path: root/arch/m68k
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26m68k: fix sigset_t accessor functionsAndreas Schwab
commit 34fa78b59c52d1db3513db4c1a999db26b2e9ac2 upstream. The sigaddset/sigdelset/sigismember functions that are implemented with bitfield insn cannot allow the sigset argument to be placed in a data register since the sigset is wider than 32 bits. Remove the "d" constraint from the asm statements. The effect of the bug is that sending RT signals does not work, the signal number is truncated modulo 32. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09m68k: Correct the Atari ALLOWINT definitionMikael Pettersson
commit c663600584a596b5e66258cc10716fb781a5c2c9 upstream. Booting a 3.2, 3.3, or 3.4-rc4 kernel on an Atari using the `nfeth' ethernet device triggers a WARN_ONCE() in generic irq handling code on the first irq for that device: WARNING: at kernel/irq/handle.c:146 handle_irq_event_percpu+0x134/0x142() irq 3 handler nfeth_interrupt+0x0/0x194 enabled interrupts Modules linked in: Call Trace: [<000299b2>] warn_slowpath_common+0x48/0x6a [<000299c0>] warn_slowpath_common+0x56/0x6a [<00029a4c>] warn_slowpath_fmt+0x2a/0x32 [<0005b34c>] handle_irq_event_percpu+0x134/0x142 [<0005b34c>] handle_irq_event_percpu+0x134/0x142 [<0000a584>] nfeth_interrupt+0x0/0x194 [<001ba0a8>] schedule_preempt_disabled+0x0/0xc [<0005b37a>] handle_irq_event+0x20/0x2c [<0005add4>] generic_handle_irq+0x2c/0x3a [<00002ab6>] do_IRQ+0x20/0x32 [<0000289e>] auto_irqhandler_fixup+0x4/0x6 [<00003144>] cpu_idle+0x22/0x2e [<001b8a78>] printk+0x0/0x18 [<0024d112>] start_kernel+0x37a/0x386 [<0003021d>] __do_proc_dointvec+0xb1/0x366 [<0003021d>] __do_proc_dointvec+0xb1/0x366 [<0024c31e>] _sinittext+0x31e/0x9c0 After invoking the irq's handler the kernel sees !irqs_disabled() and concludes that the handler erroneously enabled interrupts. However, debugging shows that !irqs_disabled() is true even before the handler is invoked, which indicates a problem in the platform code rather than the specific driver. The warning does not occur in 3.1 or older kernels. It turns out that the ALLOWINT definition for Atari is incorrect. The Atari definition of ALLOWINT is ~0x400, the stated purpose of that is to avoid taking HSYNC interrupts. irqs_disabled() returns true if the 3-bit ipl & 4 is non-zero. The nfeth interrupt runs at ipl 3 (it's autovector 3), but 3 & 4 is zero so irqs_disabled() is false, and the warning above is generated. When interrupts are explicitly disabled, ipl is set to 7. When they are enabled, ipl is masked with ALLOWINT. On Atari this will result in ipl = 3, which blocks interrupts at ipl 3 and below. So how come nfeth interrupts at ipl 3 are received at all? That's because ipl is reset to 2 by Atari-specific code in default_idle(), again with the stated purpose of blocking HSYNC interrupts. This discrepancy means that ipl 3 can remain blocked for longer than intended. Both default_idle() and falcon_hblhandler() identify HSYNC with ipl 2, and the "Atari ST/.../F030 Hardware Register Listing" agrees, but ALLOWINT is defined as if HSYNC was ipl 3. [As an experiment I modified default_idle() to reset ipl to 3, and as expected that resulted in all nfeth interrupts being blocked.] The fix is simple: define ALLOWINT as ~0x500 instead. This makes arch_local_irq_enable() consistent with default_idle(), and prevents the !irqs_disabled() problems for ipl 3 interrupts. Tested on Atari running in an Aranym VM. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Michael Schmitz <schmitzmic@googlemail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09m68k: Make sys_atomic_cmpxchg_32 work on classic m68kAndreas Schwab
commit 9e2760d18b3cf179534bbc27692c84879c61b97c upstream. User space access must always go through uaccess accessors, since on classic m68k user space and kernel space are completely separate. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13m68k/mac: Add missing platform check before registering platform devicesGeert Uytterhoeven
commit 6cfeba53911d6d2f17ebbd1246893557d5ff5aeb upstream. On multi-platform kernels, the Mac platform devices should be registered when running on Mac only. Else it may crash later. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-14m68k: use kernel processor defines for conditional optimizationsGreg Ungerer
