path: root/arch/m68k/mac
2010-12-10fix comment typos concerning "consistent"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in arch directory.Justin P. Mattock
The patch below updates broken web addresses in the arch directory. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-01arch/m68k/mac/macboing.c: use unsigned long for irqflagsAndrew Morton
Fix the warnings arch/m68k/mac/macboing.c: In function 'mac_mksound': arch/m68k/mac/macboing.c:189: warning: comparison of distinct pointer types lacks a cast arch/m68k/mac/macboing.c:211: warning: comparison of distinct pointer types lacks a cast arch/m68k/mac/macboing.c: In function 'mac_quadra_start_bell': arch/m68k/mac/macboing.c:241: warning: comparison of distinct pointer types lacks a cast arch/m68k/mac/macboing.c:263: warning: comparison of distinct pointer types lacks a cast arch/m68k/mac/macboing.c: In function 'mac_quadra_ring_bell': arch/m68k/mac/macboing.c:283: warning: comparison of distinct pointer types lacks a cast Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09m68k/mac: Fix RTC on PMU machinesFinn Thain
Copy RTC response bytes correctly on powerbooks and duos. Thanks to Diego Cousinet who debugged this and provided me with the fix. Tested on PowerBook 190 and Duo 280c. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reported-by: Diego Cousinet <diego@pvco.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-08-09m68k/mac: Add color classic ii supportFinn Thain
Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-05-17m68k: Remove trailing spaces in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-27mac68k: start CUDA earlyFinn Thain
The valkyriefb driver needs the CUDA to work in order to set the video mode at boot. So initialise the device earlier, and bring the m68k code closer to the powermac code. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-27mac68k: move macsonic and macmace platform devicesFinn Thain
Move platform device code from the drivers to the platform init function. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-27mac68k: move mac_esp platform deviceFinn Thain
Move platform device code from the driver to the platform init function. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-27mac68k: replace mac68k SCC code with platform deviceFinn Thain
Remove the old 68k Mac serial port code and a lot of related cruft. Add new SCC platform devices to mac 68k platform. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-27mac68k: rework SWIM platform deviceFinn Thain
Adjust the platform device code to conform with the code style used in the rest of this patch series. No need to name resources nor to register devices which are not applicable. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-27mac68k: cleanupFinn Thain
Cleanup whitespace and comments. Remove some dead code. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-26m68k: mac - Add SWIM floppy supportLaurent Vivier
It allows to read data from a floppy, but not to write to, and to eject the floppy (useful on our Mac without eject button). Signed-off-by: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-26m68k: mac - Add a new entry in mac_model to identify the floppy controller type.Laurent Vivier
This patch adds a field "floppy_type" which can take the following values: MAC_FLOPPY_IWM for an IWM based mac MAC_FLOPPY_SWIM_ADDR1 for a SWIM based mac with controller at VIA1 + 0x1E000 MAC_FLOPPY_SWIM_ADDR2 for a SWIM based mac with controller at VIA1 + 0x16000 MAC_FLOPPY_IOP for an IOP based mac MAC_FLOPPY_AV for an AV based mac Signed-off-by: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: mac core - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: Kill several external declarations in source filesGeert Uytterhoeven
- Replace external declarations by proper includes where availiable. The accesses to some symbols had to be modified, as before they were declared using e.g. "extern int _end", while asm-generic/sections.h uses e.g. "extern char _end[]" - Remove unused or superfluous external declarations Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-12-28m68k: mac baboon interrupt enable/disableFinn Thain
No-one seems to know how to mask individual baboon interrupts, so we just mask the umbrella IRQ. This will work as long as only the IDE driver uses the baboon chip (it can't deadlock). Use mac_enable_irq/mac_disable_irq rather than enable_irq/disable_irq because the latter routines count the depth of nested calls which triggers a warning and call trace because IRQ_NUBUS_C is enabled twice in a row (once when the baboon handler is registered, and once when the IDE IRQ is registered). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-12-28m68k: machw.h cleanupFinn Thain
Remove some more cruft from machw.h and drop the #include where it isn't needed. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-12-28m68k: Mac via cleanup and commentryFinn Thain
No behavioural changes, just cleanups and better documentation. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-12-28m68k: Reinstate mac rtcFinn Thain
Reinstate the Mac hardware clock for CUDA ADB and Mac II ADB models. It doesn't work properly on Mac IIsi ADB and PMU ADB yet, so leave them out. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-08-05remove unneeded #include <linux/ide.h>'sAdrian Bunk
