[ Upstream commit 7cf78b6b12fd5550545e4b73b35dca18bd46b44c ]
When the option is RTC_PLL_GET, pll will be copied to userland
via copy_to_user. pll is initialized using mach_get_rtc_pll indirect
call and mach_get_rtc_pll is only assigned with function
q40_get_rtc_pll in arch/m68k/q40/config.c.
In function q40_get_rtc_pll, the field pll_ctrl is not initialized.
This will leak uninitialized stack content to userland.
Fix this by zeroing the uninitialized field.
Signed-off-by: Fuqian Huang <huangfq.daxian@gmail.com>
Link: https://lore.kernel.org/r/20190927121544.7650-1-huangfq.daxian@gmail.com
[ Upstream commit 1efdd4bd254311498123a15fa0acd565f454da97 ]
Some platforms execute their timer handler with the interrupt priority
level set below 6. That means the handler could be interrupted by another
driver and this could lead to re-entry of the timer core.
Avoid this by use of local_irq_save/restore for timer interrupt dispatch.
This provides mutual exclusion around the timer interrupt flag access
which is needed later in this series for the clocksource conversion.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Link: http://lkml.kernel.org/r/alpine.DEB.2.21.1811131407120.2697@nanos.tec.linutronix.de
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Some functions that are only called (indirectly) from setup_arch() lack
__init annotations.
Sweep of the simple cases.
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
remove m68k's mach_gettimeoffset function pointer, and instead directly
set the arch_gettimeoffset function pointer. This requires multiplying
all function results by 1000, since the removed m68k_gettimeoffset() did
this. Also, s/unsigned long/u32/ just to make the function prototypes
exactly match that of arch_gettimeoffset.
Cc: Joshua Thompson <funaho@jurai.org>
Cc: Sam Creasey <sammy@sammy.net>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Phil Blundell <philb@gnu.org>
The semantic patch that makes this change is available
in scripts/coccinelle/api/ptr_ret.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
On multi-platform kernels, the Q40/Q60 platform devices should be
registered when running on Q40/Q60 only. Else it may crash later.
Disintegrate asm/system.h for M68K.
Acked-by: Greg Ungerer <gerg@uclinux.org>
cc: linux-m68k@lists.linux-m68k.org
Convert the driver to standard spilt model arch-specific code registers
platform device to which driver code can bind later.
Also request IRQ immediately upon binding to the device instead of doing
this when serio port is being opened.
q40_irq_handler() must be kept to translate ISA IRQs to the range 1-15.
q40_probe_irq_o{ff,n}() become unused.
Cc: Richard Zidlicky <rz@linux-m68k.org>
- Rename m68k_handle_int() to generic_handle_irq(), and drop the unneeded
asmlinkage,
- Rename __m68k_handle_int() to do_IRQ().
This is a wrapper around m68k_setup_irq_chip() that discards its dummy
second parameter, to ease the future transition to genirq.
Make it more similar to the genirq version:
- Remove lock (unused as we don't do SMP anyway),
- Prepend methods with irq_,
- Make irq_startup() return unsigned int.
There are numerous broken references to Documentation files (in other
Documentation files, in comments, etc.). These broken references are
caused by typo's in the references, and by renames or removals of the
Documentation files. Some broken references are simply odd.
Fix these broken references, sometimes by dropping the irrelevant text
they were part of.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The patch below updates broken web addresses in the arch directory.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
Signed-off-by: Frans Pop <elendil@planet.nl>
- Replace external declarations by proper includes where availiable.
The accesses to some symbols had to be modified, as before they were
declared using e.g. "extern int _end", while asm-generic/sections.h uses
e.g. "extern char _end[]"
- Remove unused or superfluous external declarations
This patch changes m68k to use the new bcd2bin/bin2bcd functions instead
of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros.
It also remove local bcd2bin/bin2bcd implementations
in favor of the global ones.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch makes the following needlessly global functions static:
- q40_reset()
- q40_halt()
- q40_disable_irqs()
- q40_gettimeoffset()
- q40_hwclk()
- q40_get_ss()
- q40_set_clock_mmss()
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Spelling fixes in arch/m68k/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Add early parameter support and convert current users to it.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Reformat various m68k files, so they actually look like Linux sources.
Use the new typedef for interrupt handler function pointers rather than
actually spelling out the full thing each time. This was scripted with the
following small shell script:
#!/bin/sh
egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* |
while read i
do
echo $i
perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $?
done
Signed-Off-By: David Howells <dhowells@redhat.com>
m68k_handle_int() split in two functions: __m68k_handle_int() takes
pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs
Places where we used to call m68k_handle_int() recursively with the same
pt_regs have simply lost the second argument, the rest is switched to
__m68k_handle_int().
The rest of patch is just dropping pt_regs * where needed.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Introduce irq controller and use it to manage auto vector interrupts.
Introduce setup_irq() which can be used for irq setup.
Rename IRQ1..IRQ7 to IRQ_AUTO_1..IRQ_AUTO_7 and remove the duplicate
defintions.
arch setup
Signed-off-by: Kars de Jong <jongk@linux-m68k.org>
infrastructure for it.
Let it rip!
