commit 8474ba74193d302e8340dddd1e16c85cc4b98caf upstream.
Make sure the compiler does not modify arguments of syscall functions.
This can happen if the compiler generates a tailcall to another
function. For example, without asmlinkage_protect sys_openat is compiled
into this function:
sys_openat:
clr.l %d0
move.w 18(%sp),%d0
move.l %d0,16(%sp)
jbra do_sys_open
Note how the fourth argument is modified in place, modifying the register
%d4 that gets restored from this stack slot when the function returns to
user-space. The caller may expect the register to be unmodified across
system calls.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit d9ee489619744ee5ac246b8fb3dd65bb078d2f0a upstream.
It is possible to disable the clock selection at configuration time,
but for ColdFire targets we always expect a clock frequency to be
selected. This results in the following compile time error:
CC arch/m68k/kernel/asm-offsets.s
In file included from ./arch/m68k/include/asm/timex.h:14:0,
from include/linux/timex.h:65,
from include/linux/sched.h:19,
from arch/m68k/kernel/asm-offsets.c:14:
./arch/m68k/include/asm/coldfire.h:25:2: error: #error "Don't know what your ColdFire CPU clock frequency is??"
Remove CONFIG_CLOCK_SELECT completely and always enable CONFIG_CLOCK_FREQ
for ColdFire.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit fa95a1dd0819c9041a873b10a6d83b5134964154 upstream.
It would be nice if we could support multiple ColdFire SoC types in a
single binary - but currently the code simply does not support it.
Change the SoC selection config options to be a choice instead of
individual selectable entries.
This fixes problems with building allnoconfig, and means that a sane
linux kernel is generated for a single ColdFire SoC type.
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68k fixes from Greg Ungerer:
"Nothing big, spelling fixes and fix/cleanup for ColdFire eth device setup"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68knommu: fix fec setup warning for ColdFire 5271 builds
m68knommu: ColdFire 5271 only has a single FEC controller
m68k: Fix trivial typos in comments
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded.
Tested-by: Guenter Roeck <linux@roeck-us.net>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Read capability list as dwords, not bytes (Sean O. Stalley)
Resource management
- Don't check for PNP overlaps with unassigned PCI BARs (Bjorn Helgaas)
- Mark invalid BARs as unassigned (Bjorn Helgaas)
- Show driver, BAR#, and resource on pci_ioremap_bar() failure (Bjorn Helgaas)
- Fail pci_ioremap_bar() on unassigned resources (Bjorn Helgaas)
- Assign resources before drivers claim devices (Yijing Wang)
- Claim bus resources before pci_bus_add_devices() (Yijing Wang)
Power management
- Optimize device state transition delays (Aaron Lu)
- Don't clear ASPM bits when the FADT declares it's unsupported (Matthew Garrett)
Virtualization
- Add ACS quirks for Intel 1G NICs (Alex Williamson)
IOMMU
- Add ptr to OF node arg to of_iommu_configure() (Murali Karicheri)
- Move of_dma_configure() to device.c to help re-use (Murali Karicheri)
- Fix size when dma-range is not used (Murali Karicheri)
- Add helper functions pci_get[put]_host_bridge_device() (Murali Karicheri)
- Add of_pci_dma_configure() to update DMA configuration (Murali Karicheri)
- Update DMA configuration from DT (Murali Karicheri)
- dma-mapping: limit IOMMU mapping size (Murali Karicheri)
- Calculate device DMA masks based on DT dma-range size (Murali Karicheri)
ARM Versatile host bridge driver
- Check for devm_ioremap_resource() failures (Jisheng Zhang)
Broadcom iProc host bridge driver
- Add Broadcom iProc PCIe driver (Ray Jui)
Marvell MVEBU host bridge driver
- Add suspend/resume support (Thomas Petazzoni)
Renesas R-Car host bridge driver
- Fix position of MSI enable bit (Nobuhiro Iwamatsu)
- Write zeroes to reserved PCIEPARL bits (Nobuhiro Iwamatsu)
- Change PCIEPARL and PCIEPARH to PCIEPALR and PCIEPAUR (Nobuhiro Iwamatsu)
- Verify that mem_res is 64K-aligned (Nobuhiro Iwamatsu)
Samsung Exynos host bridge driver
- Fix INTx enablement statement termination error (Jaehoon Chung)
Miscellaneous
- Make a shareable UUID for PCI firmware ACPI _DSM (Aaron Lu)
- Clarify policy for vendor IDs in pci.txt (Michael S. Tsirkin)"
* tag 'pci-v4.1-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (36 commits)
PCI: Read capability list as dwords, not bytes
PCI: layerscape: Simplify platform_get_resource_byname() failure checking
PCI: keystone: Don't dereference possible NULL pointer
PCI: versatile: Check for devm_ioremap_resource() failures
PCI: Don't clear ASPM bits when the FADT declares it's unsupported
PCI: Clarify policy for vendor IDs in pci.txt
