[ Upstream commit 1efdd4bd254311498123a15fa0acd565f454da97 ]
Some platforms execute their timer handler with the interrupt priority
level set below 6. That means the handler could be interrupted by another
driver and this could lead to re-entry of the timer core.
Avoid this by use of local_irq_save/restore for timer interrupt dispatch.
This provides mutual exclusion around the timer interrupt flag access
which is needed later in this series for the clocksource conversion.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Link: http://lkml.kernel.org/r/alpine.DEB.2.21.1811131407120.2697@nanos.tec.linutronix.de
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
[ Upstream commit 0ca7ce7db771580433bf24454f7a1542bd326078 ]
This resolves some bugs that affect VIA timer counter accesses.
Avoid lost interrupts caused by reading the counter low byte register.
Make allowance for the fact that the counter will be decremented to
0xFFFF before being reloaded.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
[ Upstream commit 381fdd62c38344a771aed06adaf14aae65c47454 ]
This patch fixes command_line array zero-terminated
one byte over the end of the array, causing boot to hang.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
commit 28713169d879b67be2ef2f84dcf54905de238294 upstream.
This patch fixes a build failure when using GCC 8.1:
/usr/bin/ld: block/partitions/ldm.o: in function `ldm_parse_tocblock':
block/partitions/ldm.c:153: undefined reference to `strcmp'
This is caused by a new optimization which effectively replaces a
strncmp() call with a strcmp() call. This affects a number of strncmp()
call sites in the kernel.
The entire class of optimizations is avoided with -fno-builtin, which
gets enabled by -ffreestanding. This may avoid possible future build
failures in case new optimizations appear in future compilers.
I haven't done any performance measurements with this patch but I did
count the function calls in a defconfig build. For example, there are now
23 more sprintf() calls and 39 fewer strcpy() calls. The effect on the
other libc functions is smaller.
If this harms performance we can tackle that regression by optimizing
the call sites, ideally using semantic patches. That way, clang and ICC
builds might benfit too.
Cc: stable@vger.kernel.org
Reference: https://marc.info/?l=linux-m68k&m=154514816222244&w=2
[ Upstream commit ecd60532e060e45c63c57ecf1c8549b1d656d34d ]
Booting a ColdFire m68k core with MMU enabled causes a "bad page state"
oops since commit 1d40a5ea01d5 ("mm: mark pages in use for page tables"):
BUG: Bad page state in process sh pfn:01ce2
page:004fefc8 count:0 mapcount:-1024 mapping:00000000 index:0x0
flags: 0x0()
raw: 00000000 00000000 00000000 fffffbff 00000000 00000100 00000200 00000000
raw: 039c4000
page dumped because: nonzero mapcount
Modules linked in:
CPU: 0 PID: 22 Comm: sh Not tainted 4.17.0-07461-g1d40a5ea01d5 #13
Fix by calling pgtable_page_dtor() in our __pte_free_tlb() code path,
so that the PG_table flag is cleared before we free the pte page.
Note that I had to change the type of pte_free() to be static from
extern. Otherwise you get a lot of warnings like this:
./arch/m68k/include/asm/mcf_pgalloc.h:80:2: warning: ‘pgtable_page_dtor’ is static but used in inline function ‘pte_free’ which is not static
pgtable_page_dtor(page);
And making it static is consistent with our use of this in the other
m68k pgalloc definitions of pte_free().
CC: Matthew Wilcox <willy@infradead.org>
Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit 3e2816c1078eb2b5a3276eb83d4da156b3e2d04f upstream.
The resource size is 0x2000 == end - start + 1.
Therefore end == start + 0x2000 - 1.
Cc: Laurent Vivier <lvivier@redhat.com>
Cc: stable@vger.kernel.org # v4.14+
Tested-by: Stan Johnson <userm57@yahoo.com>
Acked-by: Laurent Vivier <lvivier@redhat.com>
commit 3f90f9ef2dda316d64e420d5d51ba369587ccc55 upstream.
