[ Upstream commit 061d2c1d593076424c910cb1b64ecdb5c9a6923f ]
In case the start + cache size is more than the max int the
start overflows.
Prevent the same.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
[ Upstream commit 2e14f94cf4bc2f15ca5362e81ca3a987c79e3062 ]
To prepare for more fixes, move this to arch/microblaze/Makefile.
Otherwise, the same "... is ready" would be printed multiple times.
[ Upstream commit bafcc61d998c1ca18f556d92a0e95335ac68c7da ]
"make ARCH=microblaze help" mentions simpleImage.<dt>.unstrip,
but it is not a real Make target. It does not work because Makefile
assumes "system.unstrip" is the name of DT.
$ make ARCH=microblaze CROSS_COMPILE=microblaze-linux- simpleImage.system.unstrip
[ snip ]
make[1]: *** No rule to make target 'arch/microblaze/boot/dts/system.unstrip.dtb', needed by 'arch/microblaze/boot/dts/system.dtb'. Stop.
make: *** [Makefile;1060: arch/microblaze/boot/dts] Error 2
make: *** Waiting for unfinished jobs....
simpleImage.<dt> works like a phony target that generates multiple
images. Reflect the real behavior. I removed the DT directory path
information because it is already explained a few lines below.
While I am here, I deleted the redundant *_defconfig explanation.
The top-level Makefile caters to list available defconfig files:
mmu_defconfig - Build for mmu
nommu_defconfig - Build for nommu
[ Upstream commit ece97f3a5fb50cf5f98886fbc63c9665f2bb199d ]
simpleImage generation was broken for some time. This patch is fixing
steps how simpleImage.*.ub file is generated. Steps are objdump of
vmlinux and create .ub.
Also make sure that there is striped elf version with .strip suffix.
commit 30d6e0a4190d37740e9447e4e4815f06992dd8c3 upstream.
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d0cf385160c12abd109746cad1f13e3b3e8b50b8 upstream.
commit e98b9e37ae04562d52c96f46b3cf4c2e80222dc1 upstream.
commit db0fa0cb0157 "scatterlist: use sg_phys()" did replacements of
the form:
phys_addr_t phys = page_to_phys(sg_page(s));
phys_addr_t phys = sg_phys(s) & PAGE_MASK;
However, this breaks platforms where sizeof(phys_addr_t) >
sizeof(unsigned long). Revert for 4.3 and 4.4 to make room for a
combined helper in 4.5.
Cc: <stable@vger.kernel.org>
Cc: Jens Axboe <axboe@fb.com>
Fixes: db0fa0cb0157 ("scatterlist: use sg_phys()")
Suggested-by: Joerg Roedel <joro@8bytes.org>
Reported-by: Vitaly Lavrov <vel21ripn@gmail.com>
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused
kmap_atomic_to_page"). Let's do it across the whole tree.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
* acpi-init:
clocksource: cosmetic: Drop OF 'dependency' from symbols
clocksource / arm_arch_timer: Convert to ACPI probing
clocksource: Add new CLKSRC_{PROBE,ACPI} config symbols
clocksource / ACPI: Add probing infrastructure for ACPI-based clocksources
irqchip / GIC: Convert the GIC driver to ACPI probing
irqchip / ACPI: Add probing infrastructure for ACPI-based irqchips
ACPI: Add early device probing infrastructure
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
Seeing the 'of' characters in a symbol that is being called from
ACPI seems to freak out people. So let's do a bit of pointless
renaming so that these folks do feel at home.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead
of arch code").
Reading PCI bridge windows is not arch-specific in itself, but there is PCI
core code that doesn't work correctly if we read them too early. For
example, Hannes found this case on an ARM Freescale i.mx6 board:
pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window)
pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000]
pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000]
pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100]
The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs
0x204100 of space, and mem windows are megabyte-aligned.
Bus sizing can increase a bridge window size, but never *decrease* it (see
d65245c3297a ("PCI: don't shrink bridge resources")). Prior to
dff22d2054b5, ARM didn't read bridge windows at all, so the "original size"
was zero, and we assigned a 3MB window.
