[ Upstream commit 969de0988b77e5a57aac2f7270191a3c50540c52 ]
Commit be7635e7287e ("arch, ftrace: for KASAN put hard/soft IRQ entries
into separate sections") added a new linker section, SOFTIRQENTRY_TEXT,
to the linker scripts for most architectures. It didn't add it to any of
the linker scripts for the m68k architecture. This was not really a problem
because it is only defined if either of CONFIG_FUNCTION_GRAPH_TRACER or
CONFIG_KASAN are enabled - which can never be true for m68k.
However commit 229a71860547 ("irq: Make the irqentry text section
unconditional") means that SOFTIRQENTRY_TEXT is now always defined. So on
m68k we now end up with a separate ELF section for .softirqentry.text
instead of it being part of the .text section. On some m68k targets in some
configurations this can also cause a fatal link error:
LD vmlinux
/usr/local/bin/../m68k-uclinux/bin/ld.real: section .softirqentry.text loaded at [0000000010de10c0,0000000010de12dd] overlaps section .rodata loaded at [0000000010de10c0,0000000010e0fd67]
To fix add in the missing SOFTIRQENTRY_TEXT section into the m68k linker
scripts. I noticed that m68k is also missing the IRQENTRY_TEXT section,
so this patch also adds an entry for that too.
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
[ Upstream commit f55ab8f27548ff3431a6567d400c6757c49fd520 ]
The m68k pg_data_table is a fix size array defined in arch/m68k/mm/init.c.
Index numbers within it are defined based on memory size. But for Coldfire
these don't take into account a non-zero physical RAM base address, and this
causes us to access past the end of this array at system start time.
Change the node shift calculation so that we keep the index inside its range.
Reported-by: Angelo Dureghello <angelo@sysam.it>
Tested-by: Angelo Dureghello <angelo@sysam.it>
The current ndelay() macro definition has an extra semi-colon at the
end of the line thus leading to a compilation error when ndelay is used
in a conditional block without curly braces like this one:
if (cond)
ndelay(t);
else
which, after the preprocessor pass gives:
if (cond)
m68k_ndelay(t);;
else
thus leading to the following gcc error:
error: 'else' without a previous 'if'
Remove this extra semi-colon.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Fixes: c8ee038bd1488 ("m68k: Implement ndelay() based on the existing udelay() logic")
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- EXPORT_SYMBOL for asm source by Al Viro.
This does bring a regression, because genksyms no longer generates
checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is
working on a patch to fix this.
Plus, we are talking about functions like strcpy(), which rarely
change prototypes.
- Fixes for PPC fallout of the above by Stephen Rothwell and Nick
Piggin
- fixdep speedup by Alexey Dobriyan.
- preparatory work by Nick Piggin to allow architectures to build with
-ffunction-sections, -fdata-sections and --gc-sections
- CONFIG_THIN_ARCHIVES support by Stephen Rothwell
- fix for filenames with colons in the initramfs source by me.
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits)
initramfs: Escape colons in depfile
ppc: there is no clear_pages to export
powerpc/64: whitelist unresolved modversions CRCs
kbuild: -ffunction-sections fix for archs with conflicting sections
kbuild: add arch specific post-link Makefile
kbuild: allow archs to select link dead code/data elimination
kbuild: allow architectures to use thin archives instead of ld -r
kbuild: Regenerate genksyms lexer
kbuild: genksyms fix for typeof handling
fixdep: faster CONFIG_ search
ia64: move exports to definitions
sparc32: debride memcpy.S a bit
[sparc] unify 32bit and 64bit string.h
sparc: move exports to definitions
ppc: move exports to definitions
arm: move exports to definitions
s390: move exports to definitions
m68k: move exports to definitions
alpha: move exports to actual definitions
x86: move exports to actual definitions
Pull uaccess.h prepwork from Al Viro:
"Preparations to tree-wide switch to use of linux/uaccess.h (which,
obviously, will allow to start unifying stuff for real). The last step
there, ie
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
`git grep -l "$PATT"|grep -v ^include/linux/uaccess.h`
is not taken here - I would prefer to do it once just before or just
after -rc1. However, everything should be ready for it"
* 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
remove a stray reference to asm/uaccess.h in docs
sparc64: separate extable_64.h, switch elf_64.h to it
score: separate extable.h, switch module.h to it
mips: separate extable.h, switch module.h to it
x86: separate extable.h, switch sections.h to it
remove stray include of asm/uaccess.h from cacheflush.h
mn10300: remove a bogus processor.h->uaccess.h include
xtensa: split uaccess.h into C and asm sides
bonding: quit messing with IOCTL
kill __kernel_ds_p off
mn10300: finish verify_area() off
frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h
exceptions: detritus removal
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu updates from Greg Ungerer:
"The bulk of the changes here are to clean up the ColdFire 5441x SoC
support so that it can run with MMU enabled. We have only supported it
with MMU disabled up to now.
