path: root/arch/m68k
2012-10-19m68k: Wire up kcmpGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2012-10-15m68k: Remove empty #ifdef/#else/#endif blockGeert Uytterhoeven
Leftover from commit 10b3a979347d4aba7de19e8d33eb8b87fe2a11dd ("UAPI: (Scripted) Disintegrate arch/m68k/include/asm") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-10-15Merge tag 'disintegrate-m68k-20121009' of ↵Geert Uytterhoeven
git://git.infradead.org/users/dhowells/linux-headers into for-linus
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09UAPI: (Scripted) Disintegrate arch/m68k/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09readahead: fault retry breaks mmap file read random detectionShaohua Li
.fault now can retry. The retry can break state machine of .fault. In filemap_fault, if page is miss, ra->mmap_miss is increased. In the second try, since the page is in page cache now, ra->mmap_miss is decreased. And these are done in one fault, so we can't detect random mmap file access. Add a new flag to indicate .fault is tried once. In the second try, skip ra->mmap_miss decreasing. The filemap_fault state machine is ok with it. I only tested x86, didn't test other archs, but looks the change for other archs is obvious, but who knows :) Signed-off-by: Shaohua Li <shaohua.li@fusionio.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the DEBUG_BUGVERBOSE config optionCatalin Marinas
Introduce HAVE_DEBUG_BUGVERBOSE config option and select it in corresponding architecture Kconfig files. Architectures that already select GENERIC_BUG don't need to select HAVE_DEBUG_BUGVERBOSE. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-07Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu Pull m68knommu arch updates from Greg Ungerer: "Most of it is a cleanup of the ColdFire hardware header files. We have had a few occurrances of bugs caused by inconsistent definitions of peripheral addresses. These patches make them all consistent, and also clean out a bunch of old crap. Overall we remove about 1000 lines." * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (27 commits) m68knommu: fix inconsistent formating in ColdFire 5407 definitions m68knommu: fix inconsistent formating in ColdFire 5307 definitions m68knommu: fix inconsistent formating in ColdFire 527x definitions m68knommu: fix inconsistent formating in ColdFire 5272 definitions m68knommu: fix inconsistent formating in ColdFire 523x definitions m68knommu: clean up ColdFire 54xx General Timer definitions m68knommu: clean up Pin Assignment definitions for the 54xx ColdFire CPU m68knommu: fix multi-function pin setup for FEC module on ColdFire 523x m68knommu: move ColdFire slice timer address defiens to 54xx header m68knommu: use read/write IO access functions in ColdFire m532x setup code m68knommu: modify ColdFire 532x GPIO register definitions to be consistent m68knommu: remove a lot of unsed definitions for 532x ColdFire m68knommu: use definitions for the ColdFire 528x FEC multi-function pins m68knommu: remove address offsets relative to IPSBAR for ColdFire 527x m68knommu: remove unused ColdFire 5282 register definitions m68knommu: fix wrong register offsets used for ColdFire 5272 multi-function pins m68knommu: make ColdFire 5249 MBAR2 register definitions absolute addresses m68knommu: make remaining ColdFire 5272 register definitions absolute addresses m68knommu: make ColdFire Park and Assignment register definitions absolute addresses m68knommu: make ColdFire Chip Select register definitions absolute addresses ...
2012-10-06cross-arch: don't corrupt personality flags upon exec()Jiri Kosina
Historically, the top three bytes of personality have been used for things such as ADDR_NO_RANDOMIZE, which made sense only for specific architectures. We now however have a flag there that is general no matter the architecture (UNAME26); generally we have to be careful to preserve the personality flags across exec(). This patch tries to fix all architectures that forcefully overwrite personality flags during exec() (ppc32 and s390 have been fixed recently by commits f9783ec862ea ("[S390] Do not clobber personality flags on exec") and 59e4c3a2fe9c ("powerpc/32: Don't clobber personality flags on exec") in a similar way already). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04Merge branch 'disintegrate-asm-generic' of ↵Arnd Bergmann