After dff22d2054b5, we read the bridge windows before sizing the bus. The
firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since
we never decrease the size, we kept 16MB even though we only needed 3MB.
But 16MB doesn't fit in the host bridge aperture, so we failed to assign
space for the window and the downstream devices.
I think this is a defect in the PCI core: we shouldn't rely on the firmware
to assign sensible windows.
Ray reported a similar problem, also on ARM, with Broadcom iProc.
Issues like this are too hard to fix right now, so revert dff22d2054b5.
Reported-by: Hannes <oe5hpm@gmail.com>
Reported-by: Ray Jui <rjui@broadcom.com>
Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com
Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Merge third patch-bomb from Andrew Morton:
- even more of the rest of MM
- lib/ updates
- checkpatch updates
- small changes to a few scruffy filesystems
- kmod fixes/cleanups
- kexec updates
- a dma-mapping cleanup series from hch
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits)
dma-mapping: consolidate dma_set_mask
dma-mapping: consolidate dma_supported
dma-mapping: cosolidate dma_mapping_error
dma-mapping: consolidate dma_{alloc,free}_noncoherent
dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}
mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()
mm: make sure all file VMAs have ->vm_ops set
mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()
mm: mark most vm_operations_struct const
namei: fix warning while make xmldocs caused by namei.c
ipc: convert invalid scenarios to use WARN_ON
zlib_deflate/deftree: remove bi_reverse()
lib/decompress_unlzma: Do a NULL check for pointer
lib/decompressors: use real out buf size for gunzip with kernel
fs/affs: make root lookup from blkdev logical size
sysctl: fix int -> unsigned long assignments in INT_MIN case
kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo
kexec: align crash_notes allocation to make it be inside one physical page
kexec: remove unnecessary test in kimage_alloc_crash_control_pages()
kexec: split kexec_load syscall from kexec core code
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Most architectures just call into ->dma_supported, but some also return 1
if the method is not present, or 0 if no dma ops are present (although
that should never happeb). Consolidate this more broad version into
common code.
Also fix h8300 which inorrectly always returned 0, which would have been
a problem if it's dma_set_mask implementation wasn't a similarly buggy
noop.
As a few architectures have much more elaborate implementations, we
still allow for arch overrides.
Currently there are three valid implementations of dma_mapping_error:
(1) call ->mapping_error
(2) check for a hardcoded error code
(3) always return 0
This patch provides a common implementation that calls ->mapping_error
if present, then checks for DMA_ERROR_CODE if defined or otherwise
returns 0.
Most architectures do not support non-coherent allocations and either
define dma_{alloc,free}_noncoherent to their coherent versions or stub
them out.
Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips
implements them directly.
This patch moves the Openrisc version to common code, and handles the
DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance.
Note that actual non-coherent allocations require a dma_cache_sync
implementation, so if non-coherent allocations didn't work on
an architecture before this patch they still won't work after it.
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
The linux/audit.h header uses EM_MICROBLAZE in order to define
AUDIT_ARCH_MICROBLAZE, but it's only available in the microblaze
asm headers. Move it to the common elf-em.h header so that the
define can be used on non-microblaze systems. Otherwise we get
build errors that EM_MICROBLAZE isn't defined when we try to use
the AUDIT_ARCH_MICROBLAZE symbol.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing update from Steven Rostedt:
"Mostly this is just clean ups and micro optimizations.
