path: root/arch/microblaze/Makefile
2011-01-03microblaze: trivial: Fix removed the part of lineMichal Simek
2010-10-22microblaze: Fix build with make 3.82Thomas Backlund
When running make headers_install_all on x86_64 and make 3.82 I hit this: arch/microblaze/Makefile:80: *** mixed implicit and normal rules. Stop. make: *** [headers_install_all] Error 2 So split the rules to satisfy make 3.82. Signed-off-by: Thomas Backlund <tmb@mandriva.org> Cc: Stable <stable@kernel.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-10-21microblaze: Add libgcc function directly to kernelMichal Simek
Replaced libgcc functions with asm optimized implementation. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-06-16fix typos concerning "hierarchy"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-01microblaze: Fix Makefile to delete build generated filesArun Bhanu
'make clean' does not to delete the following build generated file: arch/microblaze/boot/linux.bin.ub 'make mrproper' does not to delete the following build generated files: arch/microblaze/boot/simpleImage.* Fix the Makefile to delete these build generated files. See [1] for a discussion on why simpleImage.* files are deleted with 'make mrproper' and not with 'make clean'. [1] http://lkml.org/lkml/2010/3/12/96 Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Add a missing single quote to make 'make help' happyArun Bhanu
'make ARCH=microblaze help' fails with the following error due to a missing single quote. /bin/sh: -c: line 0: unexpected EOF while looking for matching `'' /bin/sh: -c: line 1: syntax error: unexpected end of file make: *** [help] Error 2 Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-03-11microblaze: Enable PCI, missing filesMichal Simek
There are two parts of changes. The first is just enable PCI in Makefiles and in Kconfig. The second is the rest of missing files. I didn't want to add it with previous patch because that patch is too big. Current Microblaze toolchain has problem with weak symbols that's why is necessary to apply this changes to be possible to compile pci support. Xilinx knows about this problem. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Core oprofile configs and hooksJohn Williams
Microblaze uses timer interrupt mode. Microblaze don't have any performance counter that's why we use just simple implementation. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-09-24microblaze: Support simpleImage.dts make targetMichal Simek
Instead of remembering to specify DTB= on the make commandline, this commit allows the much friendlier make simpleImage.<dts> where <dts>.dts is expected to be found in arch/microblaze/boot/dts/ The resulting vmlinux, with the compiled DTS linked in, will be copied to boot/simpleImage.<dts> This mirrors the same functionality as on PowerPC, albeit achieving it in a slightly different way. + strip simpleImage file The size of output file is very similar to linux.bin. vmlinux - full elf without fdt blob simpleImage.<dtb name>.unstrip - full elf with fdt blob simpleImage.<dtb name> - stripped elf with fdt blob Add symlink to generic system.dts in platform folder Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-09-22microblaze: Use correct kbuild variable KBUILD_CFLAGSJohn Williams
Fixes the bug introduced in 9552158573f847aa429334bb97995bb290bb4b0d Signed-off-by: John Williams <john.williams@petalogix.com>
2009-07-27microblaze: Makefile cleanupSam Ravnborg
Reviewed the Makefile on request by Michal and this is the resulting changes. o Use ':=' for assignmnet so we do not re-evaluate for each use o Use $(shell echo xxx) to remove "" o Replaced CFLAGS_KERNEL with KBUILD_CFLAGS The settings are equally relevant for modules and the linked kernel o Dropped LDFLAGS_BLOB - it is no longer used o Refactored assignmnets to libs-y and core-y o Use MMU for the MMU specific extension. "MMUEXT" was hurting my eyes and I did not wanted it spread to m68k Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-05-26microblaze_mmu_v2: MakefilesMichal Simek
2009-05-21microblaze: clean LDFLAGS to build kernelThomas Chou
Extra LDFLAGS from user space building may cause kernel failed to compile. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-04-23microblaze: Use CFLAGS_KERNEL instead of CFLAGSMichal Simek
2009-04-23microblaze: Correspond CONFIG...PCMP in Makefile/KconfigMichal Simek
Makefile contained different cpu config flag than is in Kconfig.auto in platform folder Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-03-27microblaze_v8: Makefiles for Microblaze cpuMichal Simek
Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
