path: root/arch/m32r
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for M32RDavid Howells
Disintegrate asm/system.h for M32R. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-m32r@ml.linux-m32r.org
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-24net: Add framework to allow sending packets with customized CRC.Ben Greear
This is useful for testing RX handling of frames with bad CRCs. Requires driver support to actually put the packet on the wire properly. Signed-off-by: Ben Greear <greearb@candelatech.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2012-02-21sock: Introduce the SO_PEEK_OFF sock optionPavel Emelyanov
This one specifies where to start MSG_PEEK-ing queue data from. When set to negative value means that MSG_PEEK works as ususally -- peeks from the head of the queue always. When some bytes are peeked from queue and the peeking offset is non negative it is moved forward so that the next peek will return next portion of data. When non-peeking recvmsg occurs and the peeking offset is non negative is is moved backward so that the next peek will still peek the proper data (i.e. the one that would have been picked if there were no non peeking recv in between). The offset is set using per-proto opteration to let the protocol handle the locking issues and to check whether the peeking offset feature is supported by the protocol the socket belongs to. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-14m32r: Use generic posix_types.hH. Peter Anvin
Change the m32r architecture to use <asm-generic/posix_types.h>. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1328677745-20121-11-git-send-email-hpa@zytor.com Cc: Hirokazu Takata <takata@linux-m32r.org>
2012-01-14Merge branch 'for-next' of git://git.infradead.org/users/dhowells/linux-headersLinus Torvalds
* 'for-next' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Split trivial #if defined(__KERNEL__) && X conditionals UAPI: Don't have a #elif clause in a __KERNEL__ guard in linux/soundcard.h UAPI: Fix AHZ multiple inclusion when __KERNEL__ is removed UAPI: Make linux/patchkey.h easier to parse UAPI: Fix nested __KERNEL__ guards in video/edid.h UAPI: Alter the S390 asm include guards to be recognisable by the UAPI splitter UAPI: Guard linux/cuda.h UAPI: Guard linux/pmu.h UAPI: Guard linux/isdn_divertif.h UAPI: Guard linux/sound.h UAPI: Rearrange definition of HZ in asm-generic/param.h UAPI: Make FRV use asm-generic/param.h UAPI: Make M32R use asm-generic/param.h UAPI: Make MN10300 use asm-generic/param.h UAPI: elf_read_implies_exec() is a kernel-only feature - so hide from userspace UAPI: Don't include linux/compat.h in sparc's asm/siginfo.h UAPI: Fix arch/mips/include/asm/Kbuild to have separate header-y lines
2012-01-08Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits) PM / Hibernate: Implement compat_ioctl for /dev/snapshot PM / Freezer: fix return value of freezable_schedule_timeout_killable() PM / shmobile: Allow the A4R domain to be turned off at run time PM / input / touchscreen: Make st1232 use device PM QoS constraints PM / QoS: Introduce dev_pm_qos_add_ancestor_request() PM / shmobile: Remove the stay_on flag from SH7372's PM domains PM / shmobile: Don't include SH7372's INTCS in syscore suspend/resume PM / shmobile: Add support for the sh7372 A4S power domain / sleep mode PM: Drop generic_subsys_pm_ops PM / Sleep: Remove forward-only callbacks from AMBA bus type PM / Sleep: Remove forward-only callbacks from platform bus type PM: Run the driver callback directly if the subsystem one is not there PM / Sleep: Make pm_op() and pm_noirq_op() return callback pointers PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412. PM / Sleep: Merge internal functions in generic_ops.c PM / Sleep: Simplify generic system suspend callbacks PM / Hibernate: Remove deprecated hibernation snapshot ioctls PM / Sleep: Fix freezer failures due to racy usermodehelper_is_disabled() ARM: S3C64XX: Implement basic power domain support PM / shmobile: Use common always on power domain governor ... Fix up trivial conflict in fs/xfs/xfs_buf.c due to removal of unused XBT_FORCE_SLEEP bit
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-03consolidate a bunch of ipcbuf.h instancesAl Viro
... some still remain weird :-/ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03consolidate umode_t declarationsAl Viro
2011-12-12UAPI: Make M32R use asm-generic/param.hDavid Howells
Make M32R use the generic settings to be found in asm-generic/param.h rather than defining its own as they're exactly the same. This sorts out a problem with HZ being redefined after the splitting of userspace headers from kernel headers. Signed-off-by: David Howells <dhowells@redhat.com> cc: Hirokazu Takata <takata@linux-m32r.org> cc: linux-m32r@ml.linux-m32r.org
2011-11-21freezer: remove now unused TIF_FREEZETejun Heo
Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-arch@vger.kernel.org
2011-11-17Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: include/net/bluetooth/bluetooth.h
2011-11-09net: add wireless TX status socket optionJohannes Berg
The 802.1X EAPOL handshake hostapd does requires knowing whether the frame was ack'ed by the peer. Currently, we fudge this pretty badly by not even transmitting the frame as a normal data frame but injecting it with radiotap and getting the status out of radiotap monitor as well. This is rather complex, confuses users (mon.wlan0 presence) and doesn't work with all hardware. To get rid of that hack, introduce a real wifi TX status option for data frame transmissions. This works similar to the existing TX timestamping in that it reflects the SKB back to the socket's error queue with a SCM_WIFI_STATUS cmsg that has an int indicating ACK status (0/1). Since it is possible that at some point we will want to have TX timestamping and wifi status in a single errqueue SKB (there's little point in not doing that), redefine SO_EE_ORIGIN_TIMESTAMPING to SO_EE_ORIGIN_TXSTATUS which can collect more than just the timestamp; keep the old constant as an alias of course. Currently the internal APIs don't make that possible, but it wouldn't be hard to split them up in a way that makes it possible. Thanks to Neil Horman for helping me figure out the functions that add the control messages. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-06Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scsi: drop unused Kconfig symbol pci: drop unused Kconfig symbol stmmac: drop unused Kconfig symbol x86: drop unused Kconfig symbol powerpc: drop unused Kconfig symbols powerpc: 40x: drop unused Kconfig symbol mips: drop unused Kconfig symbols openrisc: drop unused Kconfig symbols arm: at91: drop unused Kconfig symbol samples: drop unused Kconfig symbol m32r: drop unused Kconfig symbol score: drop unused Kconfig symbols sh: drop unused Kconfig symbol um: drop unused Kconfig symbol sparc: drop unused Kconfig symbol alpha: drop unused Kconfig symbol Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig as per Michal: the STMMAC_DUAL_MAC config variable is still unused and should be deleted.