There is also a few individual bug fixes across the ColdFire support
code"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: let clk_disable() return immediately if clk is NULL
m68knommu: convert printk(KERN_INFO) to pr_info()
m68knommu: clean up uClinux boot log output
m68k: generalize uboot command line support
m68k: don't panic if no hardware FPU defined
m68k: only generate FPU instructions if CONFIG_FPU enabled
m68k: always make available dump_fpu()
m68k: generalize io memory region setup for ColdFire ACR registers
m68k: move ColdFire _bootmem_alloc code
m68k: report correct FPU type on ColdFire MMU platforms
m68k: set appropriate machine type for m5411x SoC platforms
m68k: move CONFIG_FPU set to per-CPU configuration
m68knommu: fix IO write size in nettel pin set
m68knommu: switch to using IO access methods in WildFire board code
m68knommu: fix early setup to not access variables
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k updates from Geert Uytterhoeven:
- cleanups
- defconfig updates
- GPG fingerprint update
* tag 'm68k-for-v4.9-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Migrate exception table users off module.h and onto extable.h
CREDITS: Update fingerprint for Geert Uytterhoeven
m68k: Use IS_ENABLED() instead of checking for built-in or module
m68k/defconfig: Update defconfigs for v4.8-rc1
This file was only including module.h for exception table related
functions. We've now separated that content out into its own file
"extable.h" so now move over to that and avoid all the extra header
content in module.h that we don't really need to compile this.
externs and defines for stuff that is never used
In many of clk_disable() implementations, it is a no-op for a NULL
pointer input, but this is one of the exceptions.
Making it treewide consistent will allow clock consumers to call
clk_disable() without NULL pointer check.
The old style use of printk(KERN_INFO) is depracated. Convert use of it
in setup_no.c to the modern pr_info().
During the arch setup phase of kernel boot we print out in the boot banner
that we are uClinux configured. The printk currently contains a bunch of
useless newlines and carriage returns - producing wastefull empty lines.
Remove these.
The uboot command line support needs to be used by both MMU and no-MMU
setups, but currently we only have the code in the no-MMU code paths.
Move the uboot command line processing code into its own file. Add
appropriate calls to it from both the MMU and no-MMU arch setup code.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
If we boot up and find no hardware FPU we panic and die.
Change this behavior to be that if we boot up and we _expect_ a hardware
FPU to be present then panic. Don't panic if we don't actually expect to
have any hardware FPU.
This lets us compile a kernel without FPU if we really choose too.
Most of the m68k code that supports a hardware FPU is surrounded by
CONFIG_FPU. Be consistent and surround the hardware FPU instruction
setup in setup_mm.c with CONFIG_FPU as well as the check for
CONFIG_M68KFPU_EMU_ONLY.
The existing classic m68k architectures all define CONFIG_FPU, so they
see no change from this. But on ColdFire where we do not support the
emulated FP code we can now compile without CONFIG_FPU being set as well.
Our local m68k architecture dump_fpu() is conditionally compiled in on
CONFIG_FPU. That is OK for all existing MMU enabled CPU types, but won't
handle the case for some ColdFire SoC CPU parts that we want to support
that have no FPU hardware.
dump_fpu() is expected to be present by the ELF loader, so we must always
have it available and exported.
Remove the conditional and reorganize the dump_fpu hard FPU code path
to let the compiler remove code when not needed.
This change based on changes and discussion from Yannick Gicquel
<yannick.gicquel@open.eurogiciel.org>.
The ACR registers of the ColdFire define at a macro level what regions
of the addresses space should have caching or other attribute types applied.
Currently for the MMU enabled setups we map the interal IO peripheral addres
space as uncachable based on the define for the MBAR address (CONFIG_MBAR).
Not all ColdFire SoC use a programmable MBAR register address. Some parts
have fixed addressing for their internal peripheral registers.
