path: root/arch/m68k
2008-09-10m68k: Update defconfigs for 2.6.27-rc6Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02m68k: atari_keyb_init operator precedence fixMichael Schmitz
Fix operator precedence bug in atari_keyb_init, which caused a failure on CT60 Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-11m68k{,nommu}: Wire up new system callsGeert Uytterhoeven
Wire up for m68k{,nommu} the system calls that were added in the last merge window: - 4006553b06306b34054529477b06b68a1c66249b ("flag parameters: inotify_init") - ed8cae8ba01348bfd83333f4648dd807b04d7f08 ("flag parameters: pipe") - 336dd1f70ff62d7dd8655228caed4c5bfc818c56 ("flag parameters: dup2") - a0998b50c3f0b8fdd265c63e0032f86ebe377dbf ("flag parameters: epoll_create") - 9fe5ad9c8cef9ad5873d8ee55d1cf00d9b607df0 ("flag parameters add-on: remove epoll_create size param") - b087498eb5605673b0f260a7620d91818cd72304 ("flag parameters: eventfd") - 9deb27baedb79759c3ab9435a7d8b841842d56e9 ("flag parameters: signalfd") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05remove unneeded #include <linux/ide.h>'sAdrian Bunk
This patch remove unneeded #include <linux/ide.h>'s. It also adds a required #include <linux/interrupt.h> that was previously implicitely pulled by ide.h Signed-off-by: Adrian Bunk <bunk@kernel.org> [bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-26m68k: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: drop unneeded pgdat argument from free_area_init_node()Johannes Weiner
free_area_init_node() gets passed in the node id as well as the node descriptor. This is redundant as the function can trivially get the node descriptor itself by means of NODE_DATA() and the node's id. I checked all the users and NODE_DATA() seems to be usable everywhere from where this function is called. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: move bootmem descriptors definition to a single placeJohannes Weiner
There are a lot of places that define either a single bootmem descriptor or an array of them. Use only one central array with MAX_NUMNODES items instead. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20arch/m68k/mm/sun3mmu.c: Eliminate NULL test and memset after alloc_bootmemJulia Lawall
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem and related functions never return NULL and always return a zeroed region of memory. Thus a NULL test or memset after calls to these functions is unnecessary. This was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; statement S; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) .. when != E ( - BUG_ON (E == NULL); | - if (E == NULL) S ) @@ expression E,E1; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) .. when != E - memset(E,0,E1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20arch/m68k/mm/motorola.c: Eliminate NULL test and memset after alloc_bootmemJulia Lawall
2008-07-20m68k/Atari: remove the dead ATARI_SCC{,_DMA} optionsAdrian Bunk
It seems the driver was removed back in kernel 2.3 but the options were forgotten. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/Mac: remove the unused ADB_KEYBOARD optionAdrian Bunk
When the driver was removed back in 2002 the option was forgotten. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/apollo: Add missing call to apollo_parse_bootinfo()Geert Uytterhoeven
Add the missing call to apollo_parse_bootinfo(), which had been lost from a big Apollo support patch by Peter De Schrijver in 1999. Thanks to Adrian Bunk for noticing! Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/sun3/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - config.c: sun3_bootmem_alloc() - config.c: sun3_sched_init() - dvma.c: dvma_page() - idprom.c: struct Sun_Machines[] - mmu_emu.c: struct ctx_alloc[] - sun3dvma.c: iommu_use[] - sun3ints.c: led_pattern[] - remove the unused sbus.c Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/q40/config.c: make functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - q40_reset() - q40_halt() - q40_disable_irqs() - q40_gettimeoffset() - q40_hwclk() - q40_get_ss() - q40_set_clock_mmss() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/mac/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code (always) static: - baboon.c: struct baboon - baboon.c: baboon_irq() - config.c: mac_orig_videoaddr - config.c: mac_identify() - config.c: mac_report_hardware() - config.c: mac_debug_console_write() - config.c: mac_sccb_console_write() - config.c: mac_scca_console_write() - config.c: mac_init_scc_port() - oss.c: oss_irq() - oss.c: oss_nubus_irq() - psc.c: psc_debug_dump() - psc.c: psc_dma_die_die_die() - via.c: rbv_clear - remove the unused bootparse.c - #if 0 the following unused functions: - config.c: mac_debugging_short() - config.c: mac_debugging_long() - remove the following unused code: - config.c: mac_bisize - config.c: mac_env - config.c: mac_SCC_init_done - config.c: mac_SCC_reset_done - config.c: mac_init_scca_port() - config.c: mac_init_sccb_port() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/atari/debug.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions (always) static: - atari_mfp_console_write() - atari_scc_console_write() - atari_midi_console_write() - atari_init_mfp_port() - atari_init_scc_port() - atari_init_midi_port() - #if 0 the following unused functions: - atari_mfp_console_wait_key() - atari_scc_console_wait_key() - atari_midi_console_wait_key() - remove the following unused variables: - atari_MFP_init_done - atari_SCC_init_done Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/amiga/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - amiints.c: add a proper prototype for amiga_init_IRQ() in include/asm-m68k/amigaints.h - make the following needlessly global code static: - config.c: amiga_model - config.c: amiga_psfreq - config.c: amiga_serial_console_write() - #if 0 the following unused functions: - config.c: amiga_serial_puts() - config.c: amiga_serial_console_wait_key() - config.c: amiga_serial_gets() - remove the following unused variable: - config.c: amiga_masterclock Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20export amiga_vblankAdrian Bunk