If 020/030 support is enabled, get_io_area() leaves an IO_SIZE gap
between mappings which is added to the vm_struct representing the
mapping. __ioremap() uses the actual requested size (after alignment),
while __iounmap() is passed the size from the vm_struct.
On 020/030, early termination descriptors are used to set up mappings of
extent 'size', which are validated on unmapping. The unmapped gap of
size IO_SIZE defeats the sanity check of the pmd tables, causing
__iounmap() to loop forever on 030.
On 040/060, unmapping of page table entries does not check for a valid
mapping, so the umapping loop always completes there.
Adjust size to be unmapped by the gap that had been added in the
vm_struct prior.
This fixes the hang in atari_platform_init() reported a long time ago,
and a similar one reported by Finn recently (addressed by removing
ioremap() use from the SWIM driver.
Tested on my Falcon in 030 mode - untested but should work the same on
040/060 (the extra page tables cleared there would never have been set
up anyway).
Signed-off-by: Michael Schmitz <schmitzmic@gmail.com>
[geert: Minor commit description improvements]
[geert: This was fixed in 2.4.23, but not in 2.5.x]
[ Upstream commit f61e64310b75733d782e930d1fb404b84699eed6 ]
As of commit 205e1b7f51e4 ("dma-mapping: warn when there is no
coherent_dma_mask") the Freescale FEC driver is issuing the following
warning on driver initialization on ColdFire systems:
WARNING: CPU: 0 PID: 1 at ./include/linux/dma-mapping.h:516 0x40159e20
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.16.0-rc7-dirty #4
Stack from 41833dd8:
41833dd8 40259c53 40025534 40279e26 00000003 00000000 4004e514 41827000
400255de 40244e42 00000204 40159e20 00000009 00000000 00000000 4024531d
40159e20 40244e42 00000204 00000000 00000000 00000000 00000007 00000000
00000000 40279e26 4028d040 40226576 4003ae88 40279e26 418273f6 41833ef8
7fffffff 418273f2 41867028 4003c9a2 4180ac6c 00000004 41833f8c 4013e71c
40279e1c 40279e26 40226c16 4013ced2 40279e26 40279e58 4028d040 00000000
Call Trace:
[<40025534>] 0x40025534
[<4004e514>] 0x4004e514
[<400255de>] 0x400255de
[<40159e20>] 0x40159e20
It is not fatal, the driver and the system continue to function normally.
As per the warning the coherent_dma_mask is not set on this device.
There is nothing special about the DMA memory coherency on this hardware
so we can just set the mask to 32bits in the platform data for the FEC
ethernet devices.
[ Upstream commit 173a3efd3edb2ef6ef07471397c5f542a360e9c1 ]
Looking at functions with large stack frames across all architectures
led me discovering that BUG() suffers from the same problem as
fortify_panic(), which I've added a workaround for already.
In short, variables that go out of scope by calling a noreturn function
or __builtin_unreachable() keep using stack space in functions
afterwards.
A workaround that was identified is to insert an empty assembler
statement just before calling the function that doesn't return. I'm
adding a macro "barrier_before_unreachable()" to document this, and
insert calls to that in all instances of BUG() that currently suffer
from this problem.
The files that saw the largest change from this had these frame sizes
before, and much less with my patch:
fs/ext4/inode.c:82:1: warning: the frame size of 1672 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/namei.c:434:1: warning: the frame size of 904 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/super.c:2279:1: warning: the frame size of 1160 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/xattr.c:146:1: warning: the frame size of 1168 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/f2fs/inode.c:152:1: warning: the frame size of 1424 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:1195:1: warning: the frame size of 1068 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:395:1: warning: the frame size of 1084 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:298:1: warning: the frame size of 928 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:418:1: warning: the frame size of 908 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_lblcr.c:718:1: warning: the frame size of 960 bytes is larger than 800 bytes [-Wframe-larger-than=]
drivers/net/xen-netback/netback.c:1500:1: warning: the frame size of 1088 bytes is larger than 800 bytes [-Wframe-larger-than=]
In case of ARC and CRIS, it turns out that the BUG() implementation
actually does return (or at least the compiler thinks it does),
resulting in lots of warnings about uninitialized variable use and
leaving noreturn functions, such as:
block/cfq-iosched.c: In function 'cfq_async_queue_prio':
block/cfq-iosched.c:3804:1: error: control reaches end of non-void function [-Werror=return-type]
include/linux/dmaengine.h: In function 'dma_maxpq':
include/linux/dmaengine.h:1123:1: error: control reaches end of non-void function [-Werror=return-type]
This makes them call __builtin_trap() instead, which should normally
dump the stack and kill the current process, like some of the other
architectures already do.