PCI/ACPI: Optimize device state transition delays
PCI: Export pci_find_host_bridge() for use inside PCI core
PCI: Make a shareable UUID for PCI firmware ACPI _DSM
PCI: Fix typo in Thunderbolt kernel message
PCI: exynos: Fix INTx enablement statement termination error
PCI: iproc: Add Broadcom iProc PCIe support
PCI: iproc: Add DT docs for Broadcom iProc PCIe driver
PCI: Export symbols required for loadable host driver modules
PCI: Add ACS quirks for Intel 1G NICs
PCI: mvebu: Add suspend/resume support
PCI: Cleanup control flow
sparc/PCI: Claim bus resources before pci_bus_add_devices()
PCI: Assign resources before drivers claim devices (pci_scan_root_bus())
PCI: Fail pci_ioremap_bar() on unassigned resources
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Building for the ColdFire 5271 produces the following warning:
arch/m68k/coldfire/m527x.c: In function ‘m527x_fec_init’:
arch/m68k/coldfire/m527x.c:95:6: warning: unused variable ‘par’
Fix it by moving the definition of par inside the 5271 conditional code.
Reported-by: ertheb <3rth3bnospam@ethe.fr>
The inclusion of multiple FEC ethernet platform devices is based around
the FEC address definitions in the platform headers. The ColdFire m527x
platform is defining 2 FEC modules, but the 5271 SoC only has a single
FEC hardware module. The attempt to probe and init a second FEC module
causes a trap and dump on boot on this platform.
Fix the definitions so that only the 5275 SoC platform (which has 2 FEC
hardware modules) defines the second base address.
Change 'Reaceive' to 'Receive'
Change 'alighnment' to 'alignment'
Signed-off-by: Yannick Guerrini <yguerrini@tomshardware.fr>
* pci/enumeration:
PCI: Assign resources before drivers claim devices (pci_scan_bus())
* pci/virtualization:
pr_err() has a KERN_ERR built in. Smatch complains about these nowadays.
All other Ethernet drivers are builtin, for NFS root.
We have a central copy of the GPL for that, and the FSF may change
address again in the future.
Previously, pci_scan_bus() created a root PCI bus, enumerated the devices
on it, and called pci_bus_add_devices(), which made the devices available
for drivers to claim them.
Most callers assigned resources to devices after pci_scan_bus() returns,
which may be after drivers have claimed the devices. This is incorrect;
the PCI core should not change device resources while a driver is managing
the device.
Remove pci_bus_add_devices() from pci_scan_bus() and do it after any
resource assignment in the callers.
[bhelgaas: changelog, check for failure in mcf_pci_init()]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Geert Uytterhoeven <geert@linux-m68k.org>
CC: Guan Xuetao <gxt@mprc.pku.edu.cn>
CC: Richard Henderson <rth@twiddle.net>
CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
CC: Matt Turner <mattst88@gmail.com>
table levels folded. Usually, these defines are provided by
<asm-generic/pgtable-nopmd.h> and <asm-generic/pgtable-nopud.h>.
But some architectures fold page table levels in a custom way. They
need to define these macros themself. This patch adds missing defines.
The patch fixes mm->nr_pmds underflow and eliminates dead __pmd_alloc()
and __pud_alloc() on architectures without these page table levels.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic uaccess.h cleanup from Arnd Bergmann:
"Like in 3.19, I once more have a multi-stage cleanup for one
asm-generic header file, this time the work was done by Michael
Tsirkin and cleans up the uaccess.h file in asm-generic, as well as
all architectures for which the respective maintainers did not pick up
his patches directly"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (37 commits)
sparc32: nocheck uaccess coding style tweaks
sparc64: nocheck uaccess coding style tweaks
xtensa: macro whitespace fixes
sh: macro whitespace fixes
parisc: macro whitespace fixes
m68k: macro whitespace fixes
m32r: macro whitespace fixes
frv: macro whitespace fixes
cris: macro whitespace fixes
avr32: macro whitespace fixes
arm64: macro whitespace fixes
arm: macro whitespace fixes
alpha: macro whitespace fixes
blackfin: macro whitespace fixes
sparc64: uaccess_64 macro whitespace fixes
sparc32: uaccess_32 macro whitespace fixes
avr32: whitespace fix
sh: fix put_user sparse errors
metag: fix put_user sparse errors
ia64: fix put_user sparse errors
Pull m68knommu fixes from Greg Ungerer:
"Nothing big, only a small collection of minor cleanups/fixes"
arch: m68k: 68360: config: Remove unused function
m68knommu: fix irq handler types in 68360/commproc.c
m68k: remove check for CONFIG_BSEIP
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Merge misc updates from Andrew Morton:
"Bite-sized chunks this time, to avoid the MTA ratelimiting woes.
