arch/avr32/include/asm/Kbuild
arch/c6x/include/asm/Kbuild
arch/cris/include/asm/Kbuild
arch/ia64/include/asm/Kbuild
arch/mips/include/asm/Kbuild
arch/openrisc/include/asm/Kbuild
arch/powerpc/include/asm/Kbuild
arch/score/include/asm/Kbuild
Change-Id: I6800e3f03dbc40e94de1495459dec4b29df4474e
(cherry picked from commit e3fec2f74f7f90d2149a24243a4d040caabe6f30)
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
All arches do essentially the same thing now for
early_init_dt_setup_initrd_arch, so it can now be removed.
arch/arm/mm/init.c
arch/c6x/kernel/devicetree.c
arch/powerpc/kernel/prom.c
(cherry picked from commit 29eb45a9ab4839a1e9cef2bcf369b918c9c4fcad)
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: x86@kernel.org
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
Change-Id: I84b59cec16fa7e96fa8ff3de04aa959f7039a7a9
Create a weak version of early_init_dt_add_memory_arch which uses
memblock. This will unify all architectures except ones with custom
memory bank structs.
arch/openrisc/kernel/prom.c
(cherry picked from commit 068f6310b965d67d57f89ebf4c539e5933754366)
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: microblaze-uclinux@itee.uq.edu.au
Cc: linux@lists.openrisc.net
Cc: devicetree@vger.kernel.org
Change-Id: I8f3bd8d9d0816666cf90363e16f596b365db4632
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
(cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf)
arch/h8300/include/asm/Kbuild
include/linux/preempt.h
Change-Id: I544914d3c23cc50da658296a34f9f2796854e259
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
Most architectures use the same implementation. Collapse the common ones
into a single weak function that can be overridden.
(cherry picked from commit a1727da599ad030ccaf4073473fd235c8ee28219)
Change-Id: I5cfcac67b98407f8e4c4dcb89829f2a8e0d1b88b
Signed-off-by: Grant Likely <grant.likely@linaro.org>
On some PAE architectures, the entire range of physical memory could reside
outside the 32-bit limit. These systems need the ability to specify the
initrd location using 64-bit numbers.
This patch globally modifies the early_init_dt_setup_initrd_arch() function to
use 64-bit numbers instead of the current unsigned long.
There has been quite a bit of debate about whether to use u64 or phys_addr_t.
It was concluded to stick to u64 to be consistent with rest of the device
tree code. As summarized by Geert, "The address to load the initrd is decided
by the bootloader/user and set at that point later in time. The dtb should not
be tied to the kernel you are booting"
More details on the discussion can be found here:
https://lkml.org/lkml/2013/6/20/690
https://lkml.org/lkml/2012/9/13/544
(cherry picked from commit 374d5c9964c10373ba39bbe934f4262eb87d7114)
Change-Id: Iab36378e1de4e6c2cb07a3b88aeb5ff4afbe535b
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
(cherry picked from commit 407c454cb0ac6e68ca66974da787a71118cfef84)
arch/arc/mm/fault.c
arch/arm64/mm/fault.c
arch/metag/mm/fault.c
arch/parisc/mm/fault.c
Change-Id: Iee53942737627be8dd8e2e325b5ba87fe85d6814
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/266410
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
commit dfa9771a7c4784bafd0673bc7abcee3813088b77 upstream.
Fix inadvertent breakage in the clone syscall ABI for Microblaze that
was introduced in commit f3268edbe6fe ("microblaze: switch to generic
fork/vfork/clone").
The Microblaze syscall ABI for clone takes the parent tid address in the
4th argument; the third argument slot is used for the stack size. The
incorrectly-used CLONE_BACKWARDS type assigned parent tid to the 3rd
slot.
This commit restores the original ABI so that existing userspace libc
code will work correctly.
All kernel versions from v3.8-rc1 were affected.