The changes with more meat are:
- Allowing the trace event filters to filter on CPU number and
process ids
- Two new markers for trace output latency were added (10 and 100
msec latencies)
- Have tracing_thresh filter function profiling time
I also worked on modifying the ring buffer code for some future work,
and moved the adding of the timestamp around. One of my changes
caused a regression, and since other changes were built on top of it
and already tested, I had to operate a revert of that change. Instead
of rebasing, this change set has the code that caused a regression as
well as the code to revert that change without touching the other
changes that were made on top of it"
* tag 'trace-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated"
tracing: Don't make assumptions about length of string on task rename
tracing: Allow triggers to filter for CPU ids and process names
ftrace: Format MCOUNT_ADDR address as type unsigned long
tracing: Introduce two additional marks for delay
ftrace: Fix function_graph duration spacing with 7-digits
ftrace: add tracing_thresh to function profile
tracing: Clean up stack tracing and fix fentry updates
ring-buffer: Reorganize function locations
ring-buffer: Make sure event has enough room for extend and padding
ring-buffer: Move the adding of the extended timestamp out of line
ring-buffer: Add event descriptor to simplify passing data
ftrace: correct the counter increment for trace_buffer data
tracing: Fix for non-continuous cpu ids
tracing: Prefer kcalloc over kzalloc with multiply
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
Pull timer updates from Thomas Gleixner:
"Rather large, but nothing exiting:
- new range check for settimeofday() to prevent that boot time
becomes negative.
- fix for file time rounding
- a few simplifications of the hrtimer code
- fix for the proc/timerlist code so the output of clock realtime
timers is accurate
- more y2038 work
- tree wide conversion of clockevent drivers to the new callbacks"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (88 commits)
hrtimer: Handle failure of tick_init_highres() gracefully
hrtimer: Unconfuse switch_hrtimer_base() a bit
hrtimer: Simplify get_target_base() by returning current base
hrtimer: Drop return code of hrtimer_switch_to_hres()
time: Introduce timespec64_to_jiffies()/jiffies_to_timespec64()
time: Introduce current_kernel_time64()
time: Introduce struct itimerspec64
time: Add the common weak version of update_persistent_clock()
time: Always make sure wall_to_monotonic isn't positive
time: Fix nanosecond file time rounding in timespec_trunc()
timer_list: Add the base offset so remaining nsecs are accurate for non monotonic timers
cris/time: Migrate to new 'set-state' interface
kernel: broadcast-hrtimer: Migrate to new 'set-state' interface
xtensa/time: Migrate to new 'set-state' interface
unicore/time: Migrate to new 'set-state' interface
um/time: Migrate to new 'set-state' interface
sparc/time: Migrate to new 'set-state' interface
sh/localtimer: Migrate to new 'set-state' interface
score/time: Migrate to new 'set-state' interface
s390/time: Migrate to new 'set-state' interface
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.3 merge window:
Enumeration:
- Allocate ATS struct during enumeration (Bjorn Helgaas)
- Embed ATS info directly into struct pci_dev (Bjorn Helgaas)
- Reduce size of ATS structure elements (Bjorn Helgaas)
- Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas)
- iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas)
- Move MPS configuration check to pci_configure_device() (Bjorn Helgaas)
- Set MPS to match upstream bridge (Keith Busch)
- ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri)
- Add pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi)
Resource management:
- Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi)
PCI device hotplug:
- pciehp: Remove unused interrupt events (Bjorn Helgaas)
- pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas)
- pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson)
- pciehp: Simplify pcie_poll_cmd() (Yijing Wang)
- Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang)
- Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang)
- Hold pci_slot_mutex while searching bus->slots list (Yijing Wang)
Power management:
- Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui)
Virtualization:
- Add ACS quirks for Intel I219-LM/V (Alex Williamson)
- Restore ACS configuration as part of pci_restore_state() (Alexander Duyck)
MSI:
- Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu)
- Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu)
- ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi)
- Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi)
Generic host bridge driver:
- Remove dependency on ARM-specific struct hw_pci (Jayachandran C)
- Build setup-irq.o for arm64 (Jayachandran C)
- Add arm64 support (Jayachandran C)
