path: root/arch/metag
2016-03-25arch, ftrace: for KASAN put hard/soft IRQ entries into separate sectionsAlexander Potapenko
KASAN needs to know whether the allocation happens in an IRQ handler. This lets us strip everything below the IRQ entry point to reduce the number of unique stack traces needed to be stored. Move the definition of __irq_entry to <linux/interrupt.h> so that the users don't need to pull in <linux/ftrace.h>. Also introduce the __softirq_entry macro which is similar to __irq_entry, but puts the corresponding functions to the .softirqentry.text section. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - a couple of hotfixes - the rest of MM - a new timer slack control in procfs - a couple of procfs fixes - a few misc things - some printk tweaks - lib/ updates, notably to radix-tree. - add my and Nick Piggin's old userspace radix-tree test harness to tools/testing/radix-tree/. Matthew said it was a godsend during the radix-tree work he did. - a few code-size improvements, switching to __always_inline where gcc screwed up. - partially implement character sets in sscanf * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) sscanf: implement basic character sets lib/bug.c: use common WARN helper param: convert some "on"/"off" users to strtobool lib: add "on"/"off" support to kstrtobool lib: update single-char callers of strtobool() lib: move strtobool() to kstrtobool() include/linux/unaligned: force inlining of byteswap operations include/uapi/linux/byteorder, swab: force inlining of some byteswap operations include/asm-generic/atomic-long.h: force inlining of some atomic_long operations usb: common: convert to use match_string() helper ide: hpt366: convert to use match_string() helper ata: hpt366: convert to use match_string() helper power: ab8500: convert to use match_string() helper power: charger_manager: convert to use match_string() helper drm/edid: convert to use match_string() helper pinctrl: convert to use match_string() helper device property: convert to use match_string() helper lib/string: introduce match_string() helper radix-tree tests: add test for radix_tree_iter_next radix-tree tests: add regression3 test ...
2016-03-17Merge tag 'gpio-v4.6-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel v4.6. There is quite a lot of interesting stuff going on. The patches to other subsystems and arch-wide are ACKed as far as possible, though I consider things like per-arch <asm/gpio.h> as essentially a part of the GPIO subsystem so it should not be needed. Core changes: - The gpio_chip is now a *real device*. Until now the gpio chips were just piggybacking the parent device or (gasp) floating in space outside of the device model. We now finally make GPIO chips devices. The gpio_chip will create a gpio_device which contains a struct device, and this gpio_device struct is kept private. Anything that needs to be kept private from the rest of the kernel will gradually be moved over to the gpio_device. - As a result of making the gpio_device a real device, we have added resource management, so devm_gpiochip_add_data() will cut down on overhead and reduce code lines. A huge slew of patches convert almost all drivers in the subsystem to use this. - Building on making the GPIO a real device, we add the first step of a new userspace ABI: the GPIO character device. We take small steps here, so we first add a pure *information* ABI and the tool "lsgpio" that will list all GPIO devices on the system and all lines on these devices. We can now discover GPIOs properly from userspace. We still have not come up with a way to actually *use* GPIOs from userspace. - To encourage people to use the character device for the future, we have it always-enabled when using GPIO. The old sysfs ABI is still opt-in (and can be used in parallel), but is marked as deprecated. We will keep it around for the foreseeable future, but it will not be extended to cover ever more use cases. Cleanup: - Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h> includes. This dates back to when GPIO was an opt-in feature and no shared library even existed: just a header file with proper prototypes was provided and all semantics were up to the arch to implement. These patches make the GPIO chip even more a proper device and cleans out leftovers of the old in-kernel API here and there. Still some cruft is left but it's very little now. - There is still some clamping of return values for .get() going on, but we now return sane values in the vast majority of drivers and the errorpath is sanitized. Some patches for powerpc, blackfin and unicore still drop in. - We continue to switch the ARM, MIPS, blackfin, m68k local GPIO implementations to use gpiochip_add_data() and cut down on code lines. - MPC8xxx is converted to use the generic GPIO helpers. - ATH79 is converted to use the generic GPIO helpers. New drivers: - WinSystems WS16C48 - Acces 104-DIO-48E - F81866 (a F7188x variant) - Qoric (a MPC8xxx variant) - TS-4800 - SPI serializers (pisosr): simple 74xx shift registers connected to SPI to obtain a dirt-cheap output-only GPIO expander. - Texas Instruments TPIC2810 - Texas Instruments TPS65218 - Texas Instruments TPS65912 - X-Gene (ARM64) standby GPIO controller" * tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits) Revert "Share upstreaming patches" gpio: mcp23s08: Fix clearing of interrupt. gpiolib: Fix comment referring to gpio_*() in gpiod_*() gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit gpio: xgene: Fix kconfig for standby GIPO contoller gpio: Add generic serializer DT binding gpio: uapi: use 0xB4 as ioctl() major gpio: tps65912: fix bad merge Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free" gpio: omap: drop dev field from gpio_bank structure gpio: mpc8xxx: Slightly update the code for better readability gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip gpio: mpc8xxx: Fixup setting gpio direction output gpio: mcp23s08: Add support for mcp23s18 dt-bindings: gpio: altera: Fix altr,interrupt-type property gpio: add driver for MEN 16Z127 GPIO controller gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free gpio: timberdale: Switch to devm_ioremap_resource() gpio: ts4800: Add IMX51 dependency gpiolib: rewrite gpiodev_add_to_list ...