I tried adding barrier_before_unreachable() to panic() and
fortify_panic() as well, but that had very little effect, so I'm not
submitting that patch.
Vineet said:
: For ARC, it is double win.
: 1. Fixes 3 -Wreturn-type warnings
: | ../net/core/ethtool.c:311:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../kernel/sched/core.c:3246:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../include/linux/sunrpc/svc_xprt.h:180:1: warning: control reaches end of
: non-void function [-Wreturn-type]
: 2. bloat-o-meter reports code size improvements as gcc elides the
: generated code for stack return.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82365
Link: http://lkml.kernel.org/r/20171219114112.939391-1-arnd@arndb.de
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Tested-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Cc: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit 969de0988b77e5a57aac2f7270191a3c50540c52 ]
Commit be7635e7287e ("arch, ftrace: for KASAN put hard/soft IRQ entries
into separate sections") added a new linker section, SOFTIRQENTRY_TEXT,
to the linker scripts for most architectures. It didn't add it to any of
the linker scripts for the m68k architecture. This was not really a problem
because it is only defined if either of CONFIG_FUNCTION_GRAPH_TRACER or
CONFIG_KASAN are enabled - which can never be true for m68k.
However commit 229a71860547 ("irq: Make the irqentry text section
unconditional") means that SOFTIRQENTRY_TEXT is now always defined. So on
m68k we now end up with a separate ELF section for .softirqentry.text
instead of it being part of the .text section. On some m68k targets in some
configurations this can also cause a fatal link error:
LD vmlinux
/usr/local/bin/../m68k-uclinux/bin/ld.real: section .softirqentry.text loaded at [0000000010de10c0,0000000010de12dd] overlaps section .rodata loaded at [0000000010de10c0,0000000010e0fd67]
To fix add in the missing SOFTIRQENTRY_TEXT section into the m68k linker
scripts. I noticed that m68k is also missing the IRQENTRY_TEXT section,
so this patch also adds an entry for that too.
[ Upstream commit f55ab8f27548ff3431a6567d400c6757c49fd520 ]
The m68k pg_data_table is a fix size array defined in arch/m68k/mm/init.c.
Index numbers within it are defined based on memory size. But for Coldfire
these don't take into account a non-zero physical RAM base address, and this
causes us to access past the end of this array at system start time.
Change the node shift calculation so that we keep the index inside its range.
Reported-by: Angelo Dureghello <angelo@sysam.it>
Tested-by: Angelo Dureghello <angelo@sysam.it>
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
compliance tools to determine the correct license.
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu updates from Greg Ungerer:
"Only two changes. One removes unused code, the other makes local clock
code arguments consistent with generic clock code"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68knommu: remove dead code
m68k: allow NULL clock for clk_get_rate
With gcc 4.1.2:
include/linux/swapops.h: In function ‘swp_entry_to_pmd’:
include/linux/swapops.h:294: warning: missing braces around initializer
include/linux/swapops.h:294: warning: (near initialization for ‘(anonymous).pmd’)
Due to a GCC zero initializer bug (#53119), the standard "(pmd_t){ 0 }"
initializer is not accepted by all GCC versions.
In addition, on m68k pmd_t is an array instead of a single value, so we
need "(pmd_t){ { 0 }, }" instead of "(pmd_t){ 0 }".
Based on commit 9157259d16a8 ("mm: add pmd_t initializer __pmd() to
work around a GCC bug.") for sparc32.