Older m68k-linux compilers will include pre-defined symbols that confuse what processor it is being targeted for. For example gcc-4.1.2 will pre-define __mc68020__ even if you specify the target processor as -m68000 on the gcc command line. Newer versions of gcc have this corrected. In a few places the m68k code uses defined(__mc68020__) for optimizations that include instructions that are specific to the CPU 68020 and above. When compiling with older compilers this will be true even when we have selected to compile for the older 68000 processors. Switch to using the kernel processor defines, CONFIG_M68020 and friends. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: create config options for CPU classesGreg Ungerer
There are 3 families of CPU core types that we support in the m68knommu architecture branch. They are . traditional 68000 . CPU32 (a 68020 core derivative without MMU or bitfield instructions) . ColdFire It will be useful going forward to have a CONFIG_ option defined for each type. We already have one for ColdFire (CONFIG_COLDFIRE), so add for the other 2 families, CONFIG_M68000 and CONFIG_MCPU32. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: fix linker script exported name sectionsGreg Ungerer
The recent commit titled "module: Sort exported symbols" (f02e8a65) changed the exported symbol name sections. Bring the m68knommu linker script into line with those changes - including the sorting of the symbol names. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m68knommu: use generic find_next_bit_le()Akinobu Mita
The implementation of find_next_bit_le() on m68knommu is identical with the generic implementation of find_next_bit_le(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: add #define for each of optimized find bitopsAkinobu Mita
The style that we normally use in asm-generic is to test the macro itself for existence, so in asm-generic, do: #ifndef find_next_zero_bit_le extern unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset); #endif and in the architectures, write static inline unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset) #define find_next_zero_bit_le find_next_zero_bit_le This adds the #define for each of the optimized find bitops in the architectures. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m68knommu: fix build error due to the lack of find_next_bit_le()Akinobu Mita
m68knommu can't build ext4, udf, and ocfs2 due to the lack of find_next_bit_le(). This implements find_next_bit_le() on m68knommu by duplicating the generic find_next_bit_le() in lib/find_next_bit.c. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24m68knommu: Use generic show_interrupts()Geert Uytterhoeven
Apart from whitespace differences, /proc/interrupts doesn't change by enabling GENERIC_IRQ_SHOW. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: merge the mmu and non-mmu versions of sys_m68k.cGreg Ungerer
There is a lot of common code in the sys_m68k.c files. The mmu and non-mmu versions can easily be merged into a single file. There is really only 2 functions that differ in the 2 cases. A single ifdef on CONFIG_MMU can take care of this. Alternatively we could break those 2 functions out and maintain sys_m68k_no.c and sys_m68k_mm.c with just this code in it (Makefile could then just build the right one). Does anyone have strong feelings on which way they want this done? Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: use asm-generic/bitops/ext2-atomic.hAkinobu Mita
m68knommu can use generic implementation of ext2 atomic bitops. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: Remove obsolete #include <linux/sys.h>Geert Uytterhoeven
2011-05-24m68k: merge mmu and non-mmu versions of asm-offsets.cGreg Ungerer
It is strait forward to merge the mmu and non-mmu versions of asm-offstes.c. Some name changes are required for the preempt and thread_info.flags in the non-mmu entry.S assembler to make them consistent for both setups. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: merge non-mmu and mmu versions of m68k_ksyms.cGreg Ungerer
After cleaning up m68k_ksyms_no.c it is now strait forward to merge the non-mmu and mmu versions of m68k_ksyms.c. The need for the extra gcc functions is not strictly based on having an MMU or not. It is based on the family the processor belongs too, so use an appropriate conditional check. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: remove un-needed exporting of COLDFIRE symbolsGreg Ungerer
There is no reason most of the symbols enclosed in a conditional on CONFIG_COLDFIRE need to be exported. And they sure don't need to be doing it in m68k_ksyms_no.c. Move the dma symbols export (which are currently needed) to the definitions of those, and remove the rest of the exporting here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: move EXPORT of kernel_thread to function definitionGreg Ungerer