2016-03-17mm: cleanup *pte_alloc* interfacesKirill A. Shutemov
There are few things about *pte_alloc*() helpers worth cleaning up: - 'vma' argument is unused, let's drop it; - most __pte_alloc() callers do speculative check for pmd_none(), before taking ptl: let's introduce pte_alloc() macro which does the check. The only direct user of __pte_alloc left is userfaultfd, which has different expectation about atomicity wrt pmd. - pte_alloc_map() and pte_alloc_map_lock() are redefined using pte_alloc(). [sudeep.holla@arm.com: fix build for arm64 hugetlbpage] [sfr@canb.auug.org.au: fix arch/arm/mm/mmu.c some more] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-01arch/hotplug: Call into idle with a proper stateThomas Gleixner
Let the non boot cpus call into idle with the corresponding hotplug state, so the hotplug core can handle the further bringup. That's a first step to convert the boot side of the hotplugged cpus to do all the synchronization with the other side through the state machine. For now it'll only start the hotplug thread and kick the full bringup of the cpu. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Rik van Riel <riel@redhat.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/20160226182341.614102639@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-02-16gpio: Remove unused asm/gpio.h filesBjorn Helgaas
asm/gpio.h is included only by linux/gpio.h, and then only when the arch selects ARCH_HAVE_CUSTOM_GPIO_H. Only the following arches select it: arm avr32 blackfin m68k (COLDFIRE only) sh unicore32. Remove the unused asm/gpio.h files for the arches that do not select ARCH_HAVE_CUSTOM_GPIO_H. This is a follow-on to 7563bbf89d06 ("gpiolib/arches: Centralise bolierplate asm/gpio.h"). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20metag: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-18Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio barrier rework+fixes from Michael Tsirkin: "This adds a new kind of barrier, and reworks virtio and xen to use it. Plus some fixes here and there" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: (44 commits) checkpatch: add virt barriers checkpatch: check for __smp outside barrier.h checkpatch.pl: add missing memory barriers virtio: make find_vqs() checkpatch.pl-friendly virtio_balloon: fix race between migration and ballooning virtio_balloon: fix race by fill and leak s390: more efficient smp barriers s390: use generic memory barriers xen/events: use virt_xxx barriers xen/io: use virt_xxx barriers xenbus: use virt_xxx barriers virtio_ring: use virt_store_mb sh: move xchg_cmpxchg to a header by itself sh: support 1 and 2 byte xchg virtio_ring: update weak barriers to use virt_xxx Revert "virtio_ring: Update weak barriers to use dma_wmb/rmb" asm-generic: implement virt_xxx memory barriers x86: define __smp_xxx xtensa: define __smp_xxx tile: define __smp_xxx ...