git://git.infradead.org/users/dhowells/linux-headers into asm-generic Patches from David Howells <dhowells@redhat.com>: This is to complete part of the UAPI disintegration for which the preparatory patches were pulled recently. Note that there are some fixup patches which are at the base of the branch aimed at you, plus all arches get the asm-generic branch merged in too. * 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/asm-generic UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k) c6x: remove c6x signal.h UAPI: Split compound conditionals containing __KERNEL__ in Arm64 UAPI: Fix the guards on various asm/unistd.h files Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-03Merge tag 'uapi-prep-20121002' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull preparatory patches for user API disintegration from David Howells: "The patches herein prepare for the extraction of the Userspace API bits from the various header files named in the Kbuild files. New subdirectories are created under either include/uapi/ or arch/x/include/uapi/ that correspond to the subdirectory containing that file under include/ or arch/x/include/. The new subdirs under the uapi/ directory are populated with Kbuild files that mostly do nothing at this time. Further patches will disintegrate the headers in each original directory and fill in the Kbuild files as they do it. These patches also: (1) fix up #inclusions of "foo.h" rather than <foo.h>. (2) Remove some redundant #includes from the DRM code. (3) Make the kernel build infrastructure handle Kbuild files both in the old places and the new UAPI place that both specify headers to be exported. (4) Fix some kernel tools that #include kernel headers during their build. I have compile tested this with allyesconfig against x86_64, allmodconfig against i386 and a scattering of additional defconfigs of other arches. Prepared for main script Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com>" * tag 'uapi-prep-20121002' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Plumb the UAPI Kbuilds into the user header installation and checking UAPI: x86: Differentiate the generated UAPI and internal headers UAPI: Remove the objhdr-y export list UAPI: Move linux/version.h UAPI: Set up uapi/asm/Kbuild.asm UAPI: x86: Fix insn_sanity build failure after UAPI split UAPI: x86: Fix the test_get_len tool UAPI: (Scripted) Set up UAPI Kbuild files UAPI: Partition the header include path sets and add uapi/ header directories UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel system headers UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/ UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/. UAPI: Refer to the DRM UAPI headers with <...> and from certain headers only
2012-10-03asm-generic: Add default clkdev.hMark Brown
Ease the deployment of clkdev by providing a default asm/clkdev.h for use if the arch does not have an include/asm/clkdev.h. Due to limitations in Kbuild we manually add clkdev.h to all architectures that don't have one rather than having the header appear by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-10-02UAPI: (Scripted) Set up UAPI Kbuild filesDavid Howells
Set up empty UAPI Kbuild files to be populated by the header splitter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel ↵David Howells
system headers Convert #include "..." to #include <path/...> in kernel system headers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: "All pretty boring, seems like all of us had better things to do last summer..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Use PTR_RET rather than if(IS_ERR(...)) + PTR_ERR m68k/q40: Use PTR_RET rather than if(IS_ERR(...)) + PTR_ERR m68k/amiga: Use PTR_RET rather than if(IS_ERR(...)) + PTR_ERR m68k/apollo: Remove disabled definitions in apollohw.h
2012-10-01Merge tag 'tty-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/ttyLinus Torvalds
Pull TTY changes from Greg Kroah-Hartman: "As we skipped the merge window for 3.6-rc1 for the tty tree, everything is now settled down and working properly, so we are ready for 3.7-rc1. Here's the patchset, it's big, but the large changes are removing a firmware file and adding a staging tty driver (it depended on the tty core changes, so it's going through this tree instead of the staging tree.) All of these patches have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up more-or-less trivial conflicts in - drivers/char/pcmcia/synclink_cs.c: tty NULL dereference fix vs tty_port_cts_enabled() helper function - drivers/staging/{Kconfig,Makefile}: add-add conflict (dgrp driver added close to other staging drivers) - drivers/staging/ipack/devices/ipoctal.c: "split ipoctal_channel from iopctal" vs "TTY: use tty_port_register_device" * tag 'tty-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (235 commits) tty/serial: Add kgdb_nmi driver tty/serial/amba-pl011: Quiesce interrupts in poll_get_char tty/serial/amba-pl011: Implement poll_init callback tty/serial/core: Introduce poll_init callback kdb: Turn KGDB_KDB=n stubs into static inlines kdb: Implement disable_nmi command kernel/debug: Mask KGDB NMI upon entry serial: pl011: handle corruption at high clock speeds serial: sccnxp: Make 'default' choice in switch last serial: sccnxp: Remove mask termios caps for SW flow control serial: sccnxp: Report actual baudrate back to core serial: samsung: Add poll_get_char & poll_put_char Powerpc 8xx CPM_UART setting MAXIDL register proportionaly to baud rate Powerpc 8xx CPM_UART maxidl should not depend on fifo size Powerpc 8xx CPM_UART too many interrupts Powerpc 8xx CPM_UART desynchronisation serial: set correct baud_base for EXSYS EX-41092 Dual 16950 serial: omap: fix the reciever line error case 8250: blacklist Winbond CIR port 8250_pnp: do pnp probe before legacy probe ...