Using static inline functions ensure proper type checking
which also remove compilation warning for no MMU
Compilation warning:
arch/microblaze/include/asm/cacheflush.h: warning: 'addr'
may be used uninitialized in this function [-Wmaybe-uninitialized]
arch/microblaze/include/asm/uaccess.h:101:3:
warning: cast removes address space of expression
arch/microblaze/include/asm/uaccess.h:107:2:
futex_atomic_cmpxchg_inatomic exchanged if the values were
unequal rather than equal. This caused incorrect behavior
of robust futexes.
Signed-off-by: Kirk Meyer <kirk.meyer@sencore.com>
We are going to move to asm-generic/io.h but
let's fix compilation warnings first for 3.10.
Warning message:
arch/microblaze/include/asm/io.h:126:26: warning: cast to
pointer from integer of different size [-Wint-to-pointer-cast]
#define inb(port) readb((u8 *)((port)))
arch/microblaze/kernel/cpu/cache.c:148:2: warning:
'temp' is used uninitialized in this function [-Wuninitialized]
Pull microblaze updates from Michal Simek.
* 'next' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Enable IRQ in arch_cpu_idle
microblaze: Fix uaccess_ok macro
microblaze: Add support for new cpu versions and target architecture
microblaze: Do not select OPT_LIB_ASM by default
microblaze: Fix initrd support
microblaze: Do not use r6 in head.S
microblaze: pci: Remove duplicated header
microblaze: Set the default irq_domain
microblaze: pci: Remove duplicated include from pci-common.c
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Microblaze requires to enable IRQ in cpu_idle loop.
It should be the part of this patch:
"microblaze: Use generic idle loop"
(sha1: e962bb9e9cf73b8c8893c95903e791dd5ec19fb4)
Fix access_ok macro no to permit
case where user will try to access
the last address space which is equal
to segment address.
Example:
segment addr = 0xbfff ffff
address = 0xbfff fff0
size = 0x10
Current wrong implementation
0xbfff ffff >= (0xbfff fff0 | 0x10 | (0xbfff fff0 + 0x10))
0xbfff ffff >= (0xbfff fff0 | 0xc000 0000)
0xbfff ffff >= 0xf000 0000
return 0 which is access failed even the combination is valid.
because get_fs().seq returns the last valid address.
This patch fix this problem.
Size equals to zero is valid access.
Update PVR values based on reference manual.
This option is valid only for BE systems.
Initrd/ramdisk support has been never validated.
r6 stores pointer to ramdisk and shouldn't
be used before it is passed to machine_early_init.
Remove duplicated header.
Register the irq_domain created during initialization as the default so
that device drivers can pass NULL to irq_create_mapping and get a
virtual irq to pass to request_irq.
Signed-off-by: Dan Christensen <opello@opello.org>
Remove duplicated include.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull arch/metag update from James Hogan:
- Various fixes for the interrupting perf counter handling in metag's
perf backend.
- Add OProfile support based on perf.
- Sets up cache partitions for SMP so bootloader doesn't have to.
- Patch from Paul Bolle to remove ARCH_POPULATES_NODE_MAP again
(touches microblaze too).
- Add TLS pointer regset to metag ptrace api.
- Add exported metag DSP extended context handling header <asm/ech.h>.
- Increase defconfig log buffer size to 128KiB.
- Various fixes, typos, missing exports.
* tag 'metag-for-v3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
metag: defconfigs: increase log buffer 8KiB => 128KiB
metag: avoid unnecessary builtin dtb rebuilds
metag: add exported <asm/ech.h> for extended context handling
metag: export _metag_da_present and cpu_2_hwthread_id
metag: ptrace: Implement NT_METAG_TLS
memblock: Kill ARCH_POPULATES_NODE_MAP once more
metag: cachepart: fix get_global_dcache_size() typo
metag: cachepart: take into account small cache bits
metag: smp: copy cache partition and enable GCOn
metag: OProfile support
metag: perf: prepare for use by oprofile
metag: perf: don't reset TXTACTCYC
metag: perf: use hard_processor_id() to get thread
metag: perf: fix frequency sampling (dynamic period)
metag: perf: add missing prev_count updates
metag: perf: fixes for interrupting perf counters
metag: perf: fix wrap handling in delta calculation
metag: perf: fix core internal / perf channel mux
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
The early console implementations are the same all over the place. Move
the print function to kernel/printk and get rid of the copies.