2016-01-16Kconfig: remove HAVE_LATENCYTOP_SUPPORTWill Deacon
As illustrated by commit a3afe70b83fd ("[S390] latencytop s390 support."), HAVE_LATENCYTOP_SUPPORT is defined by an architecture to advertise an implementation of save_stack_trace_tsk. However, as of 9212ddb5eada ("stacktrace: provide save_stack_trace_tsk() weak alias") a dummy implementation is provided if STACKTRACE=y. Given that LATENCYTOP already depends on STACKTRACE_SUPPORT and selects STACKTRACE, we can remove HAVE_LATENCYTOP_SUPPORT altogether. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Helge Deller <deller@gmx.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching Pull livepatching updates from Jiri Kosina: - RO/NX attribute fixes for patch module relocations from Josh Poimboeuf. As part of this effort, module.c has been cleaned up as well and livepatching is piggy-backing on this cleanup. Rusty is OK with this whole lot going through livepatching tree. - symbol disambiguation support from Chris J Arges. That series is also Reviewed-by: Miroslav Benes <mbenes@suse.cz> but this came in only after I've alredy pushed out. Didn't want to rebase because of that, hence I am mentioning it here. - symbol lookup fix from Miroslav Benes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching: livepatch: Cleanup module page permission changes module: keep percpu symbols in module's symtab module: clean up RO/NX handling. module: use a structure to encapsulate layout. gcov: use within_module() helper. module: Use the same logic for setting and unsetting RO/NX livepatch: function,sympos scheme in livepatch sysfs directory livepatch: add sympos as disambiguator field to klp_reloc livepatch: add old_sympos as disambiguator field to klp_func
2016-01-12metag: define __smp_xxxMichael S. Tsirkin
This defines __smp_xxx barriers for metag, for use by virtualization. smp_xxx barriers are removed as they are defined correctly by asm-generic/barriers.h Note: as __smp_XX macros should not depend on CONFIG_SMP, they can not use the existing fence() macro since that is defined differently between SMP and !SMP. For this reason, this patch introduces a wrapper metag_fence() that doesn't depend on CONFIG_SMP. fence() is then defined using that, depending on CONFIG_SMP. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: James Hogan <james.hogan@imgtec.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-01-12metag: reuse asm-generic/barrier.hMichael S. Tsirkin
On metag dma_rmb, dma_wmb, smp_store_mb, read_barrier_depends, smp_read_barrier_depends, smp_store_release and smp_load_acquire match the asm-generic variants exactly. Drop the local definitions and pull in asm-generic/barrier.h instead. This is in preparation to refactoring this code area. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: James Hogan <james.hogan@imgtec.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2015-12-23metag: ftrace: Fix the comments for ftrace_modify_codeLi Bin
There is no need to worry about module and __init text disappearing case, because that ftrace has a module notifier that is called when a module is being unloaded and before the text goes away and this code grabs the ftrace_lock mutex and removes the module functions from the ftrace list, such that it will no longer do any modifications to that module's text, the update to make functions be traced or not is done under the ftrace_lock mutex as well. And by now, __init section codes should not been modified by ftrace, because it is black listed in recordmcount.c and ignored by ftrace. Link: http://lkml.kernel.org/r/1449367378-29430-3-git-send-email-huawei.libin@huawei.com Cc: linux-metag@vger.kernel.org Acked-by: James Hogan <james.hogan@imgtec.com> Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-12-04module: use a structure to encapsulate layout.Rusty Russell
Makes it easier to handle init vs core cleanly, though the change is fairly invasive across random architectures. It simplifies the rbtree code immediately, however, while keeping the core data together in the same cachline (now iff the rbtree code is enabled). Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-11-10Merge tag 'metag-for-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag arch updates from James Hogan: "A fix for 4KiB stacks with SMP, and a change of maintenance status to 'Odd Fixes'" * tag 'metag-for-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: MAINTAINERS: Change Meta arch port status to Odd Fixes metag: Turn irq_ctx_* macros into static inlines metag: SMP: Fix 4KiB stack setup on secondary CPUs
2015-11-09kmap_atomic_to_page() has no users, remove itNicolas Pitre