Fixes: 616b8371539a ("mm: thp: enable thp migration in generic path")
Merge more updates from Andrew Morton:
- most of the rest of MM
- a small number of misc things
- lib/ updates
- checkpatch
- autofs updates
- ipc/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (126 commits)
ipc: optimize semget/shmget/msgget for lots of keys
ipc/sem: play nicer with large nsops allocations
ipc/sem: drop sem_checkid helper
ipc: convert kern_ipc_perm.refcount from atomic_t to refcount_t
ipc: convert sem_undo_list.refcnt from atomic_t to refcount_t
ipc: convert ipc_namespace.count from atomic_t to refcount_t
kcov: support compat processes
sh: defconfig: cleanup from old Kconfig options
mn10300: defconfig: cleanup from old Kconfig options
m32r: defconfig: cleanup from old Kconfig options
drivers/pps: use surrounding "if PPS" to remove numerous dependency checks
drivers/pps: aesthetic tweaks to PPS-related content
cpumask: make cpumask_next() out-of-line
kmod: move #ifdef CONFIG_MODULES wrapper to Makefile
kmod: split off umh headers into its own file
MAINTAINERS: clarify kmod is just a kernel module loader
kmod: split out umh code into its own file
test_kmod: flip INT checks to be consistent
test_kmod: remove paranoid UINT_MAX check on uint range processing
vfat: deduplicate hex2bin()
Patch series "Define CPU_BIG_ENDIAN or warn for inconsistencies", v3.
While working on enabling queued rwlock on SPARC, found this following
code in include/asm-generic/qrwlock.h which uses CONFIG_CPU_BIG_ENDIAN to
clear a byte.
static inline u8 *__qrwlock_write_byte(struct qrwlock *lock)
return (u8 *)lock + 3 * IS_BUILTIN(CONFIG_CPU_BIG_ENDIAN);
Problem is many of the fixed big endian architectures don't define
CPU_BIG_ENDIAN and clears the wrong byte.
Define CPU_BIG_ENDIAN for all the fixed big endian architecture to fix it.
Also found few more references of this config parameter in
drivers/of/base.c
drivers/of/fdt.c
drivers/tty/serial/earlycon.c
drivers/tty/serial/serial_core.c
Be aware that this may cause regressions if someone has worked-around
problems in the above code already. Remove the work-around.
Here is our original discussion
https://lkml.org/lkml/2017/5/24/620
Link: http://lkml.kernel.org/r/1499358861-179979-2-git-send-email-babu.moger@oracle.com
Signed-off-by: Babu Moger <babu.moger@oracle.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Stafford Horne <shorne@gmail.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add enhanced Downstream Port Containment support, which prints more
details about Root Port Programmed I/O errors (Dongdong Liu)
- add Layerscape ls1088a and ls2088a support (Hou Zhiqiang)
- add MediaTek MT2712 and MT7622 support (Ryder Lee)
- add MediaTek MT2712 and MT7622 MSI support (Honghui Zhang)
- add Qualcom IPQ8074 support (Varadarajan Narayanan)
- add R-Car r8a7743/5 device tree support (Biju Das)
- add Rockchip per-lane PHY support for better power management (Shawn
Lin)
- fix IRQ mapping for hot-added devices by replacing the
pci_fixup_irqs() boot-time design with a host bridge hook called at
probe-time (Lorenzo Pieralisi, Matthew Minter)
- fix race when enabling two devices that results in upstream bridge
not being enabled correctly (Srinath Mannam)
- fix pciehp power fault infinite loop (Keith Busch)
- fix SHPC bridge MSI hotplug events by enabling bus mastering
(Aleksandr Bezzubikov)
- fix a VFIO issue by correcting PCIe capability sizes (Alex
Williamson)
- fix an INTD issue on Xilinx and possibly other drivers by unifying
INTx IRQ domain support (Paul Burton)
- avoid IOMMU stalls by marking AMD Stoney GPU ATS as broken (Joerg
Roedel)
- allow APM X-Gene device assignment to guests by adding an ACS quirk
(Feng Kan)
- fix driver crashes by disabling Extended Tags on Broadcom HT2100
(Extended Tags support is required for PCIe Receivers but not
Requesters, and we now enable them by default when Requesters support
them) (Sinan Kaya)
- fix MSIs for devices that use phantom RIDs for DMA by assuming MSIs
use the real Requester ID (not a phantom RID) (Robin Murphy)
- prevent assignment of Intel VMD children to guests (which may be
supported eventually, but isn't yet) by not associating an IOMMU with
them (Jon Derrick)
- fix Intel VMD suspend/resume by releasing IRQs on suspend (Scott
Bauer)