- fs/notify updates
- ocfs2
- some of MM"
That laconic "some MM" is mainly the removal of remap_file_pages(),
which is a big simplification of the VM, and which gets rid of a *lot*
of random cruft and special cases because we no longer support the
non-linear mappings that it used.
From a user interface perspective, nothing has changed, because the
remap_file_pages() syscall still exists, it's just done by emulating the
old behavior by creating a lot of individual small mappings instead of
one non-linear one.
The emulation is slower than the old "native" non-linear mappings, but
nobody really uses or cares about remap_file_pages(), and simplifying
the VM is a big advantage.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (78 commits)
memcg: zap memcg_slab_caches and memcg_slab_mutex
memcg: zap memcg_name argument of memcg_create_kmem_cache
memcg: zap __memcg_{charge,uncharge}_slab
mm/page_alloc.c: place zone_id check before VM_BUG_ON_PAGE check
mm: hugetlb: fix type of hugetlb_treat_as_movable variable
mm, hugetlb: remove unnecessary lower bound on sysctl handlers"?
mm: memory: merge shared-writable dirtying branches in do_wp_page()
mm: memory: remove ->vm_file check on shared writable vmas
xtensa: drop _PAGE_FILE and pte_file()-related helpers
x86: drop _PAGE_FILE and pte_file()-related helpers
unicore32: drop pte_file()-related helpers
um: drop _PAGE_FILE and pte_file()-related helpers
tile: drop pte_file()-related helpers
sparc: drop pte_file()-related helpers
sh: drop _PAGE_FILE and pte_file()-related helpers
score: drop _PAGE_FILE and pte_file()-related helpers
s390: drop pte_file()-related helpers
parisc: drop _PAGE_FILE and pte_file()-related helpers
openrisc: drop _PAGE_FILE and pte_file()-related helpers
nios2: drop _PAGE_FILE and pte_file()-related helpers
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k updates from Geert Uytterhoeven:
"Summary:
- switch to asm-generic/futex.h
- various cleanups
- defconfig updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/defconfig: Enable Ethernet bridging
m68k/defconfig: Enable Atari EtherNAT and EtherNEC Ethernet support
m68k/defconfig: Enable automounting of devtmpfs at /dev
m68k/defconfig: Enable early printk support
m68k/defconfig: Enable test modules
m68k/defconfig: Refresh defconfigs for v3.16-rc1--v3.19-rc2
m68k/atari: Remove obsolete IRQ_TYPE_*
sound: dmasound_atari: Remove obsolete IRQ_TYPE_SLOW
video: atafb: Remove obsolete IRQ_TYPE_PRIO
parport: parport_atari: Remove obsolete IRQ_TYPE_SLOW
net: atarilance: Remove obsolete IRQ_TYPE_PRIO
m68k/atari: Remove obsolete keyboard_tasklet scheduling
m68k/mac: Fix scsi_type for Mac LC and similar models
m68k: Switch to asm-generic/futex.h
m68k/mvme147: config.c - Remove unused functions
m68k/atari: atakeyb.c - Remove some unused functions
m68k/mvme16x: rtc - Don't use module_init in non-modular code
Remove the function BSP_set_clock_mmss() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Compilation of arch/m68k/68360/commproc.c fails with the following errors:
arch/m68k/68360/commproc.c:75:1: error: function declaration isn’t a prototype
arch/m68k/68360/commproc.c:211:1: error: function declaration isn’t a prototype
arch/m68k/68360/commproc.c: In function ‘cpm_install_handler’:
arch/m68k/68360/commproc.c:214:2: warning: passing argument 2 of ‘request_irq’ from incompatible pointer type
include/linux/interrupt.h:128:1: note: expected ‘irq_handler_t’ but argument is of type ‘void (*)()’
It should be using the proper irq hander type, irq_handler_t. Modify it
to use that.