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused kmap_atomic_to_page"). Let's do it across the whole tree. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06Merge tag 'devicetree-for-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: "A fairly large (by DT standards) pull request this time with the majority being some overdue moving DT binding docs around to consolidate similar bindings. - DT binding doc consolidation moving similar bindings to common locations. The majority of these are display related which were scattered in video/, fb/, drm/, gpu/, and panel/ directories. - Add new config option, CONFIG_OF_ALL_DTBS, to enable building all dtbs in the tree for most arches with dts files (except powerpc for now). - OF_IRQ=n fixes for user enabled CONFIG_OF. - of_node_put ref counting fixes from Julia Lawall. - Common DT binding for wakeup-source and deprecation of all similar bindings. - DT binding for PXA LCD controller. - Allow ignoring failed PCI resource translations in order to ignore 64-bit addresses on non-LPAE 32-bit kernels. - Support setting the NUMA node from DT instead of only from parent device. - Couple of earlycon DT parsing fixes for address and options" * tag 'devicetree-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits) MAINTAINERS: update DT binding doc locations devicetree: add Sigma Designs vendor prefix of: simplify arch_find_n_match_cpu_physical_id() function Documentation: arm: Fixed typo in socfpga fpga mgr example Documentation: devicetree: fix reference to legacy wakeup properties Documentation: devicetree: standardize/consolidate on "wakeup-source" property drivers: of: removing assignment of 0 to static variable xtensa: enable building of all dtbs mips: enable building of all dtbs metag: enable building of all dtbs metag: use common make variables for dtb builds h8300: enable building of all dtbs arm64: enable building of all dtbs arm: enable building of all dtbs arc: enable building of all dtbs arc: use common make variables for dtb builds of: add config option to enable building of all dtbs of/fdt: fix error checking for earlycon address of/overlay: add missing of_node_put of/platform: add missing of_node_put ...
2015-10-27metag: enable building of all dtbsRob Herring
Enable building all dtb files when CONFIG_OF_ALL_DTBS is enabled. The dtbs are not really dependent on a platform being enabled or any other kernel config, so for testing coverage it is convenient to build all of the dtbs. This builds all dts files in the tree, not just targets listed. Signed-off-by: Rob Herring <robh@kernel.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2015-10-27metag: use common make variables for dtb buildsRob Herring
Use dtb-y and always make variables to build dtbs instead of explicit dtbs rule. This is in preparation to support building all dtbs. Signed-off-by: Rob Herring <robh@kernel.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2015-10-06Merge tag 'v4.3-rc4' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-15metag: Turn irq_ctx_* macros into static inlinesJames Hogan
The irq_ctx_init()/irq_ctx_exit() functions are only used for 4KiB stacks, otherwise they are implemented as an empty macro. To prevent future bit rottage due to the cpu argument not being type checked, convert the macros to empty static inline functions. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2015-09-15metag: SMP: Fix 4KiB stack setup on secondary CPUsJames Hogan
Back in early 2008, 4KiB stack support was added to reduce memory consumption on workloads with lots of threads, using a separate IRQ stack per CPU to alleviate stack pressure. However the SMP code added a year and a half later didn't set up the IRQ stack when bringing up secondary CPUs, resulting in a crash when SMP is configured with 4KiB stacks, as soon as the first interrupt arrived on a secondary CPU. Fix with calls to irq_ctx_exit()/irq_ctx_exit() when bringing up/down a CPU. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2015-09-09Merge tag 'metag-for-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag updates from James Hogan: "Metag architecture changes for v4.3. Just a couple of changes for v4.3-rc1. A preparatory IRQ patch to prepare for moving irq_data struct members, and a tweak to Documentation/features since Meta2 could support THP" * tag 'metag-for-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: Documentation/features/vm: Meta2 is capable of THP metag/irq: Use access helper irq_data_get_affinity_mask()
2015-09-08Merge tag 'trace-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing update from Steven Rostedt: "Mostly this is just clean ups and micro optimizations. The changes with more meat are: - Allowing the trace event filters to filter on CPU number and process ids - Two new markers for trace output latency were added (10 and 100 msec latencies) - Have tracing_thresh filter function profiling time I also worked on modifying the ring buffer code for some future work, and moved the adding of the timestamp around. One of my changes caused a regression, and since other changes were built on top of it and already tested, I had to operate a revert of that change. Instead of rebasing, this change set has the code that caused a regression as well as the code to revert that change without touching the other changes that were made on top of it" * tag 'trace-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated" tracing: Don't make assumptions about length of string on task rename