APM X-Gene host bridge driver:
- Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang)
- Add support for a 64-bit prefetchable memory window (Duc Dang)
- Drop owner assignment from platform_driver (Krzysztof Kozlowski)
Broadcom iProc host bridge driver:
- Allow BCMA bus driver to be built as module (Hauke Mehrtens)
- Delete unnecessary checks before phy calls (Markus Elfring)
- Add arm64 support (Ray Jui)
Synopsys DesignWare host bridge driver:
- Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri)
TI DRA7xx host bridge driver:
- Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I)
- Add PM support (Kishon Vijay Abraham I)
- Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I)
- Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I)
Xilinx AXI host bridge driver:
- Check for MSI interrupt flag before handling as INTx (Russell Joyce)
Miscellaneous:
- Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa)
- Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas)
- Fix generic NCR 53c810 class code quirk (Bjorn Helgaas)
- Fix TI816X class code quirk (Bjorn Helgaas)
- Remove unused "pci_probe" flags (Bjorn Helgaas)
- Host bridge driver code simplifications (Fabio Estevam)
- Add dev_flags bit to access VPD through function 0 (Mark Rustad)
- Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad)
- Kill off set_irq_flags() usage (Rob Herring)
- Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar)
- Clean up pci_find_capability() (Wei Yang)"
* tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits)
PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI
PCI: Set MPS to match upstream bridge
PCI: Move MPS configuration check to pci_configure_device()
PCI: Drop references acquired by of_parse_phandle()
PCI/MSI: Remove unused pcibios_msi_controller() hook
PCI: Add pci_scan_root_bus_msi()
ARM/PCI: Replace panic with WARN messages on failures
PCI: generic: Add arm64 support
PCI: Build setup-irq.o for arm64
PCI: generic: Remove dependency on ARM-specific struct hw_pci
PCI: imx6: Simplify a trivial if-return sequence
PCI: spear: Use BUG_ON() instead of condition followed by BUG()
PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
PCI: Remove pci_ats_enabled()
PCI: Stop caching ATS Invalidate Queue Depth
PCI: Move ATS declarations to linux/pci.h so they're all together
PCI: Clean up ATS error handling
PCI: Use pci_physfn() rather than looking up physfn by hand
Coccinelle cleanup to replace open coded sg to physical address
translations. This is in preparation for introducing scatterlists that
reference __pfn_t.
// sg_phys.cocci: convert usage page_to_phys(sg_page(sg)) to sg_phys(sg)
// usage: make coccicheck COCCI=sg_phys.cocci MODE=patch
virtual patch
struct scatterlist *sg;
- page_to_phys(sg_page(sg)) + sg->offset
+ sg_phys(sg)
+ sg_phys(sg) & PAGE_MASK
Signed-off-by: Jens Axboe <axboe@fb.com>
Migrate microblaze driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
We weren't doing anything in ->set_mode(RESUME or ONESHOT) and so
tick_resume() set_state_oneshot() aren't implemented.
Cc: Richard Cochran <richardcochran@gmail.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
The IRQCHIP_DECLARE macro migrated to 'include/linux/irqchip.h'.
See commit 91e20b5040c67c51aad88cf87db4305c5bd7f79d
("irqchip: Move IRQCHIP_DECLARE macro to include/linux/irqchip.h").
This patch removes the inclusion of private header 'drivers/irqchip/irqchip.h'
and replaces it with the inclusion of 'include/linux/irqchip.h'.
Signed-off-by: Joel Porquet <joel@porquet.org>
Cc: vgupta@synopsys.com
Cc: monstr@monstr.eu
Cc: ralf@linux-mips.org
Cc: jason@lakedaemon.net
Link: http://lkml.kernel.org/r/12384045.pHnZrl3CFY@joel-zenbook
When we scan a PCI bus, we read PCI-PCI bridge window registers with
pci_read_bridge_bases() so we can validate the resource hierarchy. Most
architectures call pci_read_bridge_bases() from pcibios_fixup_bus(), but
PCI-PCI bridges are not arch-specific, so this doesn't need to be in
arch-specific code.
Call pci_read_bridge_bases() directly from the PCI core instead of from
arch code.
For alpha and mips, we now call pci_read_bridge_bases() always; previously
we only called it if PCI_PROBE_ONLY was set.
[bhelgaas: changelog]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
CC: Ralf Baechle <ralf@linux-mips.org>
CC: James E.J. Bottomley <jejb@parisc-linux.org>
CC: Michael Ellerman <mpe@ellerman.id.au>
CC: Bjorn Helgaas <bhelgaas@google.com>
CC: Richard Henderson <rth@twiddle.net>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: David Howells <dhowells@redhat.com>
CC: Russell King <linux@arm.linux.org.uk>
CC: Tony Luck <tony.luck@intel.com>
CC: David S. Miller <davem@davemloft.net>
CC: Ingo Molnar <mingo@redhat.com>
CC: Guenter Roeck <linux@roeck-us.net>
CC: Michal Simek <monstr@monstr.eu>
CC: Chris Zankel <chris@zankel.net>
Always we use type unsigned long to format the ip address, since the
value of ip address is never the negative.