Generalize the way we get the internal peripheral base address so all types
can be accomodated in the ACR definitions. Each ColdFire SoC type now sets
its IO memory base and size definitions (which may be based on MBAR) which
are then used in the ACR definitions.
The early ColdFire bootmem_alloc() code is currently only included in
the board support for the Coldire 54xx platforms. It will be used on all
ColdFire MMU enabled platforms as others are supported. So move the
mcf54xx_bootmem_alloc() function to be generally available to all MMU
enabled ColdFire parts (and use a more generic name for it).
Not all ColdFire SoC parts that have an MMU also have an FPU - so set
an FPU type (via m68k_fputype) appropriate for the configured platform.
With this set correctly /proc/cpuinfo will report FPU "none" on devices
that don't have one. And kernel code paths that initialize FPU hardware
will now only execute if an FPU is actually present.
Create a new machine type for platforms based around the ColdFire 5441x
SoC family. Set that machine type on startup when building for this
platform type.
Currently the ColdFire head.S hard codes a M54xx machine type at startup -
since that is the only platform type currently supported with MMU enabled.
The m5441x has an MMU and this change forms part of the support required
to run it with the MMU enabled.
Move the selection of CONFIG_FPU to each CPU type configuration.
Currently for m68k we have a global set of CONFIG_FPU based on if CONFIG_MMU
is enabled or not. There is at least one CPU family we support (m5441x)
that has an MMU but has no FPU hardware. So we need to be able to have
CONFIG_MMU set and CONFIG_FPU not set.
Whether we build for a CPU with MMU enabled or not doesn't change the
fact that it has FPU hardware support. Our current non-MMU builds have
never had CONIG_FPU enabled - and in fact the kernel will not compile
with that set and CONFIG_MMU not set at the moment. It is easy enough
to fix this - but it would involve a structure change to sigcontext.h,
and that is a user space exported header (so ABI change).
This change makes no configuration visible changes, and all configs
end up with the same configuration settings as before.
The pin write code that supports the UART signals is not using he correct
word write IO access method. It correctly reads the correct 16 bit
registrer, it should also write the new value back with a 16 bit write.
Fix it to use writew().
Most ColdFire support code has switched to using IO memory access
methods (readb/writeb/etc) when reading and writing internal peripheral
device registers. The WildFire board specific halt code was missed.
As it is now the WildFire code is broken, since all register definitions
were changed to be register addresses only some time ago.
Fix the WildFire board code to use the appropriate IO access functions.
The early setup code for the ColdFire 53xx platform accesses variables
before the RAM and other system initialization steps may have taken place.
Currently it has 2 global variables that will end up in the bss section
that are accessed during this early setup. There is a special static RAM
stack setup at this time, but not necessarily the RAM where kernel data
sections will end up.
Even on system setups where RAM is setup by a boot loader the access
to the early setup variables is before the BSS section has been initialized.
This can potentially corrupt a ram loaded root filesystem that sits in that
memory area before it has been moved.
These 2 variables are not used at all after being set, and can just be
removed.
Reported-by: Christian Gieseler <christiangieseler@yahoo.de>
On no-MMU systems the application a5 register can be overwitten with the
address of the process data segment when processing application signals.
For flat format applications compiled with full absolute relocation this
effectively corrupts the a5 register on signal processing - and this very
quickly leads to process crash and often takes out the whole system with
a panic as well.
This has no effect on flat format applications compiled with the more
common PIC methods (such as -msep-data). These format applications reserve
a5 for the pointer to the data segment anyway - so it doesn't change it.
A long time ago the a5 register was used in the code packed into the user
stack to enable signal return processing. And so it had to be restored on
end of signal cleanup processing back to the original a5 user value. This
was historically done by saving away a5 in the sigcontext structure. At
some point (a long time back it seems) the a5 restore process was changed
and it was hard coded to put the user data segment address directly into a5.
Which is ok for the common PIC compiled application case, but breaks the
full relocation application code.
We no longer use this type of signal handling mechanism and so we don't
need to do anything special to save and restore a5 at all now. So remove the
code that hard codes a5 to the address of the user data segment.