The EXPORT_SYMBOL(kernel_thread) belongs at the definition of that function, not in some other random code file. So move it there. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: move EXPORT of local checksumming functions to definitionsGreg Ungerer
The EXPORT_SYMBOL() of the local lib checksum functions belongs with the definitions, not in some other random code file. So move then there. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: move EXPORT of dump_fpu to function definitionGreg Ungerer
The EXPORT_SYMBOL(dump_fpu) belongs at the definition of the function, not in some other random code file. So move it there. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: clean up mm/init_no.cGreg Ungerer
The memory initialization code for m68knommu has grown a bit crufty, clean it up. . remove unused declaration for die_if_kernel() . remove un-needed declaration of free_initmem() . removed unused definitions of empty_bad_page and empty_bad_page_table . removed unused DEBUG code . make free_initmem() proper prototype Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: merge the mmu and non-mmu mm/MakefileGreg Ungerer
Its is trivial to megre the mmu and non-mmu arch/m68k/mm/Makefile's back into a single file. So do it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: mv kmap_mm.c to kmap.cGreg Ungerer
The non-mmu kmap_no.c has been removed. So we can move kmap_mm.c back to being the only kmap.c. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: remove stubs for __ioremap() and iounmap()Greg Ungerer
The implementation of iounmap() and __ioremap() for non-mmu m68k is trivial. We can inline them in m68knommu headers and remove the trivial implementations. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: remove unused kernel_set_cachemode()Greg Ungerer
None of the m68knommu platforms will ever use kernel_set_cachemode(). And it is specific to a couple of m68k devices. So remove it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: let Makefile sort out compiling mmu and non-mmu lib/checksum.cGreg Ungerer
We don't need an arch/m68k/lib/checksum.c wrapper to include the correct mmu or non-mmu version of the checksum code. Let the Makefile just build the appropriate one. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: remove duplicate memcpy() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate implementations of memcpy(). One is a little more optimized for the >= 68020 case, but that can easily be inserted into a single implementation of memcpy(). Clean up the exporting of this symbol too, otherwise we end up exporting it twice on a no-mmu build. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: remove duplicate memset() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate implementations of memset(). One is a little more optimized for the >= 68020 case, but that can easily be inserted into a single implementation of memset(). Clean up the exporting of this symbol too, otherwise we end up exporting it twice on a no-mmu build. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: remove duplicate memmove() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate (and identical) implementations of memmove(). Remove one of them. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: merge mmu and non-mmu versions of lib/MakefileGreg Ungerer
We can easily support the slight differences in libs needed by the mmu and non-mmu builds in a single Makefile, so merge them back into a single file again. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: merge mmu and non-mmu versions of muldi3Greg Ungerer
The implementation of gcc's muldi3 support function differs only in the use of the machine's 64 bit sized mul or not. (It isn't based on using an MMU or not). Merge the current mmu and non-mmu versions of arc/m68k/lib/muldi3 and use the appropriate pre-processor conditionals to get the right version for all m68k processor types. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20extable, core_kernel_data(): Make sure all archs define _sdataSteven Rostedt