This patch uses type unsigned long, instead of long, to format the ip
address. The code is more clearly to be viewed by using type unsigned
long, although it is correct by using either unsigned long or long.
Link: http://lkml.kernel.org/r/1436694744-16747-1-git-send-email-mhuang@redhat.com
Cc: Minfei Huang <mnfhuang@gmail.com>
Cc: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Minfei Huang <mnfhuang@gmail.com>
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Added the x86 implementation of word-at-a-time to the
generic version, which previously only supported big-endian.
Omitted the x86-specific load_unaligned_zeropad(), which in
any case is also not present for the existing BE-only
implementation of a word-at-a-time, and is only used under
CONFIG_DCACHE_WORD_ACCESS.
Added as a "generic-y" to the Kbuilds of all architectures
that didn't previously have it.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
CRIU is recreating the process memory layout by remapping the checkpointee
memory area on top of the current process (criu). This includes remapping
the vDSO to the place it has at checkpoint time.
However some architectures like powerpc are keeping a reference to the
vDSO base address to build the signal return stack frame by calling the
vDSO sigreturn service. So once the vDSO has been moved, this reference
is no more valid and the signal frame built later are not usable.
This patch serie is introducing a new mm hook framework, and a new
arch_remap hook which is called when mremap is done and the mm lock still
hold. The next patch is adding the vDSO remap and unmap tracking to the
powerpc architecture.
This patch (of 3):
This patch introduces a new set of header file to manage mm hooks:
- per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h)
- a generic header (include/linux/mm-arch-hooks.h)
The architecture which need to overwrite a hook as to redefine it in its
header file, while architecture which doesn't need have nothing to do.
The default hooks are defined in the generic header and are used in the
case the architecture is not defining it.
In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should
be moved here.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Pull Microblaze updates from Michal Simek:
- some PCI fixups
- add new MB versions
- sparse fixups
* tag 'microblaze-4.2-rc1' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze/PCI: Remove unnecessary struct pci_dev declaration
microblaze/PCI: Remove unnecessary pci_bus_find_capability() declaration
microblaze/PCI: Remove unused declarations
microblaze: Label local function static
microblaze: Add missing release version code
"PCI changes for the v4.2 merge window:
Enumeration
- Move pci_ari_enabled() to global header (Alex Williamson)
- Account for ARI in _PRT lookups (Alex Williamson)
- Remove unused pci_scan_bus_parented() (Yijing Wang)
Resource management
- Use host bridge _CRS info on systems with >32 bit addressing (Bjorn Helgaas)
- Use host bridge _CRS info on Foxconn K8M890-8237A (Bjorn Helgaas)
- Fix pci_address_to_pio() conversion of CPU address to I/O port (Zhichang Yuan)
- Add pci_bus_addr_t (Yinghai Lu)
PCI device hotplug
- Wait for pciehp command completion where necessary (Alex Williamson)
- Drop pointless ACPI-based "slot detection" check (Rafael J. Wysocki)
- Check ignore_hotplug for all downstream devices (Rafael J. Wysocki)
- Propagate the "ignore hotplug" setting to parent (Rafael J. Wysocki)
- Inline pciehp "handle event" functions into the ISR (Bjorn Helgaas)
- Clean up pciehp debug logging (Bjorn Helgaas)
Power management
- Remove redundant PCIe port type checking (Yijing Wang)
- Add dev->has_secondary_link to track downstream PCIe links (Yijing Wang)
