path: root/arch/m68knommu
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-03-04m68k{,nommu}: Wire up new timerfd syscallsGeert Uytterhoeven
m68k{,nommu}: Wire up the new timerfd syscalls, which were introduced in commit 4d672e7ac79b5ec5cdc90e450823441e20464691 ("timerfd: new timerfd API"). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: remove duplicate hw_tick() codeGreg Ungerer
Remove duplicate hw_tick() function from 68328 timers code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: update defconfigGreg Ungerer
Update the m68knommu defconfig. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: fix profile timerMatt Waddel
I was looking at timers in the Coldfire system and I noticed that the CONFIG_HIGHPROFILE option seems to be a little out of date. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: use asflags instead of EXTRA_AFLAGSGreg Ungerer
Modify the extra asm flags for debugger capabilities, use asflags instead for EXTRA_AFLAGS. Suggestion from Sam Ravnborg. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: fix coldfire interrupt exit pathWalter T Gruczka
Remove bogus conditional jump in return from interrupt path. Reorder the code path now that is not there. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xtime_lock vs update_process_timesPeter Zijlstra
Commit d3d74453c34f8fd87674a8cf5b8a327c68f22e99 ("hrtimer: fixup the HRTIMER_CB_IRQSAFE_NO_SOFTIRQ fallback") broke several archs, and since only Russell bothered to merge the fix, and Greg to ACK his arch, I'm sending this for merger. I have confirmation that the Alpha bit results in a booting kernel. That leaves: blackfin, frv, sh and sparc untested. The deadlock in question was found by Russell: IRQ handle -> timer_tick() - xtime seqlock held for write -> update_process_times() -> run_local_timers() -> hrtimer_run_queues() -> hrtimer_get_softirq_time() - tries to get a read lock Now, Thomas assures me the fix is trivial, only do_timer() needs to be done under the xtime_lock, and update_process_times() can savely be removed from under it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Greg Ungerer <gerg@uclinux.org> CC: Richard Henderson <rth@twiddle.net> CC: Bryan Wu <bryan.wu@analog.com> CC: David Howells <dhowells@redhat.com> CC: Paul Mundt <lethal@linux-sh.org> CC: William Irwin <wli@holomorphy.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08procfs: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove inclusions of <linux/autoconf.h>Ralf Baechle
Nothing should ever include this file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: "Mike Frysinger" <vapier.adi@gmail.com> Acked-by: "Bryan Wu" <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68knommu: remove duplicate exportsAdrian Bunk
One EXPORT_SYMBOL should be enough for everyone. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68knommu: removing config variable DUMPTOFLASHJiri Olsa
Removing config variable DUMPTOFLASH, since it is not used Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68knomu: remove dead config symbols from m68knomu codeJiri Olsa
remove dead config symbols from m68knommu code Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: new timerfd APIDavide Libenzi
This is the new timerfd API as it is implemented by the following patch: int timerfd_create(int clockid, int flags); int timerfd_settime(int ufd, int flags, const struct itimerspec *utmr, struct itimerspec *otmr); int timerfd_gettime(int ufd, struct itimerspec *otmr); The timerfd_create() API creates an un-programmed timerfd fd. The "clockid" parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME. The timerfd_settime() API give new settings by the timerfd fd, by optionally retrieving the previous expiration time (in case the "otmr" parameter is not NULL). The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit is set in the "flags" parameter. Otherwise it's a relative time. The timerfd_gettime() API returns the next expiration time of the timer, or {0, 0} if the timerfd has not been set yet. Like the previous timerfd API implementation, read(2) and poll(2) are supported (with the same interface). Here's a simple test program I used to exercise the new timerfd APIs: http://www.xmailserver.org/timerfd-test2.c [akpm@linux-foundation.org: coding-style cleanups] [akpm@linux-foundation.org: fix ia64 build] [akpm@linux-foundation.org: fix m68k build] [akpm@linux-foundation.org: fix mips build] [akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds] [heiko.carstens@de.ibm.com: fix s390] [akpm@linux-foundation.org: fix powerpc build] [akpm@linux-foundation.org: fix sparc64 more] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01m68knommu: remove dead timer int pending codeGreg Ungerer
Remove all the dead timer interrupt checking functions for the ColdFire CPU "timers" hardware that are not used after switching to GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: remove empty timer offset function for 68360Greg Ungerer
Switching to GENERIC_TIME means we no longer need the empty timer offset function for the 68360 CPU. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: remove local gettimeofday codeGreg Ungerer
Remove unused local gettimeofday functions, now that we are using GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: set config to use GENERIC_TIMEGreg Ungerer
Switch m68knommu arch to using GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: switch ColdFire TIMER to use GENERIC_TIMEGreg Ungerer
Switch the ColdFire TIMER timer to use GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: switch ColdFire PIT timer to use GENERIC_TIMEGreg Ungerer
Switch the ColdFire PIT timer to using GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: switch 68328 timer to use GENERIC_TIMEGreg Ungerer
Switch the 68328 CPU timer code to using GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: remove dead code from m68knommu timer codeGreg Ungerer
Remove unused LED heartbeat code from m68knommu timer code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: create common DMA table for ColdFire CPUsGreg Ungerer
Move the ColdFire DMA address table into its own file, and out of each of the different CPU config files. No need to have a copy of it in each of the config setup files. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: modify Makefiles to support common coldfire directoryGreg Ungerer
Modify Makefiles to support separate coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire vectors.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU vectors.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire timers.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU timers.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire pit.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU pit.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire head.S to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU head.S to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire entry.S to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU entry.S to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5407 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5407 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 532x ColdFire partsGreg Ungerer
Switch to platform style configuration for 532x ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 527x ColdFire partsGreg Ungerer
Switch to platform style configuration for 527x ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5307 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5307 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 528x ColdFire partsGreg Ungerer
Switch to platform style configuration for 528x ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5249 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5249 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5272 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5272 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 520x ColdFire partsGreg Ungerer
Switch to platform style configuration for 520x ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 523x ColdFire partsGreg Ungerer
Switch to platform style configuration for 523x ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5206e ColdFire partsGreg Ungerer
Switch to platform style configuration for 5206e ColdFire parts. Initial support is for the UARTs. DMA support is moved to common code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5206 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5206 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-23m68knommu: mark mem init functions as __initGreg Ungerer
Mark the m68knommu memory init functions as __init. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: mark setup_arch() as __initGreg Ungerer
Mark the m68knommu setup_arch() function as __init. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: cleanup 68VZ328 init codeGreg Ungerer
Removed header includes not needed. Remove use of old m68knommu timer function pointers. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: cleanup 68EZ328 init codeGreg Ungerer
Clean up 68EZ328 timer support code. Removed header includes not needed. Remove use of old m68knommu timer function pointers. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