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"RTC for 4.8
Cleanups:
- huge cleanup of rtc-generic and char/genrtc this allowed to cleanup
rtc-cmos, rtc-sh, rtc-m68k, rtc-powerpc and rtc-parisc
- move mn10300 to rtc-cmos
Subsystem:
- fix wakealarms after hibernate
- multiples fixes for rctest
- simplify implementations of .read_alarm
New drivers:
- Maxim MAX6916
Drivers:
- ds1307: fix weekday
- m41t80: add wakeup support
- pcf85063: add support for PCF85063A variant
- rv8803: extend i2c fix and other fixes
- s35390a: fix alarm reading, this fixes instant reboot after
shutdown for QNAP TS-41x
- s3c: clock fixes"
* tag 'rtc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (65 commits)
rtc: rv8803: Clear V1F when setting the time
rtc: rv8803: Stop the clock while setting the time
rtc: rv8803: Always apply the I²C workaround
rtc: rv8803: Fix read day of week
rtc: rv8803: Remove the check for valid time
rtc: rv8803: Kconfig: Indicate rx8900 support
rtc: asm9260: remove .owner field for driver
rtc: at91sam9: Fix missing spin_lock_init()
rtc: m41t80: add suspend handlers for alarm IRQ
rtc: m41t80: make it a real error message
rtc: pcf85063: Add support for the PCF85063A device
rtc: pcf85063: fix year range
rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracy
rtc: explicitly set tm_sec = 0 for drivers with minute accurancy
rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq()
rtc: s3c: Remove unnecessary call to disable already disabled clock
rtc: abx80x: use devm_add_action_or_reset()
rtc: m41t80: use devm_add_action_or_reset()
rtc: fix a typo and reduce three empty lines to one
rtc: s35390a: improve two comments in .set_alarm
"This series is all about Nicolas flat format support for MMU systems.
Traditional m68k no-MMU flat format binaries can now be run on m68k
MMU enabled systems too. The series includes some nice cleanups of
the binfmt_flat code and converts it to using proper user space
accessor functions.
With all this in place you can boot and run a complete no-MMU flat
format based user space on an MMU enabled system"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: enable binfmt_flat on systems with an MMU
binfmt_flat: allow compressed flat binary format to work on MMU systems
binfmt_flat: add MMU-specific support
binfmt_flat: update libraries' data segment pointer with userspace accessors
binfmt_flat: use clear_user() rather than memset() to clear .bss
binfmt_flat: use proper user space accessors with old relocs code
binfmt_flat: use proper user space accessors with relocs processing code
binfmt_flat: clean up create_flat_tables() and stack accesses
binfmt_flat: use generic transfer_args_to_stack()
elf_fdpic_transfer_args_to_stack(): make it generic
binfmt_flat: prevent kernel dammage from corrupted executable headers
binfmt_flat: convert printk invocations to their modern form
binfmt_flat: assorted cleanups
m68k: use same start_thread() on MMU and no-MMU
m68k: fix file path comment
m68k: fix bFLT executable running on MMU enabled systems
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Now that the generic changes are in place, this can be enabled on m68k
with the use of proper user space accessors in the flat_get_addr_from_rp()
and flat_put_addr_at_rp() handlers as rp actually holds a user space
address.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
We always have vma->vm_mm around.
Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com
Pull locking updates from Ingo Molnar:
"The locking tree was busier in this cycle than the usual pattern - a
couple of major projects happened to coincide.
The main changes are:
- implement the atomic_fetch_{add,sub,and,or,xor}() API natively
across all SMP architectures (Peter Zijlstra)
- add atomic_fetch_{inc/dec}() as well, using the generic primitives
(Davidlohr Bueso)
- optimize various aspects of rwsems (Jason Low, Davidlohr Bueso,
Waiman Long)
- optimize smp_cond_load_acquire() on arm64 and implement LSE based
atomic{,64}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}()
on arm64 (Will Deacon)
- introduce smp_acquire__after_ctrl_dep() and fix various barrier
mis-uses and bugs (Peter Zijlstra)
- after discovering ancient spin_unlock_wait() barrier bugs in its
implementation and usage, strengthen its semantics and update/fix
usage sites (Peter Zijlstra)
- optimize mutex_trylock() fastpath (Peter Zijlstra)
- ... misc fixes and cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits)
locking/atomic: Introduce inc/dec variants for the atomic_fetch_$op() API
locking/barriers, arch/arm64: Implement LDXR+WFE based smp_cond_load_acquire()
locking/static_keys: Fix non static symbol Sparse warning
locking/qspinlock: Use __this_cpu_dec() instead of full-blown this_cpu_dec()
locking/atomic, arch/tile: Fix tilepro build
locking/atomic, arch/m68k: Remove comment
locking/atomic, arch/arc: Fix build
locking/Documentation: Clarify limited control-dependency scope
locking/atomic, arch/rwsem: Employ atomic_long_fetch_add()
locking/atomic, arch/qrwlock: Employ atomic_fetch_add_acquire()
locking/atomic, arch/mips: Convert to _relaxed atomics
locking/atomic, arch/alpha: Convert to _relaxed atomics
locking/atomic: Remove the deprecated atomic_{set,clear}_mask() functions
locking/atomic: Remove linux/atomic.h:atomic_fetch_or()
locking/atomic: Implement atomic{,64,_long}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}()
locking/atomic: Fix atomic64_relaxed() bits
locking/atomic, arch/xtensa: Implement atomic_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/x86: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/tile: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
locking/atomic, arch/sparc: Implement atomic{,64}_fetch_{add,sub,and,or,xor}()
The MMU and no-MMU versions of start_thread() are now identical, so use
the same common code for both.