2011-10-31m32r: drop unused Kconfig symbolPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-10-17m32r: Allow use of atomic64Steven Rostedt
Atomic64 is now a valid type in Linux. Archs that do not have their own version of atomic64 operators are to use the generic operations. The m32r architecture needs to define GENERIC_ATOMIC64. Link: http://lkml.kernel.org/r/20111013085936.GA13046@elte.hu Link: http://lkml.kernel.org/r/1318516816.12224.12.camel@gandalf.stny.rr.com Link: http://lkml.kernel.org/r/20111017185440.GB5545@elte.hu Acked-by: Hirokazu Takata <takata@linux-m32r.org> Acked-by: David Rientjes <rientjes@google.com> Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25m32r, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24Merge branch 'for-upstream' of git://openrisc.net/jonas/linuxLinus Torvalds
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits) OpenRISC: Add MAINTAINERS entry OpenRISC: Miscellaneous OpenRISC: Library routines OpenRISC: Headers OpenRISC: Traps OpenRISC: Module support OpenRISC: GPIO OpenRISC: Scheduling/Process management OpenRISC: Idle/Power management OpenRISC: System calls OpenRISC: IRQ OpenRISC: Timekeeping OpenRISC: DMA OpenRISC: PTrace OpenRISC: Build infrastructure OpenRISC: Signal handling OpenRISC: Memory management OpenRISC: Device tree OpenRISC: Boot code iomap: make IOPORT/PCI mapping functions conditional ...
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22asm-generic: move archictures to common delay.hJonas Bonn
This patch moves the in-tree architectures that were using the 'generic' delay.h over to using the header file in asm-generic. This is not done using the generic-y mechanism as none of these arch's have started using that mechanism yet. This is a trivial change to make later when the arch begins using generic-y. Note the subtle change to the avr32 and SH architectures where the argument to __const_udelay was previously using the rounded down constant value instead of the rounded up value. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2011-07-05m32r: Use generic PREEMPT configFrederic Weisbecker
Use the generic preempt config definition in m32r instead of using a custom one. This also makes it handle the new CONFIG_PREEMPT_COUNT that need to be selected by CONFIG_PREEMPT. Without that it breaks kernel/sched.c: In function 'preempt_schedule': kernel/sched.c:4364: error: implicit declaration of function 'add_preempt_count_notrace' kernel/sched.c:4366: error: implicit declaration of function 'sub_preempt_count_notrace' Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org>
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: remove redundant declarationKOSAKI Motohiro
They have no meaning. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: convert cpumask apiKOSAKI Motohiro
We plan to remove cpus_xx() old cpumask APIs later. Also, we plan to change mm_cpu_mask() implementation, allocate only nr_cpu_ids, thus *mm_cpu_mask() is dangerous operation. Then, this patch convert them. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Remove unused PROC_CHANGE_PENALTY constantStephen Boyd
This constant hasn't been used since before the git era (2.6.12) and thus can be dropped. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Richard Weinberger <richard@nod.at> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25m32r, mm: set all online nodes in N_NORMAL_MEMORYDavid Rientjes
For m32r, N_NORMAL_MEMORY represents all nodes that have present memory since it does not support HIGHMEM. This patch sets the bit at the time the node is initialized. If N_NORMAL_MEMORY is not accurate, slub may encounter errors since it uses this nodemask to setup per-cache kmem_cache_node data structures. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-20extable, core_kernel_data(): Make sure all archs define _sdataSteven Rostedt
A new utility function (core_kernel_data()) is used to determine if a passed in address is part of core kernel data or not. It may or may not return true for RO data, but this utility must work for RW data. Thus both _sdata and _edata must be defined and continuous, without .init sections that may later be freed and replaced by volatile memory (memory that can be freed). This utility function is used to determine if data is safe from ever being freed. Thus it should return true for all RW global data that is not in a module or has been allocated, or false otherwise. Also change core_kernel_data() back to the more precise _sdata condition and document the function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: JamesE.J.Bottomley <jejb@parisc-linux.org> Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com Signed-off-by: Ingo Molnar <mingo@elte.hu> ---- arch/alpha/kernel/vmlinux.lds.S | 1 + arch/m32r/kernel/vmlinux.lds.S | 1 + arch/m68k/kernel/vmlinux-std.lds | 2 ++ arch/m68k/kernel/vmlinux-sun3.lds | 1 + arch/mips/kernel/vmlinux.lds.S | 1 + arch/parisc/kernel/vmlinux.lds.S | 3 +++ kernel/extable.c | 12 +++++++++++- 7 files changed, 20 insertions(+), 1 deletion(-)
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-24m32r: Use generic show_interrupts()Thomas Gleixner
2011-03-24m32r: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