This patch remove unneeded #include <linux/ide.h>'s. It also adds a required #include <linux/interrupt.h> that was previously implicitely pulled by ide.h Signed-off-by: Adrian Bunk <bunk@kernel.org> [bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-20m68k/mac/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code (always) static: - baboon.c: struct baboon - baboon.c: baboon_irq() - config.c: mac_orig_videoaddr - config.c: mac_identify() - config.c: mac_report_hardware() - config.c: mac_debug_console_write() - config.c: mac_sccb_console_write() - config.c: mac_scca_console_write() - config.c: mac_init_scc_port() - oss.c: oss_irq() - oss.c: oss_nubus_irq() - psc.c: psc_debug_dump() - psc.c: psc_dma_die_die_die() - via.c: rbv_clear - remove the unused bootparse.c - #if 0 the following unused functions: - config.c: mac_debugging_short() - config.c: mac_debugging_long() - remove the following unused code: - config.c: mac_bisize - config.c: mac_env - config.c: mac_SCC_init_done - config.c: mac_SCC_reset_done - config.c: mac_init_scca_port() - config.c: mac_init_sccb_port() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05m68k: remove old mac_esp cruftFinn Thain
Remove the rest of the old mac_esp driver. Also ditch the rest of the machw mechanism, it needs to be replaced by a fake openfirmware tree. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove /proc/mac_iopAlexey Dobriyan
Entry creation was commented for a long time and right now it stands on the way of ->get_info removal, so unless nobody objects... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28m68k: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mac68k: remove dead codeFinn Thain
Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68k: kill arch/m68k/mac/mac_ksyms.cAdrian Bunk
EXPORT_SYMBOL's belong to the actual code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: arch/m68k/Simon Arlott
Spelling fixes in arch/m68k/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-20m68k: missing __initAl Viro
2007-07-20m68k: missing exportsAl Viro
2007-06-01m68k: parenthesis balanceMariusz Kozlowski
Balance parenthesis in m68k mac debug code. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SPIN_LOCK_UNLOCKED cleanup in arch/m68kMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Mac IRQ cleanupFinn Thain
There are no slow IRQs on Macs since Roman Zippel's IRQ reorganisation that went into 2.6.16 and removed mac_irq_list[] and the do_mac_irq_list() dispatcher. (They were implemented in do_mac_irq_list() by lowering the IPL.) Hence there's no more use for mutual exclusion in the Mac interrupt dispatchers. Remove it. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Mac nubus IRQ fixes (plan E)Finn Thain
Some Macs lack a slot interrupt enable register. So the existing code makes disabled and unregistered slot IRQ lines outputs set high. This seems to work on quadras, but does not work on genuine VIAs (perhaps the card still succeeds in pulling the line low, or perhaps because this increases the settle time on the port A input, meaning that the CA1 IRQ could fire before the slot line reads active). Because of this, the nubus_active flags were used to mask IRQs, which is actually worse than the problem it tries to solve. Any interrupt masked by nubus_active will remain asserted and prevent further transitions on CA1. And so the nubus gets wedged regardless of hardware (emulated VIA ASIC, real VIA chip or RBV). The best solution to this hardware limitation of genuine VIAs is to disable the umbrella SLOTS IRQ when disabling a slot on those machines. Unfortunately, this means all slot IRQs get disabled when any slot IRQ is disabled. But it is only a problem when there's more than 1 device using nubus interrupts. Another potential problem for genuine VIAs is an unregistered nubus IRQ. Eventually it will be possible to enable the CA1 interrupt by installing its handler only _after_ all nubus drivers have loaded but _before_ the kernel needs them, at which time this last problem can be fixed. For now it can be worked around: - disable MacOS extensions - don't boot MacOS (use the Emile bootloader instead) - get the bootloaders to disable ROM drivers (Penguin does this for video cards already, don't know about Emile) - physically remove unsupported cards Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Mac IRQ prepFinn Thain
Make sure that there are no slot IRQs asserted before leaving the nubus handler. If there are and we don't then the nubus gets wedged because this prevents a CA1 transition, which means no more nubus IRQs. Make the interrupt dispatch loops terminate sooner. Explicitly initialise the VIA latches to make the code more easily understood. Also some cleanups. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: reverse Mac IRQ damageFinn Thain
Reverse the last of a monumental brown-paper-bag commit that went into the 2.3 kernel. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Mac interrupt prioritiesFinn Thain
Add some more machines that support A/UX interrupt priorities. There are probably others as well, but I've only tested these ones so far. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: early parameter supportRoman Zippel
Add early parameter support and convert current users to it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: reformat various m68k filesRoman Zippel
Reformat various m68k files, so they actually look like Linux sources. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: convert mac irq codeRoman Zippel
Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: introduce irq controllerRoman Zippel
Introduce irq controller and use it to manage auto vector interrupts. Introduce setup_irq() which can be used for irq setup. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] m68k: m68k mac VIA2 fixes and cleanupsFinn Thain
Some fixes and cleanups from the linux-mac68k repo. Fix mac_esp by clearing the VIA2 SCSI IRQ flag before the SCSI IRQ handler is invoked. Also fix a race condition caused by unmasking a nubus slot IRQ then setting the relevant nubus_active bit. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: Moved initialisation of conswitchp from subarches to global ↵Al Viro
arch setup Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: NULL noise removalAl Viro