Remove the wrong full path name of this file.
Even after recent changes to support running flat format executables on
MMU enabled systems (by nicolas.pitre@linaro.org) they still failed to
run on m68k/ColdFire MMU enabled systems. On trying to run a flat format
binary the application would immediately crash with a SIGSEGV.
Code to setup the D5 register with the base of the application data
region was only in the non-MMU code path, so it was not being set for
the MMU enabled case. Flat binaries on m68k/ColdFire use this to support
GOT/PIC flat built application code.
Fix this so that D5 is always setup when loading/running a bFLT executable
on m68k systems.
Pull m68k upddates from Geert Uytterhoeven:
- assorted spelling fixes
- defconfig updates
* tag 'm68k-for-v4.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/defconfig: Update defconfigs for v4.7-rc2
m68k: Assorted spelling fixes
- s/acccess/access/
- s/accoding/according/
- s/addad/added/
- s/addreess/address/
- s/allocatiom/allocation/
- s/Assember/Assembler/
- s/compactnes/compactness/
- s/conneced/connected/
- s/decending/descending/
- s/diectly/directly/
- s/diplacement/displacement/
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
[geert: Squashed, fix arch/m68k/ifpsp060/src/pfpsp.S]
This is the third version of the patchset previously sent [1]. I have
basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get
rid of superfluous gfp flags" which went through dm tree. I am sending
it now because it is tree wide and chances for conflicts are reduced
considerably when we want to target rc2. I plan to send the next step
and rename the flag and move to a better semantic later during this
release cycle so we will have a new semantic ready for 4.8 merge window
hopefully.
Motivation:
While working on something unrelated I've checked the current usage of
__GFP_REPEAT in the tree. It seems that a majority of the usage is and
always has been bogus because __GFP_REPEAT has always been about costly
high order allocations while we are using it for order-0 or very small
orders very often. It seems that a big pile of them is just a
copy&paste when a code has been adopted from one arch to another.
I think it makes some sense to get rid of them because they are just
making the semantic more unclear. Please note that GFP_REPEAT is
documented as
* __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt
* _might_ fail. This depends upon the particular VM implementation.
while !costly requests have basically nofail semantic. So one could
reasonably expect that order-0 request with __GFP_REPEAT will not loop
for ever. This is not implemented right now though.
I would like to move on with __GFP_REPEAT and define a better semantic
for it.
$ git grep __GFP_REPEAT origin/master | wc -l
111
$ git grep __GFP_REPEAT | wc -l
36
So we are down to the third after this patch series. The remaining
places really seem to be relying on __GFP_REPEAT due to large allocation
requests. This still needs some double checking which I will do later
after all the simple ones are sorted out.
I am touching a lot of arch specific code here and I hope I got it right
but as a matter of fact I even didn't compile test for some archs as I
do not have cross compiler for them. Patches should be quite trivial to
review for stupid compile mistakes though. The tricky parts are usually
hidden by macro definitions and thats where I would appreciate help from
arch maintainers.
[1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org
This patch (of 19):
__GFP_REPEAT has a rather weak semantic but since it has been introduced
around 2.6.12 it has been ignored for low order allocations. Yet we
have the full kernel tree with its usage for apparently order-0
allocations. This is really confusing because __GFP_REPEAT is
explicitly documented to allow allocation failures which is a weaker
semantic than the current order-0 has (basically nofail).