- fix a Function-Level Reset issue with Intel 750 NVMe by waiting
longer (up to 60sec instead of 1sec) for device to become ready
(Sinan Kaya)
- fix a Function-Level Reset issue on iProc Stingray by working around
hardware defects in the CRS implementation (Oza Pawandeep)
- fix an issue with Intel NVMe P3700 after an iProc reset by adding a
delay during shutdown (Oza Pawandeep)
- fix a Microsoft Hyper-V lockdep issue by polling instead of blocking
in compose_msi_msg() (Stephen Hemminger)
- fix a wireless LAN driver timeout by clearing DesignWare MSI
interrupt status after it is handled, not before (Faiz Abbas)
- fix DesignWare ATU enable checking (Jisheng Zhang)
- reduce Layerscape dependencies on the bootloader by doing more
initialization in the driver (Hou Zhiqiang)
- improve Intel VMD performance allowing allocation of more IRQ vectors
than present CPUs (Keith Busch)
- improve endpoint framework support for initial DMA mask, different
BAR sizes, configurable page sizes, MSI, test driver, etc (Kishon
Vijay Abraham I, Stan Drozd)
- rework CRS support to add periodic messages while we poll during
enumeration and after Function-Level Reset and prepare for possible
other uses of CRS (Sinan Kaya)
- clean up Root Port AER handling by removing unnecessary code and
moving error handler methods to struct pcie_port_service_driver
(Christoph Hellwig)
- clean up error handling paths in various drivers (Bjorn Andersson,
Fabio Estevam, Gustavo A. R. Silva, Harunobu Kurokawa, Jeffy Chen,
Lorenzo Pieralisi, Sergei Shtylyov)
- clean up SR-IOV resource handling by disabling VF decoding before
updating the corresponding resource structs (Gavin Shan)
- clean up DesignWare-based drivers by unifying quirks to update Class
Code and Interrupt Pin and related handling of write-protected
registers (Hou Zhiqiang)
- clean up by adding empty generic pcibios_align_resource() and
pcibios_fixup_bus() and removing empty arch-specific implementations
(Palmer Dabbelt)
- request exclusive reset control for several drivers to allow cleanup
elsewhere (Philipp Zabel)
- constify various structures (Arvind Yadav, Bhumika Goyal)
- convert from full_name() to %pOF (Rob Herring)
- remove unused variables from iProc, HiSi, Altera, Keystone (Shawn
Lin)
* tag 'pci-v4.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (170 commits)
PCI: xgene: Clean up whitespace
PCI: xgene: Define XGENE_PCI_EXP_CAP and use generic PCI_EXP_RTCTL offset
PCI: xgene: Fix platform_get_irq() error handling
PCI: xilinx-nwl: Fix platform_get_irq() error handling
PCI: rockchip: Fix platform_get_irq() error handling
PCI: altera: Fix platform_get_irq() error handling
PCI: spear13xx: Fix platform_get_irq() error handling
PCI: artpec6: Fix platform_get_irq() error handling
PCI: armada8k: Fix platform_get_irq() error handling
PCI: dra7xx: Fix platform_get_irq() error handling
PCI: exynos: Fix platform_get_irq() error handling
PCI: iproc: Clean up whitespace
PCI: iproc: Rename PCI_EXP_CAP to IPROC_PCI_EXP_CAP
PCI: iproc: Add 500ms delay during device shutdown
PCI: Fix typos and whitespace errors
PCI: Remove unused "res" variable from pci_resource_io()
PCI: Correct kernel-doc of pci_vpd_srdt_size(), pci_vpd_srdt_tag()
PCI/AER: Reformat AER register definitions
iommu/vt-d: Prevent VMD child devices from being remapping targets
x86/PCI: Use is_vmd() rather than relying on the domain number
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k updates from Geert Uytterhoeven:
- restore symbol versions for symbols exported from assembly
- defconfig updates
- Mac fixes
* tag 'm68k-for-v4.14-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/mac: Avoid soft-lockup warning after mach_power_off
m68k/mac: Don't hang waiting for Cuda power-down command
m68k: Restore symbol versions for symbols exported from assembly
m68k/defconfig: Update defconfigs for v4.13-rc1
As CONFIG_RTC_DRV_M5441x doesn't exist because the driver never made it
upstream, there is no device to register. Remove code that is never
compiled and init_BSP() as it doesn't do anything.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Make the behaviour of clk_get_rate consistent with common clk's
clk_get_rate by accepting NULL clocks as parameter. Some device
drivers rely on this, and will cause an OOPS otherwise.