tracing: Allow triggers to filter for CPU ids and process names ftrace: Format MCOUNT_ADDR address as type unsigned long tracing: Introduce two additional marks for delay ftrace: Fix function_graph duration spacing with 7-digits ftrace: add tracing_thresh to function profile tracing: Clean up stack tracing and fix fentry updates ring-buffer: Reorganize function locations ring-buffer: Make sure event has enough room for extend and padding ring-buffer: Get timestamp after event is allocated ring-buffer: Move the adding of the extended timestamp out of line ring-buffer: Add event descriptor to simplify passing data ftrace: correct the counter increment for trace_buffer data tracing: Fix for non-continuous cpu ids tracing: Prefer kcalloc over kzalloc with multiply
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
2015-08-12Merge branch 'locking/arch-atomic' into locking/core, because it's ready for ↵Ingo Molnar
upstream Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-07treewide: Fix typo compatability -> compatibilityLaurent Pinchart
Even though 'compatability' has a dedicated entry in the Wiktionary, it's listed as 'Mispelling of compatibility'. Fix it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> for the atomic_helper.c Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-08-03locking, arch: use WRITE_ONCE()/READ_ONCE() in ↵Andrey Konovalov
smp_store_release()/smp_load_acquire() Replace ACCESS_ONCE() macro in smp_store_release() and smp_load_acquire() with WRITE_ONCE() and READ_ONCE() on x86, arm, arm64, ia64, metag, mips, powerpc, s390, sparc and asm-generic since ACCESS_ONCE() does not work reliably on non-scalar types. WRITE_ONCE() and READ_ONCE() were introduced in the following commits: 230fa253df63 ("kernel: Provide READ_ONCE and ASSIGN_ONCE") 43239cbe79fc ("kernel: Change ASSIGN_ONCE(val, x) to WRITE_ONCE(x, val)") Signed-off-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Alexander Duyck <alexander.h.duyck@redhat.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@suse.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arch@vger.kernel.org Link: http://lkml.kernel.org/r/1438528264-714-1-git-send-email-andreyknvl@google.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-27atomic: Collapse all atomic_{set,clear}_mask definitionsPeter Zijlstra
Move the now generic definitions of atomic_{set,clear}_mask() into linux/atomic.h to avoid endless and pointless repetition. Also, provide an atomic_andnot() wrapper for those few archs that can implement that. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-27atomic: Provide atomic_{or,xor,and}Peter Zijlstra
Implement atomic logic ops -- atomic_{or,xor,and}. These will replace the atomic_{set,clear}_mask functions that are available on some archs. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-27metag: Provide atomic_{or,xor,and}Peter Zijlstra
2015-07-20ftrace: Format MCOUNT_ADDR address as type unsigned longMinfei Huang
Always we use type unsigned long to format the ip address, since the value of ip address is never the negative. This patch uses type unsigned long, instead of long, to format the ip address. The code is more clearly to be viewed by using type unsigned long, although it is correct by using either unsigned long or long. Link: http://lkml.kernel.org/r/1436694744-16747-1-git-send-email-mhuang@redhat.com Cc: Minfei Huang <mnfhuang@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-14metag/irq: Use access helper irq_data_get_affinity_mask()Jiang Liu
This is a preparatory patch for moving irq_data struct members. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2015-07-08Make asm/word-at-a-time.h available on all architecturesChris Metcalf
Added the x86 implementation of word-at-a-time to the generic version, which previously only supported big-endian. Omitted the x86-specific load_unaligned_zeropad(), which in any case is also not present for the existing BE-only implementation of a word-at-a-time, and is only used under CONFIG_DCACHE_WORD_ACCESS. Added as a "generic-y" to the Kbuilds of all architectures that didn't previously have it. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25mm/hugetlb: remove arch_prepare/release_hugepage from arch headersDominik Dingel
Nobody used these hooks so they were removed from common code, and can now be removed from the architectures. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-24mm/hugetlb: reduce arch dependent code about hugetlb_prefault_arch_hookZhang Zhen
Currently we have many duplicates in definitions of hugetlb_prefault_arch_hook. In all architectures this function is empty. Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/hugetlb: reduce arch dependent code about huge_pmd_unshareZhang Zhen
Currently we have many duplicates in definitions of huge_pmd_unshare. In all architectures this function just returns 0 when CONFIG_ARCH_WANT_HUGE_PMD_SHARE is N. This patch puts the default implementation in mm/hugetlb.c and lets these architectures use the common code. Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Rientjes <rientjes@google.com> Cc: James Yang <James.Yang@freescale.com> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24metag: use for_each_sg()Akinobu Mita