A new utility function (core_kernel_data()) is used to determine if a passed in address is part of core kernel data or not. It may or may not return true for RO data, but this utility must work for RW data. Thus both _sdata and _edata must be defined and continuous, without .init sections that may later be freed and replaced by volatile memory (memory that can be freed). This utility function is used to determine if data is safe from ever being freed. Thus it should return true for all RW global data that is not in a module or has been allocated, or false otherwise. Also change core_kernel_data() back to the more precise _sdata condition and document the function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: JamesE.J.Bottomley <jejb@parisc-linux.org> Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com Signed-off-by: Ingo Molnar <mingo@elte.hu> ---- arch/alpha/kernel/vmlinux.lds.S | 1 + arch/m32r/kernel/vmlinux.lds.S | 1 + arch/m68k/kernel/vmlinux-std.lds | 2 ++ arch/m68k/kernel/vmlinux-sun3.lds | 1 + arch/mips/kernel/vmlinux.lds.S | 1 + arch/parisc/kernel/vmlinux.lds.S | 3 +++ kernel/extable.c | 12 +++++++++++- 7 files changed, 20 insertions(+), 1 deletion(-)
2011-05-19input/atari: Use the correct mouse interrupt hookMichael Schmitz
The Atari keyboard driver calls atari_mouse_interrupt_hook if it's set, not atari_input_mouse_interrupt_hook. Fix below. [geert] Killed off atari_mouse_interrupt_hook completely, after fixing another incorrect assignment in atarimouse.c. Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19m68k/atari: Do not use "/" in interrupt namesGeert Uytterhoeven
It may trigger a warning in fs/proc/generic.c:__xlate_proc_name() when trying to add an entry for the interrupt handler to sysfs. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19m68k: unistd - Comment out definitions for unimplemented syscallsGeert Uytterhoeven
Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19m68k: Really wire up sys_pselect6 and sys_ppollGeert Uytterhoeven
We reserved the numbers a long time ago, but never wired them up in the syscall table as they need TIF_RESTORE_SIGMASK, which we only got last year in commit cb6831d5d3099e772a510eb3e1ed0760ccffb45e ("m68k: Switch to saner sigsuspend()") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: stable@kernel.org
2011-05-19m68k: Merge mmu and non-mmu versions of sys_call_tableGeert Uytterhoeven
Impact for nommu: - Store table in .rodata instead of .text, - Let kernel/sys_ni.c handle the stubbing of MMU-only syscalls, - Implement sys_mremap and sys_nfsservct, - Remove unused padding at the end of the table. Impact for mmu: - Store table in .rodata instead of .data. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-05-19m68k: bitops - Never step beyond the end of the bitmapGeert Uytterhoeven
find_next bitops on m68k (find_next_zero_bit, find_next_bit, and find_next_bit_le) may cause out of bounds memory access when the bitmap size in bits % 32 != 0 and offset (the bitnumber to start searching at) is very close to the bitmap size. For example, unsigned long bitmap[2] = { 0, 0 }; find_next_bit(bitmap, 63, 62); 1. find_next_bit() tries to find any set bits in bitmap[1], but no bits set. 2. Then find_first_bit(bimap + 2, -1) 3. Unfortunately find_first_bit() takes unsigned int as the size argument. 4. find_first_bit will access bitmap[2~] until it find any set bits. Add missing tests for stepping beyond the end of the bitmap to all find_{first,next}_*() functions, and make sure they never return a value larger than the bitmap size. Reported-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19m68k: bitops - offset == ((long)p - (long)vaddr) * 8Geert Uytterhoeven
Hence use "offset" in find_next_{,zero_}bit(), like is already done for find_next_{,zero_}bit_le() Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-04-27m68k/mm: Set all online nodes in N_NORMAL_MEMORYMichael Schmitz
For m68k, N_NORMAL_MEMORY represents all nodes that have present memory since it does not support HIGHMEM. This patch sets the bit at the time node_present_pages has been set by free_area_init_node. At the time the node is brought online, the node state would have to be done unconditionally since information about present memory has not yet been recorded. If N_NORMAL_MEMORY is not accurate, slub may encounter errors since it uses this nodemask to setup per-cache kmem_cache_node data structures. This pach is an alternative to the one proposed by David Rientjes <rientjes@google.com> attempting to set node state immediately when bringing the node online. Signed-off-by: Michael Schmitz <schmitz@debian.org> Tested-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> CC: stable@kernel.org
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-12m68k,m68knommu: Wire up name_to_handle_at, open_by_handle_at, clock_adjtime, ↵Geert Uytterhoeven
syncfs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-10m68k: fix comment typo 'occcured'Justin P. Mattock
The patch below changes a typo occcured to occurred in two comments. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