Fixes: facdf0ed4f59 ("m68knommu: introduce basic clk infrastructure")
Cc: Greg Ungerer <gerg@linux-m68k.org>
Cc: linux-m68k@lists.linux-m68k.org
Reported-by: Mathias Kresin <dev@kresin.me>
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Disable interrupts for power-off, like other platforms do. This prevents
meaningless warnings from the soft-lockup detector on models with a power
supply unit not under software control.
Reported-by: Stan Johnson <userm57@yahoo.com>
Testing shows that the CUDA_POWERDOWN command never completes (for a
Centris 660av or LC 475, at least). So, don't wait for command completion
on those Cuda-based models that do not support soft power. Just proceed to
log the usual message, "It is now safe to turn off your Macintosh."
WARNING: EXPORT symbol "__divsi3" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "__umodsi3" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "__mulsi3" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "__modsi3" [vmlinux] version generation failed, symbol will not be versioned.
WARNING: EXPORT symbol "__udivsi3" [vmlinux] version generation failed, symbol will not be versioned.
Add <asm/asm-prototypes.h> so that genksyms knows the types of these
symbols and can generate CRCs for them.
Fixes: d13ffb563044 ("m68k: move exports to definitions"
[geert: Add warning messages, match actual prototypes in gccint.info]
The pci_fixup_irqs() function allocates IRQs for all PCI devices present in
a system; those PCI devices possibly belong to different PCI bus trees (and
possibly rooted at different host bridges) and may well be enabled (ie
probed and bound to a driver) by the time pci_fixup_irqs() is called when
probing a given host bridge driver.
Furthermore, current kernel code relying on pci_fixup_irqs() to assign
legacy PCI IRQs to devices does not work at all for hotplugged devices in
that the code carrying out the IRQ fixup is called at host bridge driver
probe time, which just cannot take into account devices hotplugged after
the system has booted.
The introduction of map/swizzle function hooks in struct pci_host_bridge
allows us to define per-bridge map/swizzle functions that can be used at
device probe time in PCI core code to allocate IRQs for a given device
(through pci_assign_irq()).