2012-10-01Merge tag 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug - Protect acpi_pci_drivers and acpi_pci_roots (Taku Izumi) - Clear host bridge resource info to avoid issue when releasing (Yinghai Lu) - Notify acpi_pci_drivers when hot-plugging host bridges (Jiang Liu) - Use standard list ops for acpi_pci_drivers (Jiang Liu) Device hotplug - Use pci_get_domain_bus_and_slot() to close hotplug races (Jiang Liu) - Remove fakephp driver (Bjorn Helgaas) - Fix VGA ref count in hotplug remove path (Yinghai Lu) - Allow acpiphp to handle PCIe ports without native hotplug (Jiang Liu) - Implement resume regardless of pciehp_force param (Oliver Neukum) - Make pci_fixup_irqs() work after init (Thierry Reding) Miscellaneous - Add pci_pcie_type(dev) and remove pci_dev.pcie_type (Yijing Wang) - Factor out PCI Express Capability accessors (Jiang Liu) - Add pcibios_window_alignment() so powerpc EEH can use generic resource assignment (Gavin Shan) - Make pci_error_handlers const (Stephen Hemminger) - Cleanup drivers/pci/remove.c (Bjorn Helgaas) - Improve Vendor-Specific Extended Capability support (Bjorn Helgaas) - Use standard list ops for bus->devices (Bjorn Helgaas) - Avoid kmalloc in pci_get_subsys() and pci_get_class() (Feng Tang) - Reassign invalid bus number ranges (Intel DP43BF workaround) (Yinghai Lu)" * tag 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (102 commits) PCI: acpiphp: Handle PCIe ports without native hotplug capability PCI/ACPI: Use acpi_driver_data() rather than searching acpi_pci_roots PCI/ACPI: Protect acpi_pci_roots list with mutex PCI/ACPI: Use acpi_pci_root info rather than looking it up again PCI/ACPI: Pass acpi_pci_root to acpi_pci_drivers' add/remove interface PCI/ACPI: Protect acpi_pci_drivers list with mutex PCI/ACPI: Notify acpi_pci_drivers when hot-plugging PCI root bridges PCI/ACPI: Use normal list for struct acpi_pci_driver PCI/ACPI: Use DEVICE_ACPI_HANDLE rather than searching acpi_pci_roots PCI: Fix default vga ref_count ia64/PCI: Clear host bridge aperture struct resource x86/PCI: Clear host bridge aperture struct resource PCI: Stop all children first, before removing all children Revert "PCI: Use hotplug-safe pci_get_domain_bus_and_slot()" PCI: Provide a default pcibios_update_irq() PCI: Discard __init annotations for pci_fixup_irqs() and related functions PCI: Use correct type when freeing bus resource list PCI: Check P2P bridge for invalid secondary/subordinate range PCI: Convert "new_id"/"remove_id" into generic pci_bus driver attributes xen-pcifront: Use hotplug-safe pci_get_domain_bus_and_slot() ...
2012-10-01m68k: switch to generic sys_execve()/kernel_execve()Al Viro
The tricky part here is that task_pt_regs() on m68k works *only* for process inside do_signal(). However, we need something much simpler - pt_regs of a process inside do_signal() may be at different offsets from the stack bottom, depending on the way we'd entered the kernel, but for a task inside sys_execve() it *is* at constant offset. Moreover, for a kernel thread about to become a userland process the same location is also fine - setting sp to that will leave the kernel stack pointer at the very bottom of the kernel stack when we finally switch to userland. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01m68k: split ret_from_fork(), simplify kernel_thread()Al Viro
2012-10-01m68k: always set stack frame format for ColdFire on thread startGreg Ungerer
The stack frame "format" field needs to be explicitly set on thread creation on ColdFire. For a normal long word aligned user stack pointer the frame format is 0x4. We were doing this for non-MMU ColdFire, but not for the case with MMU enabled. So fix it so we always do it if targeting ColdFire. The old code happend to rely on the stack frame format being inhereted from the process calling exec. Furture changes means that may not always work, so we really do want to set it explicitly. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-27m68knommu: fix inconsistent formating in ColdFire 5407 definitionsGreg Ungerer
Fix tab broken address defines to be consistent with others in this file. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: fix inconsistent formating in ColdFire 5307 definitionsGreg Ungerer
2012-09-27m68knommu: fix inconsistent formating in ColdFire 527x definitionsGreg Ungerer
2012-09-27m68knommu: fix inconsistent formating in ColdFire 5272 definitionsGreg Ungerer
Fix tab broken defines to be consistent with others in this file. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: fix inconsistent formating in ColdFire 523x definitionsGreg Ungerer
2012-09-27m68knommu: clean up ColdFire 54xx General Timer definitionsGreg Ungerer
Convert the ColdFire 54xx CPU General Timer register address definitions to include the MCF_MBAR peripheral region offset. This makes them consistent with all other 54xx address register definitions (in m54xxsim.h). The goal is to reduce different definitions used (some including offsets and others not) causing bugs when used incorrectly. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: clean up Pin Assignment definitions for the 54xx ColdFire CPUGreg Ungerer
The Pin Assignment register definitions for the ColdFire 54xx CPU family are inconsistently named and defined compared to the other ColdFire part definitions. Rename them with the same prefix as used on other parts, MCFGPIO_PAR_, and make their definitions include the MCF_MBAR periphperal region offset. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: fix multi-function pin setup for FEC module on ColdFire 523xGreg Ungerer
