path: root/arch/m68k/math-emu
2011-07-30m68k/math-emu: Remove unnecessary codeGreg Dietsche
Remove unnecessary code that matches this coccinelle pattern if (...) return ret; return ret; Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/math-emu: Remove commented out old codeGeert Uytterhoeven
It's been unused for ages, and contains bugs (e.g. incorrect shifts in lsl64()). Reported-by: Jonathan Elchison <jelchison@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-03-16m68k: Makefiles - Change to new flags variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-09-01locking, m68k/asm-offsets: Rename signal definesHeiko Carstens
In order to be able to use asm-offsets.h in C files the existing namespace conflicts must be solved first. In asm-offsets.h there are defines for signal constants, so they can be used in assembler files. Unfortunately the existing defines use a 1:1 mapping for the macro names which results in name space conflicts if the header file would also be used in C files. So rename the created defines and add an "L" prefix to each one since that has already been done for the SIGTRAP define in entry_mm. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Horst Hartmann <horsth@linux.vnet.ibm.com> Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <20090831124416.998821502@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-31locking, m68k/asm-offsets: Rename pt_regs offset definesHeiko Carstens
In order to be able to use asm-offsets.h in C files the existing namespace conflicts must be solved first. In asm-offsets.h e.g. PT_D0 gets defined which is the offset of the d0 member of the pt_regs structure. However a same define (with a different meaning) exists in asm/ptregs.h. So rename the defines created with the asm-offset mechanism to PT_OFF_D0 etc. There also already exist a few defines with these names that have the same meaning. So remove the existing defines and use the asm-offset generated ones. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Horst Hartmann <horsth@linux.vnet.ibm.com> Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <20090831124416.666403991@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12m68k: Kill several external declarations in source filesGeert Uytterhoeven
- Replace external declarations by proper includes where availiable. The accesses to some symbols had to be modified, as before they were declared using e.g. "extern int _end", while asm-generic/sections.h uses e.g. "extern char _end[]" - Remove unused or superfluous external declarations Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-20Stringify support commasMathieu Desnoyers
> This is a no-no for those archs that still use -traditional. > > I dunno if this is a problem for you at the moment and the > > right fix is anyway to nuke -traditional. > > > > Sam Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: arch/m68k/Simon Arlott
Spelling fixes in arch/m68k/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-01-12[PATCH] m68k: broken constraints on mulu.lAl Viro
Too permissive constraint on mulu.l - the first argument should not be an a-register. Fixed by replacing "g" with "dm"; with older gcc we got lucky and it had never attempted mulu.l %a0, %d1:%d0. These days it does, with predictable objections from as(1). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
