Enable CONFIG_DEVTMPFS_MOUNT, as it's useful for initrd-less kernels.
Enable CONFIG_EARLY_PRINTK on all platforms where it's available (all
but Sun-3) and not yet enabled.
It doesn't hurt to have CONFIG_TEST_* enabled as modules.
Because of the removal of the scsi_tgt kernel module, the kbuild variables
CONFIG_SCSI_TGT, CONFIG_SCSI_SRP_TGT_ATTRS and CONFIG_SCSI_FC_TGT_ATTRS
are obsolete. This patch removes these variables. This patch is the result
of the following command:
find -name '*defconfig' | while read f; do grep -vwE 'CONFIG_SCSI_TGT|CONFIG_SCSI_SRP_TGT_ATTRS|CONFIG_SCSI_FC_TGT_ATTRS|CONFIG_SRP' $f >/tmp/t && mv /tmp/t $f; done
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Cfr. commit 7934779a69f1184f29d786b89e77dd14519bd226 ("Driver-Core: disable
/sbin/hotplug by default").
This reduces the kernel image size by ca. 160 KiB.
This reduces the kernel image size by ca. 100 KiB, while still allowing
NFS root.
It was scheduled to be removed for a long time.
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netfilter@vger.kernel.org
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
As some m68k machines have plenty of libc5 binaries in active use, enable
CONFIG_COMPAT_BRK by default.
Update the m68k defconfigs
Long overdue update of the m68k defconfigs
infrastructure for it.
Let it rip!