There used to be a Kconfig symbol BSEIP. It was PPC specific and was
removed in v2.6.27. So the check for CONFIG_BSEIP can be removed. This
means a few defines will be removed. None of the macros involved are
used, so no one should care.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Enable support for Atari EtherNAT (SMC91X) and EtherNEC (NE2000)
Ethernet support in the Atari and multiplatform defconfig files.
Enable CONFIG_DEVTMPFS_MOUNT, as it's useful for initrd-less kernels.
Enable CONFIG_EARLY_PRINTK on all platforms where it's available (all
but Sun-3) and not yet enabled.
It doesn't hurt to have CONFIG_TEST_* enabled as modules.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
IRQ_TYPE_SLOW, IRQ_TYPE_FAST, and IRQ_TYPE_PRIO are no longer used by
the Atari platform interrupt code since commit 734085651c9b80aa
("[PATCH] m68k: convert atari irq code") in v2.6.18-rc1, so drop them.
Note that their values have been reused for different purposes
(IRQ_TYPE_NONE, IRQ_TYPE_EDGE_RISING, and IRQ_TYPE_EDGE_FALLING) since
commit 6a6de9ef5850d063 ("[PATCH] genirq: core") in v2.6.18-rc1.
While working on arch/m68k/include/asm/uaccess.h, I noticed
that one macro within this header is made harder to read because it
violates a coding style rule: space is missing after comma.
Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
Fix that up using __force.
If CONFIG_VT=n:
arch/m68k/atari/built-in.o: In function `atari_keyboard_interrupt':
atakeyb.c:(.text+0x1846): undefined reference to `keyboard_tasklet'
atakeyb.c:(.text+0x1852): undefined reference to `keyboard_tasklet'
I think the keyboard_tasklet scheduling is no longer needed, as I
believe it's handled by drivers/tty/vt/keyboard.c based on events
received from the input subsystem. So just remove it.
Tested-by: Michael Schmitz <schmitz@debian.org>
Designing Cards and Drivers for the Macintosh Family, 3rd ed. on page 310
says that the I/O address space for the Mac LC is $50F0 0000 - $50FF FFFF.
The developer notes for the Classic II, LC III and IIvx/IIvi give the same
I/O address space.
That means I've assigned the wrong platform resources to those Mac models.
Fix the scsi_type initialization for the affected models, to restore the
SCSI base address to its value prior to Linux 3.18.
Also rename MAC_SCSI_CCL as MAC_SCSI_LC for the sake of correct chronology.
As of commit 00f634bc522dedc8 ("asm-generic: add generic futex for
!CONFIG_SMP") asm-generic follows the m68k futex implementation.
Remove the function mvme147_init_console_port() that is not used
anywhere.
cppcheck.
[geert: Also remove now unused m147_scc_write(), scc_write(), scc_delay()]
Remove some functions that are not used anywhere:
atari_kbd_leds() ikbd_exec() ikbd_mem_read() ikbd_mem_write()
ikbd_clock_get() ikbd_clock_set() ikbd_pause() ikbd_resume()
cppcheck.
The rtc.o is built for obj-y, i.e. always built in. It will
never be modular, so using module_init as an alias for __initcall
can be somewhat misleading.
Fix this up now, so that we can relocate module_init from
init.h into module.h in the future. If we don't do this, we'd
have to add module.h to obviously non-modular code, and that
would be a worse thing.
Note that direct use of __initcall is discouraged, vs. one
of the priority categorized subgroups. As __initcall gets
mapped onto device_initcall, our use of device_initcall
directly in this change means that the runtime impact is
zero -- it will remain at level 6 in initcall ordering.