- Use dev->has_secondary_link to find downstream links for ASPM (Yijing Wang)
- Drop __pci_disable_link_state() useless "force" parameter (Bjorn Helgaas)
- Simplify Clock Power Management setting (Bjorn Helgaas)
Virtualization
- Add ACS quirks for Intel 9-series PCH root ports (Alex Williamson)
- Add function 1 DMA alias quirk for Marvell 9120 (Sakari Ailus)
MSI
- Disable MSI at enumeration even if kernel doesn't support MSI (Michael S. Tsirkin)
- Remove unused pci_msi_off() (Bjorn Helgaas)
- Rename msi_set_enable(), msix_clear_and_set_ctrl() (Michael S. Tsirkin)
- Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl() (Michael S. Tsirkin)
- Drop pci_msi_off() calls during probe (Michael S. Tsirkin)
- Add APM X-Gene v1 PCIe MSI/MSIX termination driver (Duc Dang)
- Add APM X-Gene PCIe MSI DTS nodes (Duc Dang)
- Disable Configuration Request Retry Status for v1 silicon (Duc Dang)
- Allow config access to Root Port even when link is down (Duc Dang)
- Allow override of device tree IRQ mapping function (Hauke Mehrtens)
- Add BCMA PCIe driver (Hauke Mehrtens)
- Directly add PCI resources (Hauke Mehrtens)
- Free resource list after registration (Hauke Mehrtens)
Freescale i.MX6 host bridge driver
- Add speed change timeout message (Troy Kisky)
- Rename imx6_pcie_start_link() to imx6_pcie_establish_link() (Bjorn Helgaas)
Freescale Layerscape host bridge driver
- Use dw_pcie_link_up() consistently (Bjorn Helgaas)
- Factor out ls_pcie_establish_link() (Bjorn Helgaas)
Marvell MVEBU host bridge driver
- Remove mvebu_pcie_scan_bus() (Yijing Wang)
NVIDIA Tegra host bridge driver
- Remove tegra_pcie_scan_bus() (Yijing Wang)
- Consolidate outbound iATU programming functions (Jisheng Zhang)
- Use iATU0 for cfg and IO, iATU1 for MEM (Jisheng Zhang)
- Add support for x8 links (Zhou Wang)
- Wait for link to come up with consistent style (Bjorn Helgaas)
- Use pci_scan_root_bus() for simplicity (Yijing Wang)
Miscellaneous
- Include <linux/pci.h>, not <asm/pci.h> (Bjorn Helgaas)
- Remove unnecessary #includes of <asm/pci.h> (Bjorn Helgaas)
- Remove unused pcibios_select_root() (again) (Bjorn Helgaas)
- Remove unused pci_dma_burst_advice() (Bjorn Helgaas)
- xen/pcifront: Don't use deprecated function pci_scan_bus_parented() (Arnd Bergmann)"
* tag 'pci-v4.2-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits)
PCI: pciehp: Inline the "handle event" functions into the ISR
PCI: pciehp: Rename queue_interrupt_event() to pciehp_queue_interrupt_event()
PCI: pciehp: Make queue_interrupt_event() void
PCI: xgene: Allow config access to Root Port even when link is down
PCI: xgene: Disable Configuration Request Retry Status for v1 silicon
PCI: pciehp: Clean up debug logging
x86/PCI: Use host bridge _CRS info on systems with >32 bit addressing
PCI: imx6: Add #define PCIE_RC_LCSR
PCI: imx6: Use "u32", not "uint32_t"
PCI: Remove unused pci_scan_bus_parented()
PCI: imx6: Add speed change timeout message
PCI/ASPM: Simplify Clock Power Management setting
PCI: designware: Wait for link to come up with consistent style
PCI: layerscape: Factor out ls_pcie_establish_link()
PCI: layerscape: Use dw_pcie_link_up() consistently
PCI: dra7xx: Use dw_pcie_link_up() consistently
x86/PCI: Use host bridge _CRS info on Foxconn K8M890-8237A
PCI: pciehp: Wait for hotplug command completion where necessary
PCI: Remove unused pci_dma_burst_advice()
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
pci_dma_burst_advice() was added by e24c2d963a60 ("[PATCH] PCI: DMA
bursting advice") but apparently never used. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu> # microblaze
a6c140969b46 ("Delete pcibios_select_root") removed pcibios_select_root().