This patch fixes the following build error: <-- snip --> .. Building modules, stage 2. MODPOST 1203 modules ERROR: "amiga_vblank" [drivers/video/amifb.ko] undefined! .. make[2]: *** [__modpost] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: remove AP1000 codeAdrian Bunk
Unless I miss something that's code for a sparc machine even the sparc code no longer supports that got copied to m68k when these files were copied. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: make multi_defconfig the default defconfigAdrian Bunk
It seems to match the intention behind multi_defconfig to make it the default defconfig. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20Stringify support commasMathieu Desnoyers
> This is a no-no for those archs that still use -traditional. > > I dunno if this is a problem for you at the moment and the > > right fix is anyway to nuke -traditional. > > > > Sam Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: Allow no CPU/platform type for allnoconfigGeert Uytterhoeven
Allow no CPU/platform type for allnoconfig - Provide a dummy value for FPSTATESIZE if no CPU type was selected - Provide a dummy value for NR_IRQS if no platform type was selected - Warn the user if no CPU or platform type was selected Note: you still cannot build an allnoconfig kernel, as CONFIG_SWAP=n doesn't build and we cannot easily fix that (http://groups.google.com/group/linux.kernel/browse_thread/thread/d430c78b07e1827b) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: vmlinux-std/sun3.lds.S cleanup - use PAGE_SIZE macroCyrill Gorcunov
This patch includes page.h header into linker script that allow us to use PAGE_SIZE macro instead of numeric constant Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-02mvme16x-rtc: BKL pushdownArnd Bergmann
2008-06-20bvme6000-rtc: BKL pushdownArnd Bergmann
2008-06-06m68k: enable CONFIG_COMPAT_BRK by defaultGeert Uytterhoeven
As some m68k machines have plenty of libc5 binaries in active use, enable CONFIG_COMPAT_BRK by default. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21provide out-of-line strcat() for m68kAl Viro
Whether we sidestep it in init/main.c or not, such situations will arise again; compiler does generate calls of strcat() on optimizations, so we really ought to have an out-of-line version... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-18m68k: Add multi_defconfigGeert Uytterhoeven
Add multi_defconfig, to build a kernel for all supported m68k platforms, excluding Sun 3 (Sun 3 kernels are incompatible with all other m68k platforms) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Update defconfigsGeert Uytterhoeven
Update the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Correctly handle multi-ISA at runtimeGeert Uytterhoeven
m68k: Correctly handle multi-ISA at runtime in multi-platform kernels Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Prefix ISA type with ISA_TYPE_Geert Uytterhoeven
The *_ISA type defines are quite generic and cause namespace conflicts (e.g. with `AMIGAHW_DECLARE(GG2_ISA)' in <asm/amigahw.h>) for some kernel configurations. Use ISA_TYPE_* to avoid such conflicts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: export m68k_mmutypeGeert Uytterhoeven
UIO needs m68k_mmutype: ERROR: "m68k_mmutype" [drivers/uio/uio.ko] undefined! (noticed by Christian T. Steigies) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Q40/Q60 floppy support is brokenGeert Uytterhoeven
Mark Q40/Q60 floppy support broken: arch/m68k/q40/q40ints.c: In function 'q40_irq_handler': arch/m68k/q40/q40ints.c:214: error: implicit declaration of function 'floppy_hardint' Including <asm/floppy.h> doesn't help, as it causes a lot of additional error messages (cfr. Sun 3x). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Correct jump if not running on HP300Geert Uytterhoeven
When running a HP300-enabled kernel on non-HP300 hardware, a test in the early startup code jumps to the wrong label, causing a double bus fault. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Kill CONFIG_WHIPPET_SERIALGeert Uytterhoeven
The Hisoft Whippet PCMCIA serial driver has been removed a long time ago, but it's Kconfig symbol still existed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-05m68k: remove old mac_esp cruftFinn Thain
Remove the rest of the old mac_esp driver. Also ditch the rest of the machw mechanism, it needs to be replaced by a fake openfirmware tree. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05m68k: Handle 68040 bus faultsRoman Zippel
Fix 68040 bus fault handling, so the standard kernel exception handling can be used for i/o probing. Contrary to normal access faults there is nothing to fix, but at least we have to disable writebacks to avoid recursive faults. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29m68k: Export empty_zero_page for ZERO_PAGE usage in modules.Aneesh Kumar K.V
ext4 uses ZERO_PAGE(0) to zero out blocks. We need to export different symbols in different arches for the usage of ZERO_PAGE in modules. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-29m68k/m68kmmu: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove /proc/mac_iopAlexey Dobriyan
Entry creation was commented for a long time and right now it stands on the way of ->get_info removal, so unless nobody objects... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28m68k: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28m68k: remove redundant display of free swap space in show_mem()Johannes Weiner
show_mem() has no need to print the amount of free swap space manually because show_free_areas() does this already and is called by the former. The two outputs only differ in text formatting: printk("Free swap = %lukB\n", ...); printk("Free swap: %6ldkB\n", ...); Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18arch: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
