path: root/arch/m32r/platforms
2011-03-24m32r: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21m32r: Convert usrv platform irq handlingThomas Gleixner
Convert the irq chips to the new functions and use proper flow handlers. handle_level_irq is appropriate. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21m32r: Convert opsput_lcdpld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput lanpld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput pld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput irq chipThomas Gleixner
2011-01-21m32r: Convert oaks32r irq chipsThomas Gleixner
2011-01-21m32r: Convert mappi3 irq chipThomas Gleixner
2011-01-21m32r: Convert mappi2 irq chipThomas Gleixner
2011-01-21m32r: Convert mappi irq chipsThomas Gleixner
2011-01-21m32r: Convert m32700ut lcdpld irq chipThomas Gleixner
Convert the irq chip to the new functions and use proper flow handlers. handle_level_irq is appropriate. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21m32r: Convert m32700ut lanpld irq chipThomas Gleixner
2011-01-21m32r: Convert m32700ut pld irq chipThomas Gleixner
2011-01-21m32r: Convert m32104ut irq chipThomas Gleixner
2011-01-21m32r: Convert m32104ut irq handlingThomas Gleixner
2011-01-21m32r: Cleanup direct irq_desc accessThomas Gleixner
The irq descriptors are already initialized by the generic code. Remove the redundant init code and set the irq chip with the proper accessor function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2010-09-23genirq: Cleanup irq_chip->typename leftoversThomas Gleixner
3 years transition phase is enough. Cleanup the last users and remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Leo Chen <leochen@broadcom.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net>
2009-06-16m32r: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-03m32r: Move dot.gdbinit filesHirokazu Takata
Move dot.gdbinit files from arch/m32r/{platforms}/dot.gdbinit* to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Rearrange platform-dependent codesHirokazu Takata
Rearrange platform-dependent codes from arch/m32r/kernel/*.c to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