The multi-function pin setup code for the FEC ethernet module is using just plain wrong. Looks like it was cut-and-pasted from other init code. It has hard coded register addresses that are incorrect for the 523x, and it is manipulating bits that don't make sense. Add proper register definitions for the Pin Assignment registers of the 532x, and then use them to fix the setup code for the FEC hardware module. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: move ColdFire slice timer address defiens to 54xx headerGreg Ungerer
Move the base address defines of the ColdFire 54xx CPU slice timers into the 54xx specific header (m54xxsim.h). They are CPU specific, and belong with the CPU specific defines. Also make them relative to the MBAR peripheral region, making the define the absolute address. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: use read/write IO access functions in ColdFire m532x setup codeGreg Ungerer
Get rid of the use of local IO access macros and switch to using the standard read*/write* family of access functions for the ColdFire m532x setup code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: modify ColdFire 532x GPIO register definitions to be consistentGreg Ungerer
The ColdFire 532x CPU register definitions for the multi-function setup pins are inconsistently defined compared with other ColdFire parts. Modify the register defintions to be just the addresses, not pointers. This also fixes the erroneous use in one case of using these values in the UART setup code for the 532x. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: remove a lot of unsed definitions for 532x ColdFireGreg Ungerer
There are a lot of unused and uneccessary definitions in the header to support the ColdFire 532x CPU family. Remove the junk. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: use definitions for the ColdFire 528x FEC multi-function pinsGreg Ungerer
Currently the setup code for the FEC multi-function pins on the ColdFire 528x has the addresses hard coded in the code. Use the register defines that already exist for this. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: remove address offsets relative to IPSBAR for ColdFire 527xGreg Ungerer
Remove the last address definitions relative to the IPSBAR peripheral region for the ColdFire 527x family. This involved cleaning up some magic numbers used in the code part, and making them proper register definitions in the 527x specific header. This is part of the process of cleaning up the ColdFire register definitions to make them consistently use absolute addresses for the primary registers. This will reduce the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: remove unused ColdFire 5282 register definitionsGreg Ungerer
There is a bunch of old unused and ugly register definitions in the ColdFire 5282 header. Remove them. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: fix wrong register offsets used for ColdFire 5272 multi-function pinsGreg Ungerer
The registers used to configure and set the multifunction pins on the 5272 ColdFire are defined as absolute addresses. So the use of them does not need to be offset relative to the peripheral region address. Fix two cases of incorrect usage of these addresses. Both affect UART initialization, one in the common UART pin setup code, the other in the NETtel board specific UART signal handling. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make ColdFire 5249 MBAR2 register definitions absolute addressesGreg Ungerer
Make the ColdFire 5249 MBAR peripheral register definitions absolute addresses, instead of offsets into the region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make remaining ColdFire 5272 register definitions absolute addressesGreg Ungerer
Make the remaining definitions of the 5272 ColdFire registers absolute addresses. Currently some are relative to the MBAR peripheral region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make ColdFire Park and Assignment register definitions absolute ↵Greg Ungerer
addresses Make all definitions of the ColdFire MPARK and IRQ Assignment registers absolute addresses. Currently some are relative to the MBAR peripheral region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make ColdFire Chip Select register definitions absolute addressesGreg Ungerer
Make all definitions of the ColdFire Chip Select registers absolute addresses. Currently some are relative to the MBAR peripheral region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make ColdFire Interrupt Source register definitions absolute ↵Greg Ungerer
addresses Make all definitions of the ColdFire Interrupt Source registers absolute addresses. Currently some are relative to the MBAR peripheral region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-27m68knommu: make ColdFire Pin Assignment register definitions absolute addressesGreg Ungerer
Make all definitions of the ColdFire Pin Assignment registers absolute addresses. Currently some are relative to the MBAR peripheral region. The various ColdFire parts use different methods to address the internal registers, some are absolute, some are relative to peripheral regions which can be mapped at different address ranges (such as the MBAR and IPSBAR registers). We don't want to deal with this in the code when we are accessing these registers, so make all register definitions the absolute address - factoring out whether it is an offset into a peripheral region. This makes them all consistently defined, and reduces the occasional bugs caused by inconsistent definition of the register addresses. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