Let's simply drop __GFP_REPEAT from those places. This would allow to
identify place which really need allocator to retry harder and formulate
a more specific semantic for what the flag is supposed to do actually.
Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Helge Deller <deller@gmx.de>
Cc: Jan Kara <jack@suse.cz>
Cc: John Crispin <blogic@openwrt.org>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Rich Felker <dalias@libc.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
I misread the inline asm. It uses a rare construct to provide an input
to a previously declared output to do the atomic_read().
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: linux-m68k@lists.linux-m68k.org
Since all architectures have this implemented now natively, remove this
dead code.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Implement FETCH-OP atomic primitives, these are very similar to the
existing OP-RETURN primitives we already have, except they return the
value of the atomic variable _before_ modification.
This is especially useful for irreversible operations -- such as
bitops (because it becomes impossible to reconstruct the state prior
to modification).
The asm/rtc.h header is only used for the old gen_rtc driver
that has been replaced by rtc-generic. According to Geert
Uytterhoeven, nobody has used the old driver on m68k for
a long time, so we can now just remove the header file
and disallow the driver in Kconfig.
All files that used to include asm/rtc.h are now changed so
they include the headers that were used implicitly through
asm/rtc.h.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The q40 platform is the only machine in the kernel that provides
RTC_PLL_GET/RTC_PLL_SET ioctl commands in its rtc through the
mach_get_rtc_pll/mach_set_rtc_pll callbacks.
However, this currenctly works only in the old-style genrtc
driver, not the (somewhat) modern rtc-generic driver replacing
it. This adds an ioctl implementation to the m68k generic_rtc_ops
in order to let both drivers provide the same API.
After this, we should be able to remove support for genrtc
from the m68k architecture.
The rtc-generic driver provides an architecture specific
wrapper on top of the generic rtc_class_ops abstraction,
and m68k has another abstraction on top, which is a bit
silly.
This changes the m68k rtc-generic device to provide its
rtc_class_ops directly, to reduce the number of layers
by one.
Pull string hash improvements from George Spelvin:
"This series does several related things:
- Makes the dcache hash (fs/namei.c) useful for general kernel use.
(Thanks to Bruce for noticing the zero-length corner case)
- Converts the string hashes in <linux/sunrpc/svcauth.h> to use the
above.
- Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two
32-bit multiplies will do well enough.
- Rids the world of the bad hash multipliers in hash_32.
This finishes the job started in commit 689de1d6ca95 ("Minimal
fix-up of bad hashing behavior of hash_64()")
The vast majority of Linux architectures have hardware support for
32x32-bit multiply and so derive no benefit from "simplified"
multipliers.
The few processors that do not (68000, h8/300 and some models of
Microblaze) have arch-specific implementations added. Those
patches are last in the series.
- Overhauls the dcache hash mixing.
The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if
CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion.
Replaced with a much more careful design that's simultaneously
faster and better. (My own invention, as there was noting suitable
in the literature I could find. Comments welcome!)
- Modify the hash_name() loop to skip the initial HASH_MIX(). This
would let us salt the hash if we ever wanted to.
- Sort out partial_name_hash().
The hash function is declared as using a long state, even though
it's truncated to 32 bits at the end and the extra internal state
contributes nothing to the result. And some callers do odd things:
- fs/hfs/string.c only allocates 32 bits of state
- fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes
- Modify bytemask_from_count to handle inputs of 1..sizeof(long)
rather than 0..sizeof(long)-1. This would simplify users other
than full_name_hash"
Special thanks to Bruce Fields for testing and finding bugs in v1. (I
learned some humbling lessons about "obviously correct" code.)
On the arch-specific front, the m68k assembly has been tested in a
standalone test harness, I've been in contact with the Microblaze
maintainers who mostly don't care, as the hardware multiplier is never
omitted in real-world applications, and I haven't heard anything from
the H8/300 world"
* 'hash' of git://ftp.sciencehorizons.net/linux:
h8300: Add <asm/hash.h>
microblaze: Add <asm/hash.h>
m68k: Add <asm/hash.h>
<linux/hash.h>: Add support for architecture-specific functions
fs/namei.c: Improve dcache hash function
Eliminate bad hash multipliers from hash_32() and hash_64()
Change hash_64() return value to 32 bits
<linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string()
fs/namei.c: Add hashlen_string() function
Pull out string hash to <linux/stringhash.h>