Check success of execveat(3, '../execveat', 0)... [OK]
Check success of execveat(5, 'execveat', 0)... [OK]
Check success of execveat(6, 'execveat', 0)... [OK]
Check success of execveat(-100, '/root/selftest-exec/exec/execveat', 0)... [OK]
Check success of execveat(99, '/root/selftest-exec/exec/execveat', 0)... [OK]
Check success of execveat(8, '', 4096)... [OK]
Check success of execveat(17, '', 4096)... [OK]
Check success of execveat(9, '', 4096)... [OK]
Check success of execveat(14, '', 4096)... [OK]
Check success of execveat(15, '', 4096)... [OK]
Check failure of execveat(8, '', 0) with ENOENT... [OK]
Check failure of execveat(8, '(null)', 4096) with EFAULT... [OK]
Check success of execveat(5, 'execveat.symlink', 0)... [OK]
Check success of execveat(6, 'execveat.symlink', 0)... [OK]
Check success of execveat(-100, '/root/selftest-exec/...xec/execveat.symlink', 0)... [OK]
Check success of execveat(10, '', 4096)... [OK]
Check success of execveat(10, '', 4352)... [OK]
Check failure of execveat(5, 'execveat.symlink', 256) with ELOOP... [OK]
Check failure of execveat(6, 'execveat.symlink', 256) with ELOOP... [OK]
Check failure of execveat(-100, '/root/selftest-exec/exec/execveat.symlink', 256) with ELOOP... [OK]
Check success of execveat(3, '../script', 0)... [OK]
Check success of execveat(5, 'script', 0)... [OK]
Check success of execveat(6, 'script', 0)... [OK]
Check success of execveat(-100, '/root/selftest-exec/exec/script', 0)... [OK]
Check success of execveat(13, '', 4096)... [OK]
Check success of execveat(13, '', 4352)... [OK]
Check failure of execveat(18, '', 4096) with ENOENT... [OK]
Check failure of execveat(7, 'script', 0) with ENOENT... [OK]
Check success of execveat(16, '', 4096)... [OK]
Check success of execveat(4, '../script', 0)... [OK]
Check success of execveat(4, 'script', 0)... [OK]
Check failure of execveat(4, 'script', 0) with ENOENT... [OK]
Check failure of execveat(5, 'execveat', 65535) with EINVAL... [OK]
Check failure of execveat(5, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(6, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(-100, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(5, '', 4096) with EACCES... [OK]
Check failure of execveat(5, 'Makefile', 0) with EACCES... [OK]
Check failure of execveat(11, '', 4096) with EACCES... [OK]
Check failure of execveat(12, '', 4096) with EACCES... [OK]
Check failure of execveat(99, '', 4096) with EBADF... [OK]
Check failure of execveat(99, 'execveat', 0) with EBADF... [OK]
Check failure of execveat(8, 'execveat', 0) with ENOTDIR... [OK]
Invoke copy of 'execveat' via filename of length 4093:
Check success of execveat(19, '', 4096)... [OK]
Check success of execveat(5, 'xxxxxxxxxxxxxxxxxxxx...yyyyyyyyyyyyyyyyyyyy', 0)... [OK]
Invoke copy of 'script' via filename of length 4093:
Check success of execveat(20, '', 4096)... [OK]
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Pull asm-generic asm/io.h rewrite from Arnd Bergmann:
"While there normally is no reason to have a pull request for
asm-generic but have all changes get merged through whichever tree
needs them, I do have a series for 3.19.
There are two sets of patches that change significant portions of
asm/io.h, and this branch contains both in order to resolve the
conflicts:
- Will Deacon has done a set of patches to ensure that all
architectures define {read,write}{b,w,l,q}_relaxed() functions or
get them by including asm-generic/io.h.
These functions are commonly used on ARM specific drivers to avoid
expensive L2 cache synchronization implied by the normal
{read,write}{b,w,l,q}, but we need to define them on all
architectures in order to share the drivers across architectures
and to enable CONFIG_COMPILE_TEST configurations for them
- Thierry Reding has done an unrelated set of patches that extends
the asm-generic/io.h file to the degree necessary to make it useful
on ARM64 and potentially other architectures"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (29 commits)
ARM64: use GENERIC_PCI_IOMAP
sparc: io: remove duplicate relaxed accessors on sparc32
ARM: sa11x0: Use void __iomem * in MMIO accessors
arm64: Use include/asm-generic/io.h
ARM: Use include/asm-generic/io.h
asm-generic/io.h: Implement generic {read,write}s*()
asm-generic/io.h: Reconcile I/O accessor overrides
/dev/mem: Use more consistent data types
Change xlate_dev_{kmem,mem}_ptr() prototypes
ARM: ixp4xx: Properly override I/O accessors
ARM: ixp4xx: Fix build with IXP4XX_INDIRECT_PCI
ARM: ebsa110: Properly override I/O accessors
ARC: Remove redundant PCI_IOBASE declaration
documentation: memory-barriers: clarify relaxed io accessor semantics
x86: io: implement dummy relaxed accessor macros for writes
tile: io: implement dummy relaxed accessor macros for writes
sparc: io: implement dummy relaxed accessor macros for writes
powerpc: io: implement dummy relaxed accessor macros for writes
parisc: io: implement dummy relaxed accessor macros for writes
mn10300: io: implement dummy relaxed accessor macros for writes
Pull m68k updates from Geert Uytterhoeven.
m68k/mm: Eliminate memset after alloc_bootmem_pages
nubus: Remove superfluous interrupt disable/restore