Convert PCI host bridge initialization code to the
pci_scan_root_bus_bridge() API (that allows to pass a struct
pci_host_bridge with initialized map/swizzle pointers) and remove the
pci_fixup_irqs() call from arch code.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Several variables had their types changed from unsigned long to u32, but
the arch-specific implementations of flat_set_persistent() weren't
updated, leading to compiler warnings on blackfin and m68k:
fs/binfmt_flat.c: In function ‘load_flat_file’:
fs/binfmt_flat.c:799: warning: passing argument 2 of ‘flat_set_persistent’ from incompatible pointer type
Fixes: 468138d78510688f ("binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail")
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- Move generic-y of exported headers to uapi/asm/Kbuild for complete
de-coupling of UAPI
- Clean up scripts/Makefile.headersinst
- Fix host programs for 32 bit machine with XFS file system
* tag 'kbuild-v4.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (29 commits)
kbuild: Enable Large File Support for hostprogs
kbuild: remove wrapper files handling from Makefile.headersinst
kbuild: split exported generic header creation into uapi-asm-generic
kbuild: do not include old-kbuild-file from Makefile.headersinst
xtensa: move generic-y of exported headers to uapi/asm/Kbuild
unicore32: move generic-y of exported headers to uapi/asm/Kbuild
tile: move generic-y of exported headers to uapi/asm/Kbuild
sparc: move generic-y of exported headers to uapi/asm/Kbuild
sh: move generic-y of exported headers to uapi/asm/Kbuild
parisc: move generic-y of exported headers to uapi/asm/Kbuild
openrisc: move generic-y of exported headers to uapi/asm/Kbuild
nios2: move generic-y of exported headers to uapi/asm/Kbuild
nios2: remove unneeded arch/nios2/include/(generated/)asm/signal.h
microblaze: move generic-y of exported headers to uapi/asm/Kbuild
metag: move generic-y of exported headers to uapi/asm/Kbuild
m68k: move generic-y of exported headers to uapi/asm/Kbuild
m32r: move generic-y of exported headers to uapi/asm/Kbuild
ia64: remove redundant generic-y += kvm_para.h from asm/Kbuild
hexagon: move generic-y of exported headers to uapi/asm/Kbuild
h8300: move generic-y of exported headers to uapi/asm/Kbuild
Make the code like the rest of the kernel.
Link: http://lkml.kernel.org/r/14db9c166d5b68efa77e337cfe49bb9b29bca3f7.1499284835.git.joe@perches.com
Acked-by: Greg Ungerer <gerg@linux-m68k.org>
Pull x86nommu update from Greg Ungerer:
"Only a single change, to remove old Kconfig options from defconfigs"
m68k: defconfig: Cleanup from old Kconfig options
Since commit fcc8487d477a ("uapi: export all headers under uapi
directories"), all (and only) headers under uapi directories are
exported, but asm-generic wrappers are still exceptions.
To complete de-coupling the uapi from kernel headers, move generic-y
of exported headers to uapi/asm/Kbuild.
With this change, "make headers_install" will just need to parse
uapi/asm/Kbuild to build up exported headers.
For m68k, "generic-y += termios.h" is doubled in asm/Kbuild and
uapi/asm/Kbuild. So, the one in the former can be simply removed.
Also, move "generic-y += kprobes.h" up in order to keep the entries
sorted.
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
Pull timer updates from Thomas Gleixner:
"A rather large update for timers/timekeeping:
- compat syscall consolidation (Al Viro)
- Posix timer consolidation (Christoph Helwig / Thomas Gleixner)
- Cleanup of the device tree based initialization for clockevents and
clocksources (Daniel Lezcano)
- Consolidation of the FTTMR010 clocksource/event driver (Linus
Walleij)
- The usual set of small fixes and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (93 commits)
timers: Make the cpu base lock raw
clocksource/drivers/mips-gic-timer: Fix an error code in 'gic_clocksource_of_init()'
clocksource/drivers/fsl_ftm_timer: Unmap region obtained by of_iomap
clocksource/drivers/tcb_clksrc: Make IO endian agnostic
clocksource/drivers/sun4i: Switch to the timer-of common init
clocksource/drivers/timer-of: Fix invalid iomap check
Revert "ktime: Simplify ktime_compare implementation"
clocksource/drivers: Fix uninitialized variable use in timer_of_init
kselftests: timers: Add test for frequency step
kselftests: timers: Fix inconsistency-check to not ignore first timestamp
time: Add warning about imminent deprecation of CONFIG_GENERIC_TIME_VSYSCALL_OLD
time: Clean up CLOCK_MONOTONIC_RAW time handling
posix-cpu-timers: Make timespec to nsec conversion safe
itimer: Make timeval to nsec conversion range limited
timers: Fix parameter description of try_to_del_timer_sync()
clocksource/drivers/fttmr010: Factor out clock read code
clocksource/drivers/fttmr010: Implement delay timer
clocksource/drivers: Add timer-of common init routine
clocksource/drivers/tcb_clksrc: Save timer context on suspend/resume
no users left
on MMU targets EFAULT is possible here. Make both return 0 or error,
passing what used to be the return value of flat_get_addr_from_rp()
by reference.