But a7db50405216 ("PCI: remove pcibios_scan_all_fns()") added a few copies
back, probably with some incorrect merge conflict resolutions.
Remove the still-unused pcibios_select_root() definitions.
All users of arch/microblaze/include/asm/pci.h get it by including
include/linux/pci.h, which in turn includes <asm/pci.h> after it declares
struct pci_dev.
The forward declaration here is unnecessary, so remove it.
pci_bus_find_capability() is declared in include/linux/pci.h.
Remove the pci_bus_find_capability() declaration from
arch/microblaze/include/asm/pci.h.
The following declarations were copied from powerpc but are unused on
microblaze:
struct pci_controller *init_phb_dynamic(struct device_node *dn)
int remove_phb_dynamic(struct pci_controller *phb)
struct pci_dev *of_create_pci_dev(struct device_node *node, ...)
void of_scan_pci_bridge(struct device_node *node, ...)
void of_scan_bus(struct device_node *node, struct pci_bus *bus)
void of_rescan_bus(struct device_node *node, struct pci_bus *bus)
Remove them.
Warnings found by sparse:
arch/microblaze/kernel/dma.c:157:5: warning: symbol
'dma_direct_mmap_coherent' was not declared. Should it be static?
arch/microblaze/kernel/kgdb.c:35:14: warning: symbol 'pvr' was not
Add missing release version code for v9.4 and v9.5.
Replace all calls to ioremap_writethrough() with ioremap_wt().
Remove ioremap_writethrough() too.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Elliott@hp.com
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Cc: konrad.wilk@oracle.com
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-nvdimm@lists.01.org
Cc: stefan.bader@canonical.com
Cc: yigal@plexistor.com
Link: http://lkml.kernel.org/r/1433436928-31903-10-git-send-email-bp@alien8.de
Add ioremap_wt() to all arch-specific asm/io.h headers which
define ioremap_wc() locally. These headers do not include
<asm-generic/iomap.h>. Some of them include <asm-generic/io.h>,
but ioremap_wt() is defined for consistency since they define
all ioremap_xxx locally.
In all architectures without Write-Through support, ioremap_wt()
is defined indentical to ioremap_nocache().
frv and m68k already have ioremap_writethrough(). On those we
add ioremap_wt() indetical to ioremap_writethrough() and defines
ARCH_HAS_IOREMAP_WT in both architectures.
The ioremap_wt() interface is exported to drivers.
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Link: http://lkml.kernel.org/r/1433436928-31903-9-git-send-email-bp@alien8.de
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
the handler
Introduce faulthandler_disabled() and use it to check for irq context and
disabled pagefaults (via pagefault_disable()) in the pagefault handlers.
Please note that we keep the in_atomic() checks in place - to detect
whether in irq context (in which case preemption is always properly
disabled).
In contrast, preempt_disable() should never be used to disable pagefaults.
With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt
counter, and therefore the result of in_atomic() differs.
We validate that condition by using might_fault() checks when calling
might_sleep().
Therefore, add a comment to faulthandler_disabled(), describing why this
is needed.
faulthandler_disabled() and pagefault_disable() are defined in
linux/uaccess.h, so let's properly add that include to all relevant files.
This patch is based on a patch from Thomas Gleixner.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com
The existing code relies on pagefault_disable() implicitly disabling
preemption, so that no schedule will happen between kmap_atomic() and
kunmap_atomic().
Let's make this explicit, to prepare for pagefault_disable() not
touching preemption anymore.
Cc: hocko@suse.cz
Cc: mst@redhat.com
Link: http://lkml.kernel.org/r/1431359540-32227-5-git-send-email-dahi@linux.vnet.ibm.com
enabled
In general, non-atomic variants of user access functions must not sleep
if pagefaults are disabled.
Let's update all relevant comments in uaccess code. This also reflects
the might_sleep() checks in might_fault().
Cc: hocko@suse.cz
Cc: mst@redhat.com
Link: http://lkml.kernel.org/r/1431359540-32227-4-git-send-email-dahi@linux.vnet.ibm.com