This replaces the plain loop over the sglist array with for_each_sg() macro which consists of sg_next() function calls. Since metag doesn't select ARCH_HAS_SG_CHAIN, it is not necessary to use for_each_sg() in order to loop over each sg element. But this can help find problems with drivers that do not properly initialize their sg tables when CONFIG_DEBUG_SG is enabled. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-22Merge branch 'x86-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 core updates from Ingo Molnar: "There were so many changes in the x86/asm, x86/apic and x86/mm topics in this cycle that the topical separation of -tip broke down somewhat - so the result is a more traditional architecture pull request, collected into the 'x86/core' topic. The topics were still maintained separately as far as possible, so bisectability and conceptual separation should still be pretty good - but there were a handful of merge points to avoid excessive dependencies (and conflicts) that would have been poorly tested in the end. The next cycle will hopefully be much more quiet (or at least will have fewer dependencies). The main changes in this cycle were: * x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas Gleixner) - This is the second and most intrusive part of changes to the x86 interrupt handling - full conversion to hierarchical interrupt domains: [IOAPIC domain] ----- | [MSI domain] --------[Remapping domain] ----- [ Vector domain ] | (optional) | [HPET MSI domain] ----- | | [DMAR domain] ----------------------------- | [Legacy domain] ----------------------------- This now reflects the actual hardware and allowed us to distangle the domain specific code from the underlying parent domain, which can be optional in the case of interrupt remapping. It's a clear separation of functionality and removes quite some duct tape constructs which plugged the remap code between ioapic/msi/hpet and the vector management. - Intel IOMMU IRQ remapping enhancements, to allow direct interrupt injection into guests (Feng Wu) * x86/asm changes: - Tons of cleanups and small speedups, micro-optimizations. This is in preparation to move a good chunk of the low level entry code from assembly to C code (Denys Vlasenko, Andy Lutomirski, Brian Gerst) - Moved all system entry related code to a new home under arch/x86/entry/ (Ingo Molnar) - Removal of the fragile and ugly CFI dwarf debuginfo annotations. Conversion to C will reintroduce many of them - but meanwhile they are only getting in the way, and the upstream kernel does not rely on them (Ingo Molnar) - NOP handling refinements. (Borislav Petkov) * x86/mm changes: - Big PAT and MTRR rework: making the code more robust and preparing to phase out exposing direct MTRR interfaces to drivers - in favor of using PAT driven interfaces (Toshi Kani, Luis R Rodriguez, Borislav Petkov) - New ioremap_wt()/set_memory_wt() interfaces to support Write-Through cached memory mappings. This is especially important for good performance on NVDIMM hardware (Toshi Kani) * x86/ras changes: - Add support for deferred errors on AMD (Aravind Gopalakrishnan) This is an important RAS feature which adds hardware support for poisoned data. That means roughly that the hardware marks data which it has detected as corrupted but wasn't able to correct, as poisoned data and raises an APIC interrupt to signal that in the form of a deferred error. It is the OS's responsibility then to take proper recovery action and thus prolonge system lifetime as far as possible. - Add support for Intel "Local MCE"s: upcoming CPUs will support CPU-local MCE interrupts, as opposed to the traditional system- wide broadcasted MCE interrupts (Ashok Raj) - Misc cleanups (Borislav Petkov) * x86/platform changes: - Intel Atom SoC updates ... and lots of other cleanups, fixlets and other changes - see the shortlog and the Git log for details" * 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits) x86/hpet: Use proper hpet device number for MSI allocation x86/hpet: Check for irq==0 when allocating hpet MSI interrupts x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail genirq: Prevent crash in irq_move_irq() genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain iommu, x86: Properly handle posted interrupts for IOMMU hotplug iommu, x86: Provide irq_remapping_cap() interface iommu, x86: Setup Posted-Interrupts capability for Intel iommu iommu, x86: Add cap_pi_support() to detect VT-d PI capability iommu, x86: Avoid migrating VT-d posted interrupts iommu, x86: Save the mode (posted or remapped) of an IRTE iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip iommu: dmar: Provide helper to copy shared irte fields iommu: dmar: Extend struct irte for VT-d Posted-Interrupts iommu: Add new member capability to struct irq_remap_ops x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry() ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
