path: root/arch/m68knommu/platform/coldfire/timers.c
2011-03-25m68k: merge m68k and m68knommu arch directoriesGreg Ungerer
There is a lot of common code that could be shared between the m68k and m68knommu arch branches. It makes sense to merge the two branches into a single directory structure so that we can more easily share that common code. This is a brute force merge, based on a script from Stephen King <sfking@fdwdc.com>, which was originally written by Arnd Bergmann <arnd@arndb.de>. > The script was inspired by the script Sam Ravnborg used to merge the > includes from m68knommu. For those files common to both arches but > differing in content, the m68k version of the file is renamed to > <file>_mm.<ext> and the m68knommu version of the file is moved into the > corresponding m68k directory and renamed <file>_no.<ext> and a small > wrapper file <file>.<ext> is used to select between the two version. Files > that are common to both but don't differ are removed from the m68knommu > tree and files and directories that are unique to the m68knommu tree are > moved to the m68k tree. Finally, the arch/m68knommu tree is removed. > > To select between the the versions of the files, the wrapper uses > > #ifdef CONFIG_MMU > #include <file>_mm.<ext> > #else > #include <file>_no.<ext> > #endif On top of this file merge I have done a simplistic merge of m68k and m68knommu Kconfig, which primarily attempts to keep existing options and menus in place. Other than a handful of options being moved it produces identical .config outputs on m68k and m68knommu targets I tested it on. With this in place there is now quite a bit of scope for merge cleanups in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-03-15m68knommu: remove use of MBAR in old-style ColdFire timerGreg Ungerer
Not all ColdFire CPUs that use the old style timer hardware module use an MBAR set peripheral region. Move the TIMER base address defines to the per-CPU header files where we can set it correctly based on how the peripherals are mapped - instead of using a fake MBAR for some platforms. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up old ColdFire timer irq setupGreg Ungerer
The recent changes to the old ColdFire interrupt controller code means we no longer need to manually unmask the timer interrupt. That is now done in the interrupt controller code proper. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: simplify ColdFire "timers" clock initializationGreg Ungerer
The ColdFire "timers" clock setup can be simplified. There is really no need for the flexible per-platform setup code. The clock interrupt can be hard defined per CPU platform (in CPU include files). This makes the actual timer code simpler. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12m68knommu: init coldfire timer TRR with n - 1, not nPhilippe De Muyter
The coldfire timer must be initialised to n - 1 if we want it to count n cycles between each tick interrupt. This was already fixed, but has been lost with the conversion to GENERIC_TIMER. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: fix profile timerMatt Waddel
I was looking at timers in the Coldfire system and I noticed that the CONFIG_HIGHPROFILE option seems to be a little out of date. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: switch ColdFire TIMER to use GENERIC_TIMEGreg Ungerer
Switch the ColdFire TIMER timer to use GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire timers.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU timers.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