- NuBus improvements and cleanups
- defconfig updates
- Fix debugger syscall restart interactions, leading to the global
removal of ptrace_signal_deliver()
* tag 'm68k-for-v4.13-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Remove ptrace_signal_deliver
m68k/defconfig: Update defconfigs for v4.12-rc1
nubus: Fix pointer validation
nubus: Remove slot zero probe
Currently, internals of dma_common_mmap() is compiled out if build is
done for either NOMMU or target which explicitly says it does not
have/want coherent DMA mmap. It turned out that dma_common_mmap() can
be handy in NOMMU setup (at least for ARM).
This patch converts exitent NOMMU targets to use ARCH_NO_COHERENT_DMA_MMAP,
thus when CONFIG_MMU is gone from dma_common_mmap() their behaviour stays
unchanged.
ARM is not converted to ARCH_NO_COHERENT_DMA_MMAP because it 1)
already has mmap callback which can handle (at some extent) NOMMU 2)
already defines dummy pgprot_noncached() for NOMMU build.
c6x and frv stay untouched since they already have ARCH_NO_COHERENT_DMA_MMAP.
Cc: Steven Miao <realmz6@gmail.com>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Zankel <chris@zankel.net>
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Remove old, dead Kconfig option INET_LRO. It is gone since
commit 7bbf3cae65b6 ("ipv4: Remove inet_lro library").
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
This fixes debugger syscall restart interactions. A debugger that
modifies the tracee's program counter is expected to set the orig_d0
pseudo register to -1, to disable a possible syscall restart.
This removes the last user of the ptrace_signal_deliver hook in the ptrace
signal handling, so remove that as well.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
By moving the kernel side __SI_* defintions right next to the userspace
ones we can kill the non-uapi versions of <asm/siginfo.h> include
include/asm-generic/siginfo.h and untangle the unholy mess of includes.
[ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ]
Cc: linux-ia64@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
no callers, no consistent semantics, no sane way to use it...
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
This typo is quite common. Fix it and add it to the spelling file so
that checkpatch catches it earlier.
Link: http://lkml.kernel.org/r/20170317011131.6881-2-sboyd@codeaurora.org
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
- more kernel message modernizations and cleanups
- Mac and Nubus improvements and cleanups.
* tag 'm68k-for-v4.12-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
nubus: Add MVC and VSC video card definitions
nubus: Clean up whitespace
nubus: Clean up printk calls
nubus: Fix nubus_rewinddir
m68k/mac: Clarify IOP message alloc/free confusion
m68k/mac: Adopt platform_device_register_simple()
m68k/mac: Modernize printing of kernel messages
m68k/mac: IOP - Modernize printing of kernel messages
"The timer departement delivers:
- more year 2038 rework
- a massive rework of the arm achitected timer
- preparatory patches to allow NTP correction of clock event devices
to avoid early expiry
- the usual pile of fixes and enhancements all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits)
timer/sysclt: Restrict timer migration sysctl values to 0 and 1
arm64/arch_timer: Mark errata handlers as __maybe_unused
Clocksource/mips-gic: Remove redundant non devicetree init
MIPS/Malta: Probe gic-timer via devicetree
clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK
acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver
clocksource: arm_arch_timer: add GTDT support for memory-mapped timer
acpi/arm64: Add memory-mapped timer support in GTDT driver
clocksource: arm_arch_timer: simplify ACPI support code.
acpi/arm64: Add GTDT table parse driver
clocksource: arm_arch_timer: split MMIO timer probing.
clocksource: arm_arch_timer: add structs to describe MMIO timer
clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call
clocksource: arm_arch_timer: refactor arch_timer_needs_probing
clocksource: arm_arch_timer: split dt-only rate handling
x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks
unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks
um/time: Set ->min_delta_ticks and ->max_delta_ticks
tile/time: Set ->min_delta_ticks and ->max_delta_ticks
score/time: Set ->min_delta_ticks and ->max_delta_ticks
