changes are based on codes in arch/x86/kernel/topology.c Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-30[IA64] fix section mismatch in arch/ia64/kernel/palinfo.cHidetoshi Seto
This patch removes following warning: WARNING: vmlinux.o(.exit.text+0xb1): Section mismatch in reference from the function palinfo_exit() to the variable .cpuinit.data:palinfo_cpu_notifier Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-30[IA64] fix section mismatch in arch/ia64/kernel/irq.cHidetoshi Seto
This patch shuts up the following: WARNING: vmlinux.o(.text+0x7102): Section mismatch in reference from the function fixup_irqs() to the function .devinit.text:ia64_disable_timer() Removing ia64_disable_timer() is safe because there are no functions calling it other than the fixup_irqs(), Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-30[IA64] fix section mismatch in arch/ia64/kernel/acpi.cHidetoshi Seto
This patch kills: WARNING: vmlinux.o(.text+0x1702): Section mismatch in reference from the function acpi_register_ioapic() to the function .devinit.text:iosapic_init() Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30signals: ia64 renumber TIF_RESTORE_SIGMASKakpm@linux-foundation.org
TIF_RESTORE_SIGMASK no longer needs to be in the _TIF_WORK_* masks. Those low bits are scarce. Renumber TIF_RESTORE_SIGMASK to free one up. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29[IA64] Provide ACPI fixup for /proc/cpuinfo/physical_idAlex Chiang
Legacy HP ia64 platforms currently cannot provide /proc/cpuinfo/physical_id due to legacy SAL/PAL implementations. However, that physical topology information can be obtained via ACPI. Provide an interface that gives ACPI one last chance to provide physical_id for these legacy platforms. This logic only comes into play iff: - ACPI actually provides slot information for the CPU - we lack a valid socket_id Otherwise, we don't do anything. Since x86 uses the ACPI processor driver as well, we provide a nop stub function for arch_fix_phys_package_id() in asm-x86/topology.h Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29[IA64] Remove printk noise on unimplemented SAL_PHYSICAL_ID_INFOAlex Chiang
Commit 113134fcbca83619be4c68d0ca66db6093777b5d changed the flow of control when calling PAL_LOGICAL_TO_PHYSICAL and SAL_PHYSICAL_ID_INFO. With the change, if a platform did not implement the latter, a useless printk would appear in the boot log: ia64_sal_pltid failed with -1 So let's check the return code and only printk on a true error, and do not print anything in the unimplemented case. While we're in there, clean up some stylistic issues too. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29[IA64] allocate multiple contiguous pages via uncached allocatorDean Nelson
Enable the uncached allocator to allocate multiple pages of contiguous uncached memory. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29[IA64] bugfix: nptcg breaks cpu-hotaddHidetoshi Seto
If "max_purges" from PAL is 0, it actually means 1. However it was not handled later when a hot-added cpu pass the max_purges from PAL. This makes systems easy to go BUG_ON(). Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29ia64: use kbuild.h macros instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ia64: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma/ia64: update ia64 machvecs, swiotlb.cArthur Kepner
Change all ia64 machvecs to use the new dma_*map*_attrs() interfaces. Implement the old dma_*map_*() interfaces in terms of the corresponding new interfaces. For ia64/sn, make use of one dma attribute, DMA_ATTR_WRITE_BARRIER. Introduce swiotlb_*map*_attrs() functions. Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma: add dma_*map*_attrs() interfacesArthur Kepner
Introduce new interfaces, dma_*map*_attrs(), for passing architecture-specific attributes when memory is mapped and unmapped for DMA. Give the interfaces default implementations which ignore attributes. Also introduce the dma_{set|get}_attr() interfaces for setting and retrieving individual attributes. Define one attribute, DMA_ATTR_WRITE_BARRIER, in anticipation of its use by ia64/sn. Select whether architectures implement arch-specific versions of the dma_*map*_attrs() interfaces via HAVE_DMA_ATTRS in Kconfig. [markn@au1.ibm.com: dma_{set,get}_attr() have to be static inline] Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ia64 kvm fixes for O=... buildsAl Viro
* EXTRA_CFLAGS do not apply for *.S * don't bother with symlinks to ../lib/mem*.S, just add ../lib/mem*.o to object list Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hotplug-memory: make online_page() commonJeremy Fitzhardinge
All architectures use an effectively identical definition of online_page(), so just make it common code. x86-64, ia64, powerpc and sh are actually identical; x86-32 is slightly different. x86-32's differences arise because it puts its hotplug pages in the highmem zone. We can handle this in the generic code by inspecting the page to see if its in highmem, and update the totalhigh_pages count appropriately. This leaves init_32.c:free_new_highpage with a single caller, so I folded it into add_one_highpage_init. I also removed an incorrect comment referring to the NUMA case; any NUMA details have already been dealt with by the time online_page() is called. [akpm@linux-foundation.org: fix indenting] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Tested-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Christoph Lameter <clameter@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27KVM: add ioctls to save/store mpstateMarcelo Tosatti
So userspace can save/restore the mpstate during migration. [avi: export the #define constants describing the value] [christian: add s390 stubs] [avi: ditto for ia64] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: Rename VCPU_MP_STATE_* to KVM_MP_STATE_*Avi Kivity
We wish to export it to userspace, so move it into the kvm namespace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: hlt emulation should take in-kernel APIC/PIT timers into accountMarcelo Tosatti
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are ignored, possibly resulting in hangs. Also make sure that atomic_inc and waitqueue_active tests happen in the specified order, otherwise the following race is open: CPU0 CPU1 if (waitqueue_active(wq)) add_wait_queue() if (!atomic_read(pit_timer->pending)) schedule() atomic_inc(pit_timer->pending) Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Stub out kvmtraceAvi Kivity
2008-04-27KVM: ia64: Enable kvm build for ia64Xiantao Zhang
Update the related Makefile and KConfig for kvm build Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add kvm sal/pal virtulization supportXiantao Zhang
Some sal/pal calls would be traped to kvm for virtulization from guest firmware. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add guest interruption injection supportXiantao Zhang
process.c mainly handle interruption injection, and some faults handling. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