[akpm@linux-foundation.org: arch/mips/kernel/early_printk.c needs kernel.h for va_list]
[paul.gortmaker@windriver.com: sh4: make the bios early console support depend on EARLY_PRINTK]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Richard Weinberger <richard@nod.at>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Use helper function free_highmem_page() to free highmem pages into
the buddy system.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Use common help functions to free reserved pages.
All archs are converted over. Remove the config switch and the
fallback code.
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code
and all driver code has been switch to depend on GPIOLIB. It is thus
safe to have GENERIC_GPIO removed.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
The microblaze idle loop provides a polling and a non polling version,
which are suprisingly both polling, just with slightly different
instrumentation. Remove them and use the generic poller.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130321215234.687590459@linutronix.de
Move it to a common place. Preparatory patch for implementing
set/clear for the idle need_resched poll implementation.
Link: http://lkml.kernel.org/r/20130321215233.446034505@linutronix.de
enable/disable_hlt() does not need to be exported and can be killed on
architectures which do not use it at all.
Link: http://lkml.kernel.org/r/20130321215233.377959540@linutronix.de
The Kconfig symbol ARCH_POPULATES_NODE_MAP was killed in v3.3. After
that it popped up again in microblaze and metag. Nobody noticed,
probably because these Kconfig symbols are entirely unused and these
architectures both select HAVE_MEMBLOCK_NODE_MAP. Anyhow, these two
entries can also be killed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Michal Simek <monstr@monstr.eu>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS")
I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where
needed. I am not sure what I was thinking. Instead, just directly
select VIRT_TO_BUS where it is needed.
take them to asm/linkage.h, with default in linux/linkage.h
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures
that already provide virt_to_bus().
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: <linux-arch@vger.kernel.org>
Pull microblaze update from Michal Simek:
"Microblaze changes.
After my discussion with Arnd I have also added there asm-generic io
patch which is Acked by him and Geert."
asm-generic: io: Fix ioread16/32be and iowrite16/32be
microblaze: Do not use module.h in files which are not modules
microblaze: Fix coding style issues
microblaze: Add missing return from debugfs_tlb
microblaze: Makefile clean
microblaze: Add .gitignore entries for auto-generated files
microblaze: Fix strncpy_from_user macro
Pull ACPI and power management fixes from Rafael Wysocki:
- Fixes for blackfin and microblaze build problems introduced by the
removal of global pm_idle. From Lars-Peter Clausen.
- OPP core build fix from Shawn Guo.
- Error condition check fix for the new imx6q-cpufreq driver from Wei
Yongjun.
- Fix for an AER driver crash related to the lack of APEI
initialization for acpi=off. From Rafael J Wysocki.
- Fix for a USB breakage on Thinkpad T430 related to ACPI power
resources and PCI wakeup from Rafael J. Wysocki.
* tag 'pm+acpi-fixes-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PM: Take unusual configurations of power resources into account
imx6q-cpufreq: fix return value check in imx6q_cpufreq_probe()
PM / OPP: fix condition for empty of_init_opp_table()
ACPI / APEI: Fix crash in apei_hest_parse() for acpi=off
microblaze idle: Fix compile error
blackfin idle: Fix compile error
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Commit def8203 ("microblaze idle: delete pm_idle") introduced the following
compile error:
arch/microblaze/kernel/process.c: In function 'cpu_idle':
arch/microblaze/kernel/process.c:100: error: 'idle' undeclared (first use in this function)
arch/microblaze/kernel/process.c:100: error: (Each undeclared identifier is reported only once
arch/microblaze/kernel/process.c:100: error: for each function it appears in.)
arch/microblaze/kernel/process.c:106: error: implicit declaration of function 'idle'
This patch fixes it.
Acked-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
pm_idle on microblaze served no purpose.
Signed-off-by: Len Brown <len.brown@intel.com>
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
Based on the patch:
"lib: reduce the use of module.h wherever possible"
(sha1: 8bc3bcc93a2b4e47d5d410146f6546bca6171663)
fix all microblaze files which are not modules.
Fix coding style issues reported by checkpatch.pl.